Build_cuda_engine() throws error
Hi all, I tried using build_cuda_engine(network) but it throws the error as below
engine = builder . build_cuda_engine ( network )
AttributeError: ‘tensorrt.tensorrt.Builder’ object has no attribute ‘build_cuda_engine’. Did you mean: ‘build_engine’?
Few details about existing software/libraries
  1. Cuda version - cuda-12.2
  2. Jetpack version is 6
Please let me know what could be the reason.
Thanks and Regards
Nagaraj. Trivedi
The API has changed.
Please follow the below sample to run an ONNX model with TensorRT 8.6:
Hi, thank you for providing this info. I will try this and let you know.
Thanks and Regards
Nagaraj Trivedi
