I am using the Create 2022.2.0.rc.15 version, and I activated Modulus Core Extension to test Modulus.
Afterwards, I tried to activate Modulus FPGA Extension, but the Create app did not respond and then shut down suddenly.
For this, attach the log file in the following path:
/home/nvidia/.nvidia-omniverse/logs/Kit/Create.Next/2022.2/kit_20230102_095142.log
[ext: omni.usd.config-1.0.0] no deps
[ext: omni.kit.pip_archive-0.0.0] deps:
-> (name: 'omni.kit.pipapi', tag: '', version: '0.0.0+cp37', exact: 1, optional: 0) selected: [omni.kit.pipapi-0.0.0]
[ext: omni.kit.pipapi-0.0.0] no deps
[ext: omni.kit.splash-0.2.1] deps:
-> (name: 'omni.kit.agent', tag: '', version: '0.1.1+cp37', exact: 1, optional: 0) selected: [omni.kit.agent-0.1.1]
-> (name: 'omni.kit.async_engine', tag: '', version: '0.0.0+cp37', exact: 1, optional: 0) selected: [omni.kit.async_engine-0.0.0]
-> (name: 'omni.kit.window.splash', tag: '', version: '0.0.0+lx64.r.cp37', exact: 1, optional: 0) selected: [omni.kit.window.splash-0.0.0]
[ext: omni.kit.agent-0.1.1] no deps
[ext: omni.kit.async_engine-0.0.0] no deps
[ext: omni.kit.window.splash-0.0.0] deps:
-> (name: 'omni.assets.plugins', tag: '', version: '0.0.0+lx64.r', exact: 1, optional: 0) selected: [omni.assets.plugins-0.0.0]
[ext: omni.kit.renderer.init-0.0.0] deps:
-> (name: 'carb.windowing.plugins', tag: '', version: '1.0.0+lx64.r', exact: 1, optional: 0) selected: [carb.windowing.plugins-1.0.0]
-> (name: 'omni.gpu_foundation', tag: '', version: '0.0.0+lx64.r.cp37', exact: 1, optional: 0) selected: [omni.gpu_foundation-0.0.0]
[ext: carb.windowing.plugins-1.0.0] no deps
[ext: omni.assets.plugins-0.0.0] no deps
[ext: omni.gpu_foundation-0.0.0] deps:
-> (name: 'omni.stats', tag: '', version: '0.0.0+lx64.r.cp37', exact: 1, optional: 0) selected: [omni.stats-0.0.0]
[ext: omni.stats-0.0.0] no deps
[ext: modulus_ext.core-22.9.0] no deps
2023-01-02 00:53:50 [127,635ms] [Info] [omni.ext.impl._internal] Adding /home/nvidia/Omniverse/data/Kit/Create.Next/2022.2/exts/3/modulus_scenario_fpga-22.9.0+cp37 to sys.path
2023-01-02 00:53:50 [127,635ms] [Info] [omni.ext.plugin] About to startup: [ext: modulus_scenario_fpga-22.9.0] (order: 0) Triggered by API/CLI/Config. (path: /home/nvidia/Omniverse/data/Kit/Create.Next/2022.2/exts/3/modulus_scenario_fpga-22.9.0+cp37)
2023-01-02 00:53:50 [127,635ms] [Info] [omni.kit.app.plugin] [127.679s] [ext: modulus_scenario_fpga-22.9.0] startup
2023-01-02 00:53:53 [131,109ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2023-01-02 00:53:53 [131,109ms] [Warning] [carb.crashreporter-breakpad.plugin] A crash has occurred. If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:'/home/nvidia/Omniverse/data/Kit/Create.Next/2022.2/7e93826d-d31b-4728-e395118a-63c1106d.dmp' svr:'https://services.nvidia.com/submit'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = '7e93826d-d31b-4728-e395118a-63c1106d'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1672620702'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '131'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '103.5+release.6246.9e251c6b.tc'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Create.Next'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'started'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.2.0-rc.15'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = 'modulus_ext.ui-2.0.0,hpcvis.vtkm_bridge.core-1.0.2-alpha-03'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCiNumber = '11398318'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '9e251c6b'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '103'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '5'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '6246'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '103.5.0'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuId = 'Intel64 Family 23 Model 49 Stepping 0'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuName = 'AMD EPYC-Rome Processor'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuVendor = 'AuthenticAMD'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopOrigin = '(0, 0)'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopSize = '1680x1050'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] displayCount = '1'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_0 = '1680x1050x32bit@60Hz'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Create Next'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] externalBuild = '1'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_0 = '525.60'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_0 = '13136560128'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_0 = 'NVIDIA RTX A2000 12GB'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = '525.60'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = 'ToggleExtension(ext_id=modulus_scenario_fpga-22.9.0,enable=True)'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = 'CreatePrim(prim_path=/World/defaultLight,prim_type=DistantLight,select_new_prim=False,attributes=?,create_default_xform=True),ToggleExtension(ext_id=modulus_scenario_fpga-22.9.0,enable=True)'
2023-01-02 00:53:53 [131,110ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 85.3267/95.9325GB, Swap: 0/0GB, VM: 1.71799e+10/1.71799e+10GB'
2023-01-02 00:53:53 [131,111ms] [Warning] [carb.crashreporter-breakpad.plugin] osDistro = 'ubuntu'
2023-01-02 00:53:53 [131,111ms] [Warning] [carb.crashreporter-breakpad.plugin] osName = '20.04.5 LTS (Focal Fossa)'
