Hello Richard!
This has been a very long journey with AWS support, and now I am back here for you.
So I started to work with the settings you gave me above, we did that together with AWS support. We did all sort of tricks with Disable ECC. But those tricks needed to be done with command prompt for each gpu ( 8 on this case ) and also re-boot was required every time to get it looking like this:
Attached GPUs : 8
GPU 00000000:9E:00.0
ECC Mode
Current : Disabled
Pending : Disabled
So then after realizing how diffigult and slow it is for me, AWS support desiced to go this way:
" My name is Sumit.
I tried the installation of Omniverse USD composer and was able to install and launch successfully on g6e.8xlarge.
Initially when the Nvidia drivers were not installed, I got the same error as you. After installing the GRID drivers available from AWS, the installation went through. Can you install the latest NVIDIA GRID drivers following below article and try installing the composer again. https://docs.aws.amazon.com/AWSEC2/latest/UserGuide/install-nvidia-driver.html#nvidia-GRID-driver
Richard, I tried to follow those docs but I got an issue with:
no credentials configured to access the S3 bucket
That was solved finally by other method: assign an instance profile
So I did that with creatign a role and attaching that to my VM, and with that I could use the power shell to access buckets.
So I installed the GRID drivers that AWS support guy Sumit wanted me to do.
Composer runs fine, but with very poor multi-gpu performance.
Check that out:
Kit 106 is not booting up at all..
That is the only reason I would need those multi gpu´s
Kit 107 boots but multi GPU performance is still bad with it also.
New issue arises with testing the Kit 107 rendering.
Horizontal lines, usually they are fixed by deactivation of the cache in Path Traced rendering, but now it does not work.
See the video:
I also made test renders to see it it really is there and yes the lines are there:
So are these Grid Drivers ok for me?
If they are, what should I do to make the performance better & solve the line rendering issue?
Pekka
