I am trying to accelerate my code using OpenACC. I did not receive any compilation errors, however when running the code I receive the error “call to cuInit returned error -1: Other” when calling the first OpenACC directive.
In a similar forum topic it was mentioned that this might be due to the driver attempting to run the code on Linux on a “/dev/nvidia[0…n]” device that is not available. It was then suggested run pgaccelinfo as root and then switching back to the regular user.
(The forum topic I am referring to is What is "call to cuInit returned error 999: Unknown&quo )
Running pgaccelinfo as root yields
CUDA Driver Version: 6050
NVRM version: NVIDIA UNIX x86_64 Kernel Module 340.93 Wed Aug 19 16:49:15 PDT 2015
Device Number: 0
Device Name: Tesla K40c
Device Revision Number: 3.5
Global Memory Size: 12079136768
Number of Multiprocessors: 15
Number of SP Cores: 2880
Number of DP Cores: 960
Concurrent Copy and Execution: Yes
Total Constant Memory: 65536
Total Shared Memory per Block: 49152
Registers per Block: 65536
Warp Size: 32
Maximum Threads per Block: 1024
Maximum Block Dimensions: 1024, 1024, 64
Maximum Grid Dimensions: 2147483647 x 65535 x 65535
Maximum Memory Pitch: 2147483647B
Texture Alignment: 512B
Clock Rate: 745 MHz
Execution Timeout: No
Integrated Device: No
Can Map Host Memory: Yes
Compute Mode: default
Concurrent Kernels: Yes
ECC Enabled: Yes
Memory Clock Rate: 3004 MHz
Memory Bus Width: 384 bits
L2 Cache Size: 1572864 bytes
Max Threads Per SMP: 2048
Async Engines: 2
Unified Addressing: Yes
Managed Memory: Yes
PGI Compiler Option: -ta=tesla:cc35
though when switching back to a regular user and running pgaccelinfo again results in
No accelerators found.
and when running the code as a regular user I still receive the same error.
It turns out I can run my program as root with the accelerator, though I would like to be able to run my code as a regular user, too.
If anyone has an idea to what is happening and what I can do to omit changing to root in order to run my program, that will be highly appreciated.
Thanks and regards,
Nils
PS: I am using Ubuntu 14.04 and PGI 15.7
