Kit 106 crashed, help me to understand why?
Operating System:
Windows
Linux
Kit Version:
107
106
105
Kit Template:
USD Composer
USD Explorer
USD Viewer
Custom
GPU Hardware:
A series (Blackwell)
A series (ADA)
A series
50 series
40 series
30 series
GPU Driver:
Latest
Recommended (573.xx)
Other
just crashed, I opened it and was writing email.
Microsoft Windows [Version 10.0.26100.3775]
(c) Microsoft Corporation. All rights reserved.
C:\Users\varis>cd ..
C:\Users>cd..
C:>cd kit-app-template106
C:\kit-app-template106>cd kit-app-template
C:\kit-app-template106\kit-app-template>repo.bat launch -d
[ctrl+c to Exit]
? Select with arrow keys which App you would like to launch: cineshare106.my_usd_composer.kit
launching cineshare106.my_usd_composer.kit!
Loading user config located at: ‘C:/Users/varis/AppData/Local/ov/data/Kit/Cineshare 106 Composer/0.1/user.config.json’
[Info] [carb] Logging to file: C:/Users/varis/.nvidia-omniverse/logs/Kit/Cineshare 106 Composer/0.1/kit_20250505_105333.log
[1.914s] [ext: omni.kit.async_engine-0.0.1] startup
[2.772s] [ext: omni.metrics.core-0.0.1] startup
[2.776s] [ext: omni.client.lib-1.0.0] startup
[3.211s] [ext: omni.blobkey-1.1.2] startup
[3.228s] [ext: omni.activity.core-1.0.1] startup
[3.278s] [ext: omni.datastore-0.0.0] startup
[3.284s] [ext: omni.stats-1.0.1] startup
[3.295s] [ext: omni.client-1.2.2] startup
[3.304s] [ext: omni.assets.plugins-0.0.0] startup
[3.316s] [ext: omni.ujitso.default-1.0.0] startup
[3.323s] [ext: omni.hsscclient-1.1.1] startup
2025-05-05 07:53:36 [2,693ms] [Warning] [omni.datastore] OmniHub is inaccessible
[3.385s] [ext: omni.gpu_foundation.shadercache.d3d12-1.0.0] startup
[3.436s] [ext: omni.activity.profiler-1.0.4] startup
[3.457s] [ext: omni.gpu_foundation-0.0.0] startup
[3.539s] [ext: carb.windowing.plugins-1.0.0] startup
[3.577s] [ext: omni.kit.renderer.init-0.0.0] startup
[3.580s] [ext: omni.kit.pipapi-0.0.0] startup
[3.596s] [ext: omni.kit.pip_archive-0.0.0] startup
[3.604s] [ext: omni.materialx.libs-1.0.6] startup
[3.662s] [ext: omni.kit.loop-default-0.2.0] startup
[3.666s] [ext: omni.kit.test-1.1.2] startup
2025-05-05 07:53:37 [3,639ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) UHD Graphics 770
2025-05-05 07:53:37 [3,641ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) UHD Graphics 770
[4.639s] [ext: omni.usd.config-1.0.5] startup
| Driver Version: 572.83 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA RTX 6000 Ada Generation | Yes: 0 | | 48413 MB | 10de | 9c420100.. |
| | | | | | 26b1 | 0 |
| | | | | | 1 | |
| 1 | Intel(R) UHD Graphics 770 | | | 128 MB | 8086 | d8530100.. |
| | | | | | a780 | 0 |
| | | | | | N/A | |
| OS: Windows 11 Pro, Version: 10.0 (24H2), Build: 26100, Kernel: 10.0.26100.3775
| Processor: Intel(R) Core™ i9-14900K
| Cores: 24 | Logical Cores: 32
| Total Memory (MB): 130758 | Free Memory: 110620
| Total Page/Swap (MB): 138950 | Free Page/Swap: 113850
[4.678s] [ext: omni.gpucompute.plugins-0.0.0] startup
[4.722s] [ext: omni.usd.libs-1.0.1] startup
[4.992s] [ext: omni.kit.telemetry-0.5.1] startup
[5.086s] [ext: omni.mdl-55.0.1] startup
[5.145s] [ext: omni.iray.libs-0.0.0] startup
[5.285s] [ext: omni.mdl.neuraylib-0.2.10] startup
[5.315s] [ext: omni.kit.usd.mdl-1.0.7] startup
[5.601s] [ext: omni.services.pip_archive-0.13.11] startup
[5.607s] [ext: omni.appwindow-1.1.9] startup
[5.632s] [ext: omni.kit.renderer.core-1.0.2] startup
[5.649s] [ext: omni.kit.renderer.capture-0.0.0] startup
[5.673s] [ext: omni.kit.renderer.imgui-1.0.2] startup
[5.705s] [ext: omni.ui-2.26.5] startup
[5.771s] [ext: omni.kit.mainwindow-1.0.3] startup
[5.788s] [ext: carb.audio-0.1.0] startup
[5.795s] [ext: omni.uiaudio-1.0.0] startup
[5.805s] [ext: omni.kit.uiapp-0.0.0] startup
[5.807s] [ext: omni.usd.schema.metrics.assembler-106.5.0] startup
[5.831s] [ext: omni.usd.schema.audio-0.0.0] startup
[5.856s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[5.872s] [ext: omni.usd.schema.anim-0.0.0] startup
[5.963s] [ext: omni.graph.exec-0.9.4] startup
[5.967s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[5.981s] [ext: omni.kit.exec.core-0.13.4] startup
[6.000s] [ext: omni.kit.actions.core-1.0.0] startup
[6.024s] [ext: omni.usd_resolver-1.0.0] startup
[6.055s] [ext: omni.kit.commands-1.4.9] startup
[6.134s] [ext: omni.usd.core-1.4.2] startup
[6.140s] [ext: usdrt.scenegraph-7.5.1] startup
[6.323s] [ext: omni.resourcemonitor-107.0.0] startup
[6.341s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[6.411s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[6.488s] [ext: omni.kit.widget.nucleus_connector-1.1.10] startup
[6.527s] [ext: omni.timeline-1.0.11] startup
[6.550s] [ext: omni.kit.usd_undo-0.1.8] startup
[6.565s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[6.576s] [ext: omni.usd-1.12.4] startup
[6.810s] [ext: omni.kit.asset_converter-2.8.4] startup
[6.910s] [ext: omni.anim.behavior.schema-106.5.0] startup
[6.938s] [ext: omni.usd.fileformat.sbsar-107.0.2] startup
[7.065s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[7.084s] [ext: omni.anim.graph.schema-106.5.0] startup
[7.112s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[7.142s] [ext: omni.usd.schema.physx-106.5.7] startup
