Here is my app’s start log
Loading user config located at: 'C:/nv_ov/data/Kit/Warehouse.Generator/0.2/user.config.json'
2024-02-15 08:50:51 [143ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.core-103.4.0+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-02-15 08:50:51 [143ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.usd-103.4.0+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-02-15 08:50:51 [166ms] [Warning] [omni.ext.plugin] [ext: omni.kit.widget.timeline-105.0.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-02-15 08:50:51 [168ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.modifier.titlebar-105.1.10+105.wx64.cp310] Built using kit version: 105. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-02-15 08:50:51 [169ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.sequencer-103.4.2-dev.3+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-02-15 08:50:51 [177ms] [Warning] [omni.ext.plugin] [ext: omni.paint.brush.attributes-1.3.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-02-15 08:50:51 [199ms] [Warning] [omni.ext.plugin] [ext: omni.usd.schema.sequence-2.3.0+105.0.wx64.r.cp310] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
[0.624s] [ext: omni.kit.async_engine-0.0.0] startup
[5.917s] [ext: omni.assets.plugins-0.0.0] startup
[5.952s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[5.960s] [ext: omni.client-1.0.1] startup
[6.041s] [ext: omni.activity.core-1.0.1] startup
[6.068s] [ext: omni.stats-0.0.0] startup
[6.079s] [ext: omni.rtx.shadercache.d3d12-1.0.0] startup
[6.083s] [ext: omni.activity.profiler-1.0.2] startup
[6.100s] [ext: omni.gpu_foundation-0.0.0] startup
[6.257s] [ext: carb.windowing.plugins-1.0.0] startup
[6.515s] [ext: omni.kit.renderer.init-0.0.0] startup
[6.522s] [ext: omni.kit.pipapi-0.0.0] startup
[6.527s] [ext: omni.kit.pip_archive-0.0.0] startup
[6.531s] [ext: omni.pip.compute-1.2.0] startup
[6.534s] [ext: omni.pip.torch-2_0_1-2.0.2] startup
[6.892s] [ext: omni.pip.cloud-1.0.1] startup
[6.902s] [ext: omni.isaac.core_archive-2.2.1] startup
[6.906s] [ext: omni.kit.loop-default-0.2.0] startup
[6.913s] [ext: omni.kit.test-0.0.0] startup
[6.923s] [ext: omni.kit.telemetry-0.5.0] startup
[7.108s] [ext: omni.isaac.ml_archive-1.1.3] startup
[7.113s] [ext: omni.mtlx-0.1.0] startup
[7.118s] [ext: omni.usd.config-1.0.3] startup
[7.182s] [ext: omni.gpucompute.plugins-0.0.0] startup
[7.205s] [ext: omni.usd.libs-1.0.0] startup
[7.781s] [ext: omni.services.pip_archive-0.13.1] startup
[7.785s] [ext: omni.appwindow-1.1.5] startup
[7.809s] [ext: omni.kit.renderer.core-0.0.0] startup
[8.164s] [ext: omni.kit.renderer.capture-0.0.0] startup
[8.185s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[8.253s] [ext: carb.audio-0.1.0] startup
[8.263s] [ext: omni.ui-2.18.5] startup
[8.318s] [ext: omni.uiaudio-1.0.0] startup
[8.330s] [ext: omni.kit.mainwindow-1.0.1] startup
[8.342s] [ext: omni.kit.uiapp-0.0.0] startup
[8.344s] [ext: omni.usd.schema.metrics.assembler-105.1.2] startup
[8.413s] [ext: omni.usd.schema.physics-0.0.0] startup
[8.692s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[8.715s] [ext: omni.usd.schema.semantics-0.0.0] startup
[8.747s] [ext: omni.anim.graph.schema-105.2.2] startup
