Camera is stuck after a while and I cannot figure out why
Hey there.
I am having a problem that I cannot seem to wrap my head around and need some guidance.
I am running a dual camera system on a Jetson Xavier on a JP4.3 and so far it seems that when I run the second camera (the one on /dev/video1) at some point the stream is stuck. If I switch the cameras physically the issue persists and it is always related to /dev/video1) so I have excluded the possibility of having a faulty model.
Still I can’t seem to figure out what’s causing the problem so any help is highly appreciated.
I took a trace and here is it:
Trace
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
     kworker/0:2-1637  [000] ....    90.439147: rtos_queue_peek_from_isr_failed: tstamp:3146936674 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    90.607117: rtos_queue_peek_from_isr_failed: tstamp:3151936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    90.775088: rtos_queue_peek_from_isr_failed: tstamp:3156936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    90.943124: rtos_queue_peek_from_isr_failed: tstamp:3161936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    91.111074: rtos_queue_peek_from_isr_failed: tstamp:3166936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    91.279304: rtos_queue_peek_from_isr_failed: tstamp:3171936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    91.447122: rtos_queue_peek_from_isr_failed: tstamp:3176936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    91.559094: rtos_queue_peek_from_isr_failed: tstamp:3181936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    91.727316: rtos_queue_peek_from_isr_failed: tstamp:3186936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    91.895099: rtos_queue_peek_from_isr_failed: tstamp:3191936662 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    92.063069: rtos_queue_peek_from_isr_failed: tstamp:3196936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    92.231063: rtos_queue_peek_from_isr_failed: tstamp:3201936671 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    92.399059: rtos_queue_peek_from_isr_failed: tstamp:3206936622 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    92.567091: rtos_queue_peek_from_isr_failed: tstamp:3211936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    92.679075: rtos_queue_peek_from_isr_failed: tstamp:3216936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    92.847106: rtos_queue_peek_from_isr_failed: tstamp:3221936671 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    93.015092: rtos_queue_peek_from_isr_failed: tstamp:3226936666 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    93.183062: rtos_queue_peek_from_isr_failed: tstamp:3231936671 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    93.351020: rtos_queue_peek_from_isr_failed: tstamp:3236936622 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    93.519024: rtos_queue_peek_from_isr_failed: tstamp:3241936623 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    93.691029: rtos_queue_peek_from_isr_failed: tstamp:3246936625 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    93.803000: rtos_queue_peek_from_isr_failed: tstamp:3251936622 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    93.970986: rtos_queue_peek_from_isr_failed: tstamp:3256936623 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    94.138977: rtos_queue_peek_from_isr_failed: tstamp:3261936622 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    94.306992: rtos_queue_peek_from_isr_failed: tstamp:3266936623 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    94.478996: rtos_queue_peek_from_isr_failed: tstamp:3271936625 queue:0x0bcbcf78
     kworker/0:2-1637  [000] ....    94.647075: rtos_queue_peek_from_isr_failed: tstamp:3276936625 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    94.758990: rtos_queue_peek_from_isr_failed: tstamp:3281936623 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    94.926957: rtos_queue_peek_from_isr_failed: tstamp:3286936622 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    95.095005: rtos_queue_peek_from_isr_failed: tstamp:3291936626 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    95.262962: rtos_queue_peek_from_isr_failed: tstamp:3296936618 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    95.322962: rtos_queue_peek_from_isr_failed: tstamp:3298355228 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    99.098874: rtos_queue_peek_from_isr_failed: tstamp:3416275491 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    99.098879: rtcpu_start: tstamp:3416276718
     kworker/0:0-4     [000] ....    99.098881: rtos_queue_send_from_isr_failed: tstamp:3416285153 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.098881: rtos_queue_send_from_isr_failed: tstamp:3416285290 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.098882: rtos_queue_send_from_isr_failed: tstamp:3416285427 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.098883: rtos_queue_send_from_isr_failed: tstamp:3416285560 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.098884: rtos_queue_send_from_isr_failed: tstamp:3416285692 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.098908: rtcpu_string: tstamp:3416286109 id:0x04010000 str:"Configuring ISP GoS.
     kworker/0:0-4     [000] ....    99.098941: rtcpu_string: tstamp:3416286273 id:0x04010000 str:"  VM GOS[#0] addr=0xc2100000
     kworker/0:0-4     [000] ....    99.098951: rtcpu_string: tstamp:3416286517 id:0x04010000 str:"  VM GOS[#1] addr=0xc2101000
     kworker/0:0-4     [000] ....    99.098959: rtcpu_string: tstamp:3416286769 id:0x04010000 str:"  VM GOS[#2] addr=0xc2102000
     kworker/0:0-4     [000] ....    99.098966: rtcpu_string: tstamp:3416286992 id:0x04010000 str:"  VM GOS[#3] addr=0xc2103000
     kworker/0:0-4     [000] ....    99.098973: rtcpu_string: tstamp:3416287213 id:0x04010000 str:"  VM GOS[#4] addr=0xc2104000
     kworker/0:0-4     [000] ....    99.098981: rtcpu_string: tstamp:3416287435 id:0x04010000 str:"  VM GOS[#5] addr=0xc2105000
     kworker/0:0-4     [000] ....    99.098988: rtcpu_string: tstamp:3416298421 id:0x04010000 str:"WARNING: t194/isp5.c:901 [config_channel] ""
     kworker/0:0-4     [000] ....    99.098989: rtcpu_string: tstamp:3416298781 id:0x04010000 str:"All error notifications not enabled: correctable"
     kworker/0:0-4     [000] ....    99.098991: rtcpu_string: tstamp:3416298886 id:0x04010000 str:"=0x00 uncorrectable=0x00"
     kworker/0:0-4     [000] ....    99.098992: rtcpu_string: tstamp:3416299066 id:0x04010000 str:"""
     kworker/0:0-4     [000] ....    99.266855: rtos_queue_peek_from_isr_failed: tstamp:3421275848 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    99.326840: rtos_queue_send_from_isr_failed: tstamp:3424132006 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.326845: rtos_queue_send_from_isr_failed: tstamp:3424132146 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.326846: rtos_queue_send_from_isr_failed: tstamp:3424132283 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.326847: rtos_queue_send_from_isr_failed: tstamp:3424132417 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.326847: rtos_queue_send_from_isr_failed: tstamp:3424132549 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.326849: rtcpu_string: tstamp:3424132956 id:0x04010000 str:"Configuring VI GoS."
     kworker/0:0-4     [000] ....    99.326874: rtcpu_string: tstamp:3424133117 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000"
     kworker/0:0-4     [000] ....    99.326881: rtcpu_string: tstamp:3424133353 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000"
     kworker/0:0-4     [000] ....    99.326888: rtcpu_string: tstamp:3424133602 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000"
     kworker/0:0-4     [000] ....    99.326894: rtcpu_string: tstamp:3424133821 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000"
     kworker/0:0-4     [000] ....    99.326900: rtcpu_string: tstamp:3424134040 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000"
     kworker/0:0-4     [000] ....    99.326905: rtcpu_string: tstamp:3424134261 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000"
     kworker/0:0-4     [000] ....    99.326911: rtcpu_string: tstamp:3424141730 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
     kworker/0:0-4     [000] ....    99.326914: rtcpu_string: tstamp:3424141835 id:0x04010000 str:"on 2.2"
     kworker/0:0-4     [000] ....    99.326920: rtos_queue_send_from_isr_failed: tstamp:3424152798 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.326921: rtos_queue_send_from_isr_failed: tstamp:3424152951 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.326921: rtos_queue_send_from_isr_failed: tstamp:3424153091 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.326922: rtos_queue_send_from_isr_failed: tstamp:3424153223 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.326929: rtos_queue_send_from_isr_failed: tstamp:3424153357 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.382842: rtos_queue_peek_from_isr_failed: tstamp:3426275844 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    99.550850: rtos_queue_send_from_isr_failed: tstamp:3431054843 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.550855: rtos_queue_send_from_isr_failed: tstamp:3431054979 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.550856: rtos_queue_send_from_isr_failed: tstamp:3431055118 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.550856: rtos_queue_send_from_isr_failed: tstamp:3431055250 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.550857: rtos_queue_send_from_isr_failed: tstamp:3431055385 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.550858: rtos_queue_send_from_isr_failed: tstamp:3431055574 queue:0x0bcb4190
     kworker/0:0-4     [000] ....    99.550863: rtos_queue_send_from_isr_failed: tstamp:3431055700 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.550864: rtos_queue_send_from_isr_failed: tstamp:3431055826 queue:0x0bcb89f8
     kworker/0:0-4     [000] ....    99.550865: rtos_queue_send_from_isr_failed: tstamp:3431055952 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.550866: rtos_queue_send_from_isr_failed: tstamp:3431056076 queue:0x0bcba578
     kworker/0:0-4     [000] ....    99.550867: rtos_queue_send_from_isr_failed: tstamp:3431056195 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.550867: rtos_queue_send_from_isr_failed: tstamp:3431056319 queue:0x0bcbb338
     kworker/0:0-4     [000] ....    99.550868: rtos_queue_send_from_isr_failed: tstamp:3431056439 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.550869: rtos_queue_send_from_isr_failed: tstamp:3431056561 queue:0x0bcbc0f8
     kworker/0:0-4     [000] ....    99.550870: rtos_queue_send_from_isr_failed: tstamp:3431056680 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.550870: rtos_queue_send_from_isr_failed: tstamp:3431085364 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.550871: rtos_queue_send_from_isr_failed: tstamp:3431085503 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.550872: rtos_queue_send_from_isr_failed: tstamp:3431085640 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.550872: rtos_queue_send_from_isr_failed: tstamp:3431085774 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.550873: rtos_queue_send_from_isr_failed: tstamp:3431085906 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.550874: rtos_queue_send_from_isr_failed: tstamp:3431089240 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.550875: rtos_queue_send_from_isr_failed: tstamp:3431089375 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.550875: rtos_queue_send_from_isr_failed: tstamp:3431089511 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.550876: rtos_queue_send_from_isr_failed: tstamp:3431089643 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.550877: rtos_queue_send_from_isr_failed: tstamp:3431089778 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.550877: rtos_queue_send_from_isr_failed: tstamp:3431196306 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.550878: rtos_queue_send_from_isr_failed: tstamp:3431196444 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.550879: rtos_queue_send_from_isr_failed: tstamp:3431196583 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.550880: rtos_queue_send_from_isr_failed: tstamp:3431196717 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.550880: rtos_queue_send_from_isr_failed: tstamp:3431196863 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.550883: rtcpu_string: tstamp:3431197256 id:0x04010000 str:"Configuring VI GoS."
