We use one max9296+two max96705+ two sensor on xavier jetpack4.4.
When I’ve enabled the trace,and I got the following error:
trace log:
# tracer: nop
# entries-in-buffer/entries-written: 828/828 #P:8
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:3-1706 [000] .... 40.397652: rtos_queue_peek_from_isr_failed: tstamp:1618727472 queue:0x0bcbcf78
v4l2-ctl-9040 [007] .... 40.595609: tegra_channel_open: vi-output, imx390 8-0024
v4l2-ctl-9040 [007] .... 40.595629: tegra_channel_set_power: imx390 8-0024 : 0x1
v4l2-ctl-9040 [007] .... 40.595665: camera_common_s_power: status : 0x1
v4l2-ctl-9040 [001] .... 40.597857: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
v4l2-ctl-9040 [001] .... 40.597862: csi_s_power: enable : 0x1
v4l2-ctl-9040 [001] .... 40.598954: tegra_channel_close: vi-output, imx390 8-0024
v4l2-ctl-9040 [001] .... 40.598960: tegra_channel_set_power: imx390 8-0024 : 0x0
v4l2-ctl-9040 [001] .... 40.598962: camera_common_s_power: status : 0x0
v4l2-ctl-9040 [001] .... 40.601662: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
v4l2-ctl-9040 [001] .... 40.601667: csi_s_power: enable : 0x0
kworker/0:3-1706 [000] .... 40.744782: rtos_queue_peek_from_isr_failed: tstamp:1628727519 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 40.864512: rtos_queue_peek_from_isr_failed: tstamp:1633727520 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 41.044064: rtos_queue_peek_from_isr_failed: tstamp:1638727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 41.217365: rtos_queue_peek_from_isr_failed: tstamp:1643727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 41.331463: rtos_queue_peek_from_isr_failed: tstamp:1648727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 41.511030: rtos_queue_peek_from_isr_failed: tstamp:1653727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 41.690628: rtos_queue_peek_from_isr_failed: tstamp:1658727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 41.810236: rtos_queue_peek_from_isr_failed: tstamp:1663727516 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 41.993953: rtos_queue_peek_from_isr_failed: tstamp:1668727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 42.173508: rtos_queue_peek_from_isr_failed: tstamp:1673727518 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 42.293162: rtos_queue_peek_from_isr_failed: tstamp:1678727512 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 42.465557: rtos_queue_peek_from_isr_failed: tstamp:1683727563 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 42.640401: rtos_queue_peek_from_isr_failed: tstamp:1688727471 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 42.823988: rtos_queue_peek_from_isr_failed: tstamp:1693727514 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 42.943788: rtos_queue_peek_from_isr_failed: tstamp:1698727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 43.123375: rtos_queue_peek_from_isr_failed: tstamp:1703727551 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 43.303002: rtos_queue_peek_from_isr_failed: tstamp:1708727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 43.422788: rtos_queue_peek_from_isr_failed: tstamp:1713727519 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 43.602389: rtos_queue_peek_from_isr_failed: tstamp:1718727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 43.778101: rtos_queue_peek_from_isr_failed: tstamp:1723727471 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 43.897821: rtos_queue_peek_from_isr_failed: tstamp:1728727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 44.077406: rtos_queue_peek_from_isr_failed: tstamp:1733727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 44.249138: rtos_queue_peek_from_isr_failed: tstamp:1738727511 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 44.424759: rtos_queue_peek_from_isr_failed: tstamp:1743727474 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 44.536608: rtos_queue_peek_from_isr_failed: tstamp:1748727511 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 44.708217: rtos_queue_peek_from_isr_failed: tstamp:1753727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 44.891860: rtos_queue_peek_from_isr_failed: tstamp:1758727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 45.063605: rtos_queue_peek_from_isr_failed: tstamp:1763727515 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 45.179431: rtos_queue_peek_from_isr_failed: tstamp:1768727551 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 45.359065: rtos_queue_peek_from_isr_failed: tstamp:1773727551 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 45.418899: rtos_queue_peek_from_isr_failed: tstamp:1775939157 queue:0x0bcbcf78
gst-plugin-scan-9163 [000] .... 46.322667: tegra_channel_open: vi-output, imx390 8-0024
gst-plugin-scan-9163 [000] .... 46.324544: tegra_channel_set_power: imx390 8-0024 : 0x1
gst-plugin-scan-9163 [000] .... 46.324551: camera_common_s_power: status : 0x1
gst-plugin-scan-9163 [000] .... 46.324910: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
gst-plugin-scan-9163 [000] .... 46.324912: csi_s_power: enable : 0x1
gst-plugin-scan-9163 [002] .... 46.326446: tegra_channel_close: vi-output, imx390 8-0024
gst-plugin-scan-9163 [002] .... 46.326452: tegra_channel_set_power: imx390 8-0024 : 0x0
gst-plugin-scan-9163 [002] .... 46.326457: camera_common_s_power: status : 0x0
gst-plugin-scan-9163 [002] .... 46.326617: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
gst-plugin-scan-9163 [002] .... 46.326619: csi_s_power: enable : 0x0
gst-launch-1.0-9161 [006] .... 46.465204: tegra_channel_open: vi-output, imx390 8-0024
gst-launch-1.0-9161 [006] .... 46.465224: tegra_channel_set_power: imx390 8-0024 : 0x1
gst-launch-1.0-9161 [006] .... 46.465250: camera_common_s_power: status : 0x1
gst-launch-1.0-9161 [005] .... 46.475230: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
gst-launch-1.0-9161 [005] .... 46.475240: csi_s_power: enable : 0x1
gst-launch-1.0-9161 [005] .... 46.475400: tegra_channel_close: vi-output, imx390 8-0024
gst-launch-1.0-9161 [005] .... 46.475407: tegra_channel_set_power: imx390 8-0024 : 0x0
gst-launch-1.0-9161 [005] .... 46.475416: camera_common_s_power: status : 0x0
gst-launch-1.0-9161 [004] .... 46.476357: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
gst-launch-1.0-9161 [004] .... 46.476363: csi_s_power: enable : 0x0
gst-launch-1.0-9161 [006] .... 46.511971: tegra_channel_open: vi-output, imx390 8-0024
gst-launch-1.0-9161 [006] .... 46.511992: tegra_channel_set_power: imx390 8-0024 : 0x1
gst-launch-1.0-9161 [006] .... 46.512005: camera_common_s_power: status : 0x1
gst-launch-1.0-9161 [004] .... 46.517525: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
gst-launch-1.0-9161 [004] .... 46.517535: csi_s_power: enable : 0x1
v4l2src0:src-9197 [006] .... 46.528835: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 13
v4l2src0:src-9197 [000] .... 46.549299: tegra_channel_set_stream: enable : 0x1
v4l2src0:src-9197 [006] .... 46.555292: tegra_channel_set_stream: 15a00000.nvcsi--1 : 0x1
v4l2src0:src-9197 [006] .... 46.555297: csi_s_stream: enable : 0x1
v4l2src0:src-9197 [006] .... 46.555331: tegra_channel_set_stream: imx390 8-0024 : 0x1
kworker/0:3-1706 [000] .... 46.576847: rtos_queue_peek_from_isr_failed: tstamp:1811710347 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 46.576852: rtcpu_start: tstamp:1811711934
kworker/0:3-1706 [000] .... 46.576854: rtos_queue_send_from_isr_failed: tstamp:1811842569 queue:0x0bcb41f8
kworker/0:3-1706 [000] .... 46.576854: rtos_queue_send_from_isr_failed: tstamp:1811842776 queue:0x0bcb8a60
kworker/0:3-1706 [000] .... 46.576855: rtos_queue_send_from_isr_failed: tstamp:1811842977 queue:0x0bcba5e0
kworker/0:3-1706 [000] .... 46.576856: rtos_queue_send_from_isr_failed: tstamp:1811843175 queue:0x0bcbb3a0
kworker/0:3-1706 [000] .... 46.576856: rtos_queue_send_from_isr_failed: tstamp:1811843373 queue:0x0bcbc160
kworker/0:3-1706 [000] .... 46.576858: rtcpu_string: tstamp:1811843962 id:0x04010000 str:"Configuring VI GoS.
