Hi!
I’m new to Omniverse in general.
I installed it in a 2xRTX 2080 Ti computer.
I’m running Omniverse Create using the following command:
./omni.create.singlegpu.sh --/renderer/activeGpu=1
However, the startup process is particularly slow, ranging from ~450 to ~600s.
Here’s the launch log:
Loading user config located at: '/home/rmclabs/.local/share/ov/data/Kit/Create.Next/2021.3/user.config.json'
[Info] [carb] Logging to file: /home/rmclabs/.nvidia-omniverse/logs/Kit/Create.Next/2021.3/kit_20210827_121215.log
[0.165s] [ext: omni.assets.plugins-0.0.0] startup
[0.167s] [ext: omni.kit.window.splash-0.0.0] startup
[0.199s] [ext: omni.kit.async_engine-0.0.0] startup
[0.213s] [ext: omni.kit.agent-0.1.0] startup
[0.216s] [ext: omni.kit.splash-0.2.1] startup
[0.227s] [ext: omni.kit.pipapi-0.0.0] startup
[0.234s] [ext: omni.usd.config-1.0.0] startup
[0.237s] [ext: omni.usd.libs-1.0.0] startup
[0.471s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.478s] [ext: omni.stats-0.0.0] startup
[0.481s] [ext: omni.gpu_foundation-0.0.0] startup
[0.489s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.494s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.498s] [ext: omni.hydra.iray-0.1.0] startup
[0.502s] [ext: omni.kit.loop-default-0.1.0] startup
[0.503s] [ext: omni.client-0.1.0] startup
[0.512s] [ext: omni.appwindow-1.0.0] startup
[0.536s] [ext: omni.kit.test-0.0.0] startup
[0.678s] [ext: omni.kit.renderer.core-0.0.0] startup
| Driver Version: 465.19 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 2080 Ti | | | 11510 MB | 10de | 0 |
| | | | | | 1e07 | 8de1791a.. |
| 1 | NVIDIA GeForce RTX 2080 Ti | Yes | | 11510 MB | 10de | 0 |
| | | | | | 1e07 | f4b1a1e0.. |
| OS: Linux ventanas, Version: 5.8.0-50-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12009000 (1.20.9.0)
| Processor: AMD Ryzen Threadripper 1900X 8-Core Processor | Cores: Unknown | Logical: 16
| Total Memory (MB): 64257 | Free Memory: 28171
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[2.301s] [ext: omni.ui-2.3.2] startup
[2.327s] [ext: omni.kit.mainwindow-0.0.0] startup
[2.332s] [ext: omni.kit.uiapp-0.0.0] startup
[2.333s] [ext: omni.usd.schema.physics-1.0.0] startup
[2.348s] [ext: omni.usd.schema.destruction-0.1.1] startup
[2.359s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.383s] [ext: omni.timeline-1.0.2] startup
[2.387s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[2.398s] [ext: carb.audio-0.1.0] startup
[2.401s] [ext: omni.kit.commands-0.0.0] startup
[2.408s] [ext: omni.usd-1.4.5] startup
[2.446s] [ext: omni.usd.fileformat.e57-0.1.5] startup
[2.448s] [ext: omni.usd.schema.physx-0.0.0] startup
[2.480s] [ext: omni.kit.window.script_editor-1.5.0] startup
[2.481s] [ext: omni.kit.window.usd_paths-1.0.3] startup
[2.494s] [ext: omni.kit.menu.utils-1.0.2] startup
[2.502s] [ext: omni.hydra.rtx-0.1.0] startup
[2.512s] [ext: omni.kit.usd_undo-0.1.0] startup
[2.516s] [ext: omni.kit.menu.create-1.0.1] startup
[2.520s] [ext: omni.kit.material.library-1.2.0] startup
[2.662s] [ext: omni.kit.window.drop_support-1.0.0] startup
[2.666s] [ext: omni.renderer-rtx-0.0.0] startup
[2.668s] [ext: omni.kit.context_menu-1.3.2] startup
[2.694s] [ext: omni.kit.search_core-1.0.0] startup
[2.699s] [ext: omni.kit.window.viewport-0.0.0] startup