     kworker/0:0-4     [000] ....    99.550944: rtcpu_string: tstamp:3431197418 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000"
     kworker/0:0-4     [000] ....    99.550958: rtcpu_string: tstamp:3431197661 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000"
     kworker/0:0-4     [000] ....    99.550964: rtcpu_string: tstamp:3431197910 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000"
     kworker/0:0-4     [000] ....    99.550969: rtcpu_string: tstamp:3431198130 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000"
     kworker/0:0-4     [000] ....    99.550974: rtcpu_string: tstamp:3431198348 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000"
     kworker/0:0-4     [000] ....    99.550979: rtcpu_string: tstamp:3431198567 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000"
     kworker/0:0-4     [000] ....    99.550984: rtos_queue_send_from_isr_failed: tstamp:3431202159 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.550985: rtos_queue_send_from_isr_failed: tstamp:3431202308 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.550986: rtos_queue_send_from_isr_failed: tstamp:3431202444 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.550987: rtos_queue_send_from_isr_failed: tstamp:3431202579 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.550987: rtos_queue_send_from_isr_failed: tstamp:3431202711 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.550988: rtos_queue_send_from_isr_failed: tstamp:3431207584 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.550989: rtos_queue_send_from_isr_failed: tstamp:3431207719 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.550990: rtos_queue_send_from_isr_failed: tstamp:3431207855 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.550990: rtos_queue_send_from_isr_failed: tstamp:3431207989 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.550991: rtos_queue_send_from_isr_failed: tstamp:3431208121 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.550993: rtos_queue_peek_from_isr_failed: tstamp:3431275843 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    99.662854: rtos_queue_send_from_isr_failed: tstamp:3434746408 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.662858: rtos_queue_send_from_isr_failed: tstamp:3434746547 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.662879: rtos_queue_send_from_isr_failed: tstamp:3434746684 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.662880: rtos_queue_send_from_isr_failed: tstamp:3434746819 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.662881: rtos_queue_send_from_isr_failed: tstamp:3434746957 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.662883: rtcpu_string: tstamp:3434747750 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000"
     kworker/0:0-4     [000] ....    99.662909: rtcpu_vinotify_error: tstamp:3434751644 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3434748527 data:0x00010000
     kworker/0:0-4     [000] ....    99.662910: rtcpu_vinotify_event: tstamp:3434754232 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:3434748527 data:0x00010000
     kworker/0:0-4     [000] ....    99.718854: rtcpu_vinotify_event: tstamp:3435240779 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2537974656 data:0x10000000
     kworker/0:0-4     [000] ....    99.718857: rtcpu_vinotify_event: tstamp:3435240931 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2538001088 data:0x31000001
     kworker/0:0-4     [000] ....    99.718858: rtcpu_vinotify_event: tstamp:3435241058 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2538008864 data:0x07020001
     kworker/0:0-4     [000] ....    99.718865: rtos_queue_send_from_isr_failed: tstamp:3435791666 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.718866: rtos_queue_send_from_isr_failed: tstamp:3435791809 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.718866: rtos_queue_send_from_isr_failed: tstamp:3435791950 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.718867: rtos_queue_send_from_isr_failed: tstamp:3435792082 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.718885: rtos_queue_send_from_isr_failed: tstamp:3435792216 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.718886: rtos_queue_send_from_isr_failed: tstamp:3435805797 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.718886: rtos_queue_send_from_isr_failed: tstamp:3435805934 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.718887: rtos_queue_send_from_isr_failed: tstamp:3435806072 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.718888: rtos_queue_send_from_isr_failed: tstamp:3435806207 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.718888: rtos_queue_send_from_isr_failed: tstamp:3435806339 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.718889: rtcpu_vinotify_event: tstamp:3436217549 tag:FS channel:0x00 frame:0 vi_tstamp:3435772872 data:0x00000014
     kworker/0:0-4     [000] ....    99.718890: rtcpu_vinotify_event: tstamp:3436217684 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3435772875 data:0x00000000
     kworker/0:0-4     [000] ....    99.718891: rtcpu_vinotify_event: tstamp:3436217833 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3435773295 data:0x00000001
     kworker/0:0-4     [000] ....    99.718891: rtcpu_vinotify_event: tstamp:3436217960 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2570566848 data:0x08020001
     kworker/0:0-4     [000] ....    99.718892: rtcpu_vinotify_event: tstamp:3436218102 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2571261376 data:0x10000000
     kworker/0:0-4     [000] ....    99.718893: rtcpu_vinotify_event: tstamp:3436218225 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2571288128 data:0x31000002
     kworker/0:0-4     [000] ....    99.718894: rtos_queue_peek_from_isr_failed: tstamp:3436275844 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    99.718895: rtcpu_vinotify_event: tstamp:3436499184 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3436494549 data:0x077f0002
     kworker/0:0-4     [000] ....    99.718896: rtcpu_vinotify_event: tstamp:3436499313 tag:FE channel:0x00 frame:0 vi_tstamp:3436494569 data:0x00000024
     kworker/0:0-4     [000] ....    99.718896: rtcpu_vinotify_event: tstamp:3436499459 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3436494571 data:0x00000000
     kworker/0:0-4     [000] ....    99.718897: rtcpu_vinotify_event: tstamp:3436499581 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3436494573 data:0x00000000
     kworker/0:0-4     [000] ....    99.718898: rtcpu_vinotify_event: tstamp:3436499721 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2593662240 data:0x02020001
     kworker/0:0-4     [000] ....    99.718898: rtcpu_vinotify_event: tstamp:3436499843 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2593673280 data:0x00020001
     kworker/0:0-4     [000] ....    99.718900: rtos_queue_send_from_isr_failed: tstamp:3436837360 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.718901: rtos_queue_send_from_isr_failed: tstamp:3436837515 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.718901: rtos_queue_send_from_isr_failed: tstamp:3436837658 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.718902: rtos_queue_send_from_isr_failed: tstamp:3436837792 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.718903: rtos_queue_send_from_isr_failed: tstamp:3436837925 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.718903: rtcpu_vinotify_event: tstamp:3436949872 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2593698912 data:0x07020002
     kworker/0:0-4     [000] ....    99.718904: rtcpu_vinotify_event: tstamp:3436950003 tag:FS channel:0x00 frame:0 vi_tstamp:3436814545 data:0x00000014
     kworker/0:0-4     [000] ....    99.718905: rtcpu_vinotify_event: tstamp:3436950153 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3436814547 data:0x00000000
     kworker/0:0-4     [000] ....    99.718906: rtcpu_vinotify_event: tstamp:3436950276 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3436814968 data:0x00000001
     kworker/0:0-4     [000] ....    99.718906: rtcpu_vinotify_event: tstamp:3436950416 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2603900384 data:0x08020002
     kworker/0:0-4     [000] ....    99.718907: rtcpu_vinotify_event: tstamp:3436950538 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2604070080 data:0x10000000
     kworker/0:0-4     [000] ....    99.718908: rtcpu_vinotify_event: tstamp:3436950678 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2604096832 data:0x31000003
     kworker/0:0-4     [000] ....    99.775003: rtcpu_vinotify_event: tstamp:3437860180 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3437536222 data:0x077f0002
     kworker/0:0-4     [000] ....    99.775007: rtcpu_vinotify_event: tstamp:3437860324 tag:FE channel:0x00 frame:0 vi_tstamp:3437536241 data:0x00000024
     kworker/0:0-4     [000] ....    99.775008: rtcpu_vinotify_event: tstamp:3437860455 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3437536244 data:0x00000000
     kworker/0:0-4     [000] ....    99.775009: rtcpu_vinotify_event: tstamp:3437860598 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3437536245 data:0x00000000
     kworker/0:0-4     [000] ....    99.775010: rtcpu_vinotify_event: tstamp:3437860722 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2626995744 data:0x02020002
     kworker/0:0-4     [000] ....    99.775010: rtcpu_vinotify_event: tstamp:3437860862 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2627006784 data:0x00020002
     kworker/0:0-4     [000] ....    99.775011: rtcpu_vinotify_event: tstamp:3437860984 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2627026432 data:0x07020003
