ModuleNotFoundError: No module named 'omni.kit.usd'
I am using Ubuntu 22.04 with CUDA Version: 12.3 and NVIDIA GeForce RTX 4060 Ti. I have installed Isaac Sim version 4.2.0.
When I run the command python -m omnigibson.examples.environments.behavior_env_demo , I encounter the following error:
[INFO] [omnigibson] Demo /home/ariel/project/OmniGibson/omnigibson/examples/environments/behavior_env_demo.py
    Description:
    Generates a BEHAVIOR Task environment in an online fashion.
    It steps the environment 100 times with random actions sampled from the action space,
    using the Gym interface, resetting it 10 times.
Here is a list of available online object samplings:
[1] False: Use a pre-sampled cached BEHAVIOR activity scene
[2] True: Sample the BEHAVIOR activity in an online fashion
Choose a online object sampling (enter a number from 1 to 2): 1
[INFO] [omnigibson.simulator] ----- Starting OmniGibson. This will take 10-30 seconds... -----
Starting kit application with the following args:  ['/home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/apps/omnigibson.kit', '--/app/tokens/exe-path=/home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1280', '--/app/renderer/resolution/height=720', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=False', '--/app/fastShutdown=True', '--ext-folder', '/home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/exts', '--ext-folder', '/home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/apps', '--/physics/cudaDevice=0', '--portable']
Passing the following args to the base kit application:  []
[Info] [carb] Logging to file: /home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/kit/logs/Kit/Isaac-Sim/4.2/kit_20241002_104223.log
2024-10-02 02:42:23 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
2024-10-02 02:42:23 [9ms] [Warning] [omni.ext.plugin] [ext: .git] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/.git' or '/home/ariel/project/OmniGibson/.git/config'
2024-10-02 02:42:23 [9ms] [Warning] [omni.ext.plugin] [ext: .github] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/.github' or '/home/ariel/project/OmniGibson/.github/config'
2024-10-02 02:42:23 [9ms] [Warning] [omni.ext.plugin] [ext: .overrides] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/.overrides' or '/home/ariel/project/OmniGibson/.overrides/config'
2024-10-02 02:42:23 [9ms] [Warning] [omni.ext.plugin] [ext: docker] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/docker' or '/home/ariel/project/OmniGibson/docker/config'
2024-10-02 02:42:23 [9ms] [Warning] [omni.ext.plugin] [ext: docs] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/docs' or '/home/ariel/project/OmniGibson/docs/config'
2024-10-02 02:42:23 [9ms] [Warning] [omni.ext.plugin] [ext: omnigibson.egg-info] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/omnigibson.egg-info' or '/home/ariel/project/OmniGibson/omnigibson.egg-info/config'
2024-10-02 02:42:23 [9ms] [Warning] [omni.ext.plugin] [ext: omnigibson] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/omnigibson' or '/home/ariel/project/OmniGibson/omnigibson/config'
2024-10-02 02:42:23 [9ms] [Warning] [omni.ext.plugin] [ext: tests] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/tests' or '/home/ariel/project/OmniGibson/tests/config'
2024-10-02 02:42:23 [9ms] [Warning] [omni.ext.plugin] [ext: scripts] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/scripts' or '/home/ariel/project/OmniGibson/scripts/config'
[0.073s] Failed to solve some dependencies locally, syncing with extension registry...