[7.214s] [ext: omni.usd.schema.sequence-2.3.1] startup
[7.236s] [ext: omni.kit.property.adapter.core-1.0.2] startup
[7.284s] [ext: omni.graph.core-2.181.8] startup
[7.313s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[7.326s] [ext: omni.kit.property.adapter.usd-1.0.2] startup
[7.347s] [ext: omni.kit.property.adapter.fabric-1.0.3] startup
[7.371s] [ext: omni.graph.tools-1.79.1] startup
[7.738s] [ext: omni.ui_query-1.1.7] startup
[7.749s] [ext: omni.kit.menu.core-1.1.2] startup
[7.757s] [ext: omni.kit.collaboration.channel_manager-1.0.12] startup
[7.774s] [ext: omni.kit.clipboard-1.0.5] startup
[7.782s] [ext: omni.kit.widget.path_field-2.0.11] startup
[7.800s] [ext: omni.kit.widget.context_menu-1.2.4] startup
[7.817s] [ext: omni.kit.usd.layers-2.2.0] startup
[7.889s] [ext: omni.index.libs-380600.1777.0] startup
[7.890s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[7.909s] [ext: omni.kit.notification_manager-1.0.9] startup
[7.941s] [ext: omni.kit.context_menu-1.8.3] startup
[7.973s] [ext: omni.index-1.0.1] startup
[7.978s] [ext: omni.kit.helper.file_utils-0.1.9] startup
[8.001s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[8.014s] [ext: omni.kit.widget.filebrowser-2.10.52] startup
[8.083s] [ext: omni.kit.search_core-1.0.6] startup
[8.100s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[8.151s] [ext: omni.ui.scene-1.11.2] startup
[8.172s] [ext: omni.kit.widget.versioning-1.4.9] startup
[8.217s] [ext: omni.kit.widget.search_delegate-1.0.6] startup
[8.238s] [ext: omni.kit.widget.options_button-1.0.3] startup
[8.252s] [ext: omni.hydra.rtx.shadercache.d3d12-1.0.0] startup
[8.263s] [ext: omni.kit.window.filepicker-2.11.7] startup
[8.480s] [ext: omni.kit.widget.filter-1.1.4] startup
[8.495s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[8.500s] [ext: omni.volume-0.5.0] startup
[8.523s] [ext: omni.ujitso.client-0.0.0] startup
[8.526s] [ext: omni.kit.hotkeys.core-1.3.10] startup
[8.578s] [ext: omni.hydra.rtx-1.0.0] startup
[8.661s] [ext: omni.kit.window.file_importer-1.1.14] startup
[8.727s] [ext: omni.kit.window.file_exporter-1.0.31] startup
[8.751s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[8.776s] [ext: omni.kit.menu.utils-1.7.7] startup
[8.828s] [ext: omni.kit.widget.stage-2.11.6] startup
[8.974s] [ext: omni.kit.hydra_texture-1.4.0] startup
[8.990s] [ext: omni.kit.material.library-1.5.15] startup
[9.058s] [ext: omni.hydra.engine.stats-1.0.3] startup
[9.068s] [ext: omni.kit.widget.highlight_label-1.0.3] startup
[9.082s] [ext: omni.kit.viewport.scene_camera_model-1.0.5] startup
[9.091s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[9.124s] [ext: omni.kit.widget.viewport-107.0.7] startup
[9.174s] [ext: omni.kit.viewport.registry-104.0.6] startup
[9.184s] [ext: omni.kit.viewport.legacy_gizmos-1.0.16] startup
[9.192s] [ext: omni.kit.window.drop_support-1.0.4] startup
[9.203s] [ext: omni.kit.raycast.query-1.0.5] startup
[9.221s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[9.230s] [ext: omni.kit.viewport.window-107.0.8] startup
[9.590s] [ext: omni.kit.window.property-1.11.5] startup
[9.635s] [ext: omni.kit.stage_template.core-1.1.22] startup
[9.645s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[9.664s] [ext: omni.kit.widget.prompt-1.0.7] startup
[9.676s] [ext: omni.kit.window.file-1.3.57] startup
[9.711s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[9.725s] [ext: omni.kit.widget.settings-1.2.2] startup
[9.753s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[9.809s] [ext: omni.kit.window.content_browser-2.10.3] startup
2025-05-05 07:53:43 [9,222ms] [Warning] [omni.ext._impl._internal] Found class WrappedClass derived from omni.ext.IExt in module: ‘omni.kit.window.content_browser’, but it was imported from other extension: ‘c:\kit-app-template106/kit-app-template/build/windows-x86_64/release/kit/kernel/py\omni\kit\app_impl_init.py’, which is not a subpath to: ‘c:\kit-app-template106\kit-app-template_build\windows-x86_64\release\extscache\omni.kit.window.content_browser-2.10.3+d02c707b’. Do not import IExt derived class from other extension in your public namespace.
[9.969s] [ext: omni.kit.window.preferences-1.7.0] startup
[10.061s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[10.100s] [ext: omni.kit.window.extensions-1.4.25] startup
[10.196s] [ext: omni.kit.viewport.utility-1.0.18] startup
[10.203s] [ext: omni.kit.property.usd-4.2.16] startup
[10.309s] [ext: omni.graph-1.140.2] startup
[11.169s] [ext: omni.graph.image.core-0.6.0] startup
[11.175s] [ext: omni.graph.ui-1.91.0] startup
[11.411s] [ext: omni.graph.image.nodes-1.3.0] startup
[11.421s] [ext: omni.graph.action_core-1.1.7] startup
[11.437s] [ext: omni.graph.nodes-1.162.1] startup
[11.499s] [ext: omni.graph.action_nodes-1.40.1] startup
[11.517s] [ext: omni.kit.manipulator.viewport-107.0.1] startup
[11.536s] [ext: omni.graph.ui_nodes-1.40.1] startup
[11.558s] [ext: omni.graph.io-1.20.0] startup
2025-05-05 07:53:44 [10,931ms] [Warning] [omni.graph.io._impl.extension] omni.graph.io is deprecated. Nodes in this extension have been moved to omni.graph.nodes. Update any dependencies accordingly.