     kworker/0:0-4     [000] ....    99.775012: rtcpu_vinotify_event: tstamp:3437861123 tag:FS channel:0x00 frame:0 vi_tstamp:3437856217 data:0x00000014
     kworker/0:0-4     [000] ....    99.775013: rtcpu_vinotify_event: tstamp:3437861250 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3437856219 data:0x00000000
     kworker/0:0-4     [000] ....    99.775016: rtos_queue_send_from_isr_failed: tstamp:3437880433 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.775017: rtos_queue_send_from_isr_failed: tstamp:3437880574 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.775017: rtos_queue_send_from_isr_failed: tstamp:3437880714 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.775018: rtos_queue_send_from_isr_failed: tstamp:3437880848 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.775019: rtos_queue_send_from_isr_failed: tstamp:3437880980 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.775039: rtcpu_vinotify_event: tstamp:3438317045 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3437856640 data:0x00000001
     kworker/0:0-4     [000] ....    99.775040: rtcpu_vinotify_event: tstamp:3438317173 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2637237248 data:0x08020003
     kworker/0:0-4     [000] ....    99.775041: rtcpu_vinotify_event: tstamp:3438317317 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2637468288 data:0x10000000
     kworker/0:0-4     [000] ....    99.775041: rtcpu_vinotify_event: tstamp:3438317438 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2637495040 data:0x31000004
     kworker/0:0-4     [000] ....    99.830846: rtos_queue_send_from_isr_failed: tstamp:3438733362 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.830850: rtos_queue_send_from_isr_failed: tstamp:3438733506 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.830870: rtos_queue_send_from_isr_failed: tstamp:3438733646 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.830870: rtos_queue_send_from_isr_failed: tstamp:3438733785 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.830871: rtos_queue_send_from_isr_failed: tstamp:3438733917 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.830873: rtcpu_string: tstamp:3438735748 id:0x04010000 str:"ISP GOS[#0] set to VM GOS[5] base 0xc2105000"
     kworker/0:0-4     [000] ....    99.830902: rtcpu_vinotify_event: tstamp:3438805504 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3438577895 data:0x077f0002
     kworker/0:0-4     [000] ....    99.830903: rtcpu_vinotify_event: tstamp:3438805635 tag:FE channel:0x00 frame:0 vi_tstamp:3438577914 data:0x00000024
     kworker/0:0-4     [000] ....    99.830904: rtcpu_vinotify_event: tstamp:3438805783 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3438577916 data:0x00000000
     kworker/0:0-4     [000] ....    99.830905: rtcpu_vinotify_event: tstamp:3438805909 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3438577919 data:0x00000000
     kworker/0:0-4     [000] ....    99.830905: rtcpu_vinotify_event: tstamp:3438806054 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2660329280 data:0x02020003
     kworker/0:0-4     [000] ....    99.830906: rtcpu_vinotify_event: tstamp:3438806176 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2660340320 data:0x00020003
     kworker/0:0-4     [000] ....    99.830907: rtcpu_vinotify_event: tstamp:3438806317 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2660360000 data:0x07020004
     kworker/0:0-4     [000] ....    99.833896: rtcpu_vinotify_event: tstamp:3438906158 tag:FS channel:0x00 frame:0 vi_tstamp:3438897891 data:0x00000014
     kworker/0:0-4     [000] ....    99.833898: rtcpu_vinotify_event: tstamp:3438906310 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3438897893 data:0x00000000
     kworker/0:0-4     [000] ....    99.833899: rtcpu_vinotify_event: tstamp:3438906435 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3438898313 data:0x00000001
     kworker/0:0-4     [000] ....    99.833900: rtcpu_vinotify_event: tstamp:3438906591 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2670567424 data:0x08020004
     kworker/0:0-4     [000] ....    99.833901: rtcpu_vinotify_event: tstamp:3438906713 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2670746016 data:0x10000000
     kworker/0:0-4     [000] ....    99.833902: rtos_queue_send_from_isr_failed: tstamp:3438919980 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.833903: rtos_queue_send_from_isr_failed: tstamp:3438920123 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.833917: rtos_queue_send_from_isr_failed: tstamp:3438920262 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.833917: rtos_queue_send_from_isr_failed: tstamp:3438920407 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.833918: rtos_queue_send_from_isr_failed: tstamp:3438920539 queue:0x0bcbc160
     kworker/0:0-4     [000] ....    99.924057: rtcpu_vinotify_event: tstamp:3439391224 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2670852832 data:0x31000005
     kworker/0:0-4     [000] ....    99.924062: rtos_queue_send_from_isr_failed: tstamp:3439674598 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....    99.924063: rtos_queue_send_from_isr_failed: tstamp:3439674739 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....    99.924064: rtos_queue_send_from_isr_failed: tstamp:3439674879 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....    99.924065: rtos_queue_send_from_isr_failed: tstamp:3439675014 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....    99.924066: rtos_queue_send_from_isr_failed: tstamp:3439675146 queue:0x0bcbc160
     kworker/0:0-4     [000] ....   100.034664: rtcpu_vinotify_event: tstamp:3439879909 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3439619567 data:0x077f0002
     kworker/0:0-4     [000] ....   100.034687: rtcpu_vinotify_event: tstamp:3439880054 tag:FE channel:0x00 frame:0 vi_tstamp:3439619587 data:0x00000024
     kworker/0:0-4     [000] ....   100.034688: rtcpu_vinotify_event: tstamp:3439880184 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3439619589 data:0x00000000
     kworker/0:0-4     [000] ....   100.034689: rtcpu_vinotify_event: tstamp:3439880328 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3439619591 data:0x00000000
     kworker/0:0-4     [000] ....   100.034689: rtcpu_vinotify_event: tstamp:3439880451 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2693662784 data:0x02020004
     kworker/0:0-4     [000] ....   100.034690: rtcpu_vinotify_event: tstamp:3439880591 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2693673824 data:0x00020004
     kworker/0:0-4     [000] ....   100.034691: rtcpu_vinotify_event: tstamp:3439880713 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2693693472 data:0x07020005
     kworker/0:0-4     [000] ....   100.126451: rtos_queue_send_from_isr_failed: tstamp:3439955626 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....   100.126455: rtos_queue_send_from_isr_failed: tstamp:3439955770 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....   100.126456: rtos_queue_send_from_isr_failed: tstamp:3439955909 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....   100.126456: rtos_queue_send_from_isr_failed: tstamp:3439956041 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....   100.126457: rtos_queue_send_from_isr_failed: tstamp:3439956172 queue:0x0bcbc160
     kworker/0:0-4     [000] ....   100.126459: rtcpu_vinotify_event: tstamp:3440367873 tag:FS channel:0x00 frame:0 vi_tstamp:3439939563 data:0x00000014
     kworker/0:0-4     [000] ....   100.126460: rtcpu_vinotify_event: tstamp:3440368010 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3439939566 data:0x00000000
     kworker/0:0-4     [000] ....   100.126460: rtcpu_vinotify_event: tstamp:3440368160 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3439939986 data:0x00000001
     kworker/0:0-4     [000] ....   100.126461: rtcpu_vinotify_event: tstamp:3440368284 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2703900992 data:0x08020005
     kworker/0:0-4     [000] ....   100.126462: rtcpu_vinotify_event: tstamp:3440368426 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2704071488 data:0x10000000
     kworker/0:0-4     [000] ....   100.126478: rtcpu_vinotify_event: tstamp:3440368548 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2704098240 data:0x31000006
     kworker/0:0-4     [000] ....   100.178840: rtcpu_vinotify_event: tstamp:3440665880 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3440661241 data:0x077f0002
     kworker/0:0-4     [000] ....   100.178845: rtcpu_vinotify_event: tstamp:3440666007 tag:FE channel:0x00 frame:0 vi_tstamp:3440661259 data:0x00000024
     kworker/0:0-4     [000] ....   100.178872: rtos_queue_send_from_isr_failed: tstamp:3440889306 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....   100.178874: rtos_queue_send_from_isr_failed: tstamp:3440889446 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....   100.178874: rtos_queue_send_from_isr_failed: tstamp:3440889585 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....   100.178875: rtos_queue_send_from_isr_failed: tstamp:3440889717 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....   100.178876: rtos_queue_send_from_isr_failed: tstamp:3440889850 queue:0x0bcbc160
