Hello, I opened the demo marbles scene in Create and save only the marbles to their own USD file.
When I import those marbles into a new empty scene (drag and drop from Content browser), and then attempt to Duplicate a marble (crtl+D), nothing happens.
I notice that the console gives me the following error:
2021-07-27 22:35:05 [Error] [carb.python] Failed to execute a command: CopyPrim.
File "c:\users\<USERNAME>\appdata\local\ov\pkg\create-2021.3.1\kit\extscore\omni.kit.menu.utils\omni\kit\menu\utils\scripts\app_menu.py", line 153, in on_input
callback()
File "c:\users\<USERNAME>\appdata\local\ov\pkg\create-2021.3.1\kit\exts\omni.kit.menu.edit\omni\kit\menu\edit\scripts\edit.py", line 261, in <lambda>
onclick_fn=lambda: EditMenuExtension.duplicate_prim(False, False),
File "c:\users\<USERNAME>\appdata\local\ov\pkg\create-2021.3.1\kit\exts\omni.kit.menu.edit\omni\kit\menu\edit\scripts\edit.py", line 458, in duplicate_prim
"CopyPrims", paths_from=copy_paths, duplicate_layers=duplicate_layers, combine_layers=combine_layers
File "c:\users\<USERNAME>\appdata\local\ov\pkg\create-2021.3.1\kit\extscore\omni.kit.commands\omni\kit\commands\command.py", line 228, in execute
return omni.kit.undo.execute(command, name, kwargs)
File "c:\users\<USERNAME>\appdata\local\ov\pkg\create-2021.3.1\kit\extscore\omni.kit.commands\omni\kit\undo\undo.py", line 72, in execute
result = _execute(command, name, level, history_key)
File "c:\users\<USERNAME>\appdata\local\ov\pkg\create-2021.3.1\kit\extscore\omni.kit.commands\omni\kit\undo\undo.py", line 279, in _execute
result = command.do()
File "c:\users\<USERNAME>\appdata\local\ov\pkg\create-2021.3.1\kit\extscore\omni.usd\omni\usd\commands\usd_commands.py", line 400, in do
exclusive_select=False,
[...skipped...]
File "c:\users\<USERNAME>\appdata\local\ov\pkg\create-2021.3.1\kit\extscore\omni.kit.commands\omni\kit\undo\undo.py", line 312, in _execute
raise e
File "c:\users\<USERNAME>\appdata\local\ov\pkg\create-2021.3.1\kit\extscore\omni.usd\omni\usd\commands\usd_commands.py", line 346, in do
Sdf.CopySpec(layer, self._path_from, dst_layer, self._path_to)
<class 'pxr.Tf.ErrorException'>
Error in 'pxrInternal_v0_20__pxrReserved__::SdfCopySpec' at line 573 in file E:\w\ca6c508eae419cf8\USD\pxr\usd\sdf\copyUtils.cpp : 'Cannot copy unknown spec at </World/___SOLO_Marbles/Marbles/A_marble_01> from layer <omniverse://localhost/Projects/Marbles/Parts/SOLO_Marbles.usd>'