kworker/0:3-1706 [000] .... 46.576885: rtcpu_string: tstamp:1811844214 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:3-1706 [000] .... 46.576895: rtcpu_string: tstamp:1811844524 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:3-1706 [000] .... 46.576904: rtcpu_string: tstamp:1811844859 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:3-1706 [000] .... 46.576913: rtcpu_string: tstamp:1811845142 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:3-1706 [000] .... 46.576922: rtcpu_string: tstamp:1811845423 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:3-1706 [000] .... 46.576930: rtcpu_string: tstamp:1811845709 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:3-1706 [000] .... 46.576939: rtcpu_string: tstamp:1811853687 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
kworker/0:3-1706 [000] .... 46.576940: rtcpu_string: tstamp:1811853856 id:0x04010000 str:"on 2.2
kworker/0:3-1706 [000] .... 46.576949: rtos_queue_send_from_isr_failed: tstamp:1811884621 queue:0x0bcb41f8
kworker/0:3-1706 [000] .... 46.576950: rtos_queue_send_from_isr_failed: tstamp:1811884854 queue:0x0bcb8a60
kworker/0:3-1706 [000] .... 46.576951: rtos_queue_send_from_isr_failed: tstamp:1811885064 queue:0x0bcba5e0
kworker/0:3-1706 [000] .... 46.576951: rtos_queue_send_from_isr_failed: tstamp:1811885260 queue:0x0bcbb3a0
kworker/0:3-1706 [000] .... 46.576952: rtos_queue_send_from_isr_failed: tstamp:1811885457 queue:0x0bcbc160
kworker/0:3-1706 [000] .... 46.576952: rtcpu_string: tstamp:1811886557 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:3-1706 [000] .... 46.576961: rtos_queue_send_from_isr_failed: tstamp:1812076303 queue:0x0bcb41f8
kworker/0:3-1706 [000] .... 46.576962: rtos_queue_send_from_isr_failed: tstamp:1812076457 queue:0x0bcb8a60
kworker/0:3-1706 [000] .... 46.576962: rtos_queue_send_from_isr_failed: tstamp:1812076597 queue:0x0bcba5e0
kworker/0:3-1706 [000] .... 46.576963: rtos_queue_send_from_isr_failed: tstamp:1812076729 queue:0x0bcbb3a0
kworker/0:3-1706 [000] .... 46.576964: rtos_queue_send_from_isr_failed: tstamp:1812076861 queue:0x0bcbc160
kworker/0:3-1706 [000] .... 46.576965: rtcpu_nvcsi_intr: tstamp:1812079325 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000001
kworker/0:3-1706 [000] .... 46.576967: rtcpu_vinotify_error: tstamp:1812084736 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1812084059 data:0x00000100
kworker/0:3-1706 [000] .... 46.576968: rtcpu_vinotify_event: tstamp:1812166370 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2145831520 data:0x10000000
kworker/0:3-1706 [000] .... 46.576969: rtcpu_vinotify_event: tstamp:1812166502 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2145835328 data:0x31000001
kworker/0:3-1706 [000] .... 46.576969: rtcpu_vinotify_event: tstamp:1812166646 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2145836320 data:0x07020001
kworker/0:3-1706 [000] .... 46.576970: rtcpu_vinotify_event: tstamp:1812166768 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2145887680 data:0x10000000
kworker/0:3-1706 [000] .... 46.576970: rtcpu_vinotify_event: tstamp:1812166909 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:2145891520 data:0x31000002
kworker/0:3-1706 [000] .... 46.576971: rtcpu_vinotify_event: tstamp:1812167044 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1812084059 data:0x00000100
kworker/0:3-1706 [000] .... 46.632764: rtos_queue_send_from_isr_failed: tstamp:1813318756 queue:0x0bcb41f8
kworker/0:3-1706 [000] .... 46.632768: rtos_queue_send_from_isr_failed: tstamp:1813318896 queue:0x0bcb8a60
kworker/0:3-1706 [000] .... 46.632769: rtos_queue_send_from_isr_failed: tstamp:1813319036 queue:0x0bcba5e0
kworker/0:3-1706 [000] .... 46.632770: rtos_queue_send_from_isr_failed: tstamp:1813319168 queue:0x0bcbb3a0
kworker/0:3-1706 [000] .... 46.632771: rtos_queue_send_from_isr_failed: tstamp:1813319301 queue:0x0bcbc160
kworker/0:3-1706 [000] .... 46.632773: rtcpu_vinotify_error: tstamp:1813325071 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1813324399 data:0x00000100
kworker/0:3-1706 [000] .... 46.632774: rtcpu_vinotify_event: tstamp:1813418442 tag:FS channel:0x00 frame:0 vi_tstamp:1813306615 data:0x00000012
kworker/0:3-1706 [000] .... 46.632775: rtcpu_vinotify_event: tstamp:1813418573 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1813306615 data:0x00000000
kworker/0:3-1706 [000] .... 46.632776: rtcpu_vinotify_event: tstamp:1813418714 tag:FE channel:0x00 frame:0 vi_tstamp:1813306876 data:0x00000022
kworker/0:3-1706 [000] .... 46.632777: rtcpu_vinotify_event: tstamp:1813418840 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:0 vi_tstamp:1813306876 data:0x01000000
kworker/0:3-1706 [000] .... 46.632777: rtcpu_vinotify_event: tstamp:1813418984 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2191247232 data:0x01020001
kworker/0:3-1706 [000] .... 46.632778: rtcpu_vinotify_event: tstamp:1813419111 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1813306876 data:0x00000000
kworker/0:3-1706 [000] .... 46.632785: rtcpu_vinotify_event: tstamp:1813419259 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1813324399 data:0x00000100
kworker/0:3-1706 [000] .... 46.692652: rtcpu_vinotify_event: tstamp:1814656855 tag:FS channel:0x00 frame:0 vi_tstamp:1814656027 data:0x00000012
kworker/0:3-1706 [000] .... 46.692656: rtcpu_vinotify_event: tstamp:1814657000 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1814656028 data:0x00000000
kworker/0:3-1706 [000] .... 46.692657: rtcpu_vinotify_event: tstamp:1814657130 tag:FE channel:0x00 frame:0 vi_tstamp:1814656287 data:0x00000022
kworker/0:3-1706 [000] .... 46.692658: rtcpu_vinotify_error: tstamp:1814674474 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1814673811 data:0x00000100