[11.571s] [ext: omni.graph.action-1.120.0] startup
[11.578s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[11.641s] [ext: omni.graph.bundle.action-2.20.0] startup
[11.658s] [ext: omni.debugdraw-0.1.3] startup
[11.677s] [ext: omni.kit.widget.graph-1.12.17] startup
[11.770s] [ext: omni.kit.manipulator.transform-106.0.1] startup
[11.822s] [ext: omni.kit.widget.toolbar-1.7.3] startup
[11.927s] [ext: omni.curve.creator-105.0.5] startup
[11.943s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[11.952s] [ext: omni.kit.widget.stage_icons-1.0.6] startup
[11.962s] [ext: omni.kit.manipulator.tool.snap-1.5.12] startup
[12.023s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[12.045s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[12.080s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[12.136s] [ext: omni.kit.window.stage-2.5.11] startup
[12.163s] [ext: omni.kit.menu.create-1.0.17] startup
[12.179s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[12.202s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[12.223s] [ext: omni.kit.stage_templates-1.2.6] startup
[12.250s] [ext: omni.anim.asset-106.5.1] startup
[12.256s] [ext: omni.kit.browser.core-2.3.11] startup
[12.324s] [ext: omni.anim.retarget.core-106.5.1] startup
[12.375s] [ext: omni.ramp-105.1.16] startup
[12.401s] [ext: omni.kit.browser.folder.core-1.10.1] startup
[12.540s] [ext: omni.scene.visualization.core-105.4.14] startup
[12.845s] [ext: omni.anim.graph.core-106.5.1] startup
[12.895s] [ext: omni.kit.widget.imageview-1.0.3] startup
[12.905s] [ext: omni.kit.browser.sample-1.4.8] startup
2025-05-05 07:53:46 [12,282ms] [Warning] [omni.graph.core._impl._registration.register_python_ogn] Python import process in omni.anim.graph.core failed - ‘NoneType’ object is not subscriptable. Aborting Python node registration
[12.928s] [ext: omni.genproc.core-106.1.0] startup
[13.332s] [ext: omni.curve.manipulator-105.2.9] startup
[13.446s] [ext: omni.kit.window.quicksearch-2.4.4] startup
[13.485s] [ext: omni.kit.graph.delegate.modern-1.10.8] startup
[13.516s] [ext: omni.anim.graph.ui-106.5.0] startup
[13.698s] [ext: omni.anim.graph.bundle-106.5.0] startup
[13.708s] [ext: omni.activity.usd_resolver-1.0.3] startup
[13.716s] [ext: omni.activity.pump-1.0.0] startup
[13.723s] [ext: omni.kit.window.cursor-1.1.4] startup
[13.738s] [ext: omni.activity.ui-1.1.1] startup
[13.821s] [ext: omni.kit.viewport.menubar.core-107.1.2] startup
[14.025s] [ext: omni.kit.viewport.actions-107.0.0] startup
[14.050s] [ext: omni.kit.usd.collect-2.2.22] startup
[14.077s] [ext: omni.kit.viewport.menubar.display-107.0.3] startup
[14.104s] [ext: omni.scene.optimizer.core-106.1.10] startup
[14.221s] [ext: omni.asset_validator.core-0.16.2] startup
[14.446s] [ext: omni.anim.skelJoint-106.5.1] startup
[14.488s] [ext: omni.configurator_publisher-1.1.2] startup
[14.534s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[14.543s] [ext: omni.kit.tool.collect-2.2.16] startup
[14.578s] [ext: omni.kit.menu.stage-1.2.5] startup
[14.592s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[14.614s] [ext: omni.kit.browser.asset-1.3.11] startup
[14.641s] [ext: omni.graph.scriptnode-1.40.1] startup
[14.651s] [ext: omni.graph.telemetry-2.30.2] startup
[14.670s] [ext: omni.graph.window.core-1.130.1] startup
[14.778s] [ext: omni.kit.manipulator.prim.core-107.0.7] startup
[14.851s] [ext: omni.fabric.commands-1.1.5] startup
[14.878s] [ext: omni.anim.curve.core-1.2.0] startup
[14.943s] [ext: omni.kit.manipulator.camera-106.0.3] startup
[14.986s] [ext: omni.graph.window.generic-1.40.0] startup
[15.026s] [ext: omni.graph.window.action-1.40.0] startup
[15.059s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[15.074s] [ext: omni.kit.manipulator.prim.fabric-107.0.4] startup
[15.092s] [ext: omni.anim.curve.ui-1.4.0] startup
[15.133s] [ext: omni.kit.debug.python-0.2.4] startup
[omni.kit.debug.python] Listening python debugger on: (‘127.0.0.1’, 3000)
[16.126s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[16.148s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[16.149s] [ext: omni.anim.curve.bundle-1.2.3] startup
[16.151s] [ext: omni.kit.widget.timeline-105.0.1] startup
[16.189s] [ext: omni.kit.debug.vscode-0.1.4] startup
[16.197s] [ext: omni.kit.debug.settings-0.1.8] startup
[16.372s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[16.443s] [ext: omni.kit.window.script_editor-1.7.8] startup
[16.473s] [ext: omni.kit.window.commands-0.2.7] startup
[16.496s] [ext: omni.kit.viewport.menubar.render-107.0.8] startup
[16.530s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[16.601s] [ext: omni.kit.dev.utilities.bundle-0.2.1] startup
[16.613s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[16.615s] [ext: omni.kit.browser.configurator_samples-1.0.2] startup
[16.641s] [ext: omni.timeline.live_session-1.0.8] startup
[16.696s] [ext: omni.kit.collaboration.selection_outline-1.0.7] startup
[16.727s] [ext: omni.anim.curve_editor-106.4.0] startup
[16.867s] [ext: omni.kit.developer.bundle-0.2.0] startup
[16.879s] [ext: omni.kit.sequencer.usd-103.4.6] startup
[16.899s] [ext: omni.kit.collaboration.viewport.camera-2.0.18] startup
[16.950s] [ext: omni.kvdb-106.5.7] startup
[16.965s] [ext: omni.anim.shared.core-106.0.2] startup
[16.986s] [ext: omni.kit.property.sequence-0.3.1] startup
[17.014s] [ext: omni.kit.actions.window-1.1.1] startup
[17.089s] [ext: omni.localcache-106.5.7] startup
[17.104s] [ext: omni.kit.preferences.animation-1.2.0] startup
[17.142s] [ext: omni.usdphysics-106.5.7] startup
[17.147s] [ext: omni.physx.foundation-106.5.7] startup
[17.170s] [ext: omni.convexdecomposition-106.5.7] startup
[17.187s] [ext: omni.anim.widget.timeline-0.1.12] startup
[17.290s] [ext: omni.kit.sequencer.core-103.4.2] startup
[17.321s] [ext: omni.physx.cooking-106.5.7] startup
[17.339s] [ext: omni.warp.core-1.5.0] startup
[17.708s] [ext: omni.kit.window.sequencer-103.4.4] startup
2025-05-05 07:53:51 [17,190ms] [Warning] [pxr.OmniAudioSchema] pxr.OmniAudioSchema is deprecated - please use OmniAudioSchema instead
[18.017s] [ext: omni.kit.hotkeys.window-1.4.8] startup
[18.098s] [ext: omni.physx-106.5.7] startup
[18.143s] [ext: omni.warp-1.5.0] startup
[18.194s] [ext: omni.kit.mesh.raycast-105.4.0] startup
[18.210s] [ext: omni.kit.window.toolbar-1.6.2] startup
[18.239s] [ext: omni.physx.stageupdate-106.5.7] startup
[18.279s] [ext: omni.kit.manipulator.tool.mesh_snap-1.4.5] startup
Warp 1.5.0 initialized:
