ModuleNotFoundError: No module named 'omni.kit.usd' with Isaac Sim 4.5.0 + Isaac Lab 2.3.0
Environment:
  • **OS:**​ Ubuntu Linux
  • **Isaac Sim:**​ 4.5.0 (installed via pip install 'isaacsim[all]' --extra-index-url ``https://pypi.nvidia.com)
  • **Isaac Lab:**​ 2.3.0 (cloned from GitHub, checked out to tag v2.3.0)
  • **Conda Environment:**​ unitree_rl(Python 3.10)
  • **NVIDIA Driver:**​ 570.195.03
  • **CUDA Version:**​ 12.8
Issue:
When attempting to run any graphical Isaac Lab demo (e.g., ./isaaclab.sh -p scripts/demos/bipeds.py), the application fails to start and throws a ModuleNotFoundErrorfor omni.kit.usd. The full error traceback is:
[INFO] Using python from: /home/sj/miniconda3/envs/unitree_rl/bin/python
[WARN][AppLauncher]: There are no arguments attached to the ArgumentParser object. If you have your own arguments, please load your own arguments before calling the AppLauncher.add_app_launcher_args method. This allows the method to check the validity of the arguments and perform checks for argument names.
[INFO][AppLauncher]: Using device: cuda:0
[INFO][AppLauncher]: Loading experience file: /home/sj/Desktop/IsaacLab/apps/isaacsim_4_5/isaaclab.python.kit
[Warning] [simulation_app.simulation_app] Modules: [‘omni.kit_app’] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [simulation_app.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(…)
Loading user config located at: ‘/home/sj/miniconda3/envs/unitree_rl/lib/python3.10/site-packages/omni/data/Kit/Isaac-Sim/4.5/user.config.json’
[Info] [carb] Logging to file: /home/sj/miniconda3/envs/unitree_rl/lib/python3.10/site-packages/omni/logs/Kit/Isaac-Sim/4.5/kit_20251216_170814.log
2025-12-16 09:08:14 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
2025-12-16 09:08:14 [3ms] [Warning] [omni.ext.plugin] [ext: rendering_modes] Extensions config ‘extension.toml’ doesn’t exist ‘/home/sj/Desktop/IsaacLab/apps/isaacsim_4_5/rendering_modes’ or ‘/home/sj/Desktop/IsaacLab/apps/isaacsim_4_5/rendering_modes/config’
[0.058s] Failed to solve some dependencies locally, syncing with extension registry…
2025-12-16 09:08:14 [17ms] [Warning] [omni.ext.plugin] [ext: rendering_modes] Extensions config ‘extension.toml’ doesn’t exist ‘/home/sj/Desktop/IsaacLab/apps/isaacsim_4_5/rendering_modes’ or ‘/home/sj/Desktop/IsaacLab/apps/isaacsim_4_5/rendering_modes/config’
[0.062s] [ext: omni.kit.async_engine-0.0.1] startup
[0.065s] [ext: omni.client.lib-1.0.0] startup
[0.107s] [ext: omni.kit.registry.nucleus-0.0.0] startup
2025-12-16 09:08:16 [1,052ms] [Error] [omni.kit.registry.nucleus.index_v2.index_sync] Syncing registry index failed for url: ‘https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/106/shared/v2’. Exception: Failed to connect to the registry: ‘https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/106/shared/v2’
2025-12-16 09:08:16 [1,812ms] [Error] [omni.kit.registry.nucleus.index_v2.index_sync] Syncing registry index failed for url: ‘https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/sdk/106.5/d02c707b/v2’. Exception: Failed to connect to the registry: ‘https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/sdk/106.5/d02c707b/v2’
2025-12-16 09:08:18 [3,874ms] [Error] [omni.ext.plugin] Failed to resolve extension dependencies. Failure hints:
[isaaclab.python-2.3.0] dependency: ‘omni.kit.menu.edit’ = { version=‘^’ } can’t be satisfied. Available versions:
(none found)
Synced registries:
  • kit/default : found 0 packages (couldn’t connect or empty)
  • kit/sdk : found 0 packages (couldn’t connect or empty)
  • kit/community : found 484 packages
2025-12-16 09:08:18 [3,874ms] [Error] [omni.kit.app.plugin] Exiting app because of dependency solver failure…
File “/home/sj/Desktop/IsaacLab/scripts/demos/bipeds.py”, line 30, in
app_launcher = AppLauncher(args_cli)
File “/home/sj/Desktop/IsaacLab/source/isaaclab/isaaclab/app/app_launcher.py”, line 127, in init
self._create_app()
File “/home/sj/Desktop/IsaacLab/source/isaaclab/isaaclab/app/app_launcher.py”, line 811, in _create_app
self._app = SimulationApp(self._sim_app_config, experience=self._sim_experience_file)
File “/home/sj/miniconda3/envs/unitree_rl/lib/python3.10/site-packages/isaacsim/exts/isaacsim.simulation_app/isaacsim/simulation_app/simulation_app.py”, line 227, in init
from .utils import create_new_stage, open_stage
File “/home/sj/miniconda3/envs/unitree_rl/lib/python3.10/site-packages/isaacsim/exts/isaacsim.simulation_app/isaacsim/simulation_app/utils.py”, line 17, in
from omni.kit.usd import layers
ModuleNotFoundError: No module named ‘omni.kit.usd’
2025-12-16 09:08:18 [3,878ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
**BUT,**Isaac Lab headless training works fine.
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