     kworker/0:0-4     [000] ....   100.218874: rtos_queue_send_from_isr_failed: tstamp:3441045429 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....   100.218878: rtos_queue_send_from_isr_failed: tstamp:3441045573 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....   100.218879: rtos_queue_send_from_isr_failed: tstamp:3441045713 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....   100.218879: rtos_queue_send_from_isr_failed: tstamp:3441045845 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....   100.218880: rtos_queue_send_from_isr_failed: tstamp:3441045979 queue:0x0bcbc160
     kworker/0:0-4     [000] ....   100.311092: rtcpu_vinotify_event: tstamp:3441149726 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3440661262 data:0x00000000
     kworker/0:0-4     [000] ....   100.311096: rtcpu_vinotify_event: tstamp:3441149856 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3440661264 data:0x00000000
     kworker/0:0-4     [000] ....   100.311097: rtcpu_vinotify_event: tstamp:3441150000 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2727001664 data:0x02020005
     kworker/0:0-4     [000] ....   100.311097: rtcpu_vinotify_event: tstamp:3441150123 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2727012992 data:0x00020005
     kworker/0:0-4     [000] ....   100.311098: rtcpu_vinotify_event: tstamp:3441150263 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2727033056 data:0x07020006
     kworker/0:0-4     [000] ....   100.311099: rtcpu_vinotify_event: tstamp:3441150388 tag:FS channel:0x00 frame:0 vi_tstamp:3440981236 data:0x00000014
     kworker/0:0-4     [000] ....   100.311100: rtcpu_vinotify_event: tstamp:3441150532 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3440981238 data:0x00000000
     kworker/0:0-4     [000] ....   100.311100: rtcpu_vinotify_event: tstamp:3441150656 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3440981658 data:0x00000001
     kworker/0:0-4     [000] ....   100.311101: rtcpu_vinotify_event: tstamp:3441150796 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2737234496 data:0x08020006
     kworker/0:0-4     [000] ....   100.311102: rtcpu_vinotify_event: tstamp:3441150918 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2737412192 data:0x10000000
     kworker/0:0-4     [000] ....   100.311102: rtcpu_vinotify_event: tstamp:3441151058 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2737438944 data:0x31000007
     kworker/0:0-4     [000] ....   100.311105: rtos_queue_peek_from_isr_failed: tstamp:3441275845 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....   100.311105: rtcpu_vinotify_event: tstamp:3441707614 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3441702913 data:0x077f0002
     kworker/0:0-4     [000] ....   100.311106: rtcpu_vinotify_event: tstamp:3441707763 tag:FE channel:0x00 frame:0 vi_tstamp:3441702932 data:0x00000024
     kworker/0:0-4     [000] ....   100.311107: rtcpu_vinotify_event: tstamp:3441707895 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3441702935 data:0x00000000
     kworker/0:0-4     [000] ....   100.311107: rtcpu_vinotify_event: tstamp:3441708042 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3441702936 data:0x00000000
     kworker/0:0-4     [000] ....   100.311108: rtcpu_vinotify_event: tstamp:3441708165 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2760329888 data:0x02020006
     kworker/0:0-4     [000] ....   100.311111: rtos_queue_send_from_isr_failed: tstamp:3442141936 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....   100.311129: rtos_queue_send_from_isr_failed: tstamp:3442142081 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....   100.311129: rtos_queue_send_from_isr_failed: tstamp:3442142222 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....   100.311130: rtos_queue_send_from_isr_failed: tstamp:3442142357 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....   100.311131: rtos_queue_send_from_isr_failed: tstamp:3442142490 queue:0x0bcbc160
     kworker/0:0-4     [000] ....   100.311131: rtcpu_vinotify_event: tstamp:3442174466 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2760346496 data:0x00020006
     kworker/0:0-4     [000] ....   100.311132: rtcpu_vinotify_event: tstamp:3442174595 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2760366560 data:0x07020007
     kworker/0:0-4     [000] ....   100.311133: rtcpu_vinotify_event: tstamp:3442174743 tag:FS channel:0x00 frame:0 vi_tstamp:3442022908 data:0x00000014
     kworker/0:0-4     [000] ....   100.311133: rtcpu_vinotify_event: tstamp:3442174873 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3442022910 data:0x00000000
     kworker/0:0-4     [000] ....   100.311134: rtcpu_vinotify_event: tstamp:3442175018 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3442023331 data:0x00000001
     kworker/0:0-4     [000] ....   100.311135: rtcpu_vinotify_event: tstamp:3442175178 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2770568000 data:0x08020007
     kworker/0:0-4     [000] ....   100.311136: rtcpu_vinotify_event: tstamp:3442175319 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2770727200 data:0x10000000
     kworker/0:0-4     [000] ....   100.311136: rtcpu_vinotify_event: tstamp:3442175440 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2770753952 data:0x31000008
     kworker/0:0-4     [000] ....   100.311137: rtcpu_vinotify_event: tstamp:3443068545 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3442744585 data:0x077f0002
     kworker/0:0-4     [000] ....   100.311138: rtcpu_vinotify_event: tstamp:3443068672 tag:FE channel:0x00 frame:0 vi_tstamp:3442744605 data:0x00000024
     kworker/0:0-4     [000] ....   100.311139: rtcpu_vinotify_event: tstamp:3443068817 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3442744607 data:0x00000000
     kworker/0:0-4     [000] ....   100.311139: rtcpu_vinotify_event: tstamp:3443068943 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3442744609 data:0x00000000
     kworker/0:0-4     [000] ....   100.311140: rtcpu_vinotify_event: tstamp:3443069084 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2793663360 data:0x02020007
     kworker/0:0-4     [000] ....   100.311141: rtcpu_vinotify_event: tstamp:3443069206 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2793674400 data:0x00020007
     kworker/0:0-4     [000] ....   100.311141: rtcpu_vinotify_event: tstamp:3443069349 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2793694016 data:0x07020008
     kworker/0:0-4     [000] ....   100.311142: rtcpu_vinotify_event: tstamp:3443069471 tag:FS channel:0x00 frame:0 vi_tstamp:3443064581 data:0x00000014
     kworker/0:0-4     [000] ....   100.311143: rtos_queue_send_from_isr_failed: tstamp:3443219818 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....   100.311144: rtos_queue_send_from_isr_failed: tstamp:3443219961 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....   100.311145: rtos_queue_send_from_isr_failed: tstamp:3443220102 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....   100.311145: rtos_queue_send_from_isr_failed: tstamp:3443220237 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....   100.311146: rtos_queue_send_from_isr_failed: tstamp:3443220369 queue:0x0bcbc160
     kworker/0:0-4     [000] ....   100.311147: rtcpu_vinotify_event: tstamp:3443541639 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3443064583 data:0x00000000
     kworker/0:0-4     [000] ....   100.311147: rtcpu_vinotify_event: tstamp:3443541767 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3443065004 data:0x00000001
     kworker/0:0-4     [000] ....   100.311148: rtcpu_vinotify_event: tstamp:3443541914 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2803904896 data:0x08020008
     kworker/0:0-4     [000] ....   100.311149: rtcpu_vinotify_event: tstamp:3443542036 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2804123648 data:0x10000000
     kworker/0:0-4     [000] ....   100.311149: rtcpu_vinotify_event: tstamp:3443542177 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2804150368 data:0x31000009
     kworker/0:0-4     [000] ....   100.311150: rtcpu_vinotify_event: tstamp:3444030200 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3443786258 data:0x077f0002
     kworker/0:0-4     [000] ....   100.311151: rtcpu_vinotify_event: tstamp:3444030346 tag:FE channel:0x00 frame:0 vi_tstamp:3443786277 data:0x00000024
     kworker/0:0-4     [000] ....   100.311152: rtcpu_vinotify_event: tstamp:3444030477 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3443786280 data:0x00000000
     kworker/0:0-4     [000] ....   100.311153: rtcpu_vinotify_event: tstamp:3444030618 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3443786281 data:0x00000000
     kworker/0:0-4     [000] ....   100.311153: rtcpu_vinotify_event: tstamp:3444030742 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2826996896 data:0x02020008
     kworker/0:0-4     [000] ....   100.311154: rtcpu_vinotify_event: tstamp:3444030883 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2827007936 data:0x00020008
     kworker/0:0-4     [000] ....   100.311155: rtcpu_vinotify_event: tstamp:3444031006 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2827027584 data:0x07020009
     kworker/0:0-4     [000] ....   100.311155: rtcpu_vinotify_event: tstamp:3444110276 tag:FS channel:0x00 frame:0 vi_tstamp:3444106254 data:0x00000014
     kworker/0:0-4     [000] ....   100.311156: rtcpu_vinotify_event: tstamp:3444110416 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3444106256 data:0x00000000
     kworker/0:0-4     [000] ....   100.311157: rtcpu_vinotify_event: tstamp:3444110560 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3444106676 data:0x00000001
     kworker/0:0-4     [000] ....   100.311157: rtcpu_vinotify_event: tstamp:3444110682 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2837235040 data:0x08020009