[8.775s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[8.798s] [ext: omni.usd.schema.audio-0.0.0] startup
[8.813s] [ext: omni.usd.schema.anim-0.0.0] startup
[8.883s] [ext: omni.usd.schema.physx-0.0.0] startup
2024-02-15 08:50:59 [8,754ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) HD Graphics 630
2024-02-15 08:50:59 [8,755ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) HD Graphics 630
[8.962s] [ext: omni.anim.navigation.schema-105.2.0] startup
[8.982s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[9.000s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[9.020s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[9.047s] [ext: omni.kit.window.popup_dialog-2.0.23] startup
[9.074s] [ext: omni.timeline-1.0.9] startup
[9.093s] [ext: omni.graph.exec-0.3.0] startup
[9.109s] [ext: omni.kit.widget.nucleus_connector-1.1.4] startup
[9.127s] [ext: omni.usd_resolver-1.0.1] startup
[9.170s] [ext: omni.kit.exec.core-0.5.0] startup
| Driver Version: 546.33 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 2080 | Yes: 0 | | 8002 MB | 10de | 81270200.. |
| | | | | | 1e87 | 0 |
| | | | | | 1 | |
| 1 | Intel(R) HD Graphics 630 | | | 128 MB | 8086 | 0b370200.. |
| | | | | | 5912 | 0 |
| | | | | | N/A | |
| OS: Windows 11 Enterprise, Version: 10.0 (23H2), Build: 22631, Kernel: 10.0.22621.3007
| Processor: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz | Cores: 4 | Logical: 8
| Total Memory (MB): 32599 | Free Memory: 28091
| Total Page/Swap (MB): 73559 | Free Page/Swap: 67558
[9.192s] [ext: omni.kit.actions.core-1.0.0] startup
[9.319s] [ext: omni.usd.core-1.1.8] startup
[9.334s] [ext: omni.resourcemonitor-105.0.0] startup
[9.352s] [ext: omni.kit.commands-1.4.6] startup
[9.384s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[9.402s] [ext: omni.hydra.usdrt_delegate-7.2.34] startup
[9.452s] [ext: omni.hydra.scene_delegate-0.3.2] startup
[9.472s] [ext: omni.kit.widget.path_field-2.0.8] startup
[9.481s] [ext: omni.usd-1.10.18] startup
[9.683s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[9.691s] [ext: omni.kit.helper.file_utils-0.1.6] startup
[9.754s] [ext: omni.iray.libs-0.0.0] startup
[10.049s] [ext: omni.kit.widget.filebrowser-2.3.35] startup
[10.078s] [ext: omni.kit.notification_manager-1.0.6] startup
[10.094s] [ext: omni.kit.widget.browser_bar-2.0.9] startup
[10.122s] [ext: omni.kit.search_core-1.0.5] startup
[10.132s] [ext: omni.mdl.neuraylib-0.2.0] startup
[10.148s] [ext: omni.kit.widget.search_delegate-1.0.4] startup
[10.160s] [ext: omni.volume-0.4.0] startup
[10.182s] [ext: omni.kit.widget.versioning-1.4.6] startup
[10.196s] [ext: omni.ui.scene-1.7.0] startup
[10.228s] [ext: omni.mdl-0.2.1] startup
[10.315s] [ext: omni.kit.clipboard-1.0.3] startup
[10.322s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[10.331s] [ext: omni.kit.window.filepicker-2.10.13] startup
[10.392s] [ext: omni.kit.collaboration.channel_manager-1.0.11] startup
[10.402s] [ext: omni.kit.window.file_importer-1.0.22] startup
[10.430s] [ext: omni.kit.usd.layers-2.1.27] startup
[10.493s] [ext: omni.kit.menu.utils-1.5.6] startup
[10.529s] [ext: omni.hydra.rtx-0.1.0] startup
[10.641s] [ext: omni.hydra.pxr-1.1.6] startup
[10.652s] [ext: omni.kit.material.library-1.3.41] startup
[10.674s] [ext: omni.kit.hydra_texture-1.1.12] startup