CUDA Toolkit 11.8, Driver 12.8
Devices:
“cpu” : “Intel64 Family 6 Model 183 Stepping 1, GenuineIntel”
“cuda:0” : “NVIDIA RTX 6000 Ada Generation” (48 GiB, sm_89, mempool enabled)
Kernel cache:
C:\Users\varis\AppData\Local\NVIDIA\warp\Cache\1.5.0
[18.546s] [ext: omni.anim.time_samples_player-106.4.4] startup
[18.569s] [ext: omni.physx.zerogravity-106.5.7] startup
[18.690s] [ext: omni.kit.core.collection-0.2.0] startup
[18.705s] [ext: omni.kit.widget.layers-1.8.2] startup
[18.852s] [ext: omni.rtx.window.settings-0.6.17] startup
[18.903s] [ext: omni.genproc.ui-105.1.2] startup
[18.953s] [ext: omni.kit.property.collection-0.2.0] startup
[18.968s] [ext: omni.kit.property.layer-1.1.8] startup
[19.002s] [ext: omni.kit.ngsearch-0.3.3] startup
[19.019s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[19.020s] [ext: omni.genproc.bundle-105.1.0] startup
[19.021s] [ext: omni.kit.search.files-1.0.4] startup
[19.035s] [ext: omni.mdl.usd_converter-1.0.24] startup
[19.056s] [ext: omni.kit.search.service-0.1.12] startup
[19.669s] [ext: omni.kit.thumbnails.mdl-1.0.24] startup
[19.762s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[19.788s] [ext: omni.kit.stage.copypaste-1.2.2] startup
[19.812s] [ext: omni.kit.stage.mdl_converter-1.0.7] startup
[19.833s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[19.858s] [ext: omni.kit.browser.material-1.6.0] startup
[19.897s] [ext: omni.kit.property.material-1.10.17] startup
[20.018s] [ext: omni.kit.window.material_graph-1.8.19] startup
[20.350s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[20.372s] [ext: omni.kit.tool.remove_unused.core-0.1.2] startup
[20.385s] [ext: omni.kit.widgets.custom-1.0.9] startup
[20.505s] [ext: omni.kit.menu.aov-1.1.5] startup
[20.520s] [ext: omni.kit.usdz_export-1.0.7] startup
[20.537s] [ext: omni.kit.window.material-1.6.2] startup
[20.607s] [ext: omni.anim.timeline-106.4.2] startup
[20.623s] [ext: omni.simready.explorer-1.1.1] startup
[20.729s] [ext: omni.kit.variant.editor-106.1.1] startup
[20.849s] [ext: omni.kit.thumbnails.usd-1.0.9] startup
[21.290s] [ext: omni.kit.tool.asset_exporter-1.6.2] startup
[21.324s] [ext: omni.kit.tool.remove_unused.controller-0.1.3] startup
[21.338s] [ext: omni.kit.usda_edit-1.1.14] startup
[21.406s] [ext: omni.kit.variant.presenter-107.0.0] startup
[21.452s] [ext: omni.kit.widget.calendar-1.0.8] startup
[21.470s] [ext: omni.kit.ui.actions-1.0.2] startup
[21.493s] [ext: omni.kit.viewport.menubar.framerate-1.0.9] startup
[21.511s] [ext: omni.kit.viewport.ready-1.0.6] startup
[21.522s] [ext: omni.kit.widget.collection-0.1.18] startup
[21.553s] [ext: omni.kit.viewport_widgets_manager-1.0.8] startup
[21.571s] [ext: omni.kit.widget.extended_searchfield-1.0.29] startup
[21.654s] [ext: omni.kit.widget.sliderbar-1.0.10] startup
[21.680s] [ext: omni.kit.widget.live-2.1.8] startup
[21.702s] [ext: omni.kit.window.about-1.2.6] startup
[21.727s] [ext: omni.kit.window.collection-0.2.0] startup
[21.749s] [ext: omni.services.transport.client.base-1.2.4] startup
[21.759s] [ext: omni.kit.window.console-0.2.14] startup
[21.785s] [ext: omni.kit.environment.core-1.3.15] startup
[21.961s] [ext: omni.videoencoding-0.1.1] startup
[21.981s] [ext: omni.anim.window.timeline-106.4.0] startup
[22.074s] [ext: omni.kit.data2ui.core-1.0.27] startup
[22.104s] [ext: omni.services.client-0.5.3] startup
[23.511s] [ext: omni.graph.examples.cpp-1.40.0] startup
[23.525s] [ext: omni.kit.property.environment-1.2.1] startup
[23.591s] [ext: omni.kit.capture.viewport-1.5.3] startup
[23.625s] [ext: omni.kit.window.title-1.1.5] startup
[23.636s] [ext: omni.kit.data2ui.usd-1.0.27] startup
[23.783s] [ext: omni.services.transport.client.http_async-1.4.0] startup
[23.799s] [ext: omni.kit.selection-0.1.5] startup
[23.814s] [ext: omni.kit.window.environment-1.7.3] startup
[23.875s] [ext: omni.kit.window.imageviewer-1.0.7] startup
[23.908s] [ext: omni.kit.window.modifier.titlebar-105.2.16] startup
[23.953s] [ext: omni.no_code_ui.bundle-1.0.27] startup
[23.954s] [ext: omni.kit.window.movie_capture-2.4.2] startup
[24.059s] [ext: omni.kit.menu.edit-1.1.25] startup
[24.093s] [ext: omni.kit.window.privacy-0.1.1] startup
[24.104s] [ext: omni.asset_validator.ui-0.16.2] startup
[24.157s] [ext: omni.light_rigs-106.3.7] startup
[24.168s] [ext: omni.no_code_ui.authoring-1.0.27] startup
[24.169s] [ext: omni.hydra.scene_api-0.1.2] startup
[24.180s] [ext: omni.kit.property.audio-1.0.16] startup
[24.201s] [ext: omni.kit.converter.common-503.2.4] startup
[24.321s] [ext: omni.kit.property.camera-1.0.9] startup
[24.335s] [ext: omni.kit.property.light-1.0.11] startup
[24.354s] [ext: omni.kit.property.render-1.1.3] startup
[24.368s] [ext: omni.kit.property.geometry-1.3.3] startup
[24.395s] [ext: omni.kit.property.transform-1.5.10] startup
[24.433s] [ext: omni.rtx.settings.core-0.6.3] startup
[24.468s] [ext: omni.kit.converter.dgn_core-503.3.6] startup
[24.708s] [ext: omni.command.usd-1.0.3] startup
[24.718s] [ext: omni.scene.optimizer.ui-106.1.10] startup
[24.803s] [ext: omni.kit.window.status_bar-0.1.7] startup
[24.809s] [ext: omni.scene.visualization.ui-105.1.3] startup
[24.832s] [ext: omni.kit.property.bundle-1.3.2] startup
[24.854s] [ext: omni.kit.tool.asset_importer-2.12.3] startup
[24.857s] [ext: omni.kit.converter.hoops_core-504.4.4] startup
[24.921s] [ext: omni.kit.converter.jt_core-503.2.6] startup
[24.991s] [ext: omni.scene.optimizer.bundle-106.1.10] startup
[24.992s] [ext: omni.usd.metrics.assembler-106.5.0] startup
[25.013s] [ext: omni.scene.visualization.bundle-105.1.0] startup
[25.016s] [ext: omni.kit.property.sbsar-107.0.1] startup
[25.048s] [ext: omni.kit.converter.dgn-503.3.3] startup
[25.083s] [ext: omni.kit.converter.hoops-504.4.5] startup
[25.098s] [ext: omni.kit.converter.jt-503.2.4] startup
[25.113s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[25.144s] [ext: omni.usd.metrics.assembler.ui-106.5.0] startup
[25.195s] [ext: omni.kit.window.usd_paths-1.0.7] startup
[25.208s] [ext: omni.kit.menu.file-1.1.15] startup
[25.232s] [ext: omni.kit.quicklayout-1.0.8] startup
[25.247s] [ext: omni.kit.window.stats-0.1.7] startup
[25.257s] [ext: omni.kit.menu.common-1.1.9] startup
[25.274s] [ext: omni.kit.converter.cad-202.4.0] startup
[25.275s] [ext: my_company.my_usd_composer_setup_extension-0.1.0] startup
[25.295s] [ext: cineshare106.my_usd_composer-0.1.0] startup
