Bus Mastering DMA on Xavier NX
I’m working on Xavier NX that is connected to Xilinx FPGA through PCIe (Xavier NX as endpoint). I need to transfer buffer (say 12MB in size) between two boards (in both direction). I supposed to use bus mastering DMA on Xavier NX to perform this. But, I didn’t get any supported documents or similar examples on xavier side. Can anybody help me…?
Thanks all…
Sorry for the late response, is this still an issue to support? Thanks
Is there any documents or examples to do “bus mastering DMA over PCIe on xavier nx (xavier is endpoint)” ?
Thank you.
Refer to
  1. Tegra virtual Ethernet driver over PCIe
    kernel/nvidia/drivers/pci/endpoint/functions/pci-epf-tegra-vnet.c → EP driver
    kernel/nvidia/drivers/net/ethernet/nvidia/pcie/tegra_vnet.c → EP client driver in host
  2. PCIe DMA test driver which has simple directed test for both direct and linked list mode.
    kernel/nvidia/drivers/misc/tegra-pcie-ep-mem.c → EP client driver
  3. Refer to PCIE_DMA registers in PCIe IATU section of Xavier TRM.
Thanks,
Manikanta