[6.073s] [ext: omni.anim.skelJoint-102.2.0] startup
[6.551s] [ext: omni.kit.search.files-1.0.1] startup
[7.483s] [ext: omni.kit.viewport_widgets_manager-1.0.2] startup
[8.432s] [ext: omni.services.facilities.base-1.0.0] startup
[8.736s] [ext: omni.kit.collaboration.channel_manager-1.0.2] startup
[10.007s] [ext: omni.kit.notification_manager-1.0.0] startup
[11.861s] [ext: omni.services.transport.client.base-1.0.0] startup
[13.683s] [ext: omni.services.core-1.1.1] startup
[20.782s] [ext: omni.kit.collaboration.viewport.camera-1.0.1] startup
[22.481s] [ext: omni.services.client-0.2.0] startup
[30.301s] [ext: omni.services.transport.server.base-1.0.0] startup
[31.261s] [ext: omni.kit.widget.path_field-2.0.3] startup
[32.733s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[53.026s] [ext: omni.services.transport.server.http-1.0.0] startup
[62.245s] [ext: omni.kit.window.popup_dialog-2.0.2] startup
[64.533s] [ext: omni.kit.widget.filebrowser-2.2.10] startup
[66.831s] [ext: omni.kit.widget.browser_bar-2.0.2] startup
[67.802s] [ext: omni.kit.widget.versioning-1.3.4] startup
[69.721s] [ext: omni.kit.thumbnails.images-0.1.0] startup
[71.148s] [ext: omni.kit.widget.zoombar-1.0.1] startup
[73.175s] [ext: omni.kit.widget.searchfield-1.0.4] startup
[74.149s] [ext: omni.kit.stage_templates-1.0.6] startup
[74.934s] [ext: omni.kit.window.filepicker-2.4.4] startup
[90.538s] [ext: omni.kit.browser.core-1.1.7] startup
[93.131s] [ext: omni.kit.window.file-1.3.3] startup
[98.714s] [ext: omni.kit.browser.folder.core-1.1.4] startup
[101.029s] [ext: omni.kit.renderer.capture-0.0.0] startup
[103.434s] [ext: omni.kit.window.content_browser-2.4.5] startup
[106.017s] [ext: omni.kit.browser.sky-1.0.7] startup
[109.814s] [ext: omni.kit.thumbnails.usd-0.5.0] startup
[115.787s] [ext: omni.kit.widget.settings-1.0.0] startup
[117.949s] [ext: omni.kit.widget.prompt-1.0.0] startup
[120.317s] [ext: omni.videoencoding-0.1.0] startup
[120.830s] [ext: omni.rtx.window.settings-0.6.0] startup
[121.621s] [ext: omni.kit.widget.imageview-1.0.0] startup
[123.027s] [ext: omni.kit.capture-0.4.6] startup
[124.454s] [ext: omni.iray.settings.core-0.6.2] startup
[125.272s] [ext: omni.kit.window.quicksearch-2.0.5] startup
[127.001s] [ext: omni.kit.widget.sliderbar-1.0.3] startup
[129.291s] [ext: omni.rtx.settings.core-0.5.4] startup
[132.684s] [ext: omni.kit.quicksearch.menu-0.8.2] startup
[134.623s] [ext: omni.kit.window.movie_maker-0.5.5] startup
[137.193s] [ext: omni.kit.window.status_bar-0.1.0] startup
[137.201s] [ext: omni.services.registry-1.0.0] startup
[145.582s] [ext: omni.kit.asset_converter-1.1.29] startup
[147.492s] [ext: omni.kit.widget.graph-1.1.4] startup
[149.024s] [ext: omni.kit.widget.timeline-102.1.2] startup
[151.046s] [ext: omni.anim.curve-102.1.4] startup
[154.447s] [ext: omni.kit.tool.asset_exporter-1.0.7] startup
[157.728s] [ext: omni.kit.window.extensions-1.0.2] startup
[160.816s] [ext: omni.kit.menu.file-1.0.3] startup
[163.308s] [ext: omni.kit.window.cursor-1.0.1] startup
[164.583s] [ext: omni.kit.window.console-0.1.0] startup
[164.587s] [ext: omni.kit.quicksearch.deeptag-0.8.1] startup
[167.752s] [ext: omni.kit.widget.live-0.1.0] startup
[167.765s] [ext: omni.kit.browser.sample-1.0.3] startup
[171.797s] [ext: omni.kit.window.property-1.6.2] startup