2023-01-02 00:53:53 [131,111ms] [Warning] [carb.crashreporter-breakpad.plugin] osVersion = '20.4.5'
2023-01-02 00:53:53 [131,111ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
2023-01-02 00:53:53 [131,111ms] [Warning] [carb.crashreporter-breakpad.plugin] primaryDisplayRes = '1680x1050x32bit@60Hz'
2023-01-02 00:53:53 [131,111ms] [Warning] [carb.crashreporter-breakpad.plugin] startup_time = '11.749120306'
2023-01-02 00:53:53 [131,111ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = '
| Driver Version: 525.60.13 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA RTX A2000 12GB | Yes: 0 | | 12528 MB | 10de | 0 |
| | | | | | 2571 | fd91fe72.. |
| OS: Linux omni-linux-2, Version: 5.15.0-56-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Processor: AMD EPYC-Rome Processor | Cores: Unknown | Logical: 15
| Total Memory (MB): 98234 | Free Memory: 92017
| Total Page/Swap (MB): 0 | Free Page/Swap: 0
2023-01-02 00:53:53 [131,111ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '1557253993858345301'
2023-01-02 00:54:01 [139,329ms] [Warning] [carb.crashreporter-breakpad.plugin] uploaded minidump: file: '/home/nvidia/Omniverse/data/Kit/Create.Next/2022.2/7e93826d-d31b-4728-e395118a-63c1106d.dmp', code:200, response:
2023-01-02 00:54:01 [139,329ms] [Warning] [carb.crashreporter-breakpad.plugin] 0000018420d7ffb8-1d4333
2023-01-02 00:54:01 [139,329ms] [Warning] [carb.crashreporter-breakpad.plugin] deleting minidump: '/home/nvidia/Omniverse/data/Kit/Create.Next/2022.2/7e93826d-d31b-4728-e395118a-63c1106d.dmp' (use setting "/crashreporter/preserveDump=true" to save).
2023-01-02 00:54:01 [139,330ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file '/home/nvidia/Omniverse/data/Kit/Create.Next/2022.2/7e93826d-d31b-4728-e395118a-63c1106d.dmp'
2023-01-02 00:54:01 [139,330ms] [Error] [carb.crashreporter-breakpad.plugin] dump file size is -1 bytes, file is not readable.
2023-01-02 00:54:01 [139,331ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 65755 thread 65755
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata:
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = '7e93826d-d31b-4728-e395118a-63c1106d'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1672620702'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '131'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '103.5+release.6246.9e251c6b.tc'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Create.Next'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'started'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.2.0-rc.15'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = 'modulus_ext.ui-2.0.0,hpcvis.vtkm_bridge.core-1.0.2-alpha-03'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCiNumber = '11398318'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '9e251c6b'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '103'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '5'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '6246'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '103.5.0'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuId = 'Intel64 Family 23 Model 49 Stepping 0'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuName = 'AMD EPYC-Rome Processor'
2023-01-02 00:54:01 [139,331ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuVendor = 'AuthenticAMD'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopOrigin = '(0, 0)'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopSize = '1680x1050'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] displayCount = '1'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_0 = '1680x1050x32bit@60Hz'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Create Next'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] externalBuild = '1'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_0 = '525.60'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_0 = '13136560128'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_0 = 'NVIDIA RTX A2000 12GB'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = '525.60'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = 'ToggleExtension(ext_id=modulus_scenario_fpga-22.9.0,enable=True)'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = 'CreatePrim(prim_path=/World/defaultLight,prim_type=DistantLight,select_new_prim=False,attributes=?,create_default_xform=True),ToggleExtension(ext_id=modulus_scenario_fpga-22.9.0,enable=True)'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 85.3267/95.9325GB, Swap: 0/0GB, VM: 1.71799e+10/1.71799e+10GB'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] osDistro = 'ubuntu'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] osName = '20.04.5 LTS (Focal Fossa)'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] osVersion = '20.4.5'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] primaryDisplayRes = '1680x1050x32bit@60Hz'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] startup_time = '11.749120306'
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = '
| | | | | | Device-ID | UUID |
| | | | | | 2571 | fd91fe72.. |
2023-01-02 00:54:01 [139,332ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '1557253993858345301'
2023-01-02 00:54:01 [139,332ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 65755 backtrace follows:
2023-01-02 00:54:02 [139,506ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libpthread.so.0!funlockfile+0x60 (sigaction.c:?)
