Hi, is the list of supported Drive OS versions in the documentation here still up to date? We received P3710 940-63710-0010-D00 model devkits, and I see they’re still listed as requiring Drive OS 6.0.3.1 and not supporting future versions (no “+” symbol).
I’m having trouble flashing one to 6.0.5, and I’m wondering if this is the issue.
Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
other
Thanks @SivaRamaKrishnaNV, so you’re confirming we cannot upgrade these devkits past 6.0.3.1? It just says “no” in both rows. How do we access the latest features?
FWIW, I found the comment in the release notes about flashing issues, whose last bullet point was to try a USB2 port on the host computer. This worked fine for me and the process claims to have worked successfully. The only problem is that the username/password I supplied in the flashing process doesn’t work to log into the kit. Is that specifically the bit that’s known not to work when upgrading? Also, since the flashing procedure should be able to read the existing version on the devkit before proceeding, could it check for this and alert the user before flashing?
Dear @andrew.mcdonald,
I will double check the migration path internally and confirm.
So, Do you see flashing is successful message in sdkmanager when tried installing 6.0.5? If not, can you check 6.0.4 first? Also, please attach the flashing logs for reference(~/.nvsdkm/sdkm*.log and ~/.nvsdkm/logs)
Hello @SivaRamaKrishnaNV, is there any update on this? I’m still wondering about the supported workflows, as the info in that document is a little confusing. Since the idea of flashing is to completely overwrite what’s on the devkit (even the persistent data - we’ve nothing we need to preserve there), I’m hoping it shouldn’t matter what was on there before.