     kworker/0:0-4     [000] ....   100.311158: rtos_queue_send_from_isr_failed: tstamp:3444301797 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....   100.311159: rtos_queue_send_from_isr_failed: tstamp:3444301940 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....   100.311160: rtos_queue_send_from_isr_failed: tstamp:3444302079 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....   100.311160: rtos_queue_send_from_isr_failed: tstamp:3444302213 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....   100.311161: rtos_queue_send_from_isr_failed: tstamp:3444302347 queue:0x0bcbc160
     kworker/0:0-4     [000] ....   100.311162: rtcpu_vinotify_event: tstamp:3444567307 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2837453472 data:0x10000000
     kworker/0:0-4     [000] ....   100.311163: rtcpu_vinotify_event: tstamp:3444567435 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2837480224 data:0x3100000a
     kworker/0:0-4     [000] ....   100.311164: rtcpu_vinotify_event: tstamp:3445055768 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3444827931 data:0x077f0002
     kworker/0:0-4     [000] ....   100.311165: rtcpu_vinotify_event: tstamp:3445055897 tag:FE channel:0x00 frame:0 vi_tstamp:3444827950 data:0x00000024
     kworker/0:0-4     [000] ....   100.311166: rtcpu_vinotify_event: tstamp:3445056042 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3444827952 data:0x00000000
     kworker/0:0-4     [000] ....   100.311166: rtcpu_vinotify_event: tstamp:3445056167 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3444827954 data:0x00000000
     kworker/0:0-4     [000] ....   100.311167: rtcpu_vinotify_event: tstamp:3445056307 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2860330464 data:0x02020009
     kworker/0:0-4     [000] ....   100.311168: rtcpu_vinotify_event: tstamp:3445056428 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2860341504 data:0x00020009
     kworker/0:0-4     [000] ....   100.311168: rtcpu_vinotify_event: tstamp:3445056569 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2860361120 data:0x0702000a
     kworker/0:0-4     [000] ....   100.311169: rtos_queue_send_from_isr_failed: tstamp:3445243331 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....   100.311170: rtos_queue_send_from_isr_failed: tstamp:3445243471 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....   100.311171: rtos_queue_send_from_isr_failed: tstamp:3445243611 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....   100.311171: rtos_queue_send_from_isr_failed: tstamp:3445243745 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....   100.311172: rtos_queue_send_from_isr_failed: tstamp:3445243877 queue:0x0bcbc160
     kworker/0:0-4     [000] ....   100.311173: rtcpu_vinotify_event: tstamp:3445543979 tag:FS channel:0x00 frame:0 vi_tstamp:3445147926 data:0x00000014
     kworker/0:0-4     [000] ....   100.311174: rtcpu_vinotify_event: tstamp:3445544127 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3445147928 data:0x00000000
     kworker/0:0-4     [000] ....   100.311174: rtcpu_vinotify_event: tstamp:3445544257 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3445148349 data:0x00000001
     kworker/0:0-4     [000] ....   100.311175: rtcpu_vinotify_event: tstamp:3445544401 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2870568576 data:0x0802000a
     kworker/0:0-4     [000] ....   100.311176: rtcpu_vinotify_event: tstamp:3445544521 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2870731488 data:0x10000000
     kworker/0:0-4     [000] ....   100.311176: rtcpu_vinotify_event: tstamp:3445544663 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2870758240 data:0x3100000b
     kworker/0:0-4     [000] ....   100.311177: rtcpu_vinotify_event: tstamp:3445874237 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3445869604 data:0x077f0002
     kworker/0:0-4     [000] ....   100.311178: rtos_queue_peek_from_isr_failed: tstamp:3446275840 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....   100.311179: rtos_queue_send_from_isr_failed: tstamp:3446302541 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....   100.311180: rtos_queue_send_from_isr_failed: tstamp:3446302681 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....   100.311181: rtos_queue_send_from_isr_failed: tstamp:3446302820 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....   100.311181: rtos_queue_send_from_isr_failed: tstamp:3446302954 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....   100.311182: rtos_queue_send_from_isr_failed: tstamp:3446303086 queue:0x0bcbc160
     kworker/0:0-4     [000] ....   100.311183: rtcpu_vinotify_event: tstamp:3446324874 tag:FE channel:0x00 frame:0 vi_tstamp:3445869623 data:0x00000024
     kworker/0:0-4     [000] ....   100.311183: rtcpu_vinotify_event: tstamp:3446325009 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3445869625 data:0x00000000
     kworker/0:0-4     [000] ....   100.311184: rtcpu_vinotify_event: tstamp:3446325157 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3445869627 data:0x00000000
     kworker/0:0-4     [000] ....   100.311185: rtcpu_vinotify_event: tstamp:3446325281 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2893669280 data:0x0202000a
     kworker/0:0-4     [000] ....   100.311185: rtcpu_vinotify_event: tstamp:3446325424 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2893680608 data:0x0002000a
     kworker/0:0-4     [000] ....   100.311186: rtcpu_vinotify_event: tstamp:3446325546 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2893700672 data:0x0702000b
     kworker/0:0-4     [000] ....   100.311187: rtcpu_vinotify_event: tstamp:3446325687 tag:FS channel:0x00 frame:0 vi_tstamp:3446189599 data:0x00000014
     kworker/0:0-4     [000] ....   100.311188: rtcpu_vinotify_event: tstamp:3446325817 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3446189602 data:0x00000000
     kworker/0:0-4     [000] ....   100.311188: rtcpu_vinotify_event: tstamp:3446325958 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3446190021 data:0x00000001
     kworker/0:0-4     [000] ....   100.311189: rtcpu_vinotify_event: tstamp:3446326080 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2903902112 data:0x0802000b
     kworker/0:0-4     [000] ....   100.311190: rtcpu_vinotify_event: tstamp:3446326219 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2904070496 data:0x10000000
     kworker/0:0-4     [000] ....   100.311190: rtcpu_vinotify_event: tstamp:3446326341 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2904097248 data:0x3100000c
     kworker/0:0-4     [000] ....   100.311191: rtcpu_vinotify_event: tstamp:3446915910 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3446911276 data:0x077f0002
     kworker/0:0-4     [000] ....   100.311192: rtcpu_vinotify_event: tstamp:3446916037 tag:FE channel:0x00 frame:0 vi_tstamp:3446911296 data:0x00000024
     kworker/0:0-4     [000] ....   100.311192: rtcpu_vinotify_event: tstamp:3446916181 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3446911298 data:0x00000000
     kworker/0:0-4     [000] ....   100.311193: rtcpu_vinotify_event: tstamp:3446916306 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3446911300 data:0x00000000
     kworker/0:0-4     [000] ....   100.311194: rtos_queue_send_from_isr_failed: tstamp:3447379000 queue:0x0bcb41f8
     kworker/0:0-4     [000] ....   100.311195: rtos_queue_send_from_isr_failed: tstamp:3447379143 queue:0x0bcb8a60
     kworker/0:0-4     [000] ....   100.311196: rtos_queue_send_from_isr_failed: tstamp:3447379284 queue:0x0bcba5e0
     kworker/0:0-4     [000] ....   100.311196: rtos_queue_send_from_isr_failed: tstamp:3447379418 queue:0x0bcbb3a0
     kworker/0:0-4     [000] ....   100.311197: rtos_queue_send_from_isr_failed: tstamp:3447379551 queue:0x0bcbc160
     kworker/0:0-4     [000] ....   100.311198: rtcpu_vinotify_event: tstamp:3447399175 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2927002784 data:0x0202000b
     kworker/0:0-4     [000] ....   100.311198: rtcpu_vinotify_event: tstamp:3447399305 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2927014112 data:0x0002000b
     kworker/0:0-4     [000] ....   100.311199: rtcpu_vinotify_event: tstamp:3447399450 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2927034176 data:0x0702000c
     kworker/0:0-4     [000] ....   100.311200: rtcpu_vinotify_event: tstamp:3447399576 tag:FS channel:0x00 frame:0 vi_tstamp:3447231271 data:0x00000014
     kworker/0:0-4     [000] ....   100.311201: rtcpu_vinotify_event: tstamp:3447399719 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3447231274 data:0x00000000
     kworker/0:0-4     [000] ....   100.311201: rtcpu_vinotify_event: tstamp:3447399842 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3447231695 data:0x00000001
     kworker/0:0-4     [000] ....   100.311202: rtcpu_vinotify_event: tstamp:3447399983 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2937235680 data:0x0802000c
     kworker/0:0-4     [000] ....   100.311203: rtcpu_vinotify_event: tstamp:3447400105 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2937401504 data:0x10000000
     kworker/0:0-4     [000] ....   100.311203: rtcpu_vinotify_event: tstamp:3447400245 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2937428256 data:0x3100000d
     kworker/0:0-4     [000] ....   100.311204: rtcpu_vinotify_event: tstamp:3447957637 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3447952949 data:0x077f0002
     kworker/0:0-4     [000] ....   100.311205: rtcpu_vinotify_event: tstamp:3447957781 tag:FE channel:0x00 frame:0 vi_tstamp:3447952968 data:0x00000024