[10.692s] [ext: omni.kit.viewport.scene_camera_model-1.0.3] startup
[10.704s] [ext: omni.kit.viewport.legacy_gizmos-1.0.14] startup
[10.715s] [ext: omni.hydra.engine.stats-1.0.1] startup
[10.725s] [ext: omni.kit.widget.searchable_combobox-1.0.5] startup
[10.735s] [ext: omni.kit.menu.create-1.0.11] startup
[10.744s] [ext: omni.kit.widget.viewport-105.1.7] startup
[10.768s] [ext: omni.kit.viewport.registry-104.0.5] startup
[10.773s] [ext: omni.kit.window.drop_support-1.0.1] startup
[10.779s] [ext: omni.kit.widget.settings-1.0.6] startup
[10.788s] [ext: omni.kit.context_menu-1.6.8] startup
[10.800s] [ext: omni.kit.widget.spinner-1.0.6] startup
[10.816s] [ext: omni.kit.window.cursor-1.1.2] startup
[10.825s] [ext: omni.kit.viewport.window-105.1.12] startup
[11.117s] [ext: omni.kit.window.preferences-1.3.23] startup
[11.145s] [ext: omni.kit.viewport.menubar.core-105.0.19] startup
[11.438s] [ext: omni.kit.viewport.utility-1.0.16] startup
[11.442s] [ext: omni.kit.viewport.menubar.bottom-1.0.5] startup
[11.449s] [ext: omni.kit.viewport.menubar.nav_bar_toggle-1.0.3] startup
[11.457s] [ext: omni.kit.viewport.menubar.timeline-1.0.2] startup
[11.465s] [ext: omni.kit.widget.searchfield-1.1.3] startup
[11.474s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[11.481s] [ext: omni.kit.primitive.mesh-1.0.15] startup
[11.500s] [ext: omni.kit.widget.prompt-1.0.6] startup
[11.506s] [ext: omni.kit.collaboration.presence_layer-1.0.8] startup
[11.518s] [ext: omni.kit.browser.core-2.3.10] startup
[11.538s] [ext: omni.kit.stage_templates-1.1.20] startup
[11.550s] [ext: omni.kit.widget.live_session_management-1.2.22] startup
[11.570s] [ext: omni.kit.prim.icon-1.0.11] startup
[11.582s] [ext: omni.kit.widgets.custom-1.0.6] startup
[11.615s] [ext: omni.kit.usd_presenter.conn.manager-0.1.4] startup
[11.623s] [ext: omni.kit.widget.options_menu-1.0.5] startup
[11.632s] [ext: omni.kit.window.file_exporter-1.0.22] startup
[11.639s] [ext: omni.kit.playlist.core-1.3.1] startup
[11.653s] [ext: omni.kit.widget.filter-1.1.2] startup
[11.662s] [ext: omni.kit.window.file-1.3.44] startup
[11.676s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[11.682s] [ext: omni.kit.hotkeys.core-1.3.0] startup
[11.698s] [ext: usdrt.scenegraph-7.2.34] startup
[11.900s] [ext: omni.kit.widget.highlight_label-1.0.1] startup
[11.906s] [ext: omni.kit.window.content_browser-2.7.17] startup
[11.938s] [ext: omni.kit.widget.imageview-1.0.3] startup
[11.943s] [ext: omni.kit.viewport.actions-105.1.6] startup
[11.956s] [ext: omni.kit.window.property-1.9.6] startup
[11.970s] [ext: omni.kit.widget.stage-2.9.6] startup
[12.014s] [ext: omni.kit.window.quicksearch-2.4.1] startup
[12.029s] [ext: omni.kit.viewport.menubar.display-105.1.0] startup
[12.038s] [ext: omni.kit.property.usd-3.21.15] startup
[12.070s] [ext: omni.kit.stage.copypaste-1.2.2] startup
[12.079s] [ext: omni.kit.waypoint.core-1.4.45] startup
[12.137s] [ext: omni.kit.property.material-1.8.36] startup
[12.151s] [ext: omni.kit.browser.folder.core-1.9.7] startup
[12.180s] [ext: omni.kit.tool.camera_playlist-1.3.1] startup
[12.199s] [ext: omni.kit.markup.core-1.2.15] startup
[12.270s] [ext: omni.kit.widget.material_preview-1.0.8] startup
