Hi, I use Jetpack 3.2.1, build caffe2 from source (tag v0.4.1), cuda9, cudnn7 on TX1.
I compiled and installed caffe2 successfully, and I run python caffe2 works well with GPU. Then I try to run caffe2 in C++ with GPU support, but c++ app runs ok, but no GPU usage. This code works well on my laptop with GPU support, I don’t know why, here is my code(https://github.com/zacario-li/caffe2_Cpp_example), hope anyone could help me. Many thanks.
Looks like this issue is duplicate to this comment:
https://devtalk.nvidia.com/default/topic/1030538/jetson-tx2/caffe2-on-jetson-tx2-gpu-support-/post/5274178/#5274178
JetPack3.1 includes CUDA 8.0.
If you want to have a CUDA 9.0 environment, please upgrade your JetPack to version 3.2.1/3.3.
https://developer.nvidia.com/embedded/jetpack-archive
Sorry for my mistake, my jetpack version is v3.2.1.
Thanks for the feedback.
We are try to reproduce this issue internally.
Will update information with you later.
We try to compile caffe2 to reproduce this issue but meet some error when cmaking.
Ex. Unknown CMake command “EXCLUDE” and “caffe2_interface_library”
Suppose you built caffe2 from source, could you share your steps with us?
So that we can check the GPU utilization issue directly.
hi,
what’s your build steps? I didn’t meet this issue. I just followed the offical website build guide. The build approximately took me 50 mins to finish it.
Not sure if you have compiled the correct architecture for TX1.
Could you echo the NVCC_FLAGS_EXTRA to check if sm_53 is well-included?
https://github.com/pytorch/pytorch/blob/master/cmake/public/cuda.cmake#L332
