I am trying to load RGBD camera sensor models in Isaac Sim 2023.1.0. However, in the Isaac Sim Asset window (under sensor drop down tag) there are only 3 models shown in there (see the attached image). However, from the Create-Isaac-RGBD Sensor menu, all sensors can be loaded correctly. Is that a known bug? Is there any solution that can make the main UI Isaac Sim Asset window show all camera models?
can confirm on my end. i’ve also tried to ‘Add Collection’ in hopes that as a workaround, we can manually add the missing assets
unfortunately, any attempt to path to any of the folders containing those assets from my localhost, i got the following error message:
2023-11-07 19:45:03 [257,062ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished name='Task-1511' coro=<FolderBrowserWidget._create_filepicker.<locals>.on_click_handler() done, defined at c:/users/simpl/appdata/local/ov/pkg/isaac_sim-2023.1.0/extscache/omni.kit.browser.folder.core-1.9.7/omni/kit/browser/folder/core/widgets/folder_browser_widget.py:197> exception=NameError("name 'url' is not defined")>
File "c:/users/simpl/appdata/local/ov/pkg/isaac_sim-2023.1.0/extscache/omni.kit.browser.folder.core-1.9.7/omni/kit/browser/folder/core/widgets/folder_browser_widget.py", line 209, in on_click_handler
click_fn(fullpath)
File "c:/users/simpl/appdata/local/ov/pkg/isaac_sim-2023.1.0/extscache/omni.kit.browser.folder.core-1.9.7/omni/kit/browser/folder/core/widgets/folder_browser_widget.py", line 232, in _on_folder_picked
self._on_new_collection_added(folder)
File "c:/users/simpl/appdata/local/ov/pkg/isaac_sim-2023.1.0/extscache/omni.kit.browser.folder.core-1.9.7/omni/kit/browser/folder/core/widgets/folder_browser_widget.py", line 241, in _on_new_collection_added
if item.folder.url == url:
NameError: name 'url' is not defined
