I tried setting up xrdp with my Jetson Orin Nano and ran into crash loops as described in Bug #2160575 “/etc/X11/Xsession does not start with /bin/sh: con...” : Bugs : xorg package : Ubuntu . Changing the shebang from /bin/sh to /bin/bash fixed the issue (but I have no idea if/when the .xsessionrc might be regenerated).
$ cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.7, GCID: 42132812, BOARD: generic, EABI: aarch64, DATE: Thu Sep 18 22:54:44 UTC 2025
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
ngie@orin-nano:~/jetsonUtilities$ sudo apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Source: nvidia-jetpack (6.2.1)
Version: 6.2.1+b38
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 6.2.1+b38), nvidia-jetpack-dev (= 6.2.1+b38)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_6.2.1+b38_arm64.deb
SHA256: dd9cb893fbe7f80d2c2348b268f17c8140b18b9dbb674fa8d79facfaa2050c53
SHA1: dc630f213f9afcb6f67c65234df7ad5c019edb9c
MD5sum: 9c8dc61bdab2b816dcc7cd253bcf6482
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Source: nvidia-jetpack (6.2)
Version: 6.2+b77
Architecture: arm64
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 6.2+b77), nvidia-jetpack-dev (= 6.2+b77)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_6.2+b77_arm64.deb
SHA256: 70553d4b5a802057f9436677ef8ce255db386fd3b5d24ff2c0a8ec0e485c59cd
SHA1: 9deab64d12eef0e788471e05856c84bf2a0cf6e6
MD5sum: 4db65dc36434fe1f84176843384aee23
Source: nvidia-jetpack (6.1)
Version: 6.1+b123
Architecture: arm64
Installed-Size: 194
Depends: nvidia-jetpack-runtime (= 6.1+b123), nvidia-jetpack-dev (= 6.1+b123)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_6.1+b123_arm64.deb
SHA256: b6475a6108aeabc5b16af7c102162b7c46c36361239fef6293535d05ee2c2929
SHA1: f0984a6272c8f3a70ae14cb2ca6716b8c1a09543
MD5sum: a167745e1d88a8d7597454c8003fa9a4
