I created a scene and saved it as USD. Now I would like to import this scene from Python and obtain the World handle to access the robots in the scene and print some information. I tried this code:
#launch Isaac Sim before any other imports
#default first two lines in any standalone application
import carb
import omni
from omni.isaac.kit import SimulationApp
kit = SimulationApp({"headless": False}) # we can also run as headless.
# Locate Isaac Sim assets folder to load sample
from omni.isaac.core.utils.nucleus import get_assets_root_path, is_file
from omni.isaac.core import World
from omni.isaac.core.objects import DynamicCuboid
import numpy as np
usd_path = "test.usd"
omni.usd.get_context().open_stage(usd_path)
# Wait two frames so that stage starts loading
kit.update()
kit.update()
from omni.isaac.core.utils.stage import is_stage_loading
while is_stage_loading():
kit.update()
print("Loading Complete")
from omni.isaac.dynamic_control import _dynamic_control
dc = _dynamic_control.acquire_dynamic_control_interface()
world = dc.get_world()
carter = world.scene.get_object("carter_v1")
for i in range(500):
position, orientation = carter.get_world_pose()
linear_velocity = carter.get_linear_velocity()
# will be shown on terminal
print("Carter position is : " + str(position))
print("Carter's orientation is : " + str(orientation))
print("Carter's linear velocity is : " + str(linear_velocity))
# we have control over stepping physics and rendering in this workflow
# things run in sync
world.step(render=True) # execute one physics step and one rendering step
kit.close() # close Isaac Sim
But apparently, the get_world() method is not present:
File "C:\Users\gpepp\AppData\Local\ov\pkg\isaac_sim-2023.1.0-hotfix.1\exts\omni.isaac.examples\omni\isaac\examples\user_examples\my_application.py", line 35, in <module>
AttributeError: 'omni.isaac.dynamic_control._dynamic_control.Dynami' object has no attribute 'get_world'
How can I access the World handle then?
Thanks in advance!