[175.230s] [ext: omni.kit.widget.stage-2.6.4] startup
[175.785s] [ext: omni.create.app.resources-0.1.0] startup
[175.785s] [ext: omni.kvdb-0.0.0] startup
[175.812s] [ext: omni.kit.property.usd-3.11.3] startup
[179.685s] [ext: omni.usdphysics-1.3.8] startup
[179.687s] [ext: omni.localcache-0.0.0] startup
[180.876s] [ext: omni.convexdecomposition-1.3.8] startup
[183.201s] [ext: omni.kit.property.light-1.0.4] startup
[185.285s] [ext: omni.kit.quicksearch.actions-0.8.5] startup
[187.468s] [ext: omni.flowusd-0.1.0] startup
[189.961s] [ext: omni.kit.tool.asset_importer-2.3.10] startup
[194.076s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[196.444s] [ext: omni.physx-1.3.8-5.1] startup
[196.676s] [ext: omni.kit.tool.collect-2.0.3] startup
[200.227s] [ext: omni.kit.pointclouds-0.0.7] startup
[206.764s] [ext: omni.kit.quicksearch.settings-0.8.1] startup
[207.012s] [ext: omni.kit.quicksearch.commands-1.0.0] startup
[209.943s] [ext: omni.kit.quicksearch.material-0.8.3] startup
[212.388s] [ext: omni.physx.commands-1.3.8-5.1] startup
[213.646s] [ext: omni.debugdraw-0.1.0] startup
[214.977s] [ext: omni.kit.window.privacy-0.1.0] startup
[217.157s] [ext: omni.kit.quicksearch.hdri-0.8.4] startup
[221.486s] [ext: omni.kit.quicksearch.props-0.8.2] startup
[224.195s] [ext: omni.kit.window.about-1.0.0] startup
[226.978s] [ext: omni.command.usd-1.0.1] startup
[227.428s] [ext: omni.kit.window.preferences-1.1.3] startup
[228.299s] [ext: omni.physx.ui-1.3.8-5.1] startup
[229.813s] [ext: omni.kit.property.material-1.7.0] startup
[231.788s] [ext: omni.kit.window.toolbar-1.2.1] startup
[235.027s] [ext: omni.kit.browser.asset-1.0.5] startup
[237.313s] [ext: omni.kit.menu.edit-1.0.3] startup
[237.808s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[240.314s] [ext: omni.physx.demos-1.3.8-5.1] startup
[242.065s] [ext: omni.kit.property.physx-0.1.0] startup
[244.216s] [ext: omni.physx.tests-1.3.8-5.1] startup
[252.700s] [ext: omni.kit.selection-0.1.0] startup
[254.382s] [ext: omni.kit.window.provide_feedback-1.0.0] startup
[257.694s] [ext: omni.kit.window.stage-2.3.4] startup
[260.342s] [ext: omni.kit.profiler.window-1.3.1] startup
[264.788s] [ext: omni.physx.vehicle-1.3.8-5.1] startup
[266.597s] [ext: omni.physx.cct-1.3.8-5.1] startup
[271.136s] [ext: omni.kit.quicksearch.select-0.8.1] startup
[273.108s] [ext: omni.kit.stage_column.variant-1.0.2] startup
[276.167s] [ext: omni.kit.mesh.raycast-102.3.3] startup
[281.102s] [ext: omni.physx.zerogravity-1.3.8-5.1] startup
[285.215s] [ext: omni.physx.bundle-1.3.8-5.1] startup
[285.215s] [ext: omni.kit.widgets.custom-0.6.1] startup
[289.533s] [ext: omni.kit.widget.layers-1.5.8] startup
[293.667s] [ext: omni.kit.stage_column.payload-1.0.4] startup
[298.727s] [ext: omni.kit.window.title-1.1.0] startup
[303.500s] [ext: omni.graph.tools-1.0.0] startup
[307.455s] [ext: omni.kit.tool.paint-102.3.5] startup
[310.192s] [ext: omni.kit.property.layer-1.1.2] startup
[314.952s] [ext: omni.graph.core-1.0.2] startup
[314.959s] [ext: omni.kit.search.service-0.1.0] startup
[320.493s] [ext: omni.kit.hydra_texture-0.1.0] startup
[321.172s] [ext: omni.kit.graph.delegate.default-1.0.10] startup
[326.880s] [ext: omni.kit.tool.brush.scripting-102.1.2] startup
[330.849s] [ext: omni.kit.property.audio-1.0.5] startup
[333.417s] [ext: omni.graph-1.0.0] startup
