Required Info:
Software Version
DRIVE OS 6.0.6 -
Target OS
Linux -
SDK Manager Version
1.9.2.10884 -
Host Machine Version
native Ubuntu Linux 20.04 Host installed with DRIVE OS DOCKER Containers -
board name
p3710-10-s05
Describe the bug
According to PCIe Hot-Plug not working - #15 by BruceYangNV , in order to flash orin with soc_id, the flash.py
in host-docker should be used, rather than sdk-manager.
I think the default image on P3710 didn’t set the correct soc_id by default.
Furthermore, If I remember correctly, the SDK manager doesn’t support option “-s”.
There is an error when running flash.py
To Reproduce
zs@in-sdk-docker:/drive$ sudo -H python3 ./flash.py /dev/ttyACM0 p3710-10-s05
File "./flash.py", line 19, in <module>
from preflash import PreflashCheck
File "/drive/drive_flashing/preflash.py", line 22, in <module>
isSafety = "-safety" if os.environ["DRIVEOS_VARIANT"].endswith("safety") else ""
File "/usr/lib/python3.8/os.py", line 675, in __getitem__
raise KeyError(key) from None
KeyError: 'DRIVEOS_VARIANT'
Additional context
echo $DRIVEOS_VARIANT
linux
board_name is got using
cd /drive/drive-foundation/tools/flashtools
sudo -H python3 ./bootburn/bootburn.py --find_board_name -x /dev/ttyACM1
