Omniverse Create is crashing while exporting to gltf/glb
Omniverse Create crashes when trying to export USD file to GLTF/GLB formats.
Here is the crash report.
2022-09-28 21:51:53 [532,892ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2022-09-28 21:51:53 [532,892ms] [Warning] [carb.crashreporter-breakpad.plugin] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:‘D:/NVidia/ov/data/Kit/Create.Next/2022.2\673badf0-2a0c-455c-b528-6f438ebe7887.dmp’ svr:‘https://services.nvidia.com/submit
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = ‘673badf0-2a0c-455c-b528-6f438ebe7887’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = ‘OmniverseKit’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = ‘1664401380’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = ‘533’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = ‘103.5+release.7563.fccdfc27.tc’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = ‘Create.Next’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = ‘started’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = ‘2022.2.2-rc.2’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = ‘omni.services.streamclient.websocket-1.4.5,omni.kit.window.stream_viewport-0.1.0’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = ‘release’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = ‘tc’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCiNumber = ‘11638338’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = ‘fccdfc27’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = ‘103’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = ‘5’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = ‘0’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = ‘7563’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = ‘0’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = ‘103.5.0’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuId = ‘Intel64 Family 6 Model 165 Stepping 2’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuName = ‘Intel(R) Core™ i7-10750H CPU @ 2.60GHz’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuVendor = ‘GenuineIntel’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopOrigin = ‘(0, 0)’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopSize = ‘1920x1080’
2022-09-28 21:51:53 [532,898ms] [Warning] [carb.crashreporter-breakpad.plugin] displayCount = ‘2’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_0 = ‘1920x1080x32bit@144Hz’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_1 = ‘1920x1080x32bit@144Hz’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = ‘default’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = ‘Create Next’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] externalBuild = ‘1’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_0 = ‘516.94’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_1 = ‘0x0000’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_0 = ‘8421113856’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_1 = ‘134217728’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_0 = ‘NVIDIA GeForce RTX 2070’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_1 = ‘Intel(R) UHD Graphics’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = ‘516.94’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = ‘Undo’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = ‘ChangePrimVarCommand(prim_path=/World/Part_2,primvar_name=doNotCastShadows,value=False,type_to_create_if_not_exist=?),Group,SetMaterialStrength(rel=?,strength=strongerThanDescendants),SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True),Group,ChangeProperty(prop_path=/World/RectLight.intensity,value=10000.0,prev=15000.0),SelectAll(type=Material),Undo,SelectAll(type=Shader),Undo’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = ‘(avail/total) RAM: 16.2018/31.8244GB, Swap: 13.3728/40.8244GB, VM: 130966/131072GB’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] osDistro = ‘2009’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] osName = ‘Windows 10 Pro’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] osVersion = ‘10.0.19044’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = ‘0’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] primaryDisplayRes = ‘1920x1080x32bit@144Hz’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] startup_time = ‘11.7389619’
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = ’
| Driver Version: 516.94 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 2070 | Yes: 0 | | 8031 MB | 10de | 11e07000… |
| | | | | | 1f14 | 0 |
| 1 | Intel(R) UHD Graphics | | | 128 MB | 8086 | 11af6000… |
| | | | | | 9bc4 | 0 |
| OS: Windows, Version: 10.0, Build: 19044
| Processor: Intel(R) Core™ i7-10750H CPU @ 2.60GHz | Cores: 6 | Logical: 12
| Total Memory (MB): 32588 | Free Memory: 18616
| Total Page/Swap (MB): 41804 | Free Page/Swap: 21008
2022-09-28 21:51:53 [532,899ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = ‘3247441552125643367’
2022-09-28 21:52:06 [545,989ms] [Warning] [carb.crashreporter-breakpad.plugin] uploaded minidump: file: ‘D:/NVidia/ov/data/Kit/Create.Next/2022.2\673badf0-2a0c-455c-b528-6f438ebe7887.dmp’, code:200, response:
2022-09-28 21:52:06 [545,989ms] [Warning] [carb.crashreporter-breakpad.plugin] 0000018357b856cf-585ed
2022-09-28 21:52:06 [545,989ms] [Warning] [carb.crashreporter-breakpad.plugin] deleting minidump: ‘D:/NVidia/ov/data/Kit/Create.Next/2022.2\673badf0-2a0c-455c-b528-6f438ebe7887.dmp’ (use setting “/crashreporter/preserveDump=true” to save).
