How to load a usd as stage in extension?
Isaac Sim Version
4.5.0
Operating System
Windows 11
GPU Information
  • Model: NVIDIA RTX 4090 16GB
  • Driver Version: 537.58
Topic Description
Detailed Description
I am trying to load an usd file as a stage and then use the world to add task for a simulation, I use " stage = omni.usd.get_context().open_stage(usd_file_path, None)" and it logs error of AttributeError: ‘World’ object has no attribute ‘_scene’
Steps to Reproduce
  1. Create an extension in extension/examples
  2. In the ui file, in function setup_scene(self):
    usd_file_path = ‘path_to_any_usd’
    world = self.get_world()
    world.reset()
  3. Press the load button
Error Messages
025-04-08 09:19:00 [2,643,850ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished name=‘Task-26496’ coro=<BaseSampleUITemplate._on_load_world.._on_load_world_async() done, defined at c:/nvidia_coe/isaacsim/exts/isaacsim.examples.interactive/isaacsim/examples/interactive/base_sample/base_sample_extension.py:107> exception=AttributeError(“‘World’ object has no attribute ‘_scene’”)>
File “c:/nvidia_coe/isaacsim/exts/isaacsim.examples.interactive/isaacsim/examples/interactive/base_sample/base_sample_extension.py”, line 108, in _on_load_world_async
await self._sample.load_world_async()
File “c:/nvidia_coe/isaacsim/exts/isaacsim.examples.interactive/isaacsim/examples/interactive/base_sample/base_sample.py”, line 46, in load_world_async
await self._world.reset_async()
File “c:/nvidia_coe/isaacsim/exts/isaacsim.core.api/isaacsim/core/api/world/world.py”, line 503, in reset_async
await self.reset_async_no_set_up_scene(soft=soft)
File “c:/nvidia_coe/isaacsim/exts/isaacsim.core.api/isaacsim/core/api/world/world.py”, line 463, in reset_async_no_set_up_scene
self._scene._finalize(self.physics_sim_view)
What I’ve Tried
I tried :
def setup_scene(self):
usd_file_path = ‘F:/LamTran/Integrate/warehouse.usd’
world.reset()
return
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
Hi @tran.nguyenquanglam! If you want to load a USD as a stage in extension, please use open_stage_async and ensure_future. For example:
async def create_scenario(self):
    await omni.usd.get_context().open_stage_async("my.usd")
asyncio.ensure_future(self.create_scenario())
In the Isaac Sim 5 exts folder, you can find some examples, such as ./isaacsim.sensors.physics.examples/isaacsim/sensors/physics/examples/imu_sensor.py
Thank you Zhengwang,
I did solve it by using open_state_async. But I did realize that what cause the error before was, there was an empty stage open before, then I tried to open my usd file as stage.
Solved it by openning the usd stage instead of an empty stage in the BaseSample class
async def load_world_async(self):
        await open_stage_async(self._usd_file_path)
        self._world = World(**self._world_settings)
