This what I saw
2024-01-24 06:10:56 [64,539ms] [Warning] [gpu.foundation.plugin] Waiting for compilation of ray tracing shaders by GPU driver: 30 seconds so far
2024-01-24 06:11:26 [94,539ms] [Warning] [gpu.foundation.plugin] Waiting for compilation of ray tracing shaders by GPU driver: 60 seconds so far
2024-01-24 06:11:56 [124,539ms] [Warning] [gpu.foundation.plugin] Waiting for compilation of ray tracing shaders by GPU driver: 90 seconds so far
2024-01-24 06:12:26 [154,540ms] [Warning] [gpu.foundation.plugin] Waiting for compilation of ray tracing shaders by GPU driver: 120 seconds so far
2024-01-24 06:12:56 [184,540ms] [Warning] [gpu.foundation.plugin] Waiting for compilation of ray tracing shader/hoopla/data/dcc_check/scenes/TrawlerBoat_000.usda
Rendering /hoopla/data/dcc_check/scenes/TrawlerBoat_000.usda
2024-01-24 06:14:42 [289,942ms] [Error] [rtx.optixdenoising.plugin] [Optix] [DENOISER] Unable to load denoiser weights
2024-01-24 06:14:42 [289,942ms] [Error] [rtx.optixdenoising.plugin] optixDenoiserCreate(m_optixCtx, OPTIX_DENOISER_MODEL_KIND_AOV, &denoiserOptions, &denoiser) failed. Optix Error: OPTIX_ERROR_INTERNAL_ERROR.
Internal error
s by GPU driver: 150 seconds so far
2024-01-24 06:13:26 [214,540ms] [Warning] [gpu.foundation.plugin] Waiting for compilation of ray tracing shaders by GPU driver: 180 seconds so far
2024-01-24 06:13:56 [244,541ms] [Warning] [gpu.foundation.plugin] Waiting for compilation of ray tracing shaders by GPU driver: 210 seconds so far
2024-01-24 06:14:26 [274,541ms] [Warning] [gpu.foundation.plugin] Waiting for compilation of ray tracing shaders by GPU driver: 240 seconds so far
2024-01-24 06:14:34 [282,188ms] [Warning] [gpu.foundation.plugin] Ray tracing shader compilation finished after 247 seconds
2024-01-24 06:14:42 [289,886ms] [Warning] [carb.flatcache.plugin] UsdRelationship /Render/RenderProduct_Replicator.orderedVars has multiple targets, which is not supported
2024-01-24 06:14:42 [290,367ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2024-01-24 06:14:42 [290,367ms] [Warning] [carb.crashreporter-breakpad.plugin] A crash has occurred. If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeou
t in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2024-01-24 06:14:42 [290,367ms] [Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:'/root/.local/share/ov/data/Kit/Code/2022.3/7b0adb7c-038a-447a-4ef9618e-0112b38c.dmp' svr:'https://services
.nvidia.com/submit'
2024-01-24 06:14:42 [290,367ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
2024-01-24 06:14:42 [290,367ms] [Warning] [carb.crashreporter-breakpad.plugin] CarbSdkVersion = '129.3+129.tc95.1c400a99'
2024-01-24 06:14:42 [290,367ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = '7b0adb7c-038a-447a-4ef9618e-0112b38c'
2024-01-24 06:14:42 [290,367ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
2024-01-24 06:14:42 [290,367ms] [Warning] [carb.crashreporter-breakpad.plugin] RetryCount = '0'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1706076592'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '290'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '104.1+release.332.6846c5b6.tc'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Code'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'started'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.3.1-rc.1'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = ''
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '6846c5b6'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] buildId = '12951306'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '104'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '1'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '332'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '104.1.0'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuId = 'Intel64 Family 6 Model 151 Stepping 2'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuName = '12th Gen Intel(R) Core(TM) i9-12900KF'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuVendor = 'GenuineIntel'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Code'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] externalBuild = '1'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_0 = '535.154'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_0 = '51784974336'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_0 = 'NVIDIA RTX A6000'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = '535.154'
2024-01-24 06:14:42 [290,368ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = 'CreateNodeCommand(graph=?,node_path=/Render/PostProcess/SDGPipeline/WriterSyncGate,node_type=omni.graph.action.SyncGate,create_usd=True)'
running a Docker image of Replicator nvcr.io/nvidia/omniverse-replicator:1.6.3
it is running a procedural build of a shader attached
shader.zip (994 Bytes)
Which works fine when opacity is not mapped
Rendering is as follows
import omni.usd
from pathlib import Path
import sys
import carb
#rep.settings.set_stage_up_axis("z")
DATA_DIR = Path("/hoopla/data")
SCENES = Path("/hoopla/data/dcc_check/scenes")
ALL_SCENES = SCENES.glob(f"{sys.argv[-1]}")
for cur_scene in list(ALL_SCENES):
print(cur_scene.as_posix())
CAMERA_NAME = "/World/renderCamera"
OUTPUT_DIR = f"/hoopla/data/dcc_check/eyecandy/{cur_scene.name}"
omni.usd.get_context().open_stage(cur_scene.as_posix())
num_frames = 600
a = 1
with rep.new_layer():
camera_paths = [f"{CAMERA_NAME}"]
render_products = [rep.create.render_product(f"{CAMERA_NAME}",(1920*a,1080*a))]
with rep.trigger.on_frame(num_frames=num_frames):
print(f"Rendering {cur_scene}")
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(output_dir=OUTPUT_DIR, rgb=True)
writer.attach(render_products)
draft = False
if draft:
rep.settings.set_render_rtx_realtime("RTXAA")
else:
rep.settings.set_render_pathtraced(128)
rep.orchestrator.run()