[12.279s] [ext: omni.kit.browser.material-1.4.4] startup
[12.289s] [ext: omni.kit.tool.remove_unused.core-0.1.1] startup
[12.299s] [ext: omni.kit.markup.playlist-0.0.4] startup
[12.311s] [ext: omni.kit.window.material-1.4.0] startup
[12.333s] [ext: omni.kit.viewport.menubar.camera-105.1.9] startup
[12.354s] [ext: omni.kit.debug.python-0.2.1] startup
[omni.kit.debug.python] Running python debugger on: ('127.0.0.1', 3000)
[13.133s] [ext: omni.kit.tool.markup-1.2.68] startup
[13.209s] [ext: omni.kit.tool.remove_unused.controller-0.1.3] startup
[13.219s] [ext: omni.kit.collaboration.viewport.camera-2.0.17] startup
[13.248s] [ext: omni.kit.debug.vscode-0.1.1] startup
[13.257s] [ext: omni.rtx.window.settings-0.6.9] startup
[13.281s] [ext: omni.activity.usd_resolver-1.0.1] startup
[13.292s] [ext: omni.activity.pump-1.0.0] startup
[13.302s] [ext: omni.kit.browser.asset-1.3.6] startup
[13.316s] [ext: omni.hydra.pxr.settings-1.0.5] startup
[13.326s] [ext: omni.activity.ui-1.0.27] startup
[13.373s] [ext: omni.command.usd-1.0.2] startup
[13.381s] [ext: omni.kit.viewport.menubar.lighting-105.0.7] startup
[13.399s] [ext: omni.kit.selection-0.1.3] startup
[13.408s] [ext: omni.kit.viewport.menubar.markup-104.1.26] startup
[13.424s] [ext: omni.kit.menu.edit-1.1.14] startup
[13.440s] [ext: omni.kit.viewport.navigation.core-1.0.29] startup
[13.512s] [ext: omni.kit.window.title-1.1.3] startup
[13.519s] [ext: omni.kit.viewport.navigation.markup-1.0.30] startup
[13.526s] [ext: omni.kit.widget.layers-1.6.32] startup
[13.597s] [ext: omni.kit.viewport.navigation.capture_no_ansel-1.0.16] startup
[13.612s] [ext: omni.kit.window.section-105.1.9] startup
[13.665s] [ext: omni.kit.property.layer-1.1.5] startup
[13.682s] [ext: omni.kvdb-0.0.0] startup
[13.700s] [ext: omni.kit.viewport.navigation.section-1.0.4] startup
[13.707s] [ext: omni.kit.property.audio-1.0.9] startup
[13.727s] [ext: omni.convexdecomposition-105.1.12-5.1] startup
[13.748s] [ext: omni.localcache-0.0.0] startup
[13.762s] [ext: omni.physx.foundation-105.1.12-5.1] startup
[13.770s] [ext: omni.usdphysics-105.1.12-5.1] startup
[13.778s] [ext: omni.kit.property.camera-1.0.5] startup
[13.789s] [ext: omni.kit.property.geometry-1.2.11] startup
[13.806s] [ext: omni.kit.property.light-1.0.8] startup
[13.815s] [ext: omni.kit.manipulator.transform-104.6.15] startup
[13.826s] [ext: omni.kit.usd_undo-0.1.2] startup
[13.833s] [ext: omni.physx.cooking-105.1.12-5.1] startup
[13.866s] [ext: omni.hydra.scene_api-0.1.2] startup
[13.879s] [ext: omni.kit.raycast.query-1.0.1] startup
[13.895s] [ext: omni.kit.widget.toolbar-1.5.6] startup
[13.910s] [ext: omni.kit.property.render-1.1.1] startup
[13.928s] [ext: omni.kit.property.skel-1.0.4] startup
[13.942s] [ext: omni.physx-105.1.12-5.1] startup
2024-02-15 08:51:05 [13,844ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[13.988s] [ext: omni.kit.property.transform-1.3.10] startup
[14.005s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[14.016s] [ext: omni.kit.manipulator.tool.snap-1.4.2] startup
[14.052s] [ext: omni.debugdraw-0.1.2] startup
[14.067s] [ext: omni.kit.manipulator.viewport-104.0.9] startup
[14.077s] [ext: omni.physx.commands-105.1.12-5.1] startup
[14.092s] [ext: omni.kit.property.bundle-1.2.9] startup
