Camera Bringup - AGX ORIN Industrial - FMON_NVCSI error
Hello Everyone,
I’m trying to run a camera on a custom board with the AGX Orin Industrial version. It works well on the commercial version within the devkit using a similar device tree and driver, but it’s not working on the industrial version with custom board. I’m using JetPack 36.4.
I am getting logs from FSI, but I’m not sure what they mean and can’t find any information on them. What could I be missing?
Serial port:
verify_rate_range : FMON_NVCSI: rate 10045312 below min 18750000
fmon_update_config: FMON_NVCSI: detected fault 0x80
LOG TRACE:
 CaptureSchedule-5927    [004] .......   180.918578: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
 CaptureSchedule-5927    [004] .......   180.918582: csi_s_power: enable : 0x1
 CaptureSchedule-5927    [004] .......   180.919605: tegra_channel_set_stream: enable : 0x1
 CaptureSchedule-5927    [004] .......   180.920367: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
 CaptureSchedule-5927    [004] .......   180.920371: csi_s_stream: enable : 0x1
 CaptureSchedule-5927    [004] .......   180.920372: tegra_channel_set_stream: imx678 1-001a : 0x1
 CaptureSchedule-5927    [004] .......   181.181281: vi_task_submit: class_id:48 ch:1 syncpt_id:49 syncpt_thresh:0 pid:5927 tid:1012
 CaptureSchedule-5927    [004] .......   181.197153: vi_task_submit: class_id:48 ch:1 syncpt_id:49 syncpt_thresh:0 pid:5927 tid:1012
 CaptureSchedule-5927    [004] .......   181.197301: vi_task_submit: class_id:48 ch:1 syncpt_id:49 syncpt_thresh:0 pid:5927 tid:1012
     kworker/5:1-81      [005] .......   181.197565: rtcpu_nvcsi_intr: tstamp:7164234948 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x10000000
     kworker/5:1-81      [005] .......   181.197568: rtcpu_nvcsi_intr: tstamp:7164235442 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000008
     kworker/5:1-81      [005] .......   181.197573: rtcpu_vinotify_event: tstamp:7164805818 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:229273548256 data:0x359cc80010000000
     kworker/5:1-81      [005] .......   181.197574: rtcpu_vinotify_event: tstamp:7164805957 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:229273553600 data:0x0000000031000001
     kworker/5:1-81      [005] .......   181.197575: rtcpu_vinotify_event: tstamp:7164806110 cch:1 vi:0 tag:VIFALC_ACTIONLST channel:0x0b frame:0 vi_tstamp:229273556128 data:0x0000000007020001
     kworker/5:1-81      [005] .......   181.253567: rtcpu_vinotify_event: tstamp:7165431789 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:229289409152 data:0x359cc50010000000
     kworker/5:1-81      [005] .......   181.253570: rtcpu_vinotify_event: tstamp:7165431953 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:229289414560 data:0x0000000031000002
 CaptureSchedule-5927    [006] .......   185.826129: tegra_channel_set_stream: enable : 0x0
 CaptureSchedule-5927    [006] .......   185.826134: tegra_channel_set_stream: imx678 1-001a : 0x0
     kworker/5:1-81      [005] .......   185.873539: rtcpu_nvcsi_intr: tstamp:7310929860 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000001
     kworker/5:1-81      [005] .......   185.873542: rtcpu_nvcsi_intr: tstamp:7310929860 class:GLOBAL type:PHY_INTR1 phy:0 cil:0 st:0 vc:0 status:0x00000125
     kworker/5:1-81      [005] .......   185.873542: rtcpu_nvcsi_intr: tstamp:7310929860 class:GLOBAL type:PHY_INTR1 phy:0 cil:1 st:0 vc:0 status:0x00000104
 CaptureSchedule-5927    [006] .......   185.901547: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
 CaptureSchedule-5927    [006] .......   185.901553: csi_s_stream: enable : 0x0```
DMESG:
[ 1071.581926] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 1071.581951] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 1071.583561] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
Thanks in advance
nvarguscamerasrc throws timeout:
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. gstnvarguscamerasrc.cpp, threadExecute:734 NvBufSurfaceFromFd Failed.