     kworker/0:0-4     [000] ....   100.311205: rtcpu_vinotify_event: tstamp:3447957910 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3447952971 data:0x00000000
     kworker/0:0-4     [000] ....   100.311206: rtcpu_vinotify_event: tstamp:3447958052 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3447952972 data:0x00000000
     kworker/0:0-4     [000] ....   100.311207: rtcpu_vinotify_event: tstamp:3447958174 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2960331008 data:0x0202000c
     kworker/0:0-4     [000] ....   100.311208: rtcpu_vinotify_event: tstamp:3447958314 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2960342048 data:0x0002000c
     kworker/0:0-4     [000] ....   100.311208: rtcpu_vinotify_event: tstamp:3447958436 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2960361696 data:0x0702000d
     kworker/0:0-4     [000] ....   100.311209: rtcpu_vinotify_event: tstamp:3448424874 tag:FS channel:0x00 frame:0 vi_tstamp:3448272944 data:0x00000014
     kworker/0:0-4     [000] ....   100.311210: rtcpu_vinotify_event: tstamp:3448425005 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3448272946 data:0x00000000
     kworker/0:0-4     [000] ....   100.311211: rtcpu_vinotify_event: tstamp:3448425193 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3448273368 data:0x00000001
     kworker/0:0-4     [000] ....   100.311211: rtcpu_vinotify_event: tstamp:3448425316 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2970569184 data:0x0802000d
     kworker/0:0-4     [000] ....   100.311212: rtcpu_vinotify_event: tstamp:3448425459 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2970740000 data:0x10000000
     kworker/0:0-4     [000] ....   100.311213: rtcpu_vinotify_event: tstamp:3448425581 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2970766720 data:0x3100000e
     kworker/0:0-4     [000] ....   100.311214: rtcpu_vinotify_event: tstamp:3449318641 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3448994622 data:0x077f0002
     kworker/0:0-4     [000] ....   100.311214: rtcpu_vinotify_event: tstamp:3449318768 tag:FE channel:0x00 frame:0 vi_tstamp:3448994641 data:0x00000024
     kworker/0:0-4     [000] ....   100.311215: rtcpu_vinotify_event: tstamp:3449318912 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3448994644 data:0x00000000
     kworker/0:0-4     [000] ....   100.311216: rtcpu_vinotify_event: tstamp:3449319035 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3448994645 data:0x00000000
     kworker/0:0-4     [000] ....   100.311217: rtcpu_vinotify_event: tstamp:3449319175 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2993664544 data:0x0202000d
     kworker/0:0-4     [000] ....   100.311217: rtcpu_vinotify_event: tstamp:3449319297 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2993675616 data:0x0002000d
     kworker/0:0-4     [000] ....   100.311218: rtcpu_vinotify_event: tstamp:3449319437 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2993695232 data:0x0702000e
     kworker/0:0-4     [000] ....   100.311219: rtcpu_vinotify_event: tstamp:3449319562 tag:FS channel:0x00 frame:0 vi_tstamp:3449314617 data:0x00000014
     kworker/0:0-4     [000] ....   100.311219: rtcpu_vinotify_event: tstamp:3449319704 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:3449314619 data:0x00000000
     kworker/0:0-4     [000] ....   100.311220: rtcpu_vinotify_event: tstamp:3449319826 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:3449315040 data:0x00000001
     kworker/0:0-4     [000] ....   100.311221: rtcpu_vinotify_event: tstamp:3449791793 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3003908032 data:0x0802000e
     kworker/0:0-4     [000] ....   100.311222: rtcpu_vinotify_event: tstamp:3450279881 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:3450036295 data:0x077f0002
     kworker/0:0-4     [000] ....   100.311223: rtcpu_vinotify_event: tstamp:3450280031 tag:FE channel:0x00 frame:0 vi_tstamp:3450036314 data:0x00000024
     kworker/0:0-4     [000] ....   100.311223: rtcpu_vinotify_event: tstamp:3450280161 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:3450036316 data:0x00000000
     kworker/0:0-4     [000] ....   100.311224: rtcpu_vinotify_event: tstamp:3450280306 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:3450036318 data:0x00000000
     kworker/0:0-4     [000] ....   100.311225: rtcpu_vinotify_event: tstamp:3450280429 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3026998048 data:0x0202000e
     kworker/0:0-4     [000] ....   100.311225: rtcpu_vinotify_event: tstamp:3450280573 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:3027009088 data:0x0002000e
     kworker/0:0-4     [000] ....   100.311227: rtcpu_vinotify_error: tstamp:3450359293 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3450356713 data:0x00000589
     kworker/0:0-4     [000] ....   100.311227: rtcpu_vinotify_event: tstamp:3450768396 tag:FS channel:0x00 frame:0 vi_tstamp:3450356290 data:0x00000014
     kworker/0:0-4     [000] ....   100.311228: rtcpu_vinotify_event: tstamp:3450768541 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3450356713 data:0x00000589
     kworker/0:0-4     [000] ....   100.311229: rtcpu_vinotify_event: tstamp:3451256805 tag:FE channel:0x00 frame:0 vi_tstamp:3451077986 data:0x00000024
     kworker/0:0-4     [000] ....   100.311230: rtos_queue_peek_from_isr_failed: tstamp:3451275844 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....   100.366804: rtcpu_vinotify_error: tstamp:3451401006 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3451398386 data:0x00000589
     kworker/0:0-4     [000] ....   100.366808: rtcpu_vinotify_event: tstamp:3451745333 tag:FS channel:0x00 frame:0 vi_tstamp:3451397963 data:0x00000014
     kworker/0:0-4     [000] ....   100.366810: rtcpu_vinotify_event: tstamp:3451745464 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3451398386 data:0x00000589
     kworker/0:0-4     [000] ....   100.366810: rtcpu_vinotify_event: tstamp:3452233022 tag:FE channel:0x00 frame:0 vi_tstamp:3452119659 data:0x00000024
     kworker/0:0-4     [000] ....   100.366830: rtcpu_vinotify_error: tstamp:3452442630 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3452440058 data:0x00000589
     kworker/0:0-4     [000] ....   100.366831: rtcpu_vinotify_event: tstamp:3452721560 tag:FS channel:0x00 frame:0 vi_tstamp:3452439636 data:0x00000014
     kworker/0:0-4     [000] ....   100.366832: rtcpu_vinotify_event: tstamp:3452721701 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3452440058 data:0x00000589
     kworker/0:0-4     [000] ....   100.366832: rtcpu_vinotify_event: tstamp:3453163546 tag:FE channel:0x00 frame:0 vi_tstamp:3453161332 data:0x00000024
     kworker/0:0-4     [000] ....   100.366833: rtcpu_vinotify_error: tstamp:3453484305 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3453481730 data:0x00000589
     kworker/0:0-4     [000] ....   100.366834: rtcpu_vinotify_event: tstamp:3453649250 tag:FS channel:0x00 frame:0 vi_tstamp:3453481308 data:0x00000014
     kworker/0:0-4     [000] ....   100.366835: rtcpu_vinotify_event: tstamp:3453649375 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3453481730 data:0x00000589
     kworker/0:0-4     [000] ....   100.366836: rtcpu_vinotify_error: tstamp:3454526024 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3454523404 data:0x00000589
     kworker/0:0-4     [000] ....   100.366837: rtcpu_vinotify_event: tstamp:3454626185 tag:FE channel:0x00 frame:0 vi_tstamp:3454203005 data:0x00000024
     kworker/0:0-4     [000] ....   100.366837: rtcpu_vinotify_event: tstamp:3454626308 tag:FS channel:0x00 frame:0 vi_tstamp:3454522980 data:0x00000014
     kworker/0:0-4     [000] ....   100.366838: rtcpu_vinotify_event: tstamp:3454626450 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3454523404 data:0x00000589
     kworker/0:0-4     [000] ....   100.366839: rtcpu_vinotify_error: tstamp:3455567645 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3455565076 data:0x00000589
     kworker/0:0-4     [000] ....   100.366840: rtcpu_vinotify_event: tstamp:3455602405 tag:FE channel:0x00 frame:0 vi_tstamp:3455244677 data:0x00000024
     kworker/0:0-4     [000] ....   100.366840: rtcpu_vinotify_event: tstamp:3455602548 tag:FS channel:0x00 frame:0 vi_tstamp:3455564654 data:0x00000014
     kworker/0:0-4     [000] ....   100.366841: rtcpu_vinotify_event: tstamp:3455602672 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3455565076 data:0x00000589
     kworker/0:0-4     [000] ....   100.366843: rtos_queue_peek_from_isr_failed: tstamp:3456275841 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....   100.366844: rtcpu_vinotify_event: tstamp:3456579135 tag:FE channel:0x00 frame:0 vi_tstamp:3456286350 data:0x00000024
     kworker/0:0-4     [000] ....   100.366845: rtcpu_vinotify_error: tstamp:3456609322 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3456606749 data:0x00000589
     kworker/0:0-4     [000] ....   100.366845: rtcpu_vinotify_event: tstamp:3457067657 tag:FS channel:0x00 frame:0 vi_tstamp:3456606326 data:0x00000014
     kworker/0:0-4     [000] ....   100.366846: rtcpu_vinotify_event: tstamp:3457067798 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3456606749 data:0x00000589
     kworker/0:0-4     [000] ....   100.422828: rtcpu_vinotify_event: tstamp:3457555347 tag:FE channel:0x00 frame:0 vi_tstamp:3457328023 data:0x00000024
     kworker/0:0-4     [000] ....   100.422832: rtcpu_vinotify_error: tstamp:3457651049 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3457648422 data:0x00000589
     kworker/0:0-4     [000] ....   100.422833: rtcpu_vinotify_event: tstamp:3458043877 tag:FS channel:0x00 frame:0 vi_tstamp:3457647998 data:0x00000014
