I’m trying to define a custom USD Schema for use in Omniverse apps.
#usda 1.0
subLayers = [
@usd/schema.usda@
over "GLOBAL" (
customData = {
string libraryName = "customTestSchema"
string libraryPath = "./"
string libraryPrefix = "CTS"
bool skipCodeGeneration = false
class CustomTestPrim "CustomTestPrim" (
inherits = </Typed>
doc = """Custom Test Schema"""
# test property as a string
string custom:schema:test:testString = "default" (
doc = """This is a test string property"""
displayGroup = "Advanced"
displayName = "Test String"
# test property as an int
int custom:schema:test:testInt = 123 (
doc = """This is a test int property"""
displayName = "Test Int"
# test property as a float
float custom:schema:test:testFloat = 12.3 (
doc = """This is a test float property"""
displayName = "Test Float"
I’ve used the following sample repo/extension as reference:
- GitHub - NVIDIA-Omniverse/usd-plugin-samples: USD schema extension samples, build tools, and sample kit extensions that use those schema extensions
- usd-plugin-samples/src/kit-extension/exts/omni.example.schema at main · NVIDIA-Omniverse/usd-plugin-samples · GitHub
When enabling the schema extension (or set to autoload), Omniverse Code 2022.3.3 throws an error that “extension class wrapper for base class pxrInternal_v0_23__pxrReserved__::UsdTyped has not been created yet”
2024-01-31 22:03:39 [Error] [omni.ext._impl._internal] File "/home/username/Documents/Kit/shared/exts/custom.test.schema/custom/test/schema/__init__.py", line 10, in <module>
2024-01-31 22:03:39 [Error] [omni.ext._impl._internal] from . import _customTestSchema
2024-01-31 22:03:39 [Error] [omni.ext._impl._internal] RuntimeError: extension class wrapper for base class pxrInternal_v0_23__pxrReserved__::UsdTyped has not been created yet
I’ve included a full tar/gz of the sample schema/extension (see bottom of post). The schema is built with the build.sh script and then moved from _install folder to respective extension locations. e.g. :
./exts/custom.test.schema/custom/test/schema:
__init__.py
_customTestSchema.so
./exts/custom.test.schema/include:
api.h
customTestPrim.h
tokens.h
./exts/custom.test.schema/lib:
ibcustomTestSchema.so
./exts/custom.test.schema/resources:
generatedSchema.usda
plugInfo.json
schema.usda
I’ve also built against OpenUSD’s libraries to roughly the same result:
2024-01-31 02:55:10 [34,907ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module custom.test.schema. Error: /home/username/Documents/Kit/shared/exts/custom.test.schema/custom/test/schema/_customTestSchema.so: undefined symbol: _ZTIN32pxrInternal_v0_23__pxrReserved__8UsdTypedE. Traceback:
Platform:
- Ubuntu LTS 22.04
- Linux Computer 6.5.0-15-generic #15~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Jan 12 18:54:30 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
- NVIDIA-SMI 535.154.05 Driver Version: 535.154.05 CUDA Version: 12.2
- Omniverse Code 2022.3.3
Any tips on where I’m going wrong in building the schema/extension?
Here’s a full tar/gz of the sample schema/extension:
customtestschema.tar.gz (101.8 KB)
Thanks for the help!