kworker/0:3-1706 [000] .... 46.692659: rtcpu_vinotify_event: tstamp:1814952095 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:0 vi_tstamp:1814656287 data:0x01000000
kworker/0:3-1706 [000] .... 46.692660: rtcpu_vinotify_event: tstamp:1814952223 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:2234429088 data:0x01020001
kworker/0:3-1706 [000] .... 46.692660: rtcpu_vinotify_event: tstamp:1814952368 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1814656287 data:0x00000000
kworker/0:3-1706 [000] .... 46.692661: rtcpu_vinotify_event: tstamp:1814952498 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1814673811 data:0x00000100
kworker/0:3-1706 [000] .... 46.692662: rtcpu_vinotify_error: tstamp:1816025291 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1816024621 data:0x00000100
kworker/0:3-1706 [000] .... 46.692662: rtcpu_vinotify_event: tstamp:1816204146 tag:FS channel:0x00 frame:0 vi_tstamp:1816006837 data:0x00000012
kworker/0:3-1706 [000] .... 46.692663: rtcpu_vinotify_event: tstamp:1816204271 tag:FE channel:0x00 frame:0 vi_tstamp:1816007097 data:0x00000022
kworker/0:3-1706 [000] .... 46.692664: rtcpu_vinotify_event: tstamp:1816204421 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1816024621 data:0x00000100
kworker/0:3-1706 [000] .... 46.752607: rtos_queue_peek_from_isr_failed: tstamp:1816710691 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 46.752611: rtcpu_vinotify_error: tstamp:1817374706 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1817374032 data:0x00000100
kworker/0:3-1706 [000] .... 46.752613: rtcpu_vinotify_event: tstamp:1817456107 tag:FS channel:0x00 frame:0 vi_tstamp:1817356247 data:0x00000012
kworker/0:3-1706 [000] .... 46.752614: rtcpu_vinotify_event: tstamp:1817456249 tag:FE channel:0x00 frame:0 vi_tstamp:1817356509 data:0x00000022
kworker/0:3-1706 [000] .... 46.752615: rtcpu_vinotify_event: tstamp:1817456382 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1817374032 data:0x00000100
kworker/0:3-1706 [000] .... 46.812494: rtcpu_vinotify_event: tstamp:1818708184 tag:FS channel:0x00 frame:0 vi_tstamp:1818705659 data:0x00000012
kworker/0:3-1706 [000] .... 46.812499: rtcpu_vinotify_event: tstamp:1818708318 tag:FE channel:0x00 frame:0 vi_tstamp:1818705919 data:0x00000022
kworker/0:3-1706 [000] .... 46.812533: rtcpu_vinotify_error: tstamp:1818724119 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1818723444 data:0x00000100
kworker/0:3-1706 [000] .... 46.812535: rtcpu_vinotify_event: tstamp:1819021208 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1818723444 data:0x00000100
kworker/0:3-1706 [000] .... 46.812536: rtcpu_vinotify_error: tstamp:1820073521 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1820072855 data:0x00000100
kworker/0:3-1706 [000] .... 46.812538: rtcpu_vinotify_event: tstamp:1820073808 tag:FS channel:0x00 frame:0 vi_tstamp:1820055071 data:0x00000012
kworker/0:3-1706 [000] .... 46.812539: rtcpu_vinotify_event: tstamp:1820073949 tag:FE channel:0x00 frame:0 vi_tstamp:1820055331 data:0x00000022
kworker/0:3-1706 [000] .... 46.812541: rtcpu_vinotify_event: tstamp:1820074078 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1820072855 data:0x00000100
kworker/0:3-1706 [000] .... 46.872410: rtcpu_vinotify_error: tstamp:1821424342 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1821423664 data:0x00000100
kworker/0:3-1706 [000] .... 46.872413: rtcpu_vinotify_event: tstamp:1821431325 tag:FS channel:0x00 frame:0 vi_tstamp:1821405880 data:0x00000012
kworker/0:3-1706 [000] .... 46.872415: rtcpu_vinotify_event: tstamp:1821431449 tag:FE channel:0x00 frame:0 vi_tstamp:1821406141 data:0x00000022
kworker/0:3-1706 [000] .... 46.872416: rtcpu_vinotify_event: tstamp:1821431596 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1821423664 data:0x00000100
kworker/0:3-1706 [000] .... 46.872419: rtos_queue_peek_from_isr_failed: tstamp:1821710692 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 46.932256: rtcpu_vinotify_error: tstamp:1822773747 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1822773076 data:0x00000100
kworker/0:3-1706 [000] .... 46.932260: rtcpu_vinotify_event: tstamp:1822996331 tag:FS channel:0x00 frame:0 vi_tstamp:1822755292 data:0x00000012
kworker/0:3-1706 [000] .... 46.932261: rtcpu_vinotify_event: tstamp:1822996519 tag:FE channel:0x00 frame:0 vi_tstamp:1822755552 data:0x00000022
kworker/0:3-1706 [000] .... 46.932262: rtcpu_vinotify_event: tstamp:1822996650 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1822773076 data:0x00000100
kworker/0:3-1706 [000] .... 46.992164: rtcpu_vinotify_error: tstamp:1824123163 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1824122488 data:0x00000100
kworker/0:3-1706 [000] .... 46.992167: rtcpu_vinotify_event: tstamp:1824248293 tag:FS channel:0x00 frame:0 vi_tstamp:1824104703 data:0x00000012
kworker/0:3-1706 [000] .... 46.992169: rtcpu_vinotify_event: tstamp:1824248418 tag:FE channel:0x00 frame:0 vi_tstamp:1824104964 data:0x00000022
kworker/0:3-1706 [000] .... 46.992170: rtcpu_vinotify_event: tstamp:1824248569 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1824122488 data:0x00000100
kworker/0:3-1706 [000] .... 46.992171: rtcpu_vinotify_error: tstamp:1825473966 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1825473296 data:0x00000100
kworker/0:3-1706 [000] .... 46.992172: rtcpu_vinotify_event: tstamp:1825500353 tag:FS channel:0x00 frame:0 vi_tstamp:1825455513 data:0x00000012
kworker/0:3-1706 [000] .... 46.992174: rtcpu_vinotify_event: tstamp:1825500497 tag:FE channel:0x00 frame:0 vi_tstamp:1825455774 data:0x00000022
