Problem
Command “CopyPrim” works in my custom extension but fails when invoked in a standalone .py script
Code
create_prim( "/World/BinObjs/part01_0000",
"Xform",
usd_path=f"{ROOTDIR}/assets/bin_objects/part01.usd",
semantic_label="binObj",
omni.kit.commands.execute("CopyPrim",
path_from="/World/BinObjs/part01_0000",
path_to="/World/BinObjs/part01_0001")
Error Msg
In extension, code runs fine.
In standalone python script, however, it gives error:
Cannot insert duplicate registry entry for usd layer SdfLayer('...') and
Failed verification
Full error trace at terminal:
2022-04-25 03:40:56 [19,669ms] [Error] [omni.usd.commands.usd_commands] /World/BinObjs/part01_0001 does not exist
2022-04-25 03:40:56 [19,670ms] [Error] [omni.kit.commands.command] Failed to execute a command: CopyPrim.
File "extension_examples/user_examples/scene_generation/scene_generation_standalone.py", line 329, in <module>
binObjs = setup_scene()
File "extension_examples/user_examples/scene_generation/scene_generation_standalone.py", line 250, in setup_scene
omni.kit.commands.execute("CopyPrim", path_from=f"{prim_path}_0000", path_to=f"{prim_path}_{i:04d}", duplicate_layers=True, combine_layers=False)
File "/media/gpuadmin/4TB/smartgrasping/omniverse/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.commands/omni/kit/commands/command.py", line 235, in execute
return omni.kit.undo.execute(command, name, kwargs)
[...skipped...]
File "/media/gpuadmin/4TB/smartgrasping/omniverse/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.commands/omni/kit/undo/undo.py", line 72, in execute
result = _execute(command, name, level, history_key)
File "/media/gpuadmin/4TB/smartgrasping/omniverse/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.commands/omni/kit/undo/undo.py", line 312, in _execute
raise e
File "/media/gpuadmin/4TB/smartgrasping/omniverse/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.commands/omni/kit/undo/undo.py", line 279, in _execute
result = command.do()
File "/media/gpuadmin/4TB/smartgrasping/omniverse/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.usd/omni/usd/commands/usd_commands.py", line 334, in do
omni.usd.duplicate_prim(stage, self._path_from, self._path_to, self._duplicate_layers)
File "/media/gpuadmin/4TB/smartgrasping/omniverse/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.usd/omni/usd/_impl/utils.py", line 878, in duplicate_prim
introducing_layer, intro_prim_path = omni.usd.get_introducing_layer(usd_prim)
File "/media/gpuadmin/4TB/smartgrasping/omniverse/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.usd/omni/usd/_impl/utils.py", line 242, in get_introducing_layer
query = Usd.PrimCompositionQuery(prim)
<class 'pxr.Tf.ErrorException'>
Error in 'pxrInternal_v0_20__pxrReserved__::Sdf_LayerRegistry::InsertOrUpdate' at line 155 in file /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/sdf/layerRegistry.cpp : 'Cannot insert duplicate registry entry for usd layer SdfLayer('extension_examples/user_examples/scene_generation/assets/bin_objects/part01.usd', 'extension_examples/user_examples/scene_generation/assets/bin_objects/part01.usd') over existing entry for usd layer SdfLayer('extension_examples/user_examples/scene_generation/assets/bin_objects/part01.usd', 'extension_examples/user_examples/scene_generation/assets/bin_objects/part01.usd')'
Error in 'pxrInternal_v0_20__pxrReserved__::SdfLayer::_OpenLayerAndUnlockRegistry' at line 3054 in file /buildAgent/work/ca6c508eae419cf8/USD/pxr/usd/sdf/layer.cpp : 'Failed verification: ' _layerRegistry-> FindByIdentifier(layer->GetIdentifier()) == layer ' -- Could not find extension_examples/user_examples/scene_generation/assets/bin_objects/part01.usd'
Question
- Could you kindly advice how to resolved this error?
- Why is the behavior different when the same code runs in extension VS in standalone mode?
Any hint is much appreciated. Thanks~