2025-05-05 07:53:58 [24,660ms] [Warning] [omni.kit.renderer.plugin] Reducing ‘/app/runLoops/present/rateLimitFrequency’ from 120.000000 to primary monitor’s refresh rate of 60.000000 (‘Generic PnP Monitor’, ‘\.\DISPLAY1\Monitor0’)
[25.623s] app ready
2025-05-05 07:53:59 [25,649ms] [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults/ecoMode/enabled’
2025-05-05 07:53:59 [25,649ms] [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults/sceneDb/ambientLightIntensity’
2025-05-05 07:53:59 [25,662ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 2908577024
2025-05-05 07:53:59 [25,662ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: false
2025-05-05 07:54:01 [27,111ms] [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults-transient/meshlights/forceDisable’
[34.734s] RTX ready
2025-05-05 07:55:07 [93,362ms] [Warning] [omni.usd] Unexpected reference count of 2 for UsdStage ‘anon:000002CC0D321970:World0.usd’ while being closed in UsdContext (this may indicate it is still resident in memory).
2025-05-05 07:55:15 [101,189ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:15 [101,189ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:15 [101,190ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:15 [101,190ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:15 [101,191ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:15 [101,191ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:15 [101,194ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:15 [101,194ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:15 [101,195ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:15 [101,195ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:15 [101,196ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:15 [101,196ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:19 [105,564ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:19 [105,564ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:19 [105,566ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:19 [105,566ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:19 [105,567ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:19 [105,567ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:19 [105,569ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:19 [105,570ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:19 [105,571ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:19 [105,571ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:19 [105,572ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:19 [105,572ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:19 [105,573ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Rough_A.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:20 [106,542ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:20 [106,542ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:20 [106,543ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:20 [106,544ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:20 [106,545ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:20 [106,545ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:20 [106,548ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:20 [106,548ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:20 [106,549ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:20 [106,549ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:20 [106,551ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:20 [106,551ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Metal_Glossy_B.mdl(16,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:22 [108,130ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:22 [108,131ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:22 [108,132ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:22 [108,132ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:22 [108,133ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:22 [108,133ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:22 [108,134ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:22 [108,137ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:22 [108,137ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:22 [108,138ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:22 [108,139ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:22 [108,139ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:22 [108,140ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C188 annotation ‘::anno::physical_name’ will be ignored
2025-05-05 07:55:22 [108,140ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp warn : https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/DigitalTwin/Materials/Base/Metals/Chrome_A.mdl(15,7): C109 ‘physical_name’ has not been declared; did you mean ‘display_name’?
2025-05-05 07:55:25 [111,825ms] [Warning] [omni.hydra.scene_delegate.plugin] Calling getBypassRenderSkelMeshProcessing for prim /World/No_sims/no_sims1_01.proto_SM_MultiDepthBox_A09_Decal_01_id21 that has not been populated
2025-05-05 07:55:27 [113,113ms] [Error] [omni.hydra] [UsdToMdl] Prim ‘/Environment/Looks/Grid/Shader’ parameter ‘diffuse_texture’: References an asset that can not be found: ‘../../C:/kit-app-template106/kit-app-template/_build/windows-x86_64/release/extscache/omni.kit.stage_templates-1.2.6+d02c707b/data/ov_uv_grids_basecolor_1024.png’
2025-05-05 07:55:27 [113,114ms] [Error] [omni.hydra] [UsdToMdl] Prim ‘/Environment/Looks/Grid/Shader’ parameter ‘diffuse_texture’: References an asset that can not be found: ‘../../C:/kit-app-template106/kit-app-template/_build/windows-x86_64/release/extscache/omni.kit.stage_templates-1.2.6+d02c707b/data/ov_uv_grids_basecolor_1024.png’
2025-05-05 07:55:30 [116,814ms] [Error] [omni.hydra] [UsdToMdl] Prim ‘/Environment/Looks/Grid/Shader’ parameter ‘diffuse_texture’: References an asset that can not be found: ‘../../C:/kit-app-template106/kit-app-template/_build/windows-x86_64/release/extscache/omni.kit.stage_templates-1.2.6+d02c707b/data/ov_uv_grids_basecolor_1024.png’
2025-05-05 07:56:20 [166,391ms] [Warning] [omni.usd] UsdFrameCompletionMonitor: Timed out awaiting frame
2025-05-05 07:56:20 [166,914ms] [Error] [omni.usd] UsdFrameCompletionMonitor: Frame did not render successfully; skipping
2025-05-05 07:56:20 [166,914ms] [Error] [gpu.foundation.plugin] A GPU crash occurred. Exiting the application…
Reasons for the failure: a device lost, out of memory, or an unexpected bug.
2025-05-05 07:56:20 [166,915ms] [Error] [omni.kit.renderer.plugin] acquireNextFrameBufferNoWait: Failed to begin frame command list.
