Hi there,
Not sure why is that the Code on my machine is not stable
When running, sometimes closes itself, and sometimes crashes as executed script
Can you help check my log, Are any clues that can cause this?
Code_Logs.zip (11.9 MB)
Crash screen1
Crash screen2
Last error for reference
2023-07-19 05:38:09 [31,084ms] [Warning] [carb.crashreporter-breakpad.plugin] deleting minidump: '/home/darien/.local/share/ov/data/Kit/Code/2022.3/e34be80b-3228-4fb2-1c339a8e-f0649856.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save).
2023-07-19 05:38:09 [31,084ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file '/home/darien/.local/share/ov/data/Kit/Code/2022.3/e34be80b-3228-4fb2-1c339a8e-f0649856.dmp.zip'
2023-07-19 05:38:09 [31,084ms] [Error] [carb.crashreporter-breakpad.plugin] the dump file was deleted due to a successful upload. Its originalsize was 402922 bytes and was readable.
2023-07-19 05:38:09 [31,085ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 9128 thread 9732
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata:
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = 'e34be80b-3228-4fb2-1c339a8e-f0649856'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] RetryCount = '0'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1689745058'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] UploadSuccessful = '0'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '29'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '104.2+release.295.529af2e4.tc'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Code'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'started'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.3.3-rc.3'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = 'tmrobot.vision.synthetic_data-1.0.0'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '529af2e4'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] buildId = '14001715'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '104'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '2'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '295'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '104.2.0'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuId = 'Intel64 Family 6 Model 154 Stepping 3'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuName = '12th Gen Intel(R) Core(TM) i9-12900HK'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuVendor = 'GenuineIntel'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopOrigin = '(0, 0)'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopSize = '3840x2160'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] displayCount = '1'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_0 = '3840x2160x32bit@60Hz'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = ''
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Code'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] externalBuild = '1'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_0 = '525.125'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_1 = '0x5802005'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_0 = '17179869184'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_1 = '50328345600'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_0 = 'NVIDIA GeForce RTX 3080 Ti Laptop GPU'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_1 = 'Intel(R) Graphics (ADL GT2)'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = '525.125'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = 'CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/WriterSyncGate,node_type=omni.graph.action.SyncGate,create_usd=True)'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = 'CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnSampleUniform_04,node_type=omni.replicator.core.OgnSampleUniform,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnSampleUniform_05,node_type=omni.replicator.core.OgnSampleUniform,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnPerAxisPose_04,node_type=omni.replicator.core.OgnPerAxisPose,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnCount_08,node_type=omni.replicator.core.OgnCount,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnWritePrimAttribute_04,node_type=omni.replicator.core.OgnWritePrimAttribute,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnCount_09,node_type=omni.replicator.core.OgnCount,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnWritePrimAttribute_05,node_type=omni.replicator.core.OgnWritePrimAttribute,create_usd=True),CreateNodeCommand(graph=?,node_path=/Replicator/SDGPipeline/OgnCount_10,node_type=omni.replicator.core.OgnCount,create_usd=True),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/RenderProduct_Replicator_BasicWriterWriter,node_type=omni.replicator.core.OgnWriter,create_usd=True),CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/WriterSyncGate,node_type=omni.graph.action.SyncGate,create_usd=True)'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 45.6315/62.4959GB, Swap: 2/2GB, VM: 1.71799e+10/1.71799e+10GB'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] osDistro = 'ubuntu'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] osName = '22.04.2 LTS (Jammy Jellyfish)'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] osVersion = '22.4.2'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] primaryDisplayRes = '3840x2160x32bit@60Hz'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] startup_time = '5.236116766'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = '
| Driver Version: 525.125.06 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 3080 Ti Lap.. | Yes: 0 | | 16384 MB | 10de | 0 |
| | | | | | 2420 | 4d575e99.. |
| 1 | Intel(R) Graphics (ADL GT2) | | | 47996 MB | 8086 | 0 |
| | | | | | 46a6 | c967c73f.. |
| OS: Linux universe, Version: 5.19.0-46-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: 12th Gen Intel(R) Core(TM) i9-12900HK | Cores: Unknown | Logical: 20
| Total Memory (MB): 63995 | Free Memory: 55625
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '7372563271241801175'
2023-07-19 05:38:09 [31,085ms] [Warning] [carb.crashreporter-breakpad.plugin] userId = ''
2023-07-19 05:38:09 [31,085ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 9732 backtrace follows:
2023-07-19 05:38:09 [31,274ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2023-07-19 05:38:10 [31,413ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libgpu.foundation.plugin.so!std::vector<unsigned char, std::allocator<unsigned char> >::_M_default_append(unsigned long)+0x4740 (??:?)
2023-07-19 05:38:10 [31,558ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libgpu.foundation.plugin.so!std::vector<unsigned char, std::allocator<unsigned char> >::_M_default_append(unsigned long)+0xd7a8 (??:?)
2023-07-19 05:38:10 [31,694ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x142be (??:?)
2023-07-19 05:38:10 [31,834ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x1b4c9 (??:?)
2023-07-19 05:38:10 [31,974ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x1bb63 (??:?)
2023-07-19 05:38:10 [32,114ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x4a7db (??:?)
2023-07-19 05:38:10 [32,255ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x4e21b (??:?)
2023-07-19 05:38:10 [32,390ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libcarb.scenerenderer-rtx.plugin.so!std::_Hashtable<unsigned int, unsigned int, std::allocator<unsigned int>, std::__detail::_Identity, std::equal_to<unsigned int>, std::hash<unsigned int>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned int, false>*)+0x1a917 (??:?)
2023-07-19 05:38:11 [32,527ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: librtx.hydra.so!carb::progress::ScopedLoadingEvent* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*>(std::move_iterator<carb::progress::ScopedLoadingEvent*>, std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*)+0x78e4 (??:?)
2023-07-19 05:38:11 [32,662ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: librtx.hydra.so!carb::progress::ScopedLoadingEvent* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*>(std::move_iterator<carb::progress::ScopedLoadingEvent*>, std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*)+0xae01 (??:?)
2023-07-19 05:38:11 [32,807ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0x5e7a (??:?)
2023-07-19 05:38:11 [32,949ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0x8bab (??:?)
2023-07-19 05:38:11 [33,090ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0x92ec (??:?)
2023-07-19 05:38:11 [33,228ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libomni.usd.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)+0x4f9f (??:?)
2023-07-19 05:38:11 [33,370ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)+0x188c (??:?)
2023-07-19 05:38:12 [33,506ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)+0x2026 (??:?)
2023-07-19 05:38:12 [33,645ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()+0x8ac (??:?)
2023-07-19 05:38:12 [33,783ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()+0xe8e3 (??:?)
2023-07-19 05:38:12 [33,918ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::_M_run()+0x1d (??:?)
2023-07-19 05:38:12 [34,060ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libstdc++.so.6!std::error_code::default_error_condition() const+0x33 (??:?)
2023-07-19 05:38:12 [34,239ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libc.so.6!pthread_condattr_setpshared+0x513 (./nptl/pthread_create.c:442)
2023-07-19 05:38:13 [34,418ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libc.so.6!__xmknodat+0x230 (./misc/../sysdeps/unix/sysv/linux/x86_64/clone3.S:83)
Thanks and regards,
Darien