2023-01-02 00:54:02 [139,694ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libc.so.6!gsignal+0xcb (??:?)
2023-01-02 00:54:02 [139,882ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libc.so.6!abort+0x12b (??:?)
2023-01-02 00:54:02 [140,066ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libLLVM-12.so.1!llvm::report_fatal_error(llvm::Twine const&, bool)+0x1d9 (??:?)
2023-01-02 00:54:02 [140,255ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libLLVM-12.so.1!llvm::report_fatal_error(char const*, bool)+0x26 (??:?)
2023-01-02 00:54:03 [140,456ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libLLVM-12.so.1!LLVMParseCommandLineOptions+0xebd (??:?)
2023-01-02 00:54:03 [140,674ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libLLVM-12.so.1!llvm::cl::Option::addArgument()+0x3b (??:?)
2023-01-02 00:54:03 [140,870ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: symengine_wrapper.cpython-37m-x86_64-linux-gnu.so!PyInit_symengine_wrapper+0x39966 (??:?)
2023-01-02 00:54:03 [141,072ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: ld-linux-x86-64.so.2!_dl_rtld_di_serinfo+0x6b0a (??:?)
2023-01-02 00:54:03 [141,273ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: ld-linux-x86-64.so.2!_dl_rtld_di_serinfo+0x6c11 (??:?)
2023-01-02 00:54:04 [141,473ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libc.so.6!_dl_catch_exception+0xe5 (??:?)
2023-01-02 00:54:04 [141,687ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: ld-linux-x86-64.so.2!_dl_find_dso_for_object+0xc3f (??:?)
2023-01-02 00:54:04 [141,893ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libc.so.6!_dl_catch_exception+0x88 (??:?)
2023-01-02 00:54:04 [142,081ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: ld-linux-x86-64.so.2!_dl_find_dso_for_object+0x17a (??:?)
2023-01-02 00:54:04 [142,101ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libdl.so.2!+0x134c
2023-01-02 00:54:04 [142,281ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libc.so.6!_dl_catch_exception+0x88 (??:?)
2023-01-02 00:54:05 [142,827ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libc.so.6!_dl_catch_error+0x33 (??:?)
2023-01-02 00:54:05 [143,029ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libdl.so.2!dlerror+0x319 (??:?)
2023-01-02 00:54:05 [143,242ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libdl.so.2!dlopen+0x4a (??:?)
2023-01-02 00:54:06 [143,450ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libpython3.7m.so.1.0!_PyImport_FindSharedFuncptr+0x180 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/./Python/dynload_shlib.c:98)
2023-01-02 00:54:06 [143,651ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libpython3.7m.so.1.0!_PyImport_LoadDynamicModuleWithSpec+0x14a (/builds/omniverse/externals/python-build/_build/Python-3.7.13/./Python/importdl.c:132)
2023-01-02 00:54:06 [143,843ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libpython3.7m.so.1.0!_imp_create_dynamic+0x129 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:2176)
2023-01-02 00:54:06 [144,042ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:06 [144,241ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:07 [144,436ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:07 [144,635ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:07 [144,842ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:07 [145,046ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:07 [145,243ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:08 [145,446ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:08 [145,634ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:08 [145,829ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:08 [146,031ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:08 [146,231ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:09 [146,423ms] [Fatal] [carb.crashreporter-breakpad.plugin] 034: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:09 [146,619ms] [Fatal] [carb.crashreporter-breakpad.plugin] 035: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:09 [146,821ms] [Fatal] [carb.crashreporter-breakpad.plugin] 036: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:09 [147,018ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-01-02 00:54:09 [147,210ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-01-02 00:54:10 [147,410ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-01-02 00:54:10 [147,600ms] [Fatal] [carb.crashreporter-breakpad.plugin] 040: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-01-02 00:54:10 [147,793ms] [Fatal] [carb.crashreporter-breakpad.plugin] 041: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-01-02 00:54:10 [147,984ms] [Fatal] [carb.crashreporter-breakpad.plugin] 042: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:10 [148,192ms] [Fatal] [carb.crashreporter-breakpad.plugin] 043: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-01-02 00:54:11 [148,407ms] [Fatal] [carb.crashreporter-breakpad.plugin] 044: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-01-02 00:54:11 [148,608ms] [Fatal] [carb.crashreporter-breakpad.plugin] 045: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-01-02 00:54:11 [148,819ms] [Fatal] [carb.crashreporter-breakpad.plugin] 046: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:11 [149,018ms] [Fatal] [carb.crashreporter-breakpad.plugin] 047: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:11 [149,225ms] [Fatal] [carb.crashreporter-breakpad.plugin] 048: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:12 [149,427ms] [Fatal] [carb.crashreporter-breakpad.plugin] 049: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:12 [149,625ms] [Fatal] [carb.crashreporter-breakpad.plugin] 050: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:12 [149,822ms] [Fatal] [carb.crashreporter-breakpad.plugin] 051: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:12 [150,025ms] [Fatal] [carb.crashreporter-breakpad.plugin] 052: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:12 [150,229ms] [Fatal] [carb.crashreporter-breakpad.plugin] 053: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:13 [150,429ms] [Fatal] [carb.crashreporter-breakpad.plugin] 054: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:13 [150,639ms] [Fatal] [carb.crashreporter-breakpad.plugin] 055: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:13 [150,841ms] [Fatal] [carb.crashreporter-breakpad.plugin] 056: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:13 [151,043ms] [Fatal] [carb.crashreporter-breakpad.plugin] 057: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:13 [151,244ms] [Fatal] [carb.crashreporter-breakpad.plugin] 058: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:14 [151,448ms] [Fatal] [carb.crashreporter-breakpad.plugin] 059: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-01-02 00:54:14 [151,651ms] [Fatal] [carb.crashreporter-breakpad.plugin] 060: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-01-02 00:54:14 [151,855ms] [Fatal] [carb.crashreporter-breakpad.plugin] 061: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-01-02 00:54:14 [152,058ms] [Fatal] [carb.crashreporter-breakpad.plugin] 062: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-01-02 00:54:14 [152,260ms] [Fatal] [carb.crashreporter-breakpad.plugin] 063: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-01-02 00:54:15 [152,461ms] [Fatal] [carb.crashreporter-breakpad.plugin] 064: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:15 [152,665ms] [Fatal] [carb.crashreporter-breakpad.plugin] 065: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-01-02 00:54:15 [152,875ms] [Fatal] [carb.crashreporter-breakpad.plugin] 066: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-01-02 00:54:15 [153,080ms] [Fatal] [carb.crashreporter-breakpad.plugin] 067: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-01-02 00:54:15 [153,281ms] [Fatal] [carb.crashreporter-breakpad.plugin] 068: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:16 [153,483ms] [Fatal] [carb.crashreporter-breakpad.plugin] 069: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:16 [153,690ms] [Fatal] [carb.crashreporter-breakpad.plugin] 070: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:16 [153,893ms] [Fatal] [carb.crashreporter-breakpad.plugin] 071: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:16 [154,096ms] [Fatal] [carb.crashreporter-breakpad.plugin] 072: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:16 [154,292ms] [Fatal] [carb.crashreporter-breakpad.plugin] 073: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:17 [154,493ms] [Fatal] [carb.crashreporter-breakpad.plugin] 074: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:17 [154,693ms] [Fatal] [carb.crashreporter-breakpad.plugin] 075: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:17 [154,885ms] [Fatal] [carb.crashreporter-breakpad.plugin] 076: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:17 [155,089ms] [Fatal] [carb.crashreporter-breakpad.plugin] 077: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:17 [155,280ms] [Fatal] [carb.crashreporter-breakpad.plugin] 078: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:18 [155,473ms] [Fatal] [carb.crashreporter-breakpad.plugin] 079: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:18 [155,656ms] [Fatal] [carb.crashreporter-breakpad.plugin] 080: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:18 [155,841ms] [Fatal] [carb.crashreporter-breakpad.plugin] 081: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-01-02 00:54:18 [156,031ms] [Fatal] [carb.crashreporter-breakpad.plugin] 082: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-01-02 00:54:18 [156,220ms] [Fatal] [carb.crashreporter-breakpad.plugin] 083: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-01-02 00:54:19 [156,423ms] [Fatal] [carb.crashreporter-breakpad.plugin] 084: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-01-02 00:54:19 [156,623ms] [Fatal] [carb.crashreporter-breakpad.plugin] 085: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-01-02 00:54:19 [156,817ms] [Fatal] [carb.crashreporter-breakpad.plugin] 086: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:19 [157,017ms] [Fatal] [carb.crashreporter-breakpad.plugin] 087: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-01-02 00:54:19 [157,219ms] [Fatal] [carb.crashreporter-breakpad.plugin] 088: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-01-02 00:54:20 [157,416ms] [Fatal] [carb.crashreporter-breakpad.plugin] 089: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-01-02 00:54:20 [157,602ms] [Fatal] [carb.crashreporter-breakpad.plugin] 090: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:20 [157,801ms] [Fatal] [carb.crashreporter-breakpad.plugin] 091: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:20 [157,994ms] [Fatal] [carb.crashreporter-breakpad.plugin] 092: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:20 [158,193ms] [Fatal] [carb.crashreporter-breakpad.plugin] 093: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:21 [158,388ms] [Fatal] [carb.crashreporter-breakpad.plugin] 094: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:21 [158,581ms] [Fatal] [carb.crashreporter-breakpad.plugin] 095: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:21 [158,775ms] [Fatal] [carb.crashreporter-breakpad.plugin] 096: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:21 [158,974ms] [Fatal] [carb.crashreporter-breakpad.plugin] 097: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:21 [159,173ms] [Fatal] [carb.crashreporter-breakpad.plugin] 098: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:21 [159,370ms] [Fatal] [carb.crashreporter-breakpad.plugin] 099: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:22 [159,570ms] [Fatal] [carb.crashreporter-breakpad.plugin] 100: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:22 [159,765ms] [Fatal] [carb.crashreporter-breakpad.plugin] 101: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:22 [159,970ms] [Fatal] [carb.crashreporter-breakpad.plugin] 102: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:22 [160,165ms] [Fatal] [carb.crashreporter-breakpad.plugin] 103: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-01-02 00:54:22 [160,359ms] [Fatal] [carb.crashreporter-breakpad.plugin] 104: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-01-02 00:54:23 [160,560ms] [Fatal] [carb.crashreporter-breakpad.plugin] 105: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-01-02 00:54:23 [160,747ms] [Fatal] [carb.crashreporter-breakpad.plugin] 106: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-01-02 00:54:23 [160,954ms] [Fatal] [carb.crashreporter-breakpad.plugin] 107: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-01-02 00:54:23 [161,164ms] [Fatal] [carb.crashreporter-breakpad.plugin] 108: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:23 [161,363ms] [Fatal] [carb.crashreporter-breakpad.plugin] 109: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-01-02 00:54:24 [161,553ms] [Fatal] [carb.crashreporter-breakpad.plugin] 110: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-01-02 00:54:24 [161,741ms] [Fatal] [carb.crashreporter-breakpad.plugin] 111: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-01-02 00:54:24 [161,928ms] [Fatal] [carb.crashreporter-breakpad.plugin] 112: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:24 [162,114ms] [Fatal] [carb.crashreporter-breakpad.plugin] 113: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:24 [162,307ms] [Fatal] [carb.crashreporter-breakpad.plugin] 114: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:25 [162,508ms] [Fatal] [carb.crashreporter-breakpad.plugin] 115: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:25 [162,713ms] [Fatal] [carb.crashreporter-breakpad.plugin] 116: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:25 [162,921ms] [Fatal] [carb.crashreporter-breakpad.plugin] 117: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:25 [163,123ms] [Fatal] [carb.crashreporter-breakpad.plugin] 118: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:25 [163,329ms] [Fatal] [carb.crashreporter-breakpad.plugin] 119: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:26 [163,524ms] [Fatal] [carb.crashreporter-breakpad.plugin] 120: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:26 [163,726ms] [Fatal] [carb.crashreporter-breakpad.plugin] 121: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:26 [163,930ms] [Fatal] [carb.crashreporter-breakpad.plugin] 122: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:26 [164,144ms] [Fatal] [carb.crashreporter-breakpad.plugin] 123: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:26 [164,363ms] [Fatal] [carb.crashreporter-breakpad.plugin] 124: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:27 [164,562ms] [Fatal] [carb.crashreporter-breakpad.plugin] 125: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-01-02 00:54:27 [164,767ms] [Fatal] [carb.crashreporter-breakpad.plugin] 126: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-01-02 00:54:27 [164,966ms] [Fatal] [carb.crashreporter-breakpad.plugin] 127: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-01-02 00:54:27 [165,174ms] [Fatal] [carb.crashreporter-breakpad.plugin] 128: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-01-02 00:54:27 [165,383ms] [Fatal] [carb.crashreporter-breakpad.plugin] 129: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-01-02 00:54:28 [165,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] 