kworker/0:3-1706 [000] .... 46.992175: rtcpu_vinotify_event: tstamp:1825500630 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1825473296 data:0x00000100
kworker/0:3-1706 [000] .... 47.052058: rtos_queue_peek_from_isr_failed: tstamp:1826710692 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 47.052061: rtcpu_vinotify_error: tstamp:1826823380 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1826822709 data:0x00000100
kworker/0:3-1706 [000] .... 47.052063: rtcpu_vinotify_event: tstamp:1827065352 tag:FS channel:0x00 frame:0 vi_tstamp:1826804924 data:0x00000012
kworker/0:3-1706 [000] .... 47.052065: rtcpu_vinotify_event: tstamp:1827065478 tag:FE channel:0x00 frame:0 vi_tstamp:1826805185 data:0x00000022
kworker/0:3-1706 [000] .... 47.052066: rtcpu_vinotify_event: tstamp:1827065631 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1826822709 data:0x00000100
kworker/0:3-1706 [000] .... 47.111950: rtcpu_vinotify_event: tstamp:1828154858 tag:FS channel:0x00 frame:0 vi_tstamp:1828154336 data:0x00000012
kworker/0:3-1706 [000] .... 47.111953: rtcpu_vinotify_error: tstamp:1828172782 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1828172120 data:0x00000100
kworker/0:3-1706 [000] .... 47.111955: rtcpu_vinotify_event: tstamp:1828442540 tag:FE channel:0x00 frame:0 vi_tstamp:1828154596 data:0x00000022
kworker/0:3-1706 [000] .... 47.111956: rtcpu_vinotify_event: tstamp:1828442673 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1828172120 data:0x00000100
kworker/0:3-1706 [000] .... 47.171898: rtcpu_vinotify_error: tstamp:1829522205 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1829521531 data:0x00000100
kworker/0:3-1706 [000] .... 47.171903: rtcpu_vinotify_event: tstamp:1829694596 tag:FS channel:0x00 frame:0 vi_tstamp:1829503747 data:0x00000012
kworker/0:3-1706 [000] .... 47.171905: rtcpu_vinotify_event: tstamp:1829694721 tag:FE channel:0x00 frame:0 vi_tstamp:1829504008 data:0x00000022
kworker/0:3-1706 [000] .... 47.171906: rtcpu_vinotify_event: tstamp:1829694874 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1829521531 data:0x00000100
kworker/0:3-1706 [000] .... 47.171907: rtcpu_vinotify_error: tstamp:1830873008 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1830872341 data:0x00000100
kworker/0:3-1706 [000] .... 47.171908: rtcpu_vinotify_event: tstamp:1830946651 tag:FS channel:0x00 frame:0 vi_tstamp:1830854557 data:0x00000012
kworker/0:3-1706 [000] .... 47.171909: rtcpu_vinotify_event: tstamp:1830946795 tag:FE channel:0x00 frame:0 vi_tstamp:1830854817 data:0x00000022
kworker/0:3-1706 [000] .... 47.171910: rtcpu_vinotify_event: tstamp:1830946926 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1830872341 data:0x00000100
kworker/0:3-1706 [000] .... 47.227845: rtos_queue_peek_from_isr_failed: tstamp:1831710692 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 47.227849: rtcpu_vinotify_error: tstamp:1832222422 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1832221753 data:0x00000100
kworker/0:3-1706 [000] .... 47.227850: rtcpu_vinotify_event: tstamp:1832511649 tag:FS channel:0x00 frame:0 vi_tstamp:1832203968 data:0x00000012
kworker/0:3-1706 [000] .... 47.227852: rtcpu_vinotify_event: tstamp:1832511773 tag:FE channel:0x00 frame:0 vi_tstamp:1832204229 data:0x00000022
kworker/0:3-1706 [000] .... 47.227853: rtcpu_vinotify_event: tstamp:1832511922 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1832221753 data:0x00000100
kworker/0:3-1706 [000] .... 47.287765: rtcpu_vinotify_error: tstamp:1833571832 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1833571164 data:0x00000100
kworker/0:3-1706 [000] .... 47.287785: rtcpu_vinotify_event: tstamp:1833763612 tag:FS channel:0x00 frame:0 vi_tstamp:1833553379 data:0x00000012
kworker/0:3-1706 [000] .... 47.287787: rtcpu_vinotify_event: tstamp:1833763757 tag:FE channel:0x00 frame:0 vi_tstamp:1833553640 data:0x00000022
kworker/0:3-1706 [000] .... 47.287788: rtcpu_vinotify_event: tstamp:1833763888 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1833571164 data:0x00000100
kworker/0:3-1706 [000] .... 47.287789: rtcpu_vinotify_event: tstamp:1834904975 tag:FS channel:0x00 frame:0 vi_tstamp:1834904189 data:0x00000012
kworker/0:3-1706 [000] .... 47.287790: rtcpu_vinotify_event: tstamp:1834905099 tag:FE channel:0x00 frame:0 vi_tstamp:1834904450 data:0x00000022
kworker/0:3-1706 [000] .... 47.287791: rtcpu_vinotify_error: tstamp:1834922637 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1834921973 data:0x00000100
kworker/0:3-1706 [000] .... 47.347613: rtcpu_vinotify_event: tstamp:1835203507 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1834921973 data:0x00000100
kworker/0:3-1706 [000] .... 47.347616: rtcpu_vinotify_error: tstamp:1836272053 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1836271385 data:0x00000100
kworker/0:3-1706 [000] .... 47.347618: rtcpu_vinotify_event: tstamp:1836455465 tag:FS channel:0x00 frame:0 vi_tstamp:1836253601 data:0x00000012
kworker/0:3-1706 [000] .... 47.347619: rtcpu_vinotify_event: tstamp:1836455609 tag:FE channel:0x00 frame:0 vi_tstamp:1836253861 data:0x00000022
kworker/0:3-1706 [000] .... 47.347637: rtcpu_vinotify_event: tstamp:1836455740 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1836271385 data:0x00000100
kworker/0:3-1706 [000] .... 47.347640: rtos_queue_peek_from_isr_failed: tstamp:1836710692 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 47.407501: rtcpu_vinotify_error: tstamp:1837621510 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1837620796 data:0x00000100
kworker/0:3-1706 [000] .... 47.407504: rtcpu_vinotify_event: tstamp:1837707515 tag:FS channel:0x00 frame:0 vi_tstamp:1837603012 data:0x00000012
kworker/0:3-1706 [000] .... 47.407505: rtcpu_vinotify_event: tstamp:1837707640 tag:FE channel:0x00 frame:0 vi_tstamp:1837603273 data:0x00000022
