When I try to open the usd , I found the errors in the log
[29,690ms] [Info] [omni.usd] Loading omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd
2024-09-26 06:42:04 [30,021ms] [Info] [omni.client.plugin] 214370: provider_http: Successfully created S3 provider for https://omniverse-content-production.s3.us-west-2.amazonaws.com
2024-09-26 06:42:05 [30,700ms] [Info] [omni.client.plugin] Tick: provider_http: Using CloudFront http://dcb18d6mfegct.cloudfront.net/, List = No
2024-09-26 06:43:41 [127,288ms] [Info] [omni.client.plugin] Tick: provider_http: Read failed! Error. URI=‘http://dcb18d6mfegct.cloudfront.net/Assets/Skies/2022_1/Skies/Dynamic/ClearSky.usd’: Unknown response code from server. code=502
2024-09-26 06:43:41 [127,291ms] [Warning] [omni.usd] Warning (secondary thread): in _ReportErrors at line 2890 of /buildAgent/work/ac88d7d902b57417/USD/pxr/usd/usd/stage.cpp – In </Environment/sky>: Could not open asset @https://omniverse-content-production.s3.us-west-2.amazonaws.com/Assets/Skies/2022_1/Skies/Dynamic/ClearSky.usd@ for reference introduced by @omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd@</Environment/sky>. (instantiating stage on stage @omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd@ <0x7ce654009950>)
2024-09-26 06:46:26 [291,645ms] [Info] [omni.client.plugin] Tick: provider_http: Read failed! Error. URI=‘http://dcb18d6mfegct.cloudfront.net/Assets/Skies/2022_1/Skies/Dynamic/ClearSky.usd’: Unknown response code from server. code=502
2024-09-26 06:46:26 [291,648ms] [Info] [omni.usd] omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd opened successfully in 261.96 seconds
2024-09-26 06:46:26 [291,667ms] [Info] [rtx.scenedb.plugin] [MBVH]: Creating scene acceleration structures for context 0, device mask: 0x3
2024-09-26 06:46:26 [291,667ms] [Info] [rtx.scenedb.plugin] [MBVH]: Creating scene acceleration structure for context 0/device 0, with motion raytracing DISABLED
2024-09-26 06:46:26 [291,667ms] [Info] [rtx.scenedb.plugin] [MBVH]: Creating scene acceleration structure for context 0/device 1, with motion raytracing DISABLED
2024-09-26 06:46:26 [292,304ms] [Info] [omni.usd.audio] refreshing the USD scene state
2024-09-26 06:46:26 [292,305ms] [Info] [omni.usd.audio] audio default: ‘enable doppler’ = ‘off’
2024-09-26 06:46:26 [292,305ms] [Info] [omni.usd.audio] audio default: ‘enable distance delay’ = ‘off’
2024-09-26 06:46:26 [292,305ms] [Info] [omni.usd.audio] audio default: ‘enable interaural delay’ = ‘off’
2024-09-26 06:46:26 [292,305ms] [Info] [omni.usd.audio] updated world unit scale {1.00 => 0.01}
2024-09-26 06:46:26 [292,360ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd.
2024-09-26 06:46:26 [292,361ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer anon:0x7ce65400cd10.
2024-09-26 06:46:26 [292,365ms] [Info] [omni.kit.environment.core.models.usd_model_builder] [UsdModelBuilder] STOPPED!
2024-09-26 06:46:26 [292,365ms] [Info] [omni.kit.environment.core.models.usd_model_builder] [UsdModelBuilder] STARTED on Usd.Stage.Open(rootLayer=Sdf.Find(‘omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd’), sessionLayer=Sdf.Find(‘anon:0x7ce65400cd10’), pathResolverContext=)
2024-09-26 06:46:26 [292,365ms] [Info] [omni.kit.environment.core.ground.ground_helper] Ground found: None
2024-09-26 06:46:26 [292,377ms] [Info] [omni.kit.environment.core.sunstudy_player.player] [SunstudyPlayer] Found Dynamic sky: /Environment/sky
2024-09-26 06:46:26 [292,401ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd.
2024-09-26 06:46:26 [292,401ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer anon:0x7ce65400cd10.
2024-09-26 06:46:29 [295,201ms] [Info] [omni.client.plugin] Tick: provider_nucleus: Failed omni1CreateAsset(omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd):
2024-09-26 06:46:30 [295,525ms] [Error] [omni.usd] ERROR! Failed to save layer omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd due to permission issue.
2024-09-26 06:46:30 [295,525ms] [Info] [omni.usd] USD saving failed
2024-09-26 06:49:36 [481,749ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.ui.glyphmanager.plugin; not changing unload order