2024-10-02 02:42:23 [12ms] [Warning] [omni.ext.plugin] [ext: .github] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/.github' or '/home/ariel/project/OmniGibson/.github/config'
2024-10-02 02:42:23 [12ms] [Warning] [omni.ext.plugin] [ext: omnigibson] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/omnigibson' or '/home/ariel/project/OmniGibson/omnigibson/config'
2024-10-02 02:42:23 [12ms] [Warning] [omni.ext.plugin] [ext: scripts] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/scripts' or '/home/ariel/project/OmniGibson/scripts/config'
2024-10-02 02:42:23 [12ms] [Warning] [omni.ext.plugin] [ext: docker] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/docker' or '/home/ariel/project/OmniGibson/docker/config'
2024-10-02 02:42:23 [12ms] [Warning] [omni.ext.plugin] [ext: omnigibson.egg-info] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/omnigibson.egg-info' or '/home/ariel/project/OmniGibson/omnigibson.egg-info/config'
2024-10-02 02:42:23 [12ms] [Warning] [omni.ext.plugin] [ext: tests] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/tests' or '/home/ariel/project/OmniGibson/tests/config'
2024-10-02 02:42:23 [12ms] [Warning] [omni.ext.plugin] [ext: docs] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/docs' or '/home/ariel/project/OmniGibson/docs/config'
2024-10-02 02:42:23 [12ms] [Warning] [omni.ext.plugin] [ext: .overrides] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/.overrides' or '/home/ariel/project/OmniGibson/.overrides/config'
2024-10-02 02:42:23 [12ms] [Warning] [omni.ext.plugin] [ext: .git] Extensions config 'extension.toml' doesn't exist '/home/ariel/project/OmniGibson/.git' or '/home/ariel/project/OmniGibson/.git/config'
[0.075s] [ext: omni.kit.async_engine-0.0.1] startup
[DEBUG] [asyncio] Using selector: EpollSelector
[0.076s] [ext: omni.client-1.2.0] startup
[0.092s] [ext: omni.kit.registry.nucleus-0.0.0] startup
[INFO] [omni.kit.registry.nucleus.registry_manager] 'trusted' is not set for registry 'kit/default' in '/exts/omni.kit.registry.nucleus/registries'
[INFO] [omni.kit.registry.nucleus.registry_manager] 'trusted' is not set for registry 'kit/sdk' in '/exts/omni.kit.registry.nucleus/registries'
[INFO] [omni.kit.registry.nucleus.registry_manager] 'trusted' is not set for registry 'kit/community' in '/exts/omni.kit.registry.nucleus/registries'
2024-10-02 02:42:27 [3,650ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
        [omnigibson-2023.1.1] dependency: 'omni.kit.streamsdk.plugins' = { version='=2.5.2' } can't be satisfied. Available versions:
         - [omni.kit.streamsdk.plugins-4.5.3+106.0.0.lx64.r] (/home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/extscache/omni.kit.streamsdk.plugins-4.5.3+106.0.0.lx64.r)
         - [omni.kit.streamsdk.plugins-4.5.2+106.0.0.lx64.r] (/home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/extscache/omni.kit.streamsdk.plugins-4.5.2+106.0.0.lx64.r)
         - [omni.kit.streamsdk.plugins-4.4.0+106.0.0.lx64.r] (registry)
         - [omni.kit.streamsdk.plugins-3.2.1+105.2.lx64.r] (/home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/extscache/omni.kit.streamsdk.plugins-3.2.1+105.2.lx64.r)
         - [omni.kit.streamsdk.plugins-2.6.2+105.1.lx64.r] (registry)
         - [omni.kit.streamsdk.plugins-2.5.1+105.1.lx64.r] (registry)
         - [omni.kit.streamsdk.plugins-2.5.0+105.1.lx64.r] (registry)
         - [omni.kit.streamsdk.plugins-2.3.7+105.1.lx64.r] (registry)
         - [omni.kit.streamsdk.plugins-2.0.3+105.0.lx64.r] (registry)
 Synced registries:
         - kit/default         : found 424 packages
         - kit/sdk             : found 326 packages
         - kit/community       : found 382 packages
2024-10-02 02:42:27 [3,650ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure...