Error generated. gstnvarguscamerasrc.cpp, threadFunction:245 (propagating)
nvargus-daemon:
SCF: Error InvalidState: Sensor 0 already in same state
Feb 27 17:58:11 jetson-orin-ind nvargus-daemon[1142]: (in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
Feb 27 17:58:11 jetson-orin-ind nvargus-daemon[1142]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 0 draining session frameEnd events 3
Feb 27 17:58:11 jetson-orin-ind nvargus-daemon[1142]: (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 646)
Feb 27 17:58:11 jetson-orin-ind nvargus-daemon[1142]: SCF: Error InvalidState: Sensor 0 already in same state
Feb 27 17:58:11 jetson-orin-ind nvargus-daemon[1142]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 1 draining session frameEnd events 2
Feb 27 17:58:11 jetson-orin-ind nvargus-daemon[1142]: SCF: Error InvalidState: Sensor GUID 0 is in error state. Skipping requests, capture sequence ID = 1 continue draining session frameStart events 2
Feb 27 17:58:11 jetson-orin-ind nvargus-daemon[1142]: (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 543)
Feb 27 17:58:11 jetson-orin-ind nvargus-daemon[1142]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 2 draining session frameEnd events 1
Feb 27 17:58:11 jetson-orin-ind nvargus-daemon[1142]: Module_id 30 Severity 2 : (fusa) Error: Timeout propagating from:/capture/src/fusaViHandler.cpp 820
extended nvarus-daemon:
 SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 281470681743360 draining session frameStart events 15199644447408131
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]:  (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 529)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: SCF: Error InvalidState: Sensor GUID 0 is in error state. Skipping requests, capture sequence ID = 281470681743361 continue draining session frameStart events 15199644447408130
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]:  (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 543)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: SCF: Error InvalidState: Sensor GUID 0 is in error state. Skipping requests, capture sequence ID = 281470681743362 continue draining session frameStart events 15199644447408129
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: FiberScheduler: cc 101, session 0, fiber 0xffff44000b70 aborted in async operation
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: SCF: Error InvalidState: Sensor 0 already in same state
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]:  (in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 281470681743360 draining session frameEnd events 281470681743363
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]:  (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 646)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: returnBuffer: apiInput 0 and bufferIndex 0 and buffer 0xffff4c009910 and stream 0xffff4c001360 and instream (nil)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: Created fiber 0xffff44000fc0 for CC 103 globalID 103 session 0
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: CaptureService cancelling request 1
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: Session 0 aborting capture 103 (API ID: 3)FiberScheduler: cc 102, session 0, fiber 0xffff44000e20 aborted in async operation
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: returnBuffer: apiInput 0 and bufferIndex 0 and buffer 0xffff4c00b0d0 and stream 0xffff4c001360 and instream (nil)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: Session 0 aborting capture 102 (API ID: 2)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: Session 0 aborting capture 101 (API ID: 1)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: Thread 7 is working on CC 103 session 0 globalID 103 step 0, fiber: 0xffff44000fc0
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: Fiber 0xffff44000fc0 is aborting in CC 103 Session 0
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: FiberScheduler: cc 103 session 0, fiber 0xffff44000fc0 aborted
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: FiberScheduler: fiber 0xffff44000b70 exiting
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: FiberScheduler: fiber 0xffff44000e20 exiting
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: NvPclSettingsUpdate: Sending Updated Settings through PCL
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: NvPclSettingsApply: Applying last settings through PCL
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: disposing CC 102 Session 0
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 0, capture sequence ID = 281470681743361 draining session frameEnd events 281470681743362
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: apply:+++++++++++++++++++++++
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: returnBuffer: apiInput 0 and bufferIndex 4 and buffer 0xffff3001e010 and stream (nil) and instream (nil)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: returnBuffer: apiInput 0 and bufferIndex 5 and buffer 0xffff3001f0b0 and stream (nil) and instream (nil)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: disposing CC 101 Session 0
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: returnBuffer: apiInput 0 and bufferIndex 4 and buffer 0xffff3802b600 and stream (nil) and instream (nil)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: returnBuffer: apiInput 0 and bufferIndex 5 and buffer 0xffff3802c6a0 and stream (nil) and instream (nil)
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: Thread 8 is waiting
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: FiberScheduler: fiber 0xffff44000fc0 exiting
Feb 27 18:02:44 jetson-orin-ind nvargus-daemon[9476]: Thread 9 is waitingSCF: Error InvalidState: Sensor 0 already in same state
The error tell the data/clock lane control have problem. Looks like the sensor output signal have problem.
Please probe the signal to confirm.
Thank you, that makes sense. The camera started working in 2-lane mode. I’ll test the other 2 lanes to determine what might be wrong with them.
What about those logs from FSI? Do you know if this is something important, or can it be ignored?
Suppose it’s sensor driver message.
I don’t have idea about it.