[14.102s] [ext: omni.kit.manipulator.camera-105.0.4] startup
[14.127s] [ext: omni.warp.core-1.0.0-beta.2] startup
Warp 1.0.0-beta.2 initialized:
CUDA Toolkit: 11.5, Driver: 12.3
Devices:
"cpu" | Intel64 Family 6 Model 158 Stepping 9, GenuineIntel
"cuda:0" | NVIDIA GeForce RTX 2080 (sm_75)
Kernel cache: C:\Users\username\AppData\Local\NVIDIA Corporation\warp\Cache\1.0.0-beta.2
[14.593s] [ext: omni.usdphysics.ui-105.1.12-5.1] startup
[14.640s] [ext: omni.kit.manipulator.prim-105.0.11] startup
[14.671s] [ext: omni.kit.waypoint.playlist-1.0.7] startup
[14.691s] [ext: omni.kit.window.toolbar-1.5.4] startup
2024-02-15 08:51:05 [14,558ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated key:'SPACE (On Press)'
2024-02-15 08:51:05 [14,559ms] [Warning] [omni.kit.hotkeys.core.registry] -- Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE
2024-02-15 08:51:05 [14,560ms] [Warning] [omni.kit.hotkeys.core.registry] -- Global [omni.kit.viewport.navigation.core] omni.kit.viewport.navigation.core::omni.kit.viewport.navigation.core-next-operation.SPACE
2024-02-15 08:51:05 [14,561ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated key definition
[14.705s] [ext: omni.kit.tool.teleport-104.2.15] startup
[14.736s] [ext: omni.kit.tool.measure-105.1.76] startup
[15.015s] [ext: omni.physx.ui-105.1.12-5.1] startup
[15.122s] [ext: omni.kit.manipulator.selection-104.0.8] startup
[15.133s] [ext: omni.kit.viewport.navigation.waypoint-1.0.22] startup
[15.154s] [ext: omni.kit.viewport.navigation.walk-1.0.4] startup
[15.162s] [ext: omni.kit.viewport.navigation.teleport-1.0.16] startup
[15.171s] [ext: omni.kit.viewport.navigation.measure-1.0.5] startup
[15.184s] [ext: omni.kit.viewport.navigation.camera_manipulator-1.0.52] startup
[15.224s] [ext: omni.physx.supportui-105.1.12-5.1] startup
[15.292s] [ext: omni.kit.viewport.navigation.usd_explorer.bundle-1.0.13] startup
[15.316s] [ext: omni.kit.menu.file-1.1.7] startup
[15.479s] [ext: omni.inspect-1.0.1] startup
[15.498s] [ext: omni.graph.tools-1.41.3] startup
[15.634s] [ext: omni.graph.core-2.139.12] startup
[15.656s] [ext: omni.isaac.kit-1.4.7] startup
[15.665s] [ext: omni.graph-1.106.1] startup
[15.889s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[15.909s] [ext: omni.kit.widget.graph-1.8.4] startup
[15.957s] [ext: omni.kit.viewport.menubar.waypoint-104.2.16] startup
[15.973s] [ext: omni.kit.numpy.common-0.1.2] startup
[15.987s] [ext: omni.kit.window.extensions-1.3.0] startup
[16.037s] [ext: omni.scene.optimizer.core-105.1.8] startup
[16.090s] [ext: omni.ui_query-1.1.1] startup
[16.098s] [ext: omni.rtx.settings.core-0.5.13] startup
[16.126s] [ext: omni.kit.ngsearch-0.3.0] startup
[16.146s] [ext: omni.isaac.dynamic_control-1.2.6] startup
[16.197s] [ext: omni.physics.tensors-0.1.0] startup
[16.232s] [ext: omni.scene.optimizer.ui-105.1.3] startup
[16.275s] [ext: omni.graph.ui-1.48.0] startup
[16.418s] [ext: omni.kit.viewport.ready-1.0.5] startup
[16.428s] [ext: omni.kit.search.service-0.1.11] startup
[16.864s] [ext: omni.isaac.version-1.0.3] startup
[16.872s] [ext: omni.physx.tensors-0.1.0] startup
[16.887s] [ext: omni.scene.optimizer.bundle-105.1.8] startup
[16.891s] [ext: omni.graph.action-1.55.1] startup
[17.195s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[17.287s] [ext: omni.kit.graph.delegate.default-1.1.1] startup