2022-09-28 21:52:06 [545,990ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file ‘D:/NVidia/ov/data/Kit/Create.Next/2022.2\673badf0-2a0c-455c-b528-6f438ebe7887.dmp’
2022-09-28 21:52:06 [545,990ms] [Error] [carb.crashreporter-breakpad.plugin] dump file size is -1 bytes, file is not readable.
2022-09-28 21:52:07 [546,581ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 9964 thread 12216
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata:
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = ‘673badf0-2a0c-455c-b528-6f438ebe7887’
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = ‘OmniverseKit’
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = ‘1664401380’
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = ‘533’
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = ‘103.5+release.7563.fccdfc27.tc’
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = ‘Create.Next’
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = ‘started’
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = ‘2022.2.2-rc.2’
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = ‘omni.services.streamclient.websocket-1.4.5,omni.kit.window.stream_viewport-0.1.0’
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = ‘release’
2022-09-28 21:52:07 [546,581ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = ‘tc’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCiNumber = ‘11638338’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = ‘fccdfc27’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = ‘103’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = ‘5’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = ‘0’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = ‘7563’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = ‘0’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = ‘103.5.0’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuId = ‘Intel64 Family 6 Model 165 Stepping 2’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuName = ‘Intel(R) Core™ i7-10750H CPU @ 2.60GHz’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuVendor = ‘GenuineIntel’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopOrigin = ‘(0, 0)’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopSize = ‘1920x1080’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] displayCount = ‘2’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_0 = ‘1920x1080x32bit@144Hz’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_1 = ‘1920x1080x32bit@144Hz’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = ‘default’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = ‘Create Next’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] externalBuild = ‘1’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_0 = ‘516.94’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_1 = ‘0x0000’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_0 = ‘8421113856’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_1 = ‘134217728’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_0 = ‘NVIDIA GeForce RTX 2070’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_1 = ‘Intel(R) UHD Graphics’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = ‘516.94’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = ‘Undo’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = ‘ChangePrimVarCommand(prim_path=/World/Part_2,primvar_name=doNotCastShadows,value=False,type_to_create_if_not_exist=?),Group,SetMaterialStrength(rel=?,strength=strongerThanDescendants),SelectPrims(old_selected_paths=?,new_selected_paths=?,expand_in_stage=True),Group,ChangeProperty(prop_path=/World/RectLight.intensity,value=10000.0,prev=15000.0),SelectAll(type=Material),Undo,SelectAll(type=Shader),Undo’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = ‘(avail/total) RAM: 16.2018/31.8244GB, Swap: 13.3728/40.8244GB, VM: 130966/131072GB’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] osDistro = ‘2009’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] osName = ‘Windows 10 Pro’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] osVersion = ‘10.0.19044’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = ‘0’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] primaryDisplayRes = ‘1920x1080x32bit@144Hz’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] startup_time = ‘11.7389619’
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = ’
| | | | | | Device-ID | UUID |
| | | | | | 1f14 | 0 |
| | | | | | 9bc4 | 0 |
2022-09-28 21:52:07 [546,582ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = ‘3247441552125643367’
2022-09-28 21:52:07 [546,582ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 12216 backtrace follows:
2022-09-28 21:52:07 [546,585ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: omniverse_asset_converter.dll!+0x36b1f
2022-09-28 21:52:07 [546,585ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: omniverse_asset_converter.dll!+0x322ab
2022-09-28 21:52:07 [546,585ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: omniverse_asset_converter.dll!+0x2d496
2022-09-28 21:52:07 [546,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: omniverse_asset_converter.dll!+0x513f
2022-09-28 21:52:07 [546,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: omniverse_asset_converter.dll!+0x5ae6
2022-09-28 21:52:07 [546,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: omniverse_asset_converter.dll!+0x5999
2022-09-28 21:52:07 [546,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: ucrtbase.dll!configthreadlocale+0x92
2022-09-28 21:52:07 [546,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: KERNEL32.DLL!BaseThreadInitThunk+0x14
2022-09-28 21:52:07 [546,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: ntdll.dll!RtlUserThreadStart+0x21
Thanks,
Nandu
Hello @user91403! The crash report you sent just gives me information about your system, not what the error is. Could you attach your logs from here C:\Users\<USERNAME>\.nvidia-omniverse\logs\Kit\Create
The only thing that I can guess from this information is that you might have run out of VRAM because you are using an RTX 2070. If you could send me your logs, I can see if the error is reported there!
Thanks Wendy, I found there were some objects that were not getting converted. I was able to fix the issue.
Thanks,
Nandu