kworker/0:3-1706 [000] .... 47.407506: rtcpu_vinotify_event: tstamp:1837707791 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1837620796 data:0x00000100
kworker/0:3-1706 [000] .... 47.467406: rtcpu_vinotify_event: tstamp:1838959502 tag:FS channel:0x00 frame:0 vi_tstamp:1838953822 data:0x00000012
kworker/0:3-1706 [000] .... 47.467408: rtcpu_vinotify_event: tstamp:1838959648 tag:FE channel:0x00 frame:0 vi_tstamp:1838954083 data:0x00000022
kworker/0:3-1706 [000] .... 47.467410: rtcpu_vinotify_error: tstamp:1838972279 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1838971606 data:0x00000100
kworker/0:3-1706 [000] .... 47.467411: rtcpu_vinotify_event: tstamp:1839272528 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1838971606 data:0x00000100
kworker/0:3-1706 [000] .... 47.467455: rtcpu_vinotify_error: tstamp:1840321689 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1840321017 data:0x00000100
kworker/0:3-1706 [000] .... 47.467457: rtcpu_vinotify_event: tstamp:1840524574 tag:FS channel:0x00 frame:0 vi_tstamp:1840303234 data:0x00000012
kworker/0:3-1706 [000] .... 47.467458: rtcpu_vinotify_event: tstamp:1840524713 tag:FE channel:0x00 frame:0 vi_tstamp:1840303494 data:0x00000022
kworker/0:3-1706 [000] .... 47.467459: rtcpu_vinotify_event: tstamp:1840524863 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1840321017 data:0x00000100
kworker/0:3-1706 [000] .... 47.527299: rtcpu_vinotify_error: tstamp:1841671098 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1841670429 data:0x00000100
kworker/0:3-1706 [000] .... 47.527302: rtcpu_vinotify_event: tstamp:1841671386 tag:FS channel:0x00 frame:0 vi_tstamp:1841652645 data:0x00000012
kworker/0:3-1706 [000] .... 47.527303: rtcpu_vinotify_event: tstamp:1841671530 tag:FE channel:0x00 frame:0 vi_tstamp:1841652906 data:0x00000022
kworker/0:3-1706 [000] .... 47.527305: rtcpu_vinotify_event: tstamp:1841671659 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1841670429 data:0x00000100
kworker/0:3-1706 [000] .... 47.527306: rtos_queue_peek_from_isr_failed: tstamp:1841710692 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 47.587208: rtcpu_vinotify_error: tstamp:1843020517 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1843019841 data:0x00000100
kworker/0:3-1706 [000] .... 47.587211: rtcpu_vinotify_event: tstamp:1843028608 tag:FS channel:0x00 frame:0 vi_tstamp:1843002056 data:0x00000012
kworker/0:3-1706 [000] .... 47.587213: rtcpu_vinotify_event: tstamp:1843028731 tag:FE channel:0x00 frame:0 vi_tstamp:1843002317 data:0x00000022
kworker/0:3-1706 [000] .... 47.587214: rtcpu_vinotify_event: tstamp:1843028879 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1843019841 data:0x00000100
kworker/0:3-1706 [000] .... 47.647124: rtcpu_vinotify_error: tstamp:1844371321 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1844370650 data:0x00000100
kworker/0:3-1706 [000] .... 47.647127: rtcpu_vinotify_event: tstamp:1844593608 tag:FS channel:0x00 frame:0 vi_tstamp:1844352866 data:0x00000012
kworker/0:3-1706 [000] .... 47.647128: rtcpu_vinotify_event: tstamp:1844593749 tag:FE channel:0x00 frame:0 vi_tstamp:1844353126 data:0x00000022
kworker/0:3-1706 [000] .... 47.647130: rtcpu_vinotify_event: tstamp:1844593880 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1844370650 data:0x00000100
kworker/0:3-1706 [000] .... 47.647131: rtcpu_vinotify_error: tstamp:1845720732 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1845720062 data:0x00000100
kworker/0:3-1706 [000] .... 47.647132: rtcpu_vinotify_event: tstamp:1845845571 tag:FS channel:0x00 frame:0 vi_tstamp:1845702278 data:0x00000012
kworker/0:3-1706 [000] .... 47.647182: rtcpu_vinotify_event: tstamp:1845845696 tag:FE channel:0x00 frame:0 vi_tstamp:1845702538 data:0x00000022
kworker/0:3-1706 [000] .... 47.647184: rtcpu_vinotify_event: tstamp:1845845846 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1845720062 data:0x00000100
kworker/0:3-1706 [000] .... 47.703027: rtos_queue_peek_from_isr_failed: tstamp:1846710693 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 47.703031: rtcpu_vinotify_error: tstamp:1847070143 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1847069472 data:0x00000100
kworker/0:3-1706 [000] .... 47.703032: rtcpu_vinotify_event: tstamp:1847097629 tag:FS channel:0x00 frame:0 vi_tstamp:1847051689 data:0x00000012
kworker/0:3-1706 [000] .... 47.703034: rtcpu_vinotify_event: tstamp:1847097773 tag:FE channel:0x00 frame:0 vi_tstamp:1847051950 data:0x00000022
kworker/0:3-1706 [000] .... 47.703036: rtcpu_vinotify_event: tstamp:1847097904 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1847069472 data:0x00000100
kworker/0:3-1706 [000] .... 47.762990: rtcpu_vinotify_error: tstamp:1848420954 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1848420283 data:0x00000100
kworker/0:3-1706 [000] .... 47.762994: rtcpu_vinotify_event: tstamp:1848662629 tag:FS channel:0x00 frame:0 vi_tstamp:1848402499 data:0x00000012
kworker/0:3-1706 [000] .... 47.762996: rtcpu_vinotify_event: tstamp:1848662754 tag:FE channel:0x00 frame:0 vi_tstamp:1848402759 data:0x00000022
kworker/0:3-1706 [000] .... 47.762997: rtcpu_vinotify_event: tstamp:1848662905 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1848420283 data:0x00000100
kworker/0:3-1706 [000] .... 47.762998: rtcpu_vinotify_event: tstamp:1849752433 tag:FS channel:0x00 frame:0 vi_tstamp:1849751910 data:0x00000012
kworker/0:3-1706 [000] .... 47.762999: rtcpu_vinotify_error: tstamp:1849770355 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1849769694 data:0x00000100
kworker/0:3-1706 [000] .... 47.822839: rtcpu_vinotify_event: tstamp:1850039818 tag:FE channel:0x00 frame:0 vi_tstamp:1849752171 data:0x00000022
