Both create and view installing failed
Error occurred during installation of Create: Command failed: “F:\ov\library\create-2021.3.2\omni.create.warmup.bat”
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x00000139C37115C8>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed’)‘: /simple/dssim-py/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x00000139C3711D88>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed’)‘: /simple/dssim-py/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x00000139C371F1C8>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed’)‘: /simple/dssim-py/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x00000139C371F5C8>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed’)‘: /simple/dssim-py/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x00000139C371F648>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed’)‘: /simple/dssim-py/
ERROR: Could not find a version that satisfies the requirement dssim-py (from versions: none)
ERROR: No matching distribution found for dssim-py
WARNING: You are using pip version 20.1.1; however, version 21.2.4 is available.
You should consider upgrading via the ‘f:\ov\library\create-2021.3.2\kit\python\python.exe -m pip install --upgrade pip’ command.
w:\4e6c775e54dc6d2b\source\library\provider_file\fileproviderwin32.cpp:__cdecl `anonymous-namespace’::WatchDirectoryThread::~WatchDirectoryThread(void)():614: Assertion (m_finished.try_acquire_for(1s)) failed: Deadlocked!
Error occurred during installation of View: Command failed: “F:\ov\library\view-2021.3.2\omni.view.warmup.bat”
2021-08-31 19:34:11 [191,793ms] [Error] [carb.python] Failed to import python module omni.kit.tool.navigation. Error: No module named ‘omni.kit.viewport’. Traceback:
File “f:/ov/library/view-2021.3.2/kit/plugins/bindings-python\omni\ext\impl_internal.py”, line 65, in import_module
return importlib.import_module(name)
File “f:\ov\library\view-2021.3.2\kit\python\lib\importlib_init_.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1006, in _gcd_import
File “”, line 983, in _find_and_load
File “”, line 967, in _find_and_load_unlocked
File “”, line 677, in _load_unlocked
File “”, line 728, in exec_module
File “”, line 219, in call_with_frames_removed
File "f:\ov\library\view-2021.3.2\exts\omni.kit.tool.navigation-0.2.1+cp37\omni\kit\tool\navigation_init
.py", line 1, in
from .navigation_tool import *
File “f:\ov\library\view-2021.3.2\exts\omni.kit.tool.navigation-0.2.1+cp37\omni\kit\tool\navigation\navigation_tool.py”, line 4, in
from .navigation_panel import NavigationPanel, CAMERA_NAVIGATION_SETTIHNG_PATH
File “f:\ov\library\view-2021.3.2\exts\omni.kit.tool.navigation-0.2.1+cp37\omni\kit\tool\navigation\navigation_panel.py”, line 10, in
import omni.kit.viewport
ModuleNotFoundError: No module named ‘omni.kit.viewport’
2021-08-31 19:34:11 [191,793ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.kit.tool.navigation’ in ‘f:/ov/library/view-2021.3.2/exts/omni.kit.tool.navigation-0.2.1+cp37/.’ failed to load.
At:
f:/ov/library/view-2021.3.2/kit/plugins/bindings-python\omni\ext\impl_internal.py(169): startup_all_extensions_in_module
f:/ov/library/view-2021.3.2/kit/plugins/bindings-python\omni\ext\impl_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2):
2021-08-31 19:34:11 [191,793ms] [Error] [omni.ext.plugin] [ext: omni.kit.tool.navigation-0.2.1] Failed to process python module extension in ‘f:/ov/library/view-2021.3.2/exts/omni.kit.tool.navigation-0.2.1+cp37/.’.
2021-08-31 19:34:47 [228,663ms] [Error] [omni.kit.window.modifier.taskbar] Title Bar Modifier did not find the target window
2021-08-31 19:35:11 [251,902ms] [Error] [carb.python] Failed to import python module omni.view.file_menu. Error: No module named ‘omni.kit.tool.fileshare’. Traceback:
File “”, line 219, in _call_with_frames_removed
File “f:\ov\library\view-2021.3.2\exts\omni.view.file_menu\omni\view\file_menu.py”, line 18, in
import omni.kit.tool.fileshare
ModuleNotFoundError: No module named ‘omni.kit.tool.fileshare’
2021-08-31 19:35:11 [251,902ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.view.file_menu’ in ‘f:/ov/library/view-2021.3.2/exts/omni.view.file_menu/.’ failed to load.
At:
2021-08-31 19:35:11 [251,902ms] [Error] [omni.ext.plugin] [ext: omni.view.file_menu-0.1.0] Failed to process python module extension in ‘f:/ov/library/view-2021.3.2/exts/omni.view.file_menu/.’.
2021-08-31 19:35:13 [254,298ms] [Error] [carb.python] [py stderr]: INFO: Waiting for application startup.
2021-08-31 19:35:13 [254,312ms] [Error] [carb.python] [py stderr]: INFO: Application startup complete.
2021-08-31 19:35:13 [254,561ms] [Error] [carb.python] [py stderr]: INFO: Uvicorn running on http://0.0.0.0:8011 (Press CTRL+C to quit)
2021-08-31 19:35:17 [258,736ms] [Error] [carb.python] omni.view.menubar.connection-0.1.0 → <class ‘omni.view.menubar.connection.menubar_connection.MenubarConnectionExtension’>: extension object is still alive, something holds a reference on it. References: [“[0]:type: <class ‘method’>, id: 2056139340040”]
2021-08-31 19:35:18 [258,872ms] [Error] [carb.python] omni.kit.window.stage-2.3.4 → <class ‘omni.kit.window.stage.stage_extension.StageExtension’>: extension object is still alive, something holds a reference on it. References: [‘[0]:Dictionary[3 key(s)]’, “[1]:type: <class ‘frame’>, id: 2055345997336”]
2021-08-31 19:35:18 [259,274ms] [Error] [carb.python] omni.kit.capture-0.4.6 → <class ‘omni.kit.capture.extension.CaptureExtension’>: extension object is still alive, something holds a reference on it. References: [‘[0]:Dictionary[65 key(s)]’, ‘[1]:Dictionary[11 key(s)]’]
2021-08-31 19:35:18 [259,345ms] [Error] [carb.python] omni.kit.window.content_browser-2.4.4 → <class ‘omni.kit.window.content_browser.extension.ContentBrowserExtension’>: extension object is still alive, something holds a reference on it. References: [‘[0]:Dictionary[9 key(s)]’]
The os is win10
Hi @neoz I’m very sorry we missed this! I assume this resolved in the latest update(s), but please let us know if it wasn’t. For help reporting and incl. relevant logs, please see: How to Report an issue with Omniverse - NVIDIA Omniverse Support
Cheers,
Edmar
P.S. We are constantly adding new tutorials and aggregate them all in the “learn” tab on the launcher (also see: https://developer.nvidia.com/nvidia-omniverse-tutorials).
he / him | LinkedIn | Discord ID: Prof E#2041
Omniverse: “A New Era of Collaboration and Simulation” (video)
Omniverse Create’s latest features show & tell: Twitch livestream.
As seen in VentureBeat | Physics Showcase
Omniverse Resources:
Open Beta | Documentation | Tech Requirements | Videos | Roadmap | Twitter | Discord | Twitch
PLEASE NOTE: If you are reporting a bug/issue, please provide OS, GPU, GPU Driver, the version of the app, and full log file (if applicable). For crashes, please zip and provide a link to your logs → C:\Users\ [YOUR NAME] \ .nvidia-omniverse\logs
