I’m getting an error when trying to install Create 2021.3.5.
While installing Create, it halts on “Installing omni.create.warmup.bat” for several minutes before it aborts.
I then get an error in the notifications that reads as follows:
Hi red2dvfx,
Sorry to hear you are having this issue. I’ll pass the info along to the devs and get back to you.
thanks same error for me too
hello @jackburton09 -
Can you zip up the logs for Create and send them to us? Everything in this folder
C:\Users\YOURUSERID\.nvidia-omniverse\logs\Kit\Create.Next
The above path is assuming use used defaults for installation. If not, please see the settings for where the path is to your logs.
looks nearly the same
hello @asdpiton - can you send me your Create logs?
C:\Users\YOURUSERID.nvidia-omniverse\logs\Kit\Create.Next
I am also having an issue when I try to install Create. Blender and several others installed without an issue.
When I click install, it spins for a few seconds then I get a notification error:
ERROR
Error occurred during installation of Create: [426a56fa-8d50-4239-b9d0-15a7f88826d0] Cannot sign URL for download – FetchError: request to https://api.launcher.omniverse.nvidia.com/app/url?path=https%253A%252F%252Flauncher-prod.s3.us-east-2.amazonaws.com%252Fcreate%252F2021.3.7%252Fwindows-x86_64%252F9fa1d000e9d6f3958dfdb833774fdf7e.zip failed, reason: certificate has expired
Any thoughts?
Hello @user100771! The team is aware of the problem and is working on a solution. Thanks for letting us know!
Hi @user100771! The dev team has informed me that this error has been fixed. Please try again and let us know if you are still seeing this error!
it is working now, thanks!
Spoke too soon. It did try to install this time though so the original problem seems resolved. However, during install of Create I got the following error notification:
ERROR
Error occurred during installation of Create: Command failed: “C:\Users\robc\AppData\Local\ov\pkg\create-2021.3.7\omni.create.warmup.bat” --/app/environment/name=‘launcher_warmup’
2021-12-21 00:51:36 [9,385ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
2021-12-21 00:51:49 [22,853ms] [Error] [omni.kit.window.viewport.plugin] Failed to initialize resource manager
2021-12-21 00:51:49 [22,853ms] [Error] [omni.kit.window.viewport.plugin] Failed to prepare GPU Foundation
2021-12-21 00:51:49 [22,853ms] [Error] [omni.kit.window.viewport.plugin] Failed to startup required plugins
2021-12-21 00:51:49 [23,023ms] [Error] [carb.scripting-python.plugin] AttributeError: ‘NoneType’ object has no attribute ‘get_mouse_event_stream’
At:
c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\extscore\omni.kit.window.viewport\omni\kit\viewport\scripts\context_menu.py(27): on_startup
c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/plugins/bindings-python\omni\ext\impl_internal.py(143): _startup_ext
c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/plugins/bindings-python\omni\ext\impl_internal.py(174): startup_all_extensions_in_module
c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/plugins/bindings-python\omni\ext\impl_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2):
2021-12-21 00:51:49 [23,024ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] Failed to process python module extension in ‘c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/extscore/omni.kit.window.viewport/.’.
2021-12-21 00:51:50 [23,530ms] [Error] [omni.hydratexture.plugin] Failed to create carb::renderer::Renderer context
2021-12-21 00:51:52 [25,654ms] [Error] [omni.ext.impl. internal] Failed to import python module omni.kit.capture. Error: No module named ‘omni.kit.viewport’. Traceback:
File “c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/plugins/bindings-python\omni\ext\impl_internal.py”, line 65, in import_module
return importlib.import_module(name)
File “c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\python\lib\importlib_ init .py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1006, in _gcd_import
File “”, line 983, in _find_and_load
File “”, line 967, in _find_and_load_unlocked
File “”, line 677, in load_unlocked
File “”, line 728, in exec_module
File “”, line 219, in call_with_frames_removed
File "c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.capture\omni\kit\capture init .py", line 10, in
from .extension import CaptureExtension
File “c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.capture\omni\kit\capture\extension.py”, line 16, in
import omni.kit.viewport
ModuleNotFoundError: No module named ‘omni.kit.viewport’
2021-12-21 00:51:52 [25,655ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.kit.capture’ in ‘c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/exts/omni.kit.capture/.’ failed to load.
