I would like to create a custom USD schema type. however the documents link in the USD Schema page seems to be broken ( USD Schema — Omniverse Kit 102.1.2+release.46667.2027b54e.teamcity documentation ). Is there some tutorials related to USD Schema?
Hi @samcts
This is the code I used to create the custom schemas (RosControlFollowJointTrajectory and RosControlGripperCommand) for the ROS Control extension for example…
Hope that this code helps you in some ways:)
from pxr import Sdf
import omni.isaac.RosBridgeSchema as ROSSchema
class RosControlFollowJointTrajectory(ROSSchema.RosBridgeComponent):
def __init__(self, prim):
# RosBridgeComponent:
# __init__(_object*, pxrInternal_v0_20__pxrReserved__::UsdSchemaBase schemaObj)
# __init__(_object*, pxrInternal_v0_20__pxrReserved__::UsdPrim prim)
# __init__(_object*)
super().__init__(prim)
def __bool__(self):
return self.GetPrim().IsDefined()
@staticmethod
def Define(stage, path):
prim = stage.DefinePrim(path, "RosControlFollowJointTrajectory")
return RosControlFollowJointTrajectory(prim)
def CreateArticulationPrimRel(self):
self.GetPrim().CreateRelationship("articulationPrim")
def CreateControllerNameAttr(self, value):
self.GetPrim().CreateAttribute("controllerName", Sdf.ValueTypeNames.String, True).Set(value)
def CreateActionNamespaceAttr(self, value):
self.GetPrim().CreateAttribute("actionNamespace", Sdf.ValueTypeNames.String, True).Set(value)
@staticmethod
def Get(stage, path):
# Get(pxrInternal_v0_19__pxrReserved__::TfWeakPtr<pxrInternal_v0_19__pxrReserved__::UsdStage> stage, pxrInternal_v0_19__pxrReserved__::SdfPath path)
prim = stage.GetPrimAtPath(path)
def GetArticulationPrimRel(self):
return self.GetPrim().GetRelationship("articulationPrim")
def GetControllerNameAttr(self):
return self.GetPrim().GetAttribute("controllerName")
def GetActionNamespaceAttr(self):
return self.GetPrim().GetAttribute("actionNamespace")
@staticmethod
def GetSchemaAttributeNames(includeInherited=True):
names = []
if includeInherited:
names = ROSSchema.RosBridgeComponent.GetSchemaAttributeNames(includeInherited)
return names + ["controllerName", "actionNamespace"]
class RosControlGripperCommand(ROSSchema.RosBridgeComponent):
def __bool__(self):
@staticmethod
prim = stage.DefinePrim(path, "RosControlGripperCommand")
return RosControlGripperCommand(prim)
self.GetPrim().CreateAttribute("controllerName", Sdf.ValueTypeNames.String, False).Set(value)
self.GetPrim().CreateAttribute("actionNamespace", Sdf.ValueTypeNames.String, False).Set(value)
@staticmethod
@staticmethod
names = []