2025-05-05 07:56:20 [166,916ms] [Warning] [gpu.foundation.plugin] polling aftermath dump status …
2025-05-05 07:56:20 [166,923ms] [Error] [carb.graphics-direct3d.plugin] GPU crash is detected. Trying to write shader debug info into: C:/Users/varis/.nvidia-omniverse/logs/Kit/Cineshare 106 Composer/0.1/kit_20250505_105333-000002da2caa6e70-000002da81e3a140.nvdbg
2025-05-05 07:56:20 [166,925ms] [Error] [carb.graphics-direct3d.plugin] Shader debug info successfully written
2025-05-05 07:56:20 [166,926ms] [Warning] [carb.graphics-direct3d.plugin] GPU pagefault occured on virtual address(0x00000000bc5dc000)
2025-05-05 07:56:20 [166,927ms] [Warning] [carb.graphics-direct3d.plugin] GPU pagefault no associated data found closest allocations were:
2025-05-05 07:56:20 [166,927ms] [Warning] [carb.graphics-direct3d.plugin] 1: AddressRange(0x0000000000000000 - 0x0000000000000000) with name(dummy to ignore)
2025-05-05 07:56:20 [166,927ms] [Warning] [carb.graphics-direct3d.plugin] 2: AddressRange(0xffffffffffffffff - 0xffffffffffffffff) with name(dummy to ignore)
2025-05-05 07:56:20 [166,929ms] [Error] [carb.graphics-direct3d.plugin] GPU crash is detected. Trying to write crash dump into: C:/Users/varis/.nvidia-omniverse/logs/Kit/Cineshare 106 Composer/0.1/kit_20250505_105333-0.nv-gpudmp
2025-05-05 07:56:20 [166,930ms] [Error] [carb.graphics-direct3d.plugin] GPU crash dump is successfully written
2025-05-05 07:56:20 [167,017ms] [Warning] [gpu.foundation.plugin] successfully waited and produced aftermath dump
2025-05-05 07:56:22 [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2025-05-05 07:56:22 [142ms] [Warning] [carb.crashreporter-breakpad.plugin] Launched process ‘py-spy.exe’ as PID 10456
2025-05-05 07:56:22 [350ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] compressing 5 files into ‘C:/Users/varis/AppData/Local/ov/data/Kit/Cineshare 106 Composer/0.1\450fe8d0-0045-412b-93e5-3a31f68a812b.dmp.zip’ for upload.
2025-05-05 07:56:23 [1,133ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘C:/Users/varis/AppData/Local/ov/data/Kit/Cineshare 106 Composer/0.1\450fe8d0-0045-412b-93e5-3a31f68a812b.dmp’ with 10 retries remaining.
2025-05-05 07:56:23 [1,135ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘C:/Users/varis/AppData/Local/ov/data/Kit/Cineshare 106 Composer/0.1\450fe8d0-0045-412b-93e5-3a31f68a812b.dmp.toml’ with 10 retries remaining.
2025-05-05 07:56:23 [1,178ms] [Warning] [carb.crashreporter-breakpad.plugin] Launched process ‘crashreport.gui.exe’ as PID 3020
2025-05-05 07:56:31 [9,432ms] [Error] [carb.crashreporter-breakpad.plugin] ‘crashreport.gui.exe’ exited with code 3
2025-05-05 07:56:31 [9,438ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] user declined uploading a crash dump, will delete
2025-05-05 07:56:31 [9,438ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file ‘C:/Users/varis/AppData/Local/ov/data/Kit/Cineshare 106 Composer/0.1\450fe8d0-0045-412b-93e5-3a31f68a812b.dmp.zip’
2025-05-05 07:56:31 [9,440ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] preventing upload of minidump due to user opt-out: ‘C:/Users/varis/AppData/Local/ov/data/Kit/Cineshare 106 Composer/0.1\450fe8d0-0045-412b-93e5-3a31f68a812b.dmp.zip’
2025-05-05 07:56:31 [9,441ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] dump file size is 4054202 bytes, file is readable.
2025-05-05 07:56:32 [10,215ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 34604 thread 43108
2025-05-05 07:56:32 [10,216ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2025-05-05 07:56:32 [10,216ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] BuildGitlabJobID = ‘128178601’
2025-05-05 07:56:32 [10,217ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] CarbSdkVersion = ‘180.6+release.7436.c5558fdf.gl’
2025-05-05 07:56:32 [10,217ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] CrashTime = ‘Mon May 5 07:56:22 2025 GMT’
2025-05-05 07:56:32 [10,217ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] DriverShaderCacheWrapper = ‘disabled’
2025-05-05 07:56:32 [10,218ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] DumpId = ‘450fe8d0-0045-412b-93e5-3a31f68a812b’
2025-05-05 07:56:32 [10,218ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] LastUploadStatus = ‘0’
2025-05-05 07:56:32 [10,218ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ProductName = ‘OmniverseKit’
2025-05-05 07:56:32 [10,218ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] PythonTracebackStatus = ‘‘py-spy.exe’ successfully wrote info to C:/Users/varis/AppData/Local/ov/data/Kit/Cineshare 106 Composer/0.1/450fe8d0-0045-412b-93e5-3a31f68a812b.py.txt’
2025-05-05 07:56:32 [10,218ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] RetryCount = ‘0’
2025-05-05 07:56:32 [10,219ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] StartupTime = ‘1746431613’
2025-05-05 07:56:32 [10,219ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UploadSuccessful = ‘0’
2025-05-05 07:56:32 [10,219ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UptimeSeconds = ‘169’
2025-05-05 07:56:32 [10,219ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UserStory = ‘’
2025-05-05 07:56:32 [10,220ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UserStoryStatus = ‘‘crashreport.gui.exe’ exited with code 3’
2025-05-05 07:56:32 [10,220ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Version = ‘106.5.0+release.162521.d02c707b.gl’
2025-05-05 07:56:32 [10,220ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_active_shader_0_hash_match_count = ‘1’
2025-05-05 07:56:32 [10,220ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_active_shader_0_match_0 = ‘rtx/raytracing/PathTracing.rgs.hlsl,rayGenPathTracingMain,extra1-rq1,3ecf547f7772d46d’
2025-05-05 07:56:32 [10,220ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_active_shader_count = ‘1’
2025-05-05 07:56:32 [10,221ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_enabled = ‘1’
2025-05-05 07:56:32 [10,221ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_flags = ‘3’
2025-05-05 07:56:32 [10,221ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_status = ‘auto-enabled’
2025-05-05 07:56:32 [10,221ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_version = ‘2024.1’
2025-05-05 07:56:32 [10,221ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appName = ‘Cineshare 106 Composer’
2025-05-05 07:56:32 [10,222ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appState = ‘started’
2025-05-05 07:56:32 [10,222ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appVersion = ‘0.1.0’
2025-05-05 07:56:32 [10,222ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] autoloadExts = ‘omni.kit.property.sequence-0.3.1,omni.kit.browser.sample-1.4.8,omni.anim.graph.ui-106.5.0,omni.kit.window.sequencer-103.4.4,omni.anim.skelJoint-106.5.1,omni.anim.graph.bundle-106.5.0,omni.anim.graph.core-106.5.1,omni.kit.browser.asset-1.3.11,omni.kit.window.extensions-1.4.25,omni.simready.explorer-1.1.1,omni.physx.zerogravity-106.5.7,omni.kit.sequencer.core-103.4.2’
2025-05-05 07:56:32 [10,222ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildBranch = ‘release’
2025-05-05 07:56:32 [10,223ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildCi = ‘gl’
2025-05-05 07:56:32 [10,223ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildConfig = ‘release’
2025-05-05 07:56:32 [10,223ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabJobName = ‘kit-build-release-windows-x86_64’