At:
c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/plugins/bindings-python\omni\ext\impl_internal.py(169): startup_all_extensions_in_module
2021-12-21 00:51:52 [25,655ms] [Error] [omni.ext.plugin] [ext: omni.kit.capture-0.4.7] Failed to process python module extension in ‘c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/exts/omni.kit.capture/.’.
2021-12-21 00:51:53 [26,314ms] [Error] [omni.ext.impl. internal] Failed to import python module omni.kit.window.movie_maker. Error: No module named ‘omni.kit.capture’. Traceback:
File "c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.window.movie_maker\omni\kit\window\movie_maker init .py", line 10, in
from .extension import MovieMakerExtension
File “c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.window.movie_maker\omni\kit\window\movie_maker\extension.py”, line 13, in
from .window import MovieMakerWindow
File “c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.window.movie_maker\omni\kit\window\movie_maker\window.py”, line 14, in
import omni.kit.capture
ModuleNotFoundError: No module named ‘omni.kit.capture’
2021-12-21 00:51:53 [26,314ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.kit.window.movie_maker’ in ‘c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/exts/omni.kit.window.movie_maker/.’ failed to load.
At:
2021-12-21 00:51:53 [26,314ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.movie_maker-0.5.9] Failed to process python module extension in ‘c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/exts/omni.kit.window.movie_maker/.’.
2021-12-21 00:52:00 [33,787ms] [Error] [carb.scripting-python.plugin] ModuleNotFoundError: No module named ‘omni.kit.viewport’
At:
c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.thumbnails.usd\omni\kit\thumbnails\usd\main.py(51): on_startup
2021-12-21 00:52:00 [33,787ms] [Error] [omni.ext.plugin] [ext: omni.kit.thumbnails.usd-0.5.0] Failed to process python module extension in ‘c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/exts/omni.kit.thumbnails.usd/.’.
2021-12-21 00:52:02 [35,719ms] [Error] [omni.ext.impl. internal] Failed to import python module omni.kit.viewport_widgets_manager. Error: No module named ‘omni.kit.viewport’. Traceback:
File "c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.viewport_widgets_manager\omni\kit\viewport_widgets_manager init .py", line 9, in
from .extension import ViewportWidgetsManagerExtension, WidgetAlignment, add_widget, remove_widget
File “c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.viewport_widgets_manager\omni\kit\viewport_widgets_manager\extension.py”, line 11, in
from .manager import ViewportWidgetsManager, WidgetAlignment
File “c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.viewport_widgets_manager\omni\kit\viewport_widgets_manager\manager.py”, line 6, in
import omni.kit.viewport as vp
2021-12-21 00:52:02 [35,719ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.kit.viewport_widgets_manager’ in ‘c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/exts/omni.kit.viewport_widgets_manager/.’ failed to load.
At:
2021-12-21 00:52:02 [35,719ms] [Error] [omni.ext.plugin] [ext: omni.kit.viewport_widgets_manager-1.0.3] Failed to process python module extension in ‘c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/exts/omni.kit.viewport_widgets_manager/.’.
2021-12-21 00:52:05 [38,310ms] [Error] [omni.ext.impl. internal] Failed to import python module omni.kit.collaboration.viewport.camera. Error: No module named ‘omni.kit.viewport’. Traceback:
File "c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.collaboration.viewport.camera\omni\kit\collaboration\viewport\camera init .py", line 9, in
from .extension import ViewportCameraNameExtension
File “c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.collaboration.viewport.camera\omni\kit\collaboration\viewport\camera\extension.py”, line 11, in
from .stage_listener import StageListener
File “c:\users\robc\appdata\local\ov\pkg\create-2021.3.7\kit\exts\omni.kit.collaboration.viewport.camera\omni\kit\collaboration\viewport\camera\stage_listener.py”, line 5, in
2021-12-21 00:52:05 [38,310ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.kit.collaboration.viewport.camera’ in ‘c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/exts/omni.kit.collaboration.viewport.camera/.’ failed to load.
At:
2021-12-21 00:52:05 [38,310ms] [Error] [omni.ext.plugin] [ext: omni.kit.collaboration.viewport.camera-1.0.1] Failed to process python module extension in ‘c:/users/robc/appdata/local/ov/pkg/create-2021.3.7/kit/exts/omni.kit.collaboration.viewport.camera/.’.