130: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:28 [165,792ms] [Fatal] [carb.crashreporter-breakpad.plugin] 131: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-01-02 00:54:28 [165,998ms] [Fatal] [carb.crashreporter-breakpad.plugin] 132: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-01-02 00:54:28 [166,200ms] [Fatal] [carb.crashreporter-breakpad.plugin] 133: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-01-02 00:54:29 [166,396ms] [Fatal] [carb.crashreporter-breakpad.plugin] 134: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:29 [166,598ms] [Fatal] [carb.crashreporter-breakpad.plugin] 135: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:29 [166,798ms] [Fatal] [carb.crashreporter-breakpad.plugin] 136: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:29 [167,000ms] [Fatal] [carb.crashreporter-breakpad.plugin] 137: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:29 [167,199ms] [Fatal] [carb.crashreporter-breakpad.plugin] 138: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:30 [167,401ms] [Fatal] [carb.crashreporter-breakpad.plugin] 139: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:30 [167,607ms] [Fatal] [carb.crashreporter-breakpad.plugin] 140: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:30 [167,812ms] [Fatal] [carb.crashreporter-breakpad.plugin] 141: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:30 [168,012ms] [Fatal] [carb.crashreporter-breakpad.plugin] 142: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:30 [168,214ms] [Fatal] [carb.crashreporter-breakpad.plugin] 143: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:31 [168,416ms] [Fatal] [carb.crashreporter-breakpad.plugin] 144: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:31 [168,617ms] [Fatal] [carb.crashreporter-breakpad.plugin] 145: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:31 [168,810ms] [Fatal] [carb.crashreporter-breakpad.plugin] 146: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:31 [169,005ms] [Fatal] [carb.crashreporter-breakpad.plugin] 147: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-01-02 00:54:31 [169,203ms] [Fatal] [carb.crashreporter-breakpad.plugin] 148: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-01-02 00:54:32 [169,403ms] [Fatal] [carb.crashreporter-breakpad.plugin] 149: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-01-02 00:54:32 [169,607ms] [Fatal] [carb.crashreporter-breakpad.plugin] 150: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-01-02 00:54:32 [169,806ms] [Fatal] [carb.crashreporter-breakpad.plugin] 151: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-01-02 00:54:32 [170,005ms] [Fatal] [carb.crashreporter-breakpad.plugin] 152: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:32 [170,205ms] [Fatal] [carb.crashreporter-breakpad.plugin] 153: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-01-02 00:54:33 [170,403ms] [Fatal] [carb.crashreporter-breakpad.plugin] 154: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-01-02 00:54:33 [170,605ms] [Fatal] [carb.crashreporter-breakpad.plugin] 155: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-01-02 00:54:33 [170,793ms] [Fatal] [carb.crashreporter-breakpad.plugin] 156: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:33 [170,990ms] [Fatal] [carb.crashreporter-breakpad.plugin] 157: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:33 [171,188ms] [Fatal] [carb.crashreporter-breakpad.plugin] 158: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:34 [171,389ms] [Fatal] [carb.crashreporter-breakpad.plugin] 159: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:34 [171,587ms] [Fatal] [carb.crashreporter-breakpad.plugin] 160: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:34 [171,785ms] [Fatal] [carb.crashreporter-breakpad.plugin] 161: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:34 [171,981ms] [Fatal] [carb.crashreporter-breakpad.plugin] 162: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:34 [172,186ms] [Fatal] [carb.crashreporter-breakpad.plugin] 163: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:35 [172,394ms] [Fatal] [carb.crashreporter-breakpad.plugin] 164: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:35 [172,604ms] [Fatal] [carb.crashreporter-breakpad.plugin] 165: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:35 [172,805ms] [Fatal] [carb.crashreporter-breakpad.plugin] 166: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:35 [173,011ms] [Fatal] [carb.crashreporter-breakpad.plugin] 167: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:35 [173,211ms] [Fatal] [carb.crashreporter-breakpad.plugin] 168: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:36 [173,407ms] [Fatal] [carb.crashreporter-breakpad.plugin] 169: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-01-02 00:54:36 [173,587ms] [Fatal] [carb.crashreporter-breakpad.plugin] 170: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-01-02 00:54:36 [173,769ms] [Fatal] [carb.crashreporter-breakpad.plugin] 171: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-01-02 00:54:36 [173,965ms] [Fatal] [carb.crashreporter-breakpad.plugin] 