I would like to ask your advice about some devices that I will buy for my jetson xavier NX. My target is using that devices in SDK, open sources… of jetson xavier NX.
3 devices: Microphone, earphone bluetooth , usb spliter.
Microphone: I need fequence higher 16kHz , right? Because I check some topic they said jetson voice need microphone frequency higher 16kHZ.
Earphone bluetooth. i check in jetson docker docs
Through M.2 key E connector; customer must add Bluetooth hardware on production systems *
but i don’t understand. In amazon, I only see some things like bluetooth connectvity 5.0 or 5.1 , bluetooth connectvity 4.0 …
So which bluetooth connectvity suitable for jetson xavier NX ? Ooes it work with bluetooth connectivity 5.0? -
usb spliter : 4 usb ports on jetson is not enough for me so I want to expand number of usb port. Can I connect multiple camera… and use them in some SDK, open sources through usb spliter?
I have just read and collect some information from other topic and link. I really worry if I buy wrong devices and they will not work on jetson. I need you advice for 3 devices before I buy them.
Thank you so much.
Dat