2025-05-05 07:56:32 [10,223ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabJobStage = ‘kit-build’
2025-05-05 07:56:32 [10,223ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabPipelineID = ‘21399756’
2025-05-05 07:56:32 [10,224ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildHash = ‘d02c707b’
2025-05-05 07:56:32 [10,224ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildMajor = ‘106’
2025-05-05 07:56:32 [10,224ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildMinor = ‘5’
2025-05-05 07:56:32 [10,224ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildNumber = ‘162521’
2025-05-05 07:56:32 [10,225ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildPatch = ‘0’
2025-05-05 07:56:32 [10,225ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildVersion = ‘106.5.0’
2025-05-05 07:56:32 [10,226ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] carboniteFrameworkVersion = ‘180.6+release.7436.c5558fdf.gl’
2025-05-05 07:56:32 [10,226ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] carboniteSdkVersion = ‘180.6+release.7436.c5558fdf.gl’
2025-05-05 07:56:32 [10,226ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] commandLine = ‘“C:\kit-app-template106\kit-app-template_build\windows-x86_64\release\kit\kit.exe” “C:\kit-app-template106\kit-app-template_build\windows-x86_64\release\apps/cineshare106.my_usd_composer.kit” --enable omni.kit.developer.bundle’
2025-05-05 07:56:32 [10,227ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuCoreLimited = ‘-1’
2025-05-05 07:56:32 [10,227ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuId = ‘Intel64 Family 6 Model 183 Stepping 1’
2025-05-05 07:56:32 [10,227ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuLogicalCoresBareMetal = ‘32’
2025-05-05 07:56:32 [10,227ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuName = ‘Intel(R) Core™ i9-14900K’
2025-05-05 07:56:32 [10,228ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuPhysicalCoresBareMetal = ‘24’
2025-05-05 07:56:32 [10,228ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuUsageQuota = ‘-1.000000’
2025-05-05 07:56:32 [10,228ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuVendor = ‘GenuineIntel’
2025-05-05 07:56:32 [10,228ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] desktopOrigin = ‘(0, 0)’
2025-05-05 07:56:32 [10,228ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] desktopSize = ‘3840x2160’
2025-05-05 07:56:32 [10,229ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayCount = ‘1’
2025-05-05 07:56:32 [10,229ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayRes_0 = ‘3840x2160x32bit@60Hz’
2025-05-05 07:56:32 [10,229ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] environmentName = ‘’
2025-05-05 07:56:32 [10,229ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] experience = ‘Cineshare 106 Composer’
2025-05-05 07:56:32 [10,230ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] externalBuild = ‘1’
2025-05-05 07:56:32 [10,230ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuCrash = ‘1’
2025-05-05 07:56:32 [10,230ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_0 = ‘572.83’
2025-05-05 07:56:32 [10,231ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_1 = ‘0x0000’
2025-05-05 07:56:32 [10,231ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_0 = ‘50764709888’
2025-05-05 07:56:32 [10,231ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_1 = ‘134217728’
2025-05-05 07:56:32 [10,232ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpu_0 = ‘NVIDIA RTX 6000 Ada Generation’
2025-05-05 07:56:32 [10,232ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpu_1 = ‘Intel(R) UHD Graphics 770’
2025-05-05 07:56:32 [10,232ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] kitRendererDriverVersion = ‘572.83’
2025-05-05 07:56:32 [10,233ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lastCommand = ‘SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)’
2025-05-05 07:56:32 [10,233ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lastCommands = ‘SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)’
2025-05-05 07:56:32 [10,233ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildBranch = ‘HEAD’
2025-05-05 07:56:32 [10,234ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildDate = ‘Jan-16-2025’
2025-05-05 07:56:32 [10,234ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildHash = ‘c80d589’
2025-05-05 07:56:32 [10,235ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildRepo = ‘gitlab-master.nvidia.com/omniverse/physics
2025-05-05 07:56:32 [10,235ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildVersion = ‘106.5.7’
2025-05-05 07:56:32 [10,235ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] memoryStats = ‘(avail/total) RAM: 97.0819/127.694GB, Swap: 84.5135/135.694GB, VM: 130752/131072GB’
2025-05-05 07:56:32 [10,235ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] nvidia-smi = ’
==============NVSMI LOG==============
Timestamp : Mon May 5 10:53:36 2025
Driver Version : 572.83
CUDA Version : 12.8
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA RTX 6000 Ada Generation
Product Brand : NVIDIA RTX
Product Architecture : Ada Lovelace
Display Mode : Enabled
Display Active : Enabled
Persistence Mode : N/A
Addressing Mode : N/A
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-dc589ce3-edb3-def5-3c1f-067aac8e7cd7
Minor Number : N/A
VBIOS Version : 95.02.59.00.08
MultiGPU Board : No
Board ID : 0x100
Board Part Number : N/A
GPU Part Number : 26B1-870-A1
FRU Part Number : N/A
Platform Info
Chassis Serial Number : N/A
Slot Number : N/A
Tray Index : N/A
Host ID : N/A
Peer Type : N/A
Module Id : 1
GPU Fabric GUID : N/A
Inforom Version
Image Version : G133.0510.00.02
OEM Object : 2.1
ECC Object : 6.16
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : 2025/05/04 21:45:21.503
Latest Duration : 49219 us
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
vGPU Heterogeneous Mode : N/A
GPU Reset Status
Reset Required : Requested functionality has been deprecated
Drain and Reset Recommended : Requested functionality has been deprecated
GPU Recovery Action : None
GSP Firmware Version : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x26B110DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x16A11028
GPU Link Info
PCIe Generation
Max : 4
Current : 4
Device Current : 4
Device Max : 4
Host Max : 5
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 16600 KB/s
Rx Throughput : 72850 KB/s
Atomic Caps Outbound : N/A
Atomic Caps Inbound : N/A
Fan Speed : 30 %
Performance State : P0
Clocks Event Reasons
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Sparse Operation Mode : N/A
FB Memory Usage
Total : 49140 MiB
Reserved : 727 MiB
Used : 2719 MiB
Free : 45695 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 228 MiB
Free : 28 MiB
Conf Compute Protected Memory Usage
Total : N/A
Used : N/A
Free : N/A
Compute Mode : Default
Utilization
GPU : 7 %
Memory : 2 %
Encoder : 28 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 1
Average FPS : 124
Average Latency : 4713
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
DRAM Encryption Mode
Current : N/A
Pending : N/A
ECC Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable Parity : N/A
SRAM Uncorrectable SEC-DED : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
SRAM Threshold Exceeded : N/A
Aggregate Uncorrectable SRAM Sources
SRAM L2 : N/A
SRAM SM : N/A
SRAM Microcontroller : N/A
SRAM PCIE : N/A