[17.295s] [ext: omni.isaac.core-3.3.2] startup
[22.639s] [ext: omni.kit.ui_test-1.2.13] startup
[22.652s] [ext: omni.anim.retarget.core-105.1.7] startup
[22.687s] [ext: omni.timeline.live_session-1.0.7] startup
[22.716s] [ext: omni.kit.graph.editor.core-1.5.1] startup
[22.742s] [ext: omni.kit.graph.delegate.modern-1.9.1] startup
[22.757s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[22.758s] [ext: omni.anim.skelJoint-105.1.16] startup
[22.803s] [ext: omni.isaac.ui-0.13.5] startup
[22.841s] [ext: omni.graph.nodes-1.106.3] startup
[24.022s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[24.031s] [ext: omni.kit.widget.stage_icons-1.0.4] startup
[24.038s] [ext: omni.kit.widget.live-2.1.6] startup
[24.051s] [ext: omni.kit.stage_column.payload-1.0.12] startup
[24.064s] [ext: omni.isaac.utils-0.6.0] startup
[24.104s] [ext: omni.anim.graph.core-105.1.15] startup
[24.216s] [ext: omni.curve.creator-105.0.3] startup
[24.234s] [ext: omni.kit.window.stage-2.4.4] startup
[24.259s] [ext: omni.scene.visualization.core-105.4.10] startup
[24.333s] [ext: omni.ramp-105.1.14] startup
[24.356s] [ext: omni.kit.usd_presenter.tooltip-0.2.1] startup
[24.368s] [ext: omni.graph.ui_nodes-1.5.10] startup
[24.643s] [ext: omni.curve.manipulator-105.1.8] startup
[24.717s] [ext: omni.genproc.core-105.1.5] startup
[24.779s] [ext: omni.usd.metrics.assembler-105.1.8] startup
[24.805s] [ext: omni.kit.usd_presenter.render-0.1.1] startup
[24.838s] [ext: omni.graph.bundle.action-2.0.4] startup
[24.838s] [ext: omni.graph.io-1.5.1] startup
2024-02-15 08:51:15 [24,706ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [omni::fabric::IFabricUsd v0.2] (plugin: <default plugin>), by client: omni.graph.io.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
[24.887s] [ext: omni.kit.browser.sample-1.4.6] startup
[24.903s] [ext: omni.anim.navigation.core-105.1.4] startup
[24.930s] [ext: omni.usd.metrics.assembler.ui-105.1.17] startup
[24.950s] [ext: omni.kit.usd_presenter.main.menubar-1.0.34] startup
[24.970s] [ext: usdrt.gf-1.0.2] startup
[25.021s] [ext: omni.anim.graph.ui-105.1.3] startup
[25.099s] [ext: omni.anim.navigation.ui-105.1.4] startup
[25.130s] [ext: omni.anim.retarget.ui-105.1.4] startup
[25.171s] [ext: omni.kit.property.physx-0.1.0] startup
[25.230s] [ext: omni.physx.demos-105.1.12-5.1] startup
[25.242s] [ext: omni.kit.viewport.menubar.framerate-1.0.8] startup
[25.256s] [ext: omni.anim.graph.bundle-105.1.1] startup
[25.267s] [ext: omni.anim.navigation.bundle-105.1.0] startup
[25.275s] [ext: omni.anim.retarget.bundle-105.1.1] startup
[25.284s] [ext: omni.kit.scripting-105.1.3] startup
[25.316s] [ext: omni.physx.camera-105.1.12-5.1] startup
[25.348s] [ext: omni.physx.cct-105.1.12-5.1] startup
[25.428s] [ext: omni.physx.graph-105.1.12-5.1] startup
[25.465s] [ext: omni.kit.window.about-1.2.4] startup
[25.479s] [ext: omni.kit.collaboration.selection_outline-1.0.6] startup
[25.497s] [ext: omni.physx.vehicle-105.1.12-5.1] startup
[25.557s] [ext: omni.kit.quicklayout-1.0.5] startup
[25.565s] [ext: omni.kit.window.console-0.2.10] startup
[25.589s] [ext: omni.kit.window.status_bar-0.1.6] startup
[25.615s] [ext: omni.isaac.conveyor-0.3.13] startup