     kworker/0:0-4     [000] ....   100.422834: rtcpu_vinotify_event: tstamp:3458044000 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3457648422 data:0x00000589
     kworker/0:0-4     [000] ....   100.422835: rtcpu_vinotify_event: tstamp:3458532286 tag:FE channel:0x00 frame:0 vi_tstamp:3458369695 data:0x00000024
     kworker/0:0-4     [000] ....   100.422836: rtcpu_vinotify_event: tstamp:3458692967 tag:FS channel:0x00 frame:0 vi_tstamp:3458689672 data:0x00000014
     kworker/0:0-4     [000] ....   100.422836: rtcpu_vinotify_error: tstamp:3458693938 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3458690094 data:0x00000589
     kworker/0:0-4     [000] ....   100.478801: rtcpu_vinotify_event: tstamp:3459167047 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3458690094 data:0x00000589
     kworker/0:0-4     [000] ....   100.478805: rtcpu_vinotify_event: tstamp:3459655454 tag:FE channel:0x00 frame:0 vi_tstamp:3459411368 data:0x00000024
     kworker/0:0-4     [000] ....   100.478806: rtcpu_vinotify_error: tstamp:3459734340 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3459731767 data:0x00000589
     kworker/0:0-4     [000] ....   100.478807: rtcpu_vinotify_event: tstamp:3460143257 tag:FS channel:0x00 frame:0 vi_tstamp:3459731345 data:0x00000014
     kworker/0:0-4     [000] ....   100.478808: rtcpu_vinotify_event: tstamp:3460143380 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3459731767 data:0x00000589
     kworker/0:0-4     [000] ....   100.478808: rtcpu_vinotify_event: tstamp:3460631665 tag:FE channel:0x00 frame:0 vi_tstamp:3460453041 data:0x00000024
     kworker/0:0-4     [000] ....   100.538782: rtcpu_vinotify_error: tstamp:3460776074 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3460773440 data:0x00000589
     kworker/0:0-4     [000] ....   100.538788: rtcpu_vinotify_event: tstamp:3461120189 tag:FS channel:0x00 frame:0 vi_tstamp:3460773017 data:0x00000014
     kworker/0:0-4     [000] ....   100.538789: rtcpu_vinotify_event: tstamp:3461120331 tag:CHANSEL_NOMATCH channel:0x10 frame:0 vi_tstamp:3460773440 data:0x00000589
Also, this is the syslog at the time of the trace
Syslog
Oct  4 21:46:39  systemd[1]: Starting Snap Daemon...
Oct  4 21:46:39  snapd[8660]: AppArmor status: apparmor not enabled
Oct  4 21:46:39  snapd[8660]: daemon.go:343: started snapd/2.45.1+18.04.2 (series 16; classic; devmode) ubuntu/18.04 (arm64) linux/4.9.140-tegra.
Oct  4 21:46:40  snapd[8660]: daemon.go:436: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
Oct  4 21:46:40  systemd[1]: Started Snap Daemon.
Oct  4 21:46:40  gnome-software[8640]: enabled plugins: packagekit-refine-repos, packagekit-offline, packagekit-upgrade, shell-extensions, desktop-categories, packagekit-local, packagekit-url-to-app, ubuntuone, os-release, packagekit, systemd-updates, packagekit-proxy, fwupd, packagekit-refresh, appstream, hardcoded-featured, desktop-menu-path, rewrite-resource, packagekit-refine, odrs, steam, hardcoded-blacklist, modalias, hardcoded-popular, generic-updates, packagekit-history, snap, provenance, icons, provenance-license, key-colors, key-colors-metadata
Oct  4 21:46:40  gnome-software[8640]: disabled plugins: dummy, repos, dpkg, epiphany
Oct  4 21:46:40  dbus-daemon[4995]: [system] Activating via systemd: service name='org.freedesktop.fwupd' unit='fwupd.service' requested by ':1.147' (uid=1000 pid=8640 comm="/usr/bin/gnome-software --gapplication-service ")
Oct  4 21:46:40  systemd[1]: Starting Firmware update daemon...
Oct  4 21:46:40  fwupd[8741]: Failed to load SMBIOS: Failed to open file “/sys/firmware/dmi/tables/smbios_entry_point”: No such file or directory
Oct  4 21:46:40  fwupd[8741]: disabling plugin because: failed to startup uefi: UEFI firmware updating not supported
Oct  4 21:46:40  fwupd[8741]: disabling plugin because: failed to coldplug amt: Unable to find a ME interface
Oct  4 21:46:40  fwupd[8741]: disabling plugin because: failed to coldplug thunderbolt_power: No support for force power via kernel or bolt
Oct  4 21:46:40  fwupd[8741]: using plugins: csr, nitrokey, colorhug, unifying, dfu, upower, udev, thunderbolt, steelseries, altos, wacomhid, ebitdo
Oct  4 21:46:40  fwupd[8741]: Daemon ready for requests
Oct  4 21:46:41  dbus-daemon[4995]: [system] Successfully activated service 'org.freedesktop.fwupd'
Oct  4 21:46:41  systemd[1]: Started Firmware update daemon.
Oct  4 21:46:42  PackageKit: get-updates transaction /1096_dddededd from uid 1000 finished with success after 961ms
Oct  4 21:46:42  gnome-software[8640]: failed to call gs_plugin_add_installed on shell-extensions: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.gnome.Shell.Extensions' on object at path /org/gnome/Shell
Oct  4 21:46:42  gnome-software[8640]: Only 0 apps for recent list, hiding
Oct  4 21:46:43  kernel: [   99.098930] [RCE] Configuring ISP GoS.
Oct  4 21:46:43  kernel: [   99.098948] [RCE]   VM GOS[#0] addr=0xc2100000
Oct  4 21:46:43  kernel: [   99.098957] [RCE]   VM GOS[#1] addr=0xc2101000
Oct  4 21:46:43  kernel: [   99.098963] [RCE]   VM GOS[#2] addr=0xc2102000
Oct  4 21:46:43  kernel: [   99.098969] [RCE]   VM GOS[#3] addr=0xc2103000
Oct  4 21:46:43  kernel: [   99.098978] [RCE]   VM GOS[#4] addr=0xc2104000
Oct  4 21:46:43  kernel: [   99.098985] [RCE]   VM GOS[#5] addr=0xc2105000
Oct  4 21:46:43  kernel: [   99.098996] [RCE] WARNING: t194/isp5.c:901 [config_channel] "All error notifications not enabled: correctable=0x00 uncorrectable=0x00"
Oct  4 21:46:43  PackageKit: resolve transaction /1097_eedcbdca from uid 1000 finished with success after 620ms
Oct  4 21:46:43  nvargus-daemon[6236]: === NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections...=== gst-launch-1.0[8832]: Connection established (7F9FA0D1D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Oct  4 21:46:43  nvargus-daemon[6236]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Oct  4 21:46:43  nvargus-daemon[6236]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Oct  4 21:46:43  nvargus-daemon[6236]: NvPclHwGetModuleList: No module data found
Oct  4 21:46:43  nvargus-daemon[6236]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Oct  4 21:46:43  nvargus-daemon[6236]: ---- imager: Found override file [/var/nvidia/nvcam/settings/front.isp]. ----
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 18: Error: Invalid isp config attribute: "sensor.companding.enable=TRUE"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 19: Error: Invalid isp config attribute: "sensor.companding.LUT={2048,2048,65536,3040,1048576,4000,1048576,4096}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 20: Error: Invalid isp config attribute: "scene.brightnessKey={0.01,0.02,0.05,0.1,0.2,0.5,1}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 21: Error: Invalid isp config attribute: "scene.toneTable.axisX={10,100,1000,10000}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 22: Error: Invalid isp config attribute: "scene.toneTable.axisY={30,60,90,120}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 23: Error: Invalid isp config attribute: "saturation.strength={0.0,0,0,0,0,0,0}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 24: Error: Invalid isp config attribute: "noiseReduction.strength={0.5,0.5,0.5,0.5,0.5,0.5,0.5}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 25: Error: Invalid isp config attribute: "sharpness.strength={0.5,0.5,0.5,0.5,0.5,0.5,0.5}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 26: Error: Invalid isp config attribute: "gtm.enable=TRUE"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 27: Error: Invalid isp config attribute: "gtm.preset[0]={0,0,0.25,0.25,0.5,0.5,0.75,0.75,1,1}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 28: Error: Invalid isp config attribute: "dae.mode=1"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 29: Error: Invalid isp config attribute: "dae.enableGammaPQ=TRUE"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 30: Error: Invalid isp config attribute: "dae.EVCompensation=0.0"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 31: Error: Invalid isp config attribute: "dae.highlightControl=0.5"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 32: Error: Invalid isp config attribute: "dae.shadowControl=0.5"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 33: Error: Invalid isp config attribute: "ltm.enable=TRUE"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 34: Error: Invalid isp config attribute: "ltm.enableLf=TRUE"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 38: Error: Invalid isp config attribute: "ltm.strength={0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 39: Error: Invalid isp config attribute element: "awb.nightmode.enable=TRUE"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 40: Error: Invalid isp config attribute element: "awb.nightmode.gains={2.5,1,1,3.2}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 41: Error: Invalid isp config attribute: "em.initialState=0"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 42: Error: Invalid isp config attribute: "em.thresholdLow=2080"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 43: Error: Invalid isp config attribute: "em.thresholdHigh=3232"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 47: Error: Invalid isp config attribute: "em.preset[0].wbgains={1.5,1.0,1.0,1.5}"
Oct  4 21:46:43  nvargus-daemon[6236]: NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 51: Error: Invalid isp config attribute: "em.preset[1].wbgains={1.5,1.0,1.0,1.5}"
Oct  4 21:46:43  nvargus-daemon[6236]: CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/rear.isp]. ----
Oct  4 21:46:43  kernel: [   99.326867] [RCE] Configuring VI GoS.
