Environment
- NRE Container:
nvcr.io/nvidia/nre/nre-ga:26.02.00 - GPU: NVIDIA RTX PRO 6000 Blackwell Max-Q (98GB)
- Dataset: NVIDIA PAI (PhysicalAI-Autonomous-Vehicles), clip
4848b5fd-72a8-4594-a2eb-9d5702f694e0 - Config: Based on
configs/apps/prod/Hyperion-8.1/car2sim_6cam.yaml(PPISP post-processing)
Summary
When training with PPISP post-processing (override /model/post_processing@model.post_processing.b: ppisp) and then attempting to render from the saved checkpoint using mode=val, the following error occurs:
RuntimeError
Can't access the shape of an uninitialized parameter or buffer.
This error usually happens in `load_state_dict` when trying to load an
uninitialized parameter into an initialized one. Call `forward` to
initialize the parameters before accessing their attributes.
This prevents any mode=val rendering from a PPISP-trained checkpoint, making it impossible to render novel views or ego views after training completes.
Steps to Reproduce
1. Train with PPISP post-processing (succeeds)
docker run --shm-size=64g --rm --gpus "device=0" \
-e NGC_API_KEY="${NGC_API_KEY}" \
-e WANDB_MODE=disabled \
--volume "${DATA_DIR}:/workdir/dataset" \
--volume "${OUTPUT_DIR}:/workdir/output" \
--volume "${CUSTOM_CONFIG_DIR}:/app/internal/scripts/pycena/runtime/pycena_run.runfiles/_main/configs/custom" \
nvcr.io/nvidia/nre/nre-ga:26.02.00 \
mode=train \
out_dir=/workdir/output \
--config-name=configs/custom/nv_prod.yaml \
dataset.path="/workdir/dataset/${MANIFEST}" \
trainer.max_epochs=1 \
trainer.world_size=1 \
+log_level=2
Training completes successfully. Checkpoint saved at ${RUN_ID}/checkpoints/last.ckpt.
2. Render from checkpoint using mode=val (fails)
mode=val \
--config-name="/workdir/output/${RUN_ID}/config/parsed.yaml" \
dataset.val_camera_frame_step=1 \
system.test.save_results=true \
system.test.save_videos=true
Error:
Validation DataLoader 0: 0%| | 0/2396 [00:00<?, ?it/s]
RuntimeError: Can't access the shape of an uninitialized parameter or buffer.
3. Workarounds attempted (all fail with same error)
model.calib.name=skip-calib— same errordataset.precompute_rendering_data=false— same error~model.post_processing(Hydra delete) — same error
Expected Behavior
mode=val should successfully load the PPISP-trained checkpoint and render frames, just as it does for checkpoints trained with bilateral_grid_per_camera post-processing.
Actual Behavior
The PPISP module has parameters that are only initialized during a forward pass in training. When mode=val tries to load the checkpoint via load_state_dict(), these parameters are still uninitialized, causing the RuntimeError.
Impact
- Cannot render novel views from a PPISP-trained checkpoint
- Cannot iterate on camera rigs without retraining from scratch
mode=trainvalworkaround does produce renders, but:- Only renders what was configured at training time
- Cannot resume from checkpoint — starts training over again
- Makes it impossible to experiment with different novel view parameters post-training
Working Comparison
Training with bilateral_grid_per_camera post-processing (default in configs/apps/AV/ configs) produces checkpoints that work correctly with mode=val:
# This works:
defaults:
- /model/post_processing@model.post_processing.b: bilateral_grid_per_camera
- /model/post_processing@model.post_processing.c: bilateral_grid_per_frame
# This does NOT work with mode=val:
defaults:
- override /model/post_processing@model.post_processing.b: ppisp
- override /model/post_processing@model.post_processing.c: null
Suggested Fix
The PPISP module should either:
- Initialize all parameters in
__init__()rather than lazily duringforward(), or - Handle uninitialized parameters gracefully during
load_state_dict(), or - Support a
mode=valcode path that initializes parameters before loading the checkpoint
Config Used
Custom config based on car2sim_6cam.yaml, with all NVIDIA production settings (MCMC strategy, road semantic, calib, 6cam Hyperion 8.1 sensors):
defaults:
- /apps/AV/_base_3dgut_dynamic_road_semantic.yaml
- /apps/prod/options/artifact: default
- /apps/prod/options/nrend: disabled
- /apps/prod/options/difix/3dgut: disabled
- /apps/prod/options/mesh: disabled
- /apps/prod/options/ground: enabled
- /apps/prod/options/subsampling/3dgut: batch_sampler_4
- /apps/prod/Hyperion-8.1/options/sensors: hyperion8.1_6cam_1lidar
- /apps/prod/Hyperion-8.1/options/validation: default
- /apps/prod/options/calib: enabled
- /apps/AV/module_mixins/_mcmc_mixin.yaml
- override /model/gaussians/strategy@model.strategy: mcmc
- override /logger: dummy
dataset:
n_samples_per_epoch: 40000
lidar_ids:
- lidar_top_360fov
# ... (full config available on request)
