I have installed xrdp into Jetson nano then I use Windows remote desktop to logon into it, I can see the big nvidia logo then the connection stopped.
I got this message:
If I run systemctl status xrdp on nano, I got this:
● xrdp.service - xrdp daemon
Loaded: loaded (/lib/systemd/system/xrdp.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2021-11-01 20:11:44 CST; 22min ago
Docs: man:xrdp(8)
man:xrdp.ini(5)
Process: 5236 ExecStart=/usr/sbin/xrdp $XRDP_OPTIONS (code=exited, status=0/SUCCESS)
Process: 5193 ExecStartPre=/bin/sh /usr/share/xrdp/socksetup (code=exited, status=0/SUCCESS)
Main PID: 5320 (xrdp)
Tasks: 2 (limit: 4181)
CGroup: /system.slice/xrdp.service
├─5320 /usr/sbin/xrdp
└─7700 /usr/sbin/xrdp
11月 01 20:18:48 conti-nano xrdp[7700]: (7700)(548461133840)[DEBUG] Closed socket 17 (AF_UNIX)
11月 01 20:18:51 conti-nano xrdp[7700]: (7700)(548461133840)[DEBUG] Closed socket 17 (AF_UNIX)
11月 01 20:18:55 conti-nano xrdp[7700]: (7700)(548461133840)[DEBUG] Closed socket 17 (AF_UNIX)
11月 01 20:18:58 conti-nano xrdp[7700]: (7700)(548461133840)[DEBUG] Closed socket 17 (AF_UNIX)
11月 01 20:19:02 conti-nano xrdp[7700]: (7700)(548461133840)[DEBUG] Closed socket 17 (AF_UNIX)
11月 01 20:19:05 conti-nano xrdp[7700]: (7700)(548461133840)[DEBUG] xrdp_wm_log_msg: connection problem, giving up
11月 01 20:19:05 conti-nano xrdp[7700]: (7700)(548461133840)[DEBUG] Closed socket 17 (AF_UNIX)
11月 01 20:19:05 conti-nano xrdp[7700]: (7700)(548461133840)[DEBUG] xrdp_wm_log_msg: some problem
11月 01 20:19:05 conti-nano xrdp[7700]: (7700)(548461133840)[DEBUG] xrdp_mm_module_cleanup
11月 01 20:19:05 conti-nano xrdp[7700]: (7700)(548461133840)[DEBUG] Closed socket 16 (AF_INET6 ::1 port 50988)
What could be the problem? I connected my Nano with my PC with direct cable.
(I can use vino/vnc without any issue as documented in nano’s readme document)