[25.671s] [ext: omni.physx.bundle-105.1.12-5.1] startup
[25.671s] [ext: omni.kit.thumbnails.usd-1.0.3] startup
[25.838s] [ext: omni.anim.people-0.2.4] startup
[25.853s] [ext: omni.kit.window.modifier.titlebar-105.1.15] startup
[30.592s] [ext: omni.kit.window.stats-0.1.4] startup
2024-02-15 08:51:21 [30,605ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/directLighting/enabled has been requested but is not available
2024-02-15 08:51:21 [30,606ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/reflections/enabled has been requested but is not available
2024-02-15 08:51:21 [30,607ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/translucency/enabled has been requested but is not available
2024-02-15 08:51:21 [30,608ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/raytracing/subsurface/enabled has been requested but is not available
2024-02-15 08:51:21 [30,609ms] [Warning] [omni.kit.widget.settings.settings_model] a value for setting /rtx/caustics/enabled has been requested but is not available
event type 2
2024-02-15 08:51:22 [31,632ms] [Warning] [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000012035322950>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /api/834/store/
2024-02-15 08:51:22 [31,633ms] [Warning] [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000012035388AC0>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /api/834/store/
2024-02-15 08:51:22 [31,636ms] [Warning] [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000012035388CA0>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /api/834/store/
2024-02-15 08:51:22 [31,639ms] [Warning] [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000012035389510>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /api/834/store/
2024-02-15 08:51:22 [31,643ms] [Warning] [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x00000120353895D0>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /api/834/store/
2024-02-15 08:51:22 [31,644ms] [Warning] [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x00000120353896F0>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /api/834/store/
2024-02-15 08:51:22 [31,649ms] [Warning] [urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000012035389A20>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /api/834/store/
2024-02-15 08:51:22 [31,657ms] [Warning] [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000012035389AB0>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /api/834/store/
2024-02-15 08:51:22 [31,659ms] [Warning] [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x0000012035389CF0>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /api/834/store/
event type 3 , is opened
Stage Opened!
2024-02-15 08:51:32 [41,627ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated key:'SPACE (On Press)'
2024-02-15 08:51:32 [41,629ms] [Warning] [omni.kit.hotkeys.core.registry] -- Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE
2024-02-15 08:51:32 [41,630ms] [Warning] [omni.kit.hotkeys.core.registry] -- Global [omni.kit.viewport.navigation.core] omni.kit.viewport.navigation.core::omni.kit.viewport.navigation.core-next-operation.SPACE
2024-02-15 08:51:32 [41,631ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated key definition
