Jetson / Ubuntu XRDP Setup Runbook
Took me a couple of days to get remote desktop to work on my Jetson Nano. Here is a runbook in case you run into the same issues I did.
1. Install XRDP Server
Install XRDP so the Ubuntu / Jetson machine can accept Remote Desktop Protocol connections.
sudo apt update
sudo apt install xrdp
Enable and start XRDP:
sudo systemctl enable xrdp
sudo systemctl start xrdp
Check status:
sudo systemctl status xrdp
Confirm port 3389 is listening:
ss -tlnp | grep 3389
If firewall is enabled, allow RDP:
sudo ufw allow 3389/tcp
2. Install XRDP Xorg Backend
XRDP needs the Xorg backend package so it can create a remote X session.
sudo apt update
sudo apt install xorgxrdp dbus-x11 -y
3. Initial Symptom
Problem: Login worked, but after entering the password, the remote window flashed the NVIDIA logo and disappeared.
This indicated that XRDP authentication succeeded, Xorg started, but the desktop/window manager immediately exited.
4. Check XRDP Session Logs
Check the XRDP session manager log:
sudo journalctl -u xrdp-sesman -n 50 --no-pager
The important lines from the log were:
[INFO ] starting Xorg session...
[INFO ] Session started successfully for user tuna on display 10
[WARN ] Window manager exited with non-zero exit code 2
[WARN ] Window manager exited quickly (0 secs)
[INFO ] ++ terminated session: username tuna, display :10.0
This confirmed XRDP was not the main failure. The window manager / desktop environment was failing.
5. Check Xorg XRDP Log
Check the Xorg XRDP log:
cat ~/.xorgxrdp.10.log | tail -50
The key result was:
Server terminated successfully (0). Closing log file.
That meant the XRDP X server itself did not crash. The failure was still the desktop session.
6. Disable Wayland for NVIDIA / XRDP Stability
GNOME + NVIDIA + Wayland can cause XRDP login loops or immediate disconnects.
sudo nano /etc/gdm3/custom.conf
Find this line:
#WaylandEnable=false
Change it to:
WaylandEnable=false
Then reboot or restart the display manager:
sudo reboot
7. Install XFCE Desktop
GNOME can be unreliable under XRDP on Jetson/NVIDIA systems. XFCE is lighter and usually works better.
sudo apt update
sudo apt install xfce4 xfce4-goodies xorgxrdp dbus-x11 -y
8. Switch from GDM3 to LightDM
For Jetson + NVIDIA + XRDP, LightDM is usually more stable than GDM3.
sudo apt update
sudo apt install lightdm -y
If prompted, select:
lightdm
If it does not prompt, force the selection:
sudo dpkg-reconfigure lightdm
Then choose:
lightdm
Reboot:
sudo reboot
9. Set the User Session to XFCE
Create or replace the user XRDP session file:
rm -f ~/.xsession ~/.Xauthority ~/.ICEauthority
echo "startxfce4" > ~/.xsession
chmod +x ~/.xsession
10. Fix /etc/xrdp/startwm.sh
The key fix was editing XRDP’s startup script so it does not fall through to the default Xsession startup.
sudo nano /etc/xrdp/startwm.sh
Incorrect version
This was not ideal because after startxfce4 exits or fails, it continues into /etc/X11/Xsession:
if test -r /etc/profile; then
        . /etc/profile
fi
if test -r ~/.profile; then
        . ~/.profile
fi
unset DBUS_SESSION_BUS_ADDRESS
unset XDG_RUNTIME_DIR
startxfce4
test -x /etc/X11/Xsession && exec /etc/X11/Xsession
exec /bin/sh /etc/X11/Xsession
Correct working version
Use this instead:
        . /etc/profile
fi
        . ~/.profile
fi
exec startxfce4
Important: The key line is exec startxfce4. Remove or comment out these fallback lines:
11. Restart XRDP Services
After editing startwm.sh, restart XRDP:
sudo systemctl restart xrdp
sudo systemctl restart xrdp-sesman
If needed, reboot:
sudo reboot
12. Login Notes
  • Use the Ubuntu/Linux username and password, for example tuna.
  • Do not use Microsoft account credentials.
  • If a session dropdown appears, use Xorg.
  • If the same user is already logged in locally on the Jetson monitor, log out locally first before using XRDP.
13. Optional: Test With a Fresh RDP User
If the normal user profile is broken, create a clean test user:
sudo adduser rdpuser
sudo usermod -aG sudo rdpuser
Set XFCE for that user:
sudo su - rdpuser
exit
Restart XRDP:
Then try logging in as rdpuser.
14. Remmina Client Resolution Fix
Once login worked, the RDP screen was tiny because XRDP negotiated a small resolution like 592x440. Since the client was Remmina on Ubuntu, set resolution in Remmina.
Recommended Remmina settings
  1. Open Remmina.
  2. Edit the Jetson/Ubuntu RDP connection.
  3. Go to the Basic tab.
  4. Set Resolution to 1920x1080.
  5. Save and reconnect.
Other useful options:
1920x1080
1920x1200
2560x1440
Fullscreen shortcut in Remmina:
F11
15. Final Working Stack
Component Working Choice
RDP server XRDP
XRDP backend xorgxrdp
Desktop environment XFCE
Display manager LightDM
Session startup exec startxfce4 in /etc/xrdp/startwm.sh
Client Remmina on Ubuntu
16. Useful Debug Commands
sudo journalctl -u xrdp -n 50 --no-pager
sudo journalctl -u xrdp-sesman -n 80 --no-pager
cat ~/.xsession-errors
loginctl
Many thanks for the sharing.
Much of this setup process is handled by GitHub - kyroskoh/setup-xrdp-script: XRDP + Desktop Environment Setup (Ubuntu). Supports (XFCE or GNOME) · GitHub BTW (just to save you and others time trying to replicate this in the future). It relies on Xsession to start X11 sessions and maintain them, in lieu of using gdm for interactive logins.
All that you’d need to do is the following:
  1. Execute this to disable gdm:
sudo systemctl set-default multi-user.target
  1. Reboot afterwards.
  2. Grab the script from the required repo and run it as desired.
Please note that if you’re using xrdp as I suggested above, you might run into the issue described in BUG REPORT: nvidia-jetpack 6.2.1 .xsessionrc generated by not dash-compatible; results in crash loops when run without bash . TL;DR: change the NVIDIA provided Xsession script from /bin/sh to /bin/bash, since it relies on bashisms to function. We’ll see how 7.2 fares, but 6.2.1 definitely crash loops like I described…