kworker/0:3-1706 [000] .... 47.822842: rtcpu_vinotify_event: tstamp:1850039953 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1849769694 data:0x00000100
kworker/0:3-1706 [000] .... 47.822844: rtcpu_vinotify_error: tstamp:1851119775 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1851119105 data:0x00000100
kworker/0:3-1706 [000] .... 47.822845: rtcpu_vinotify_event: tstamp:1851291872 tag:FS channel:0x00 frame:0 vi_tstamp:1851101321 data:0x00000012
kworker/0:3-1706 [000] .... 47.822846: rtcpu_vinotify_event: tstamp:1851291996 tag:FE channel:0x00 frame:0 vi_tstamp:1851101582 data:0x00000022
kworker/0:3-1706 [000] .... 47.822847: rtcpu_vinotify_event: tstamp:1851292147 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1851119105 data:0x00000100
kworker/0:3-1706 [000] .... 47.882738: rtos_queue_peek_from_isr_failed: tstamp:1851710693 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 47.882742: rtcpu_vinotify_error: tstamp:1852469190 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1852468517 data:0x00000100
kworker/0:3-1706 [000] .... 47.882743: rtcpu_vinotify_event: tstamp:1852543927 tag:FS channel:0x00 frame:0 vi_tstamp:1852450733 data:0x00000012
kworker/0:3-1706 [000] .... 47.882745: rtcpu_vinotify_event: tstamp:1852544071 tag:FE channel:0x00 frame:0 vi_tstamp:1852450993 data:0x00000022
kworker/0:3-1706 [000] .... 47.882746: rtcpu_vinotify_event: tstamp:1852544202 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1852468517 data:0x00000100
kworker/0:3-1706 [000] .... 47.942654: rtcpu_vinotify_error: tstamp:1853819998 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1853819327 data:0x00000100
kworker/0:3-1706 [000] .... 47.942656: rtcpu_vinotify_event: tstamp:1854108926 tag:FS channel:0x00 frame:0 vi_tstamp:1853801543 data:0x00000012
kworker/0:3-1706 [000] .... 47.942658: rtcpu_vinotify_event: tstamp:1854109050 tag:FE channel:0x00 frame:0 vi_tstamp:1853801803 data:0x00000022
kworker/0:3-1706 [000] .... 47.942659: rtcpu_vinotify_event: tstamp:1854109198 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1853819327 data:0x00000100
kworker/0:3-1706 [000] .... 47.942660: rtcpu_vinotify_error: tstamp:1855169408 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1855168738 data:0x00000100
kworker/0:3-1706 [000] .... 47.942662: rtcpu_vinotify_event: tstamp:1855360894 tag:FS channel:0x00 frame:0 vi_tstamp:1855150954 data:0x00000012
kworker/0:3-1706 [000] .... 47.942663: rtcpu_vinotify_event: tstamp:1855361037 tag:FE channel:0x00 frame:0 vi_tstamp:1855151215 data:0x00000022
kworker/0:3-1706 [000] .... 47.942664: rtcpu_vinotify_event: tstamp:1855361168 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1855168738 data:0x00000100
kworker/0:3-1706 [000] .... 48.002630: rtcpu_vinotify_event: tstamp:1856501147 tag:FS channel:0x00 frame:0 vi_tstamp:1856500365 data:0x00000012
kworker/0:3-1706 [000] .... 48.002634: rtcpu_vinotify_event: tstamp:1856501270 tag:FE channel:0x00 frame:0 vi_tstamp:1856500626 data:0x00000022
kworker/0:3-1706 [000] .... 48.002636: rtcpu_vinotify_error: tstamp:1856518816 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1856518149 data:0x00000100
kworker/0:3-1706 [000] .... 48.002638: rtos_queue_peek_from_isr_failed: tstamp:1856710691 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 48.002640: rtcpu_vinotify_event: tstamp:1856800788 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1856518149 data:0x00000100
kworker/0:3-1706 [000] .... 48.058484: rtcpu_vinotify_error: tstamp:1857869630 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1857868959 data:0x00000100
kworker/0:3-1706 [000] .... 48.058489: rtcpu_vinotify_event: tstamp:1858052742 tag:FS channel:0x00 frame:0 vi_tstamp:1857851176 data:0x00000012
kworker/0:3-1706 [000] .... 48.058490: rtcpu_vinotify_event: tstamp:1858052887 tag:FE channel:0x00 frame:0 vi_tstamp:1857851436 data:0x00000022
kworker/0:3-1706 [000] .... 48.058491: rtcpu_vinotify_event: tstamp:1858053018 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1857868959 data:0x00000100
kworker/0:3-1706 [000] .... 48.114400: rtcpu_vinotify_error: tstamp:1859219043 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1859218371 data:0x00000100
kworker/0:3-1706 [000] .... 48.114419: rtcpu_vinotify_event: tstamp:1859304798 tag:FS channel:0x00 frame:0 vi_tstamp:1859200587 data:0x00000012
kworker/0:3-1706 [000] .... 48.114420: rtcpu_vinotify_event: tstamp:1859304923 tag:FE channel:0x00 frame:0 vi_tstamp:1859200847 data:0x00000022
kworker/0:3-1706 [000] .... 48.114421: rtcpu_vinotify_event: tstamp:1859305072 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1859218371 data:0x00000100
kworker/0:3-1706 [000] .... 48.114422: rtcpu_vinotify_event: tstamp:1860556781 tag:FS channel:0x00 frame:0 vi_tstamp:1860549998 data:0x00000012
kworker/0:3-1706 [000] .... 48.114422: rtcpu_vinotify_event: tstamp:1860556925 tag:FE channel:0x00 frame:0 vi_tstamp:1860550259 data:0x00000022
kworker/0:3-1706 [000] .... 48.114423: rtcpu_vinotify_error: tstamp:1860568453 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1860567782 data:0x00000100
kworker/0:3-1706 [000] .... 48.170349: rtcpu_vinotify_event: tstamp:1860869809 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1860567782 data:0x00000100
kworker/0:3-1706 [000] .... 48.170355: rtos_queue_peek_from_isr_failed: tstamp:1861710692 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 48.170356: rtcpu_vinotify_error: tstamp:1861917865 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1861917194 data:0x00000100
kworker/0:3-1706 [000] .... 48.170357: rtcpu_vinotify_event: tstamp:1862121821 tag:FS channel:0x00 frame:0 vi_tstamp:1861899410 data:0x00000012
