Hi, I have a doubt about the driver limitation of FFmpeg process you can run at the same time.
The limitation of only 2 works for NVENC: is per card or is per computer? if you have 2 gtx cards, can you run 4 works? could be better to have only one quadro card?
In my work we have to encode to several formats for streaming, normally we encode to 360 - 720 and 1080 (3 simultaneous ffmpeg process) , we make a parallel transcoding by CPU right now, but we want to use GPU because we made some tests and works very fast.
Can you help me to understand better this policy?
ps: Is true that a RTX can double the performance of the GTX 10X0 series in encoding?
