Building extension - attribute error
Upon building an simple extension I wanted to make a button that would spawn Dynamic Cuboids the ones you gave as an example at core api tutorials.
error goes as follows: AttributeError: ‘NoneType’ object has no attribute ‘scene’
And the code I wrote for the extension is:
import omni.ext
import omni.ui as ui
from omni.isaac.examples.base_sample import BaseSample
import asyncio
import numpy as np
from omni.isaac.core.objects import DynamicCuboid
class MyWindow(ui.Window, BaseSample):
def init(self, title: str = None, delegate=None, **kwargs):
super().init(title, **kwargs)
self.world = None
self._world = None
self.proj_scale_model_0=None
self.proj_scale_model_1=None
self.frame.set_build_fn(self._build_window)
self._controller = None
self._articulation_controller = None
def _on_clear(self):
    asyncio.ensure_future(self.clear_async())
    return
def _on_usd_load(self):
    prim = stage.DefinePrim("/World", "Xform")
    prim.GetReferences().AddReference("/home/mario/Documents/IsaacSaveFile/UR10-zavrsni_INTERIJER.usd")
    return
def setup_post_load(self):
    world = self.get_world()
    world.scene.add(
        DynamicCuboid(
            prim_path="/World/random_cube",
            name="fancy_cube",
            position=np.array([0.3, 0.3, 0.3]),
            size=np.array([0.0515, 0.0515, 0.0515]),
            color=np.array([0, 0, 1.0]),
    return
def _build_window(self):
    with ui.ScrollingFrame():
        with ui.VStack(spacing = 0, height = 0):
            with ui.CollapsableFrame("USD"):
                with ui.VStack(height=0):
                    ui.Button("USD Load", clicked_fn=lambda: clicked_usd_load())
                    def clicked_usd_load():
                        self._on_usd_load()
                        print("USD Loaded")
                        return
                    ui.Button("Clear", clicked_fn=lambda: clicked_clear())
                    def clicked_clear():
                        self._on_clear()
                        print("Viewport Cleared!")
                    ui.Button("Add Cube", clicked_fn=lambda: clicked_add_cube())
                    def clicked_add_cube():
                        self.setup_post_load()
                        print("Cube Added!")
class MyExtension(omni.ext.IExt):
def on_startup(self, ext_id):
print(“MyExtension startup”)
self._window = MyWindow(“Proba”, width=300, height=300)
def on_shutdown(self):
    print("MyExtension shutdown")
    if self._window:
        self._window.destroy()
        self._window = None
This problem is introduction into some other problems I had with translating core api tutorials into my own examples, I wonder where have I made an oversight.
Thank you!
Hi @user102346. From the error message, it seems like self.get_world() is possibly returning None. I would start looking there. Have a look at this video for how you can interactively debug your code with VSCode: How to Debug Your Kit Extension Using VSCode Debugger with Omniverse Code App - YouTube