[344.250s] [ext: omni.kit.property.camera-1.0.3] startup
[346.573s] [ext: omni.kit.widget.material_preview-1.0.2] startup
[351.478s] [ext: omni.kit.graph.editor.core-1.0.0] startup
[351.531s] [ext: omni.kit.thumbnails.mdl-1.0.6] startup
[354.696s] [ext: omni.kit.property.geometry-1.2.0] startup
[357.876s] [ext: omni.graph.expression-1.0.0] startup
2021-08-27 16:18:17 [362,145ms] [Warning] [omni.graph.core.plugin] Node type name 'Expression' is missing the unique namespace
[362.191s] [ext: omni.kit.tool.brush.scatter-102.3.4] startup
[369.619s] [ext: omni.kit.compatibility_checker-0.1.0] startup
[375.253s] [ext: omni.kit.window.material_graph-1.4.2] startup
[382.484s] [ext: omni.kit.browser.material-1.1.5] startup
[382.534s] [ext: omni.kit.property.transform-1.0.2] startup
[388.869s] [ext: omni.kit.tool.brush.attribute-102.0.0] startup
[402.815s] [ext: omni.kit.tool.brush.modify-102.3.3] startup
[403.181s] [ext: omni.kit.tool.brush.select-102.3.3] startup
[406.146s] [ext: omni.kit.quicklayout-1.0.1] startup
[410.747s] [ext: omni.kit.window.material-1.0.1] startup
[413.553s] [ext: omni.kit.property.bundle-1.2.4] startup
[420.038s] [ext: omni.kit.window.imageviewer-1.0.3] startup
[427.045s] [ext: omni.kit.telemetry-0.1.0] startup
[427.112s] [ext: omni.kit.tool.paint.bundle-102.3.6] startup
[427.112s] [ext: omni.create.app.setup-0.2.0] startup
[Warning] [omni.telemetry.transmitter] Couldn't acquire tokens interface and initialize default tokens.
Looking in indexes: https://pypi.org/simple, https://pypi.perflab.nvidia.com/simple/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f7739eb30d0>: Failed to establish a new connection: [Errno -2] Name or service not known')': /simple/dssim-py/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f7739eb3a10>: Failed to establish a new connection: [Errno -2] Name or service not known')': /simple/dssim-py/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f7739eb3950>: Failed to establish a new connection: [Errno -2] Name or service not known')': /simple/dssim-py/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f7739eb3550>: Failed to establish a new connection: [Errno -2] Name or service not known')': /simple/dssim-py/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7f7739ec12d0>: Failed to establish a new connection: [Errno -2] Name or service not known')': /simple/dssim-py/
ERROR: Could not find a version that satisfies the requirement dssim-py (from versions: none)
ERROR: No matching distribution found for dssim-py
WARNING: You are using pip version 20.1.1; however, version 21.2.4 is available.
You should consider upgrading via the '/home/rmclabs/.local/share/ov/pkg/create-2021.3.2/kit/python/bin/python3 -m pip install --upgrade pip' command.
2021-08-27 16:19:39 [444,036ms] [Warning] [carb.python] [omni.kit.pipapi] 'dssim-py' failed to install.
2021-08-27 16:19:40 [444,445ms] [Warning] [omni.kit.ui] Failed to remove menu with path: Window/Material Preview. It doesn't exist.
[444.514s] [ext: omni.kit.window.stats-0.1.0] startup
[444.571s] [ext: omni.create-2021.3.2-rc.5] startup
[444.572s] app started
[450.457s] [ext: omni.kit.builtin.init] startup
[450.462s] [ext: omni.kit.builtin.menu] startup
Is this an expected behaviour? What can I do to improve performance?