172: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-01-02 00:54:36 [174,165ms] [Fatal] [carb.crashreporter-breakpad.plugin] 173: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-01-02 00:54:36 [174,364ms] [Fatal] [carb.crashreporter-breakpad.plugin] 174: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:37 [174,566ms] [Fatal] [carb.crashreporter-breakpad.plugin] 175: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-01-02 00:54:37 [174,762ms] [Fatal] [carb.crashreporter-breakpad.plugin] 176: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-01-02 00:54:37 [174,953ms] [Fatal] [carb.crashreporter-breakpad.plugin] 177: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-01-02 00:54:37 [175,147ms] [Fatal] [carb.crashreporter-breakpad.plugin] 178: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:37 [175,341ms] [Fatal] [carb.crashreporter-breakpad.plugin] 179: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:38 [175,537ms] [Fatal] [carb.crashreporter-breakpad.plugin] 180: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:38 [175,732ms] [Fatal] [carb.crashreporter-breakpad.plugin] 181: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:38 [175,924ms] [Fatal] [carb.crashreporter-breakpad.plugin] 182: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:38 [176,120ms] [Fatal] [carb.crashreporter-breakpad.plugin] 183: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:38 [176,323ms] [Fatal] [carb.crashreporter-breakpad.plugin] 184: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:39 [176,528ms] [Fatal] [carb.crashreporter-breakpad.plugin] 185: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:39 [176,729ms] [Fatal] [carb.crashreporter-breakpad.plugin] 186: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:39 [176,930ms] [Fatal] [carb.crashreporter-breakpad.plugin] 187: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:39 [177,129ms] [Fatal] [carb.crashreporter-breakpad.plugin] 188: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:39 [177,331ms] [Fatal] [carb.crashreporter-breakpad.plugin] 189: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:40 [177,533ms] [Fatal] [carb.crashreporter-breakpad.plugin] 190: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:40 [177,732ms] [Fatal] [carb.crashreporter-breakpad.plugin] 191: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-01-02 00:54:40 [177,926ms] [Fatal] [carb.crashreporter-breakpad.plugin] 192: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-01-02 00:54:40 [178,122ms] [Fatal] [carb.crashreporter-breakpad.plugin] 193: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-01-02 00:54:40 [178,320ms] [Fatal] [carb.crashreporter-breakpad.plugin] 194: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-01-02 00:54:41 [178,518ms] [Fatal] [carb.crashreporter-breakpad.plugin] 195: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-01-02 00:54:41 [178,715ms] [Fatal] [carb.crashreporter-breakpad.plugin] 196: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:41 [178,913ms] [Fatal] [carb.crashreporter-breakpad.plugin] 197: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-01-02 00:54:41 [179,106ms] [Fatal] [carb.crashreporter-breakpad.plugin] 198: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-01-02 00:54:41 [179,305ms] [Fatal] [carb.crashreporter-breakpad.plugin] 199: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-01-02 00:54:42 [179,488ms] [Fatal] [carb.crashreporter-breakpad.plugin] 200: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:42 [179,685ms] [Fatal] [carb.crashreporter-breakpad.plugin] 201: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:42 [179,888ms] [Fatal] [carb.crashreporter-breakpad.plugin] 202: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:42 [180,085ms] [Fatal] [carb.crashreporter-breakpad.plugin] 203: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:42 [180,282ms] [Fatal] [carb.crashreporter-breakpad.plugin] 204: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:43 [180,479ms] [Fatal] [carb.crashreporter-breakpad.plugin] 205: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:43 [180,674ms] [Fatal] [carb.crashreporter-breakpad.plugin] 206: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:43 [180,854ms] [Fatal] [carb.crashreporter-breakpad.plugin] 207: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:43 [181,048ms] [Fatal] [carb.crashreporter-breakpad.plugin] 208: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:43 [181,249ms] [Fatal] [carb.crashreporter-breakpad.plugin] 209: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:44 [181,441ms] [Fatal] [carb.crashreporter-breakpad.plugin] 210: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:44 [181,639ms] [Fatal] [carb.crashreporter-breakpad.plugin] 211: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:44 [181,829ms] [Fatal] [carb.crashreporter-breakpad.plugin] 212: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:44 [182,028ms] [Fatal] [carb.crashreporter-breakpad.plugin] 213: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-01-02 00:54:44 [182,220ms] [Fatal] [carb.crashreporter-breakpad.plugin] 