I am using libargus to capture frames via DMA from a stereo camera. I am trying to construct a VPIImage from the frame, accessible to the VIC (bonus points for OFA and PVA as well) in the most efficient way possible (preferably ISP only, no CPU or VIC utilization to do so).
Potential input paths:
The DMA buffer file descriptor. Not sure if there’s anything I can do with this directly, but it seems plausible that I should be able to wrap it with a VPIImage. Or perhaps first wrap it in NvBuffer, then wrap with VPIImage.
An
EGLStream::Frame. I can get this by configuring the argusOutputStreamasSTREAM_TYPE_EGL, then grabbing frames via a consumer.
EGLStream::IFrameConsumer* consumer =
Argus::interface_cast<EGLStream::IFrameConsumer>(cam.consumer);
Argus::UniqueObj<EGLStream::Frame> frame(consumer->acquireFrame());
From this I can copy to NvBuffer using IImageNativeBuffer::copyToNvBuffer as is done in libargus samples. NvBuffer can be converted to VPIImage (at least theoretically, haven’t figured out the NvBuffer -->VPIImage conversion yet). The performance of this option is poor, and I haven’t even made the VPIImage yet. Copying the Frame to NvBuffer uses ~15% of the VIC per camera @30fps 1920x1200. I have 8 cameras and other algorithms I want to run on the VIC so the copy isn’t tenable.
- EGLImageKHR. This is the most efficient method I have found so far. I can accomplish this by configuring the stream as such:
Argus::UniqueObj<Argus::OutputStreamSettings> stream_settings(
isession->createOutputStreamSettings(Argus::STREAM_TYPE_BUFFER));
auto istream_settings =
Argus::interface_cast<Argus::IBufferOutputStreamSettings>(stream_settings);
istream_settings->setBufferType(Argus::BUFFER_TYPE_EGL_IMAGE);
Acquiring the filled buffer returns an Argus::Buffer which can be casted to EGLImageKHR. Wrapping in VPIImage can then be done like so:
VPIImageData data;
data.bufferType = VPI_IMAGE_BUFFER_EGLIMAGE;
data.buffer.egl = egl_image;
vpiImageCreateWrapper(&data, nullptr, VPI_BACKEND_VIC | VPI_RESTRICT_MEM_USAGE, &vpi_image);
Calling the vpiImageCreateWrapper uses ~5-10% of the CPU @30fps 1920x1200. Are there any tweaks I can make to this method, perhaps to buffer allocation that will allow the buffers to be used on the VIC (or other accelerators) without any memory operations when wrapping? Maybe I am being overly optimistic but video encode can be done without the CPU, so I was hopeful I could feed images directly to VIC, OFA, etc. without the CPU as well.
Any guidance is appreciated!