Oct  4 21:46:43  kernel: [   99.326878] [RCE] VM GOS[#0] addr=0xc2100000
Oct  4 21:46:43  kernel: [   99.326885] [RCE] VM GOS[#1] addr=0xc2101000
Oct  4 21:46:43  kernel: [   99.326891] [RCE] VM GOS[#2] addr=0xc2102000
Oct  4 21:46:43  kernel: [   99.326897] [RCE] VM GOS[#3] addr=0xc2103000
Oct  4 21:46:43  kernel: [   99.326903] [RCE] VM GOS[#4] addr=0xc2104000
Oct  4 21:46:43  kernel: [   99.326909] [RCE] VM GOS[#5] addr=0xc2105000
Oct  4 21:46:43  kernel: [   99.326917] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
Oct  4 21:46:43  nvargus-daemon[6236]: CAM: serial no file already exists, skips storing again=== gst-launch-1.0[8832]: CameraProvider initialized (0x7f98a46840)NvCameraIspConfigFileLoad: type = 0x75 Config file "camera_overrides.isp" Line 18: Error: Invalid isp config attribute: "sensor.companding.enable=TRUE"
Oct  4 21:46:43  gnome-software[8640]: Only 8 apps for popular list, hiding
Oct  4 21:46:43  kernel: [   99.550923] [RCE] Configuring VI GoS.
Oct  4 21:46:43  kernel: [   99.550955] [RCE] VM GOS[#0] addr=0xc2100000
Oct  4 21:46:43  kernel: [   99.550961] [RCE] VM GOS[#1] addr=0xc2101000
Oct  4 21:46:43  kernel: [   99.550967] [RCE] VM GOS[#2] addr=0xc2102000
Oct  4 21:46:43  kernel: [   99.550972] [RCE] VM GOS[#3] addr=0xc2103000
Oct  4 21:46:43  kernel: [   99.550977] [RCE] VM GOS[#4] addr=0xc2104000
Oct  4 21:46:43  kernel: [   99.550982] [RCE] VM GOS[#5] addr=0xc2105000
Oct  4 21:46:43  kernel: [   99.662901] [RCE] VI GOS[#0] set to VM GOS[4] base 0xc2104000
Oct  4 21:46:44  kernel: [   99.830890] [RCE] ISP GOS[#0] set to VM GOS[5] base 0xc2105000
Oct  4 21:46:44  kernel: [   99.830911] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831028] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831130] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831227] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831323] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831412] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831504] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831615] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831711] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831801] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831891] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.831981] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.832109] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.832589] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.833023] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.833461] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.833919] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.836865] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.842606] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.848412] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.854476] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.860456] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.866271] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.871822] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.877294] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.883319] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.889081] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.894858] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.900679] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.906158] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.912338] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.918358] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.924070] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.929555] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.935030] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.941315] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.946903] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.952632] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.958379] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.982772] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.988331] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.994060] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [   99.999633] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.005440] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.011643] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.016919] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.023126] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.028895] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.034695] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.039770] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.045918] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.051421] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.057163] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.062678] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.068909] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.074670] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  nvargus-daemon[6236]: CAM: serial no file already exists, skips storing again(NvCapture) Error InvalidState: Free request list is empty! (in /dvs/git/dirty/git-master_linux/camera/capture/nvcapture/capture.c, function NvCaptureGetRequest(), line 706)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/services/capture/NvCaptureViCsiHw.cpp, function startCaptureInternal(), line 597)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/services/capture/CaptureRecord.cpp, function doCSItoMemCapture(), line 517)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(), line 454)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1276)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueBubbleFillCapturesIfNeeded(), line 676)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1118)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/common/Utils.cpp, function workerThread(), line 116)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
Oct  4 21:46:44  kernel: [  100.080972] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.085970] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.092233] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.097679] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.103507] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.109241] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.114924] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.120485] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function addNewItemToSchedule(), line 908)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 395)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/components/stages/MemoryToISPCaptureStage.cpp, function doHandleRequest(), line 137)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 990)
Oct  4 21:46:44  nvargus-daemon[6236]: SCF: Error InvalidState:  (propagating from src/components/stages/SensorCaptureStage.cpp, function doHandleRequest(), line 87)
Oct  4 21:46:44  kernel: [  100.178886] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.179022] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.179125] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.179216] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.179305] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.179394] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.179492] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.179582] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.179670] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.179775] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.184246] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.189751] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.195768] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.201324] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.207332] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.213172] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.218884] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.224762] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.230469] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.236255] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.241981] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.247813] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.253851] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.259601] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.265100] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.270893] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.276684] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.282465] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.288180] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.293939] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.300246] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  kernel: [  100.305818] rtcpu_trace_isp_event event id 20 cannot be found
Oct  4 21:46:44  update-notifier[8638]: GtkDialog mapped without a transient parent. This is discouraged.
Oct  4 21:46:45  nvargus-daemon[6236]: SCF: Error Timeout:  (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Oct  4 21:46:45  nvargus-daemon[6236]: Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
Oct  4 21:46:45  snapd[8660]: daemon.go:542: gracefully waiting for running hooks
Oct  4 21:46:45  snapd[8660]: daemon.go:544: done waiting for running hooks
Oct  4 21:46:45  snapd[8660]: daemon stop requested to wait for socket activation
Oct  4 21:46:45  PackageKit: search-file transaction /1098_aebabaae from uid 1000 finished with success after 2024ms
Oct  4 21:46:45  nvargus-daemon[6236]: SCF: Error Timeout:  (propagating from src/components/amr/Snapshot.cpp, function waitForNewerSample(), line 92)
Oct  4 21:46:45  nvargus-daemon[6236]: SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
Oct  4 21:46:45  nvargus-daemon[6236]: SCF: Error Timeout:  (propagating from src/components/ac_stages/ACSynchronizeStage.cpp, function doHandleRequest(), line 126)
Oct  4 21:46:45  nvargus-daemon[6236]: SCF: Error Timeout:  (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
Thank you!
Can these two camera working well individually?
Seems so, the cameras are identical and I’ve been running a stream on video0 for 12 hours straight non-stop and it works. As I said, if I physically switch the camera modules so that the second camera is on /dev/video0 it is still working. I only find issues on /dev/video1
Do you have an idea where I might look to figure what’s going on? If I understand correctly, the FS/FE events keep coming, so the sensor is streaming, but this CHANSEL_NOMATCH error I haven’t seen before. Is there a way I can compile a custom kernel and dump the sensor data from vi for example to check what’s going on when things go wrong?
NOMATCH indicates no VI channel is enabled to capture the input stream. Don’t know why it happen suddenly.
We have a similar problem. (JP4.3 + Leopard Images imx334 kit)
The camera app captures 3 cameras for about 30-60 seconds and after that we get the same error.
Hi, were you able to root-cause or work-around the “Error InvalidState: Free request list is empty!” error? I am seeing the same intermittently on my multi-camera system.
No. Have you used a Leopard Imaging imx334 camera or another?
I found that on the imx 447 this error does not occur very often.
I’m using another camera. Thanks for sharing your findings, it seems to indicate it might be a driver-related issue.
Did you record captured stream to ssd ?
In my case, when I am recording, I get the error faster than when capturing and streaming.
Yes I’m writing to disk as well. Haven’t checked to see how the error rate is affected by writing to disk.
Some more details here https://forums.developer.nvidia.com/t/jetson-agx-jp4-3-leopardimaging-imx334-sometimes-make-self-reboot-when-capture-video
