How can i load a USD file without Replicator? I know I can use:
rep.create.from_usd("path/to/file")
The problem is that Replicator changes all the paths of all the prims in the scene. I want to load my USD file but I want that all the paths I see in the GUI are the same when I load the file from python.
Hi Federico. I think that replicator function probably adds the USD layer as a reference and you maybe want to open your USD file as a stage. If that’s the case, we have an example of how to do that here:
https://docs.omniverse.nvidia.com/kit/docs/omni.kit.usd_docs/latest/Omni.USD.html#async-operations
And there’s more information about the omni.usd API here: Overview — omni.usd 1.9.0 documentation
If I run this code following the example you mentioned:
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp(
launch_config={"renderer": "RayTracedLighting", "headless": True}
import omni.usd
from omni.kit.usd_docs import variant_example_usd_scene
usd_context = omni.usd.get_context()
result = omni.usd.get_context().open_stage(variant_example_usd_scene)
print(f"opened stage {stage} with result {result}")
I get this error:
File "prova.py", line 9, in <module>
ModuleNotFoundError: No module named 'omni.kit.usd_docs'
2023-05-08 07:30:42 [9,398ms] [Warning] [carb.audio.context] 1 contexts were leaked
/home/federico/.local/share/ov/pkg/isaac_sim-2022.2.1/python.sh: line 41: 3999991 Segmentation fault (core dumped) $python_exe "$@" $args
There was an error running python
Looks like you’re on the right track, but you should not import omni.kit.usd_docs. Remove this like entirely:
You should give open_stage() a filepath to the USD file you want to open.
result = omni.usd.get_context().open_stage("C:/the/path/to/my_stage.usd")