2021-12-21 00:52:13 [46,338ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.physxui.plugin.dll!carbOnPluginStartup
2021-12-21 00:52:13 [46,338ms] [Fatal] [carb.crashreporter-breakpad.plugin] carb.dll!releaseFramework
2021-12-21 00:52:13 [46,341ms] [Fatal] [carb.crashreporter-breakpad.plugin] carb.dll!+0x1048e
2021-12-21 00:52:13 [46,341ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.ext.plugin.dll!carbOnPluginRegisterEx
2021-12-21 00:52:13 [46,342ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.ext.plugin.dll!carbOnPluginRegisterEx
2021-12-21 00:52:13 [46,342ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.ext.plugin.dll!carbOnPluginStartup
2021-12-21 00:52:13 [46,343ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.ext.plugin.dll!carbOnPluginRegisterEx
2021-12-21 00:52:13 [46,343ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.ext.plugin.dll!carbOnPluginStartup
2021-12-21 00:52:13 [46,346ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.app.plugin.dll!+0x10f23
2021-12-21 00:52:13 [46,346ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.app.plugin.dll!+0xb4d1
2021-12-21 00:52:13 [46,349ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe!+0x21ef
2021-12-21 00:52:13 [46,349ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe!+0x2c64
2021-12-21 00:52:13 [46,349ms] [Fatal] [carb.crashreporter-breakpad.plugin] KERNEL32.DLL!BaseThreadInitThunk
2021-12-21 00:52:13 [46,349ms] [Fatal] [carb.crashreporter-breakpad.plugin] ntdll.dll!RtlUserThreadStart
I do NOT have an RTX card on this laptop so not sure if that was the issue.
I have an nvidia GTX1070 dating back a few years.
@user100771 I will forward this to our development team and have them take a look!
@user100771 Create does require the RTX Tensor Cores that are only on our RTX GPUs. That is why you are not able to launch Create.
same error for me too. Trying for so long
While installing Create and View, getting errors, which are as follow:
(For Create)
"C:\Users\rudu\AppData\Local\ov\pkg\create-2021.3.8\omni.create.warmup.bat" –
/app/environment/name='launcher_warmup'
[Error] [carb] Failed to make directory '//filesrvl1'! {error = 161}
2022-01-07 11:15:33 [347ms] [Error] [carb] Failed to make directory '//filesrvl1'! {error = 161}
2022-01-07 11:15:33 [361ms] [Error] [carb] Failed to make directory '//filesrvl1'! {error = 161}
2022-01-07 11:15:35 [2,461ms] [Error] [gpu.foundation.plugin] No device could be created. Some
2022-01-07 11:15:44 [11,035ms] [Error] [omni.kit.window.viewport.plugin] Failed to initialize
resource manager
2022-01-07 11:15:44 [11,035ms] [Error] [omni.kit.window.viewport.plugin] Failed to prepare GPU
Foundation
2022-01-07 11:15:44 [11,035ms] [Error] [omni.kit.window.viewport.plugin] Failed to startup required
plugins
2022-01-07 11:15:44 [11,179ms] [Error] [carb.scripting-python.plugin] AttributeError: 'NoneType'
object has no attribute 'get_mouse_event_stream'
At:
c:\users\rudu\appdata\local\ov\pkg\create-
2021.3.8\kit\extscore\omni.kit.window.viewport\omni\kit\viewport\scripts\context_menu.py(27):
on_startup
c:/users/rudu/appdata/local/ov/pkg/create-2021.3.8/kit/plugins/bindings-
PythonExtension.cpp::startup()(2): <module>
2022-01-07 11:15:44 [11,179ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0]
Failed to process python module extension in 'c:/users/rudu/appdata/local/ov/pkg/create-
2021.3.8/kit/extscore/omni.kit.window.viewport/.'.
