Omniverse Crash running USD demo: Cannot create cuda external memory for resource
When following the steps for this demo I receive the following errors which cause Omniverse to crash.
https://docs.omniverse.nvidia.com/guide-sdg/latest/case-studies/case1.html
I am using dual 4090 GPUs on Ubuntu 22.04 with a Ryzen 7950 CPU – no official crash dump is created. The extension hangs and then terminates without creating a crash report.
Note, that the Synthetic data is generated successfully, however the extension crashes 10 minutes later:
2024-09-03 20:22:04 [90,428ms] [Warning] [omni.replicator.core.scripts.backends.disk] No root directory specified in carb setting `/omni/replicator/backends/disk/root_dir`. Writing data to /home/blinux/omni.replicator_out/Replicator_Agent
2024-09-03 20:22:04 [90,717ms] [Warning] [omni.hydra] Disabling DLSS Frame Generation for at least one view due to incompatible render outputs and OmniGraph postprocessing being active
2024-09-03 20:22:04 [90,835ms] [Warning] [omni.syntheticdata.plugin] OgnSdPostRenderVarToHost : rendervar copy from texture directly to host buffer is counter-performant. Please use copy from texture to device buffer first.
Module omni.replicator.core.ogn.python._impl.nodes.OgnSemanticSegmentation cc3f83a load on device 'cuda:1' took 0.25 ms
2024-09-03 20:22:11 [98,062ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:22:11 [98,062ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:22:15 [101,809ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:22:15 [101,809ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:22:16 [102,771ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:22:16 [102,771ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:22:37 [123,443ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:22:37 [123,443ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:22:38 [125,021ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:22:38 [125,021ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:22:43 [130,176ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:22:43 [130,177ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:22:54 [141,152ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:22:54 [141,152ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:22:58 [144,303ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:22:58 [144,303ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:23:03 [150,259ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:23:03 [150,259ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:23:18 [164,338ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:23:18 [164,338ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:23:32 [178,366ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:23:32 [178,366ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:23:40 [186,348ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:23:40 [186,348ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:23:42 [188,680ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:23:42 [188,680ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:24:00 [207,230ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:24:00 [207,230ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:24:41 [248,192ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:24:41 [248,192ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:25:18 [284,587ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:25:18 [284,593ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:25:27 [293,820ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:25:27 [293,820ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:25:43 [309,320ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:25:43 [309,320ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:25:44 [310,527ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:25:44 [310,527ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:25:53 [319,453ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:25:53 [319,453ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:25:54 [320,509ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:25:54 [320,509ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:26:09 [336,112ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:26:09 [336,112ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:26:16 [342,876ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:26:16 [342,876ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:26:37 [364,298ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:26:37 [364,299ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:26:41 [367,455ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:26:41 [367,455ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:27:24 [410,805ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:27:24 [410,805ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:27:58 [444,327ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:27:58 [444,327ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:28:16 [463,144ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:28:16 [463,144ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:28:43 [490,277ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:28:43 [490,277ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:29:05 [511,933ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:29:05 [511,933ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:29:20 [526,735ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:29:20 [526,735ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:29:29 [535,873ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:29:29 [535,873ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:29:36 [542,668ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:29:36 [542,668ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:29:53 [560,117ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:29:53 [560,117ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:30:02 [569,026ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:30:02 [569,026ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:30:10 [577,143ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:30:10 [577,144ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:30:12 [578,394ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00009
2024-09-03 20:30:12 [578,394ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:30:26 [592,312ms] [Warning] [omni.usd] Hydra engine rtx transitioning from async (/app/runLoops/rendering_0) to synchronous rendering
2024-09-03 20:32:10 [696,313ms] [Error] [carb.graphics-vulkan.plugin] NGX EvaluateFeature failed: 0xbad00005
2024-09-03 20:32:10 [696,313ms] [Error] [carb.graphics-vulkan.plugin] Failed to evaluate DLSS feature.
2024-09-03 20:32:18 [704,311ms] [Error] [carb.cudainterop.plugin] dup failed for resourceType: 3 (file descriptor: 1299)
  Too many open files (error: 24)
2024-09-03 20:32:18 [704,311ms] [Error] [gpu.foundation.plugin] Cannot create cuda external memory for resource!
2024-09-03 20:32:18 [704,311ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 1.
ExceptionHandler::GenerateDump sys_pipe failed:Too many open files
ExceptionHandler::SendContinueSignalToChild sys_write failed:Bad file descriptor
ExceptionHandler::WaitForContinueSignal sys_read failed:Bad file descriptor
2024-09-03 20:32:18 [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
Can you try our recommended drivers please. Technical Requirements — Omniverse Materials and Rendering latest documentation (nvidia.com)
Is 535.183.01 with CUDA Version: 12.2 okay? – that is what I was using when this issue occurred.
I can downgrade to 535.129.03 if you think it will help
If it works then ok, but if you still have problems and want to rule out drive issues, you may as well be specific.
537.58 (GameReady, Studio), 537.70 (RTX/Quadro, Grid/vGPU)
Sorry, I should have specified earlier. I am running Linux, so I think the correct driver according to your link is 535.129.03
ok good