kworker/0:3-1706 [000] .... 48.170358: rtcpu_vinotify_event: tstamp:1862121947 tag:FE channel:0x00 frame:0 vi_tstamp:1861899670 data:0x00000022
kworker/0:3-1706 [000] .... 48.170358: rtcpu_vinotify_event: tstamp:1862122096 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1861917194 data:0x00000100
kworker/0:3-1706 [000] .... 48.226268: rtcpu_vinotify_error: tstamp:1863268676 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1863268003 data:0x00000100
kworker/0:3-1706 [000] .... 48.226273: rtcpu_vinotify_event: tstamp:1863268962 tag:FS channel:0x00 frame:0 vi_tstamp:1863250220 data:0x00000012
kworker/0:3-1706 [000] .... 48.226274: rtcpu_vinotify_event: tstamp:1863269106 tag:FE channel:0x00 frame:0 vi_tstamp:1863250480 data:0x00000022
kworker/0:3-1706 [000] .... 48.226275: rtcpu_vinotify_event: tstamp:1863269233 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1863268003 data:0x00000100
kworker/0:3-1706 [000] .... 48.286192: rtcpu_vinotify_error: tstamp:1864618091 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1864617414 data:0x00000100
kworker/0:3-1706 [000] .... 48.286198: rtcpu_vinotify_event: tstamp:1864625797 tag:FS channel:0x00 frame:0 vi_tstamp:1864599630 data:0x00000012
kworker/0:3-1706 [000] .... 48.286200: rtcpu_vinotify_event: tstamp:1864625920 tag:FE channel:0x00 frame:0 vi_tstamp:1864599892 data:0x00000022
kworker/0:3-1706 [000] .... 48.286201: rtcpu_vinotify_event: tstamp:1864626069 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1864617414 data:0x00000100
kworker/0:3-1706 [000] .... 48.286202: rtcpu_vinotify_error: tstamp:1865967494 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1865966826 data:0x00000100
kworker/0:3-1706 [000] .... 48.346094: rtcpu_vinotify_event: tstamp:1866190890 tag:FS channel:0x00 frame:0 vi_tstamp:1865949042 data:0x00000012
kworker/0:3-1706 [000] .... 48.346099: rtcpu_vinotify_event: tstamp:1866191033 tag:FE channel:0x00 frame:0 vi_tstamp:1865949302 data:0x00000022
kworker/0:3-1706 [000] .... 48.346100: rtcpu_vinotify_event: tstamp:1866191164 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1865966826 data:0x00000100
kworker/0:3-1706 [000] .... 48.346103: rtos_queue_peek_from_isr_failed: tstamp:1866710691 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 48.346105: rtcpu_vinotify_error: tstamp:1867318305 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1867317636 data:0x00000100
kworker/0:3-1706 [000] .... 48.346106: rtcpu_vinotify_event: tstamp:1867442852 tag:FS channel:0x00 frame:0 vi_tstamp:1867299852 data:0x00000012
kworker/0:3-1706 [000] .... 48.346108: rtcpu_vinotify_event: tstamp:1867442977 tag:FE channel:0x00 frame:0 vi_tstamp:1867300113 data:0x00000022
kworker/0:3-1706 [000] .... 48.346109: rtcpu_vinotify_event: tstamp:1867443127 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1867317636 data:0x00000100
kworker/0:3-1706 [000] .... 48.406006: rtcpu_vinotify_error: tstamp:1868667716 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1868667047 data:0x00000100
kworker/0:3-1706 [000] .... 48.406012: rtcpu_vinotify_event: tstamp:1868694906 tag:FS channel:0x00 frame:0 vi_tstamp:1868649263 data:0x00000012
kworker/0:3-1706 [000] .... 48.406014: rtcpu_vinotify_event: tstamp:1868695047 tag:FE channel:0x00 frame:0 vi_tstamp:1868649524 data:0x00000022
kworker/0:3-1706 [000] .... 48.406015: rtcpu_vinotify_event: tstamp:1868695178 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1868667047 data:0x00000100
kworker/0:3-1706 [000] .... 48.461870: rtcpu_vinotify_error: tstamp:1870017133 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1870016458 data:0x00000100
kworker/0:3-1706 [000] .... 48.461873: rtcpu_vinotify_event: tstamp:1870259910 tag:FS channel:0x00 frame:0 vi_tstamp:1869998675 data:0x00000012
kworker/0:3-1706 [000] .... 48.461874: rtcpu_vinotify_event: tstamp:1870260033 tag:FE channel:0x00 frame:0 vi_tstamp:1869998935 data:0x00000022
kworker/0:3-1706 [000] .... 48.461876: rtcpu_vinotify_event: tstamp:1870260182 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1870016458 data:0x00000100
kworker/0:3-1706 [000] .... 48.461877: rtcpu_vinotify_event: tstamp:1871348608 tag:FS channel:0x00 frame:0 vi_tstamp:1871348086 data:0x00000012
kworker/0:3-1706 [000] .... 48.461878: rtcpu_vinotify_error: tstamp:1871366533 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1871365871 data:0x00000100
kworker/0:3-1706 [000] .... 48.461879: rtcpu_vinotify_event: tstamp:1871637101 tag:FE channel:0x00 frame:0 vi_tstamp:1871348347 data:0x00000022
kworker/0:3-1706 [000] .... 48.461880: rtcpu_vinotify_event: tstamp:1871637234 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1871365871 data:0x00000100
kworker/0:3-1706 [000] .... 48.521817: rtos_queue_peek_from_isr_failed: tstamp:1871710693 queue:0x0bcbcf78
kworker/0:3-1706 [000] .... 48.521821: rtcpu_vinotify_error: tstamp:1872717349 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1872716679 data:0x00000100
kworker/0:3-1706 [000] .... 48.521823: rtcpu_vinotify_event: tstamp:1872889154 tag:FS channel:0x00 frame:0 vi_tstamp:1872698896 data:0x00000012
kworker/0:3-1706 [000] .... 48.521824: rtcpu_vinotify_event: tstamp:1872889279 tag:FE channel:0x00 frame:0 vi_tstamp:1872699157 data:0x00000022
kworker/0:3-1706 [000] .... 48.521826: rtcpu_vinotify_event: tstamp:1872889429 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1872716679 data:0x00000100
kworker/0:3-1706 [000] .... 48.581697: rtcpu_vinotify_error: tstamp:1874066763 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1874066091 data:0x00000100
kworker/0:3-1706 [000] .... 48.581700: rtcpu_vinotify_event: tstamp:1874141112 tag:FS channel:0x00 frame:0 vi_tstamp:1874048307 data:0x00000012