2022-01-07 11:15:45 [11,628ms] [Error] [omni.hydratexture.plugin] Failed to create
2022-01-07 11:15:46 [13,375ms] [Error] [omni.ext.impl.internal] Failed to import python module
omni.kit.capture. Error: No module named 'omni.kit.viewport'. Traceback:
File "c:/users/rudu/appdata/local/ov/pkg/create-2021.3.8/kit/plugins/bindings-
python\omni\ext\impl_internal.py", line 65, in import_module
File "c:\users\rudu\appdata\local\ov\pkg\create-2021.3.8\kit\python\lib\importlib_init.py",
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in call_with_frames_removed
2021.3.8\kit\exts\omni.kit.capture\omni\kit\capture_init.py", line 10, in <module>
2021.3.8\kit\exts\omni.kit.capture\omni\kit\capture\extension.py", line 16, in <module>
ModuleNotFoundError: No module named 'omni.kit.viewport'
2022-01-07 11:15:46 [13,375ms] [Error] [carb.scripting-python.plugin] Exception: Extension python
module: 'omni.kit.capture' in 'c:/users/rudu/appdata/local/ov/pkg/create-
2021.3.8/kit/exts/omni.kit.capture/.' failed to load.
At:
2022-01-07 11:15:46 [13,375ms] [Error] [omni.ext.plugin] [ext: omni.kit.capture-0.4.7] Failed to
2021.3.8/kit/exts/omni.kit.capture/.'.
2022-01-07 11:15:47 [13,923ms] [Error] [omni.ext.impl.internal] Failed to import python module
omni.kit.window.movie_maker. Error: No module named 'omni.kit.capture'. Traceback:
2021.3.8\kit\exts\omni.kit.window.movie_maker\omni\kit\window\movie_maker_init.py", line
10, in <module>
2021.3.8\kit\exts\omni.kit.window.movie_maker\omni\kit\window\movie_maker\extension.py",
line 13, in <module>
2021.3.8\kit\exts\omni.kit.window.movie_maker\omni\kit\window\movie_maker\window.py", line
14, in <module>
ModuleNotFoundError: No module named 'omni.kit.capture'
2022-01-07 11:15:47 [13,923ms] [Error] [carb.scripting-python.plugin] Exception: Extension python
module: 'omni.kit.window.movie_maker' in 'c:/users/rudu/appdata/local/ov/pkg/create-
2021.3.8/kit/exts/omni.kit.window.movie_maker/.' failed to load.
At:
2022-01-07 11:15:47 [13,924ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.movie_maker-0.5.9]
2021.3.8/kit/exts/omni.kit.window.movie_maker/.'.
2022-01-07 11:15:53 [19,714ms] [Error] [carb.scripting-python.plugin] ModuleNotFoundError: No
At:
2021.3.8\kit\exts\omni.kit.thumbnails.usd\omni\kit\thumbnails\usd\main.py(51): on_startup
2022-01-07 11:15:53 [19,714ms] [Error] [omni.ext.plugin] [ext: omni.kit.thumbnails.usd-0.5.0] Failed
2021.3.8/kit/exts/omni.kit.thumbnails.usd/.'.
2022-01-07 11:15:55 [21,712ms] [Error] [omni.ext.impl._internal] Failed to import python module
omni.kit.viewport_widgets_manager. Error: No module named 'omni.kit.viewport'. Traceback:
File "c:\users\rudu\appdata\local\ov\pkg\create-2021.3.8\kit\python\lib\importlib_init_.py",
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
2021.3.8\kit\exts\omni.kit.viewport_widgets_manager\omni\kit\viewport_widgets_manager_init
_.py", line 9, in <module>
remove_widget
2021.3.8\kit\exts\omni.kit.viewport_widgets_manager\omni\kit\viewport_widgets_manager\extens
ion.py", line 11, in <module>
2021.3.8\kit\exts\omni.kit.viewport_widgets_manager\omni\kit\viewport_widgets_manager\manag
er.py", line 6, in <module>
2022-01-07 11:15:55 [21,712ms] [Error] [carb.scripting-python.plugin] Exception: Extension python
module: 'omni.kit.viewport_widgets_manager' in 'c:/users/rudu/appdata/local/ov/pkg/create-
2021.3.8/kit/exts/omni.kit.viewport_widgets_manager/.' failed to load.
At:
2022-01-07 11:15:55 [21,712ms] [Error] [omni.ext.plugin] [ext: omni.kit.viewport_widgets_manager-
1.0.3] Failed to process python module extension in 'c:/users/rudu/appdata/local/ov/pkg/create-
2021.3.8/kit/exts/omni.kit.viewport_widgets_manager/.'.