  File "/home/ariel/miniconda3/envs/omnigibson/lib/python3.10/runpy.py", line 196, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/home/ariel/miniconda3/envs/omnigibson/lib/python3.10/runpy.py", line 86, in _run_code
    exec(code, run_globals)
  File "/home/ariel/project/OmniGibson/omnigibson/examples/environments/behavior_env_demo.py", line 58, in <module>
    main()
  File "/home/ariel/project/OmniGibson/omnigibson/examples/environments/behavior_env_demo.py", line 36, in main
    env = og.Environment(configs=cfg)
  File "/home/ariel/project/OmniGibson/omnigibson/utils/python_utils.py", line 90, in wrapper
    func(*values.args, **values.kwargs)
  File "/home/ariel/project/OmniGibson/omnigibson/envs/env_base.py", line 41, in __init__
    launch_simulator()
  File "/home/ariel/project/OmniGibson/omnigibson/simulator.py", line 174, in launch_simulator
    og.app = _launch_app()
  File "/home/ariel/project/OmniGibson/omnigibson/simulator.py", line 90, in _launch_app
    app = lazy.omni.isaac.kit.SimulationApp(config_kwargs, experience=str(kit_file_target.resolve(strict=True)))
  File "/home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py", line 214, in __init__
    from .utils import create_new_stage, open_stage, set_livesync_stage
  File "/home/ariel/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.kit/omni/isaac/kit/utils.py", line 17, in <module>
    from omni.kit.usd import layers
I am not sure what is causing this error. I can run the command ./python.sh standalone_examples/api/omni.isaac.franka/follow_target_with_rmpflow.py under the path “~/.local/share/ov/pkg/isaac-sim-4.2.0” without any issues.
Any help would be greatly appreciated. Thanks!
Thank you for reaching out about this issue. I apologize, but OmniGibson is not maintained or officially supported by NVIDIA. For questions regarding Isaac Sim version compatibility with OmniGibson, I recommend consulting the OmniGibson community directly.
Please see if How to download old versions of Isaac Sim - #6 by liujk0725 is helpful.
python source/standalone/tutorials/00_sim/create_empty.py
[WARN][AppLauncher]: There are no arguments attached to the ArgumentParser object. If you have your own arguments, please load your own arguments before calling the `AppLauncher.add_app_launcher_args` method. This allows the method to check the validity of the arguments and perform checks for argument names.
[INFO][AppLauncher]: Loading experience file: /home/rui/IsaacLab/source/apps/isaaclab.python.kit
[Warning] [omni.isaac.kit.simulation_app] Modules: ['omni.kit_app'] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(...)
Loading user config located at: '/home/rui/anaconda3/envs/isaaclab/lib/python3.10/site-packages/omni/data/Kit/Isaac-Sim/4.2/user.config.json'
[Info] [carb] Logging to file: /home/rui/anaconda3/envs/isaaclab/lib/python3.10/site-packages/omni/logs/Kit/Isaac-Sim/4.2/kit_20241126_153351.log
2024-11-26 06:33:51 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
2024-11-26 06:33:55 [3,370ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
	[isaaclab.python-1.3.0] dependency: 'omni.physx.bundle' = { version='^' } can't be satisfied. Available versions:
	 (none found)
 Synced registries:
	 - kit/default         : found 388 packages
	 - kit/sdk             : found 317 packages
	 - kit/community       : found 384 packages
2024-11-26 06:33:55 [3,370ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure...
  File "/home/rui/IsaacLab/source/standalone/tutorials/00_sim/create_empty.py", line 29, in <module>
    app_launcher = AppLauncher(args_cli)
  File "/home/rui/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/app/app_launcher.py", line 113, in __init__
    self._create_app()
  File "/home/rui/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/app/app_launcher.py", line 607, in _create_app
    self._app = SimulationApp(self._sim_app_config, experience=self._sim_experience_file)
  File "/home/rui/anaconda3/envs/isaaclab/lib/python3.10/site-packages/isaacsim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py", line 214, in __init__
  File "/home/rui/anaconda3/envs/isaaclab/lib/python3.10/site-packages/isaacsim/exts/omni.isaac.kit/omni/isaac/kit/utils.py", line 17, in <module>
similar error runnig create_env.py for ubuntu 24.04
Hello… I had the same issue this post solved my issue No module named 'omni.isaac'
