Creating a Windows USD App from the Omniverse Connect Sample
This post describes how to create a simple application that will open a USD stage located on an Omniverse Nucleus server. Once the stage is open it will simply report the stage up-axis, the stage linear units, and list all of the prim node paths.
Video Overview
Here’s a link to a video that walks through these directions (if videos are your thing). -
Download the Connect Sample
Directions for downloading the Connect Sample and finding where it is installed are in the Omniverse Connect Sample Launcher docs.
Create a Windows Console App
Use the “Create a new project” Console App template in Visual Studio to generate a “Hello World” console application.
Dependencies for Omniverse Client Library and USD
Both the Omniverse Client Library and NVIDIA’s modified USD SDK are required, so the first thing to do is to copy them into the project structure of the simple app.
From the Connect Sample root folder, these two folders should be copied (after the dependencies are fetched using either prebuild.bat or build.bat:
_build\target-deps\nv_usd_build\target-deps\omni_client_library
Both of these dependencies contain symbolic links, so care must be taken when copying them into the simple app’s folders. Robocopy does a good job of deep-copying symbolic links. The
depsfolder will hold the USD and Client Library dependencies for the application. Note that in this case the simple project is located in theX:\tmp\OmniUSDReaderdirectory.robocopy /S _build\target-deps\nv_usd X:\tmp\OmniUSDReader\deps\nv_usdrobocopy /S _build\target-deps\omni_client_library X:\tmp\OmniUSDReader\deps\omni_client_library
Project Settings
Because this application uses USD, that also means it uses Boost and TBB which require libraries, preprocessor definitions, and additional options. Also note that we only provide the 64 bit x64 platform binaries, so don’t try to build for the 32 bit platform in Visual Studio.
- Additional Library Directories:
- Debug
deps\nv_usd\debug\lib;deps\omni_client_library\debug
- Release
deps\nv_usd\release\lib;deps\omni_client_library\release
Additional Dependencies:
- Debug
ar.lib;arch.lib;gf.lib;js.lib;kind.lib;pcp.lib;plug.lib;sdf.lib;tf.lib;trace.lib;usd.lib;usdGeom.lib;vt.lib;work.lib;usdShade.lib;usdLux.lib;omniclient.lib;python37.lib;boost_python37-vc141-mt-gd-x64-1_68.lib
- Release
ar.lib;arch.lib;gf.lib;js.lib;kind.lib;pcp.lib;plug.lib;sdf.lib;tf.lib;trace.lib;usd.lib;usdGeom.lib;vt.lib;work.lib;usdShade.lib;usdLux.lib;omniclient.lib;python37.lib;boost_python37-vc141-mt-x64-1_68.lib
- Note that the boost python library is the only difference between debug and release
- Debug
C/C++ Additional Options (to silence warnings):
/wd4244 /wd4305
C/C++ Additional Include Directories:
- Debug
deps\nv_usd\debug\include;deps\omni_client_library\include
- Release
deps\nv_usd\release\include;deps\omni_client_library\include
- Debug
C/C++ Preprocessor Definitions:
- Debug
BOOST_ALL_DYN_LINK;TBB_USE_DEBUG=1;NOMINMAX
- Release
BOOST_ALL_DYN_LINK;TBB_USE_DEBUG=0;NOMINMAX
- Debug
Post-build Event to Copying Runtime Dependencies
There are a lot of runtime dependencies, to make things easy they are simply copied to the same folder as the output executable. A batch file that runs after the app is built makes this convenient and free of errors.
The copy_binary_deps.bat script is run after each build and puts the runtime dependencies in the correct place:
- Post-Build Event
- Debug
scripts\copy_binary_deps.bat debug $(OutputPath)
- Release
scripts\copy_binary_deps.bat release $(OutputPath)
- Debug
@echo off
:: copy the USD and OmniClient libs to the $(OutputPath)
:: parameters:
:: 1. debug or release
:: 2. $(OutputPath)
set BUILD_CONFIG=%1
set OUTPUT_PATH=%2
set RC_OPTS=/NP /NJH /NJS /NS /NC /NFL /NDL
echo Copying deps\nv_usd\%BUILD_CONFIG%\lib contents to %OUTPUT_PATH%
robocopy /S deps\nv_usd\%BUILD_CONFIG%\lib %OUTPUT_PATH% %RC_OPTS%
echo Copying deps\omni_client_library\%BUILD_CONFIG% contents to %OUTPUT_PATH%
robocopy /S deps\omni_client_library\%BUILD_CONFIG% %OUTPUT_PATH% %RC_OPTS%
exit /B 0
Simple App Overview
The application performs a few simple things:
- Expects one argument, the path to a USD stage
- Acceptable forms:
- omniverse://localhost/Users/test/helloworld.usd
- C:\USD\helloworld.usd
- A relative path based on the CWD of the program (helloworld.usd)
- Acceptable forms:
- Initialize Omniverse
- Set the Omniverse Client log callback
- Set the Omniverse Client log level
- Initialize the Omniverse Client library
- Register an Omniverse Client status callback
- Open the USD stage
- Print the stage’s up-axis
- Print the stage’s linear units, or “meters per unit” setting
- Traverse the stage prims and print the path of each one
- Destroy the stage object
- Shutdown the Omniverse Client library
Sources
OmniUSDReader.cpp (4.9 KB)
copy_binary_deps.bat (529 Bytes)