2022-01-07 11:15:55 [21,891ms] [Error] [carb] Failed to make directory '//filesrvl1'! {error = 161}
2022-01-07 11:15:55 [21,892ms] [Error] [carb] Failed to make directory '//filesrvl1'! {error = 161}
2022-01-07 11:16:00 [27,572ms] [Error] [carb] Failed to make directory '//filesrvl1'! {error = 161}
2022-01-07 11:16:04 [31,423ms] [Error] [carb] Failed to make directory '//filesrvl1'! {error = 161}
2022-01-07 11:16:05 [31,930ms] [Error] [omni.ext.impl.internal] Failed to import python module
omni.kit.collaboration.viewport.camera. Error: No module named 'omni.kit.viewport'. Traceback:
2021.3.8\kit\exts\omni.kit.collaboration.viewport.camera\omni\kit\collaboration\viewport\camera
init.py", line 9, in <module>
extension.py", line 11, in <module>
stage_listener.py", line 5, in <module>
2022-01-07 11:16:05 [31,930ms] [Error] [carb.scripting-python.plugin] Exception: Extension python
module: 'omni.kit.collaboration.viewport.camera' in 'c:/users/rudu/appdata/local/ov/pkg/create-
2021.3.8/kit/exts/omni.kit.collaboration.viewport.camera/.' failed to load.
At:
2022-01-07 11:16:05 [31,931ms] [Error] [omni.ext.plugin] [ext:
2021.3.8/kit/exts/omni.kit.collaboration.viewport.camera/.'.
2022-01-07 11:16:17 [43,778ms] [Fatal] [carb.crashreporter-breakpad.plugin]
2022-01-07 11:16:17 [43,780ms] [Fatal] [carb.crashreporter-breakpad.plugin] carb.dll!+0x1048e
2022-01-07 11:16:17 [43,782ms] [Fatal] [carb.crashreporter-breakpad.plugin]
2022-01-07 11:16:17 [43,784ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe!+0x21ef
2022-01-07 11:16:17 [43,784ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe!+0x2c64
KERNEL32.dll!BaseThreadInitThunk
And for View:
Error occurred during installation of View: Command failed:
"C:\Users\rudu\AppData\Local\ov\pkg\view-2021.3.10\omni.view.warmup.bat"
2022-01-07 11:22:10 [348ms] [Error] [carb] Failed to make directory '//filesrvl1'! {error = 161}
2022-01-07 11:22:10 [362ms] [Error] [carb] Failed to make directory '//filesrvl1'! {error = 161}
2022-01-07 11:22:13 [3,061ms] [Error] [gpu.foundation.plugin] No device could be created. Some
2022-01-07 11:22:22 [11,757ms] [Error] [omni.kit.window.viewport.plugin] Failed to initialize
resource manager
2022-01-07 11:22:22 [11,758ms] [Error] [omni.kit.window.viewport.plugin] Failed to prepare GPU
Foundation
2022-01-07 11:22:22 [11,758ms] [Error] [omni.kit.window.viewport.plugin] Failed to startup required
plugins
2022-01-07 11:22:22 [11,904ms] [Error] [carb.scripting-python.plugin] AttributeError: 'NoneType'
At:
c:\users\rudu\appdata\local\ov\pkg\view-
2021.3.10\kit\extscore\omni.kit.window.viewport\omni\kit\viewport\scripts\context_menu.py(27):
on_startup
c:/users/rudu/appdata/local/ov/pkg/view-2021.3.10/kit/plugins/bindings-
2022-01-07 11:22:22 [11,904ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0]
Failed to process python module extension in 'c:/users/rudu/appdata/local/ov/pkg/view-
2021.3.10/kit/extscore/omni.kit.window.viewport/.'.
ERROR: Could not find a version that satisfies the requirement numpy==1.19.0 (from versions: none)
ERROR: No matching distribution found for numpy==1.19.0
2022-01-07 11:22:35 [25,181ms] [Fatal] [carb.crashreporter-breakpad.plugin]
omni.view.compass.plugin.dll!+0x4350
2022-01-07 11:22:35 [25,182ms] [Fatal] [carb.crashreporter-breakpad.plugin]
2022-01-07 11:22:35 [25,183ms] [Fatal] [carb.crashreporter-breakpad.plugin]
2022-01-07 11:22:35 [25,185ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe!+0x21ef
2022-01-07 11:22:35 [25,185ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe!+0x2c64