SRAM Other : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows
Correctable Error : 0
Uncorrectable Error : 0
Pending : No
Remapping Failure Occurred : No
Bank Remap Availability Histogram
Max : 192 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
GPU Current Temp : 54 C
GPU T.Limit Temp : 37 C
GPU Shutdown T.Limit Temp : -7 C
GPU Slowdown T.Limit Temp : -2 C
GPU Max Operating T.Limit Temp : 0 C
GPU Target Temperature : 85 C
Memory Current Temp : N/A
Memory Max Operating T.Limit Temp : N/A
GPU Power Readings
Average Power Draw : N/A
Instantaneous Power Draw : 96.01 W
Current Power Limit : 300.00 W
Requested Power Limit : 300.00 W
Default Power Limit : 300.00 W
Min Power Limit : 100.00 W
Max Power Limit : 300.00 W
GPU Memory Power Readings
Instantaneous Power Draw : N/A
Module Power Readings
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Power Smoothing : N/A
Workload Power Profiles
Requested Profiles : N/A
Enforced Profiles : N/A
Clocks
Graphics : 2715 MHz
SM : 2715 MHz
Memory : 10000 MHz
Video : 2130 MHz
Applications Clocks
Graphics : 2505 MHz
Memory : 10001 MHz
Default Applications Clocks
Graphics : 2505 MHz
Memory : 10001 MHz
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 3105 MHz
SM : 3105 MHz
Memory : 10001 MHz
Video : 2415 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : N/A
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Bandwidth : N/A
Route Recovery in progress : N/A
Route Unhealthy : N/A
Access Timeout Recovery : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 6100
Type : C+G
Used GPU Memory : Not available in WDDM driver model
Process ID : 10296
Type : C+G
Process ID : 11980
Type : C+G
Process ID : 20524
Type : C+G
Process ID : 20968
Type : C+G
Process ID : 26908
Type : C+G
Process ID : 28584
Type : C+G
Process ID : 29264
Type : C+G
Process ID : 29752
Type : C+G
Process ID : 30208
Type : C+G
Process ID : 31012
Type : C+G
Process ID : 34948
Type : C+G
Process ID : 35616
Type : C+G
Name :
Process ID : 36992
Type : C+G
Process ID : 38404
Type : C+G
Process ID : 41340
Type : C+G
Process ID : 41496
Type : C+G
Process ID : 42068
Type : C+G
Process ID : 44188
Type : C+G
Process ID : 44760
Type : C+G
Process ID : 46020
Type : C+G
Process ID : 46392
Type : C+G
Process ID : 48056
Type : C+G
Process ID : 48920
Type : C+G
Capabilities
EGM : disabled
2025-05-05 07:56:32 [10,236ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osDistro = ‘24H2’
2025-05-05 07:56:32 [10,236ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osName = ‘Windows 11 Pro’
2025-05-05 07:56:32 [10,237ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osVersion = ‘10.00.26100’
2025-05-05 07:56:32 [10,237ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] portableMode = ‘0’
2025-05-05 07:56:32 [10,237ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] primaryDisplayRes = ‘3840x2160x32bit@60Hz’
2025-05-05 07:56:32 [10,237ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runEnvironment = ‘Individual’
2025-05-05 07:56:32 [10,237ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runningInContainer = ‘0’
2025-05-05 07:56:32 [10,238ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_debugSymbols = ‘0’
2025-05-05 07:56:32 [10,238ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIncludeOverrides = ‘0’
2025-05-05 07:56:32 [10,238ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIntermediates = ‘0’
2025-05-05 07:56:32 [10,238ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_obfuscateCode = ‘1’
2025-05-05 07:56:32 [10,238ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_optimizationLevel = ‘1’
2025-05-05 07:56:32 [10,239ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] startup_time = ‘25.293669’
2025-05-05 07:56:32 [10,239ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = ’
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| | | | | | 26b1 | 0 |
| | | | | | 1 | |
| | | | | | a780 | 0 |
| | | | | | N/A | |
2025-05-05 07:56:32 [10,239ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = ‘13431149125297212169’
2025-05-05 07:56:32 [10,239ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = ‘0’
2025-05-05 07:56:32 [10,240ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamBareMetalMB = ‘130758’
2025-05-05 07:56:32 [10,240ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamLimitedMB = ‘130758’
2025-05-05 07:56:32 [10,240ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapBareMetalMB = ‘138950’
2025-05-05 07:56:32 [10,240ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapLimitedMB = ‘138950’
2025-05-05 07:56:32 [10,240ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] userId = ‘’
2025-05-05 07:56:32 [10,241ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = ‘C:\kit-app-template106\kit-app-template’
2025-05-05 07:56:32 [10,241ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 43108 backtrace follows:
2025-05-05 07:56:32 [10,241ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: gpu.foundation.plugin.dll!omni::activity::getInstance+0x12566e
2025-05-05 07:56:32 [10,242ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: omni.usd.dll!omni::usd::UsdContext::GetGeometryPath+0x29c6
2025-05-05 07:56:32 [10,242ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: omni.usd.dll!omni::usd::LayersLegacy::resolvePrimPathsReferencesStatic+0x6c0d
2025-05-05 07:56:32 [10,244ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: carb.events.plugin.dll!+0xdda0
2025-05-05 07:56:32 [10,244ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: carb.events.plugin.dll!+0x9016
2025-05-05 07:56:32 [10,245ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: carb.events.plugin.dll!+0x111ac
2025-05-05 07:56:32 [10,247ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: omni.kit.loop-default.plugin.dll!+0x1547a
2025-05-05 07:56:32 [10,247ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: omni.kit.loop-default.plugin.dll!+0x15f28
2025-05-05 07:56:32 [10,247ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: omni.kit.loop-default.plugin.dll!+0x1e3f
2025-05-05 07:56:32 [10,248ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: ucrtbase.dll!wcsrchr+0x150
2025-05-05 07:56:32 [10,248ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: KERNEL32.DLL!BaseThreadInitThunk+0x17
2025-05-05 07:56:32 [10,248ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: ntdll.dll!RtlUserThreadStart+0x2c
[05/05/25 10:56:36] ERROR error running: launch.py:92
C:\kit-app-template106\kit-app-template_build\windows-x86_64\release\cineshar
e106.my_usd_composer.kit.bat --enable omni.kit.developer.bundle, code:
3221225477, message: “”
This is main core reason, but it does not tell me exactly why. Were you out of memory, trying to open a massive scene? It also looks like you were having some materials issues, finding the correct maps, and those maps were creating issues.
Is it just crashing on this one scene? Let me run the log by the engineers.
The other thing I see is that you have an Intel Graphics Card installed as well. Ideally that should be disabled.
Finally you are using the latest drivers. The 570 series. Can you try installing this Driver Details | NVIDIA
I started by installing the driver you linked to.
I also disabled the intel graphics.
Scene runs nice :)
The issues with the missing materials. Is there some useful tool to see these all in one window, where I could re-link them?
Pekka
You can use the “USD PATHS” utility to see every path in the scene and do a mass “find and replace”