214: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-01-02 00:54:45 [182,420ms] [Fatal] [carb.crashreporter-breakpad.plugin] 215: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-01-02 00:54:45 [182,618ms] [Fatal] [carb.crashreporter-breakpad.plugin] 216: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-01-02 00:54:45 [182,820ms] [Fatal] [carb.crashreporter-breakpad.plugin] 217: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-01-02 00:54:45 [183,024ms] [Fatal] [carb.crashreporter-breakpad.plugin] 218: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:45 [183,225ms] [Fatal] [carb.crashreporter-breakpad.plugin] 219: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-01-02 00:54:46 [183,428ms] [Fatal] [carb.crashreporter-breakpad.plugin] 220: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-01-02 00:54:46 [183,629ms] [Fatal] [carb.crashreporter-breakpad.plugin] 221: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-01-02 00:54:46 [183,830ms] [Fatal] [carb.crashreporter-breakpad.plugin] 222: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:46 [184,015ms] [Fatal] [carb.crashreporter-breakpad.plugin] 223: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:46 [184,207ms] [Fatal] [carb.crashreporter-breakpad.plugin] 224: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:47 [184,396ms] [Fatal] [carb.crashreporter-breakpad.plugin] 225: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:47 [184,573ms] [Fatal] [carb.crashreporter-breakpad.plugin] 226: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:47 [184,762ms] [Fatal] [carb.crashreporter-breakpad.plugin] 227: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:47 [184,945ms] [Fatal] [carb.crashreporter-breakpad.plugin] 228: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:47 [185,122ms] [Fatal] [carb.crashreporter-breakpad.plugin] 229: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:47 [185,301ms] [Fatal] [carb.crashreporter-breakpad.plugin] 230: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:48 [185,482ms] [Fatal] [carb.crashreporter-breakpad.plugin] 231: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:48 [185,680ms] [Fatal] [carb.crashreporter-breakpad.plugin] 232: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:48 [185,869ms] [Fatal] [carb.crashreporter-breakpad.plugin] 233: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:48 [186,069ms] [Fatal] [carb.crashreporter-breakpad.plugin] 234: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:48 [186,265ms] [Fatal] [carb.crashreporter-breakpad.plugin] 235: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-01-02 00:54:49 [186,462ms] [Fatal] [carb.crashreporter-breakpad.plugin] 236: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-01-02 00:54:49 [186,659ms] [Fatal] [carb.crashreporter-breakpad.plugin] 237: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-01-02 00:54:49 [186,858ms] [Fatal] [carb.crashreporter-breakpad.plugin] 238: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-01-02 00:54:49 [187,054ms] [Fatal] [carb.crashreporter-breakpad.plugin] 239: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-01-02 00:54:49 [187,253ms] [Fatal] [carb.crashreporter-breakpad.plugin] 240: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:50 [187,492ms] [Fatal] [carb.crashreporter-breakpad.plugin] 241: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-01-02 00:54:50 [187,692ms] [Fatal] [carb.crashreporter-breakpad.plugin] 242: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-01-02 00:54:50 [187,890ms] [Fatal] [carb.crashreporter-breakpad.plugin] 243: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-01-02 00:54:50 [188,094ms] [Fatal] [carb.crashreporter-breakpad.plugin] 244: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-01-02 00:54:50 [188,295ms] [Fatal] [carb.crashreporter-breakpad.plugin] 245: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-01-02 00:54:51 [188,508ms] [Fatal] [carb.crashreporter-breakpad.plugin] 246: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-01-02 00:54:51 [188,715ms] [Fatal] [carb.crashreporter-breakpad.plugin] 247: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-01-02 00:54:51 [188,911ms] [Fatal] [carb.crashreporter-breakpad.plugin] 248: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-01-02 00:54:51 [189,126ms] [Fatal] [carb.crashreporter-breakpad.plugin] 249: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:51 [189,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 250: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:52 [189,538ms] [Fatal] [carb.crashreporter-breakpad.plugin] 251: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:52 [189,737ms] [Fatal] [carb.crashreporter-breakpad.plugin] 252: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:52 [189,941ms] [Fatal] [carb.crashreporter-breakpad.plugin] 253: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-01-02 00:54:52 [190,150ms] [Fatal] [carb.crashreporter-breakpad.plugin] 254: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-01-02 00:54:52 [190,365ms] [Fatal] [carb.crashreporter-breakpad.plugin] 255: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