kworker/0:3-1706 [000] .... 48.581701: rtcpu_vinotify_event: tstamp:1874141255 tag:FE channel:0x00 frame:0 vi_tstamp:1874048567 data:0x00000022
kworker/0:3-1706 [000] .... 48.581703: rtcpu_vinotify_event: tstamp:1874141387 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1874066091 data:0x00000100
kworker/0:3-1706 [000] .... 48.641600: rtcpu_vinotify_error: tstamp:1875416173 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1875415503 data:0x00000100
kworker/0:3-1706 [000] .... 48.641603: rtcpu_vinotify_event: tstamp:1875706205 tag:FS channel:0x00 frame:0 vi_tstamp:1875397719 data:0x00000012
kworker/0:3-1706 [000] .... 48.641605: rtcpu_vinotify_event: tstamp:1875706331 tag:FE channel:0x00 frame:0 vi_tstamp:1875397979 data:0x00000022
kworker/0:3-1706 [000] .... 48.641606: rtcpu_vinotify_event: tstamp:1875706480 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1875415503 data:0x00000100
kworker/0:3-1706 [000] .... 48.641608: rtos_queue_peek_from_isr_failed: tstamp:1876710691 queue:0x0bcbcf78
and debug log:
[ 40.595696] imx390 8-0024: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 40.597822] imx390 8-0024: camera_common_dpd_disable: csi 2
[ 40.597851] imx390 8-0024: camera_common_dpd_disable: csi 3
[ 40.597867] t194-nvcsi 15a00000.nvcsi: csi5_power_on
[ 40.598998] imx390 8-0024: camera_common_dpd_enable: csi 2
[ 40.599026] imx390 8-0024: camera_common_dpd_enable: csi 3
[ 40.599031] imx390 8-0024: camera_common_mclk_disable: disable MCLK
[ 40.601676] t194-nvcsi 15a00000.nvcsi: csi5_power_off
[ 46.324566] imx390 8-0024: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 46.324867] imx390 8-0024: camera_common_dpd_disable: csi 2
[ 46.324906] imx390 8-0024: camera_common_dpd_disable: csi 3
[ 46.324915] t194-nvcsi 15a00000.nvcsi: csi5_power_on
[ 46.326230] t194-nvcsi 15a00000.nvcsi: csi5_mipi_cal
[ 46.326238] t194-nvcsi 15a00000.nvcsi: csi_port:2
[ 46.326487] imx390 8-0024: camera_common_dpd_enable: csi 2
[ 46.326511] imx390 8-0024: camera_common_dpd_enable: csi 3
[ 46.326515] imx390 8-0024: camera_common_mclk_disable: disable MCLK
[ 46.326622] t194-nvcsi 15a00000.nvcsi: csi5_power_off
[ 46.465284] imx390 8-0024: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 46.475165] imx390 8-0024: camera_common_dpd_disable: csi 2
[ 46.475219] imx390 8-0024: camera_common_dpd_disable: csi 3
[ 46.475248] t194-nvcsi 15a00000.nvcsi: csi5_power_on
[ 46.475506] imx390 8-0024: camera_common_dpd_enable: csi 2
[ 46.475541] imx390 8-0024: camera_common_dpd_enable: csi 3
[ 46.475550] imx390 8-0024: camera_common_mclk_disable: disable MCLK
[ 46.476375] t194-nvcsi 15a00000.nvcsi: csi5_power_off
[ 46.512033] imx390 8-0024: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 46.517486] imx390 8-0024: camera_common_dpd_disable: csi 2
[ 46.517518] imx390 8-0024: camera_common_dpd_disable: csi 3
[ 46.517540] t194-nvcsi 15a00000.nvcsi: csi5_power_on
[ 46.520101] imx390 8-0024: camera_common_try_fmt: size 1280 x 720
[ 46.520112] imx390 8-0024: camera_common_try_fmt: use_sensor_mode_id 1
[ 46.520123] imx390 8-0024: camera_common_s_fmt(8198) size 1280 x 720
[ 46.520135] imx390 8-0024: camera_common_try_fmt: size 1280 x 720
[ 46.520142] imx390 8-0024: camera_common_try_fmt: use_sensor_mode_id 1
[ 46.520155] video4linux video0: tegra_channel_update_format: Resolution= 1280x720 bytesperline=2560
[ 46.528746] tegra194-vi5 15c10000.vi: vi_channel_power_on_vi_device
[ 46.528760] tegra194-vi5 15c10000.vi: vi_capture_init++
[ 46.529255] tegra194-vi5 15c10000.vi: chan flags 4163
[ 46.529263] tegra194-vi5 15c10000.vi: chan mask ffffffffffffffff
[ 46.529267] tegra194-vi5 15c10000.vi: queue depth 4
[ 46.529272] tegra194-vi5 15c10000.vi: request size 704
[ 46.547751] tegra194-vi5 15c10000.vi: 6 GoS tables configured.
[ 46.547768] tegra194-vi5 15c10000.vi: gos[0] = 0xc2100000
[ 46.547788] tegra194-vi5 15c10000.vi: gos[1] = 0xc2101000
[ 46.547792] tegra194-vi5 15c10000.vi: gos[2] = 0xc2102000
[ 46.547795] tegra194-vi5 15c10000.vi: gos[3] = 0xc2103000
[ 46.547799] tegra194-vi5 15c10000.vi: gos[4] = 0xc2104000
[ 46.547804] tegra194-vi5 15c10000.vi: gos[5] = 0xc2105000
[ 46.547812] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 64 msg_id 16
[ 46.548689] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 64 msg_id 17
[ 46.549182] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:0
[ 46.549195] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:1
[ 46.549203] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:2
[ 46.549211] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:3
[ 46.549368] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 46.555310] t194-nvcsi 15a00000.nvcsi: csi5_start_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 46.555319] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=2, csi_port=2
[ 46.555328] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=2, csi_port=2
[ 46.555340] imx390 8-0024: imx390_set_mode:
[ 46.555446] imx390 8-0024: imx390_write_table:
[ 46.555523] imx390 8-0024: imx390_start_streaming:
[ 46.555607] max9296 8-0048: In max9296_setup_pipeline g_ctx->num_streams = 2
[ 46.555728] max9296 8-0048: In max9296_setup_pipeline index = 0 g_stream->st_data_type = 30
[ 46.555862] max9296 8-0048: In max9296_setup_pipeline index = 1 g_stream->st_data_type = 2C
[ 46.556002] max9296_get_available_pipe:line=569,i=0,dt_type=44,st_data_type=44,dst_csi_prot=0,dst_csi_ctrl=1,st_count=0
[ 46.556171] ##MAX9296:Directly out of
[ 46.556174] imx390 8-0024: imx390_write_table:
[ 46.576879] [RCE] Configuring VI GoS.
[ 46.576893] [RCE] VM GOS[#0] addr=0xc2100000
[ 46.576901] [RCE] VM GOS[#1] addr=0xc2101000
[ 46.576911] [RCE] VM GOS[#2] addr=0xc2102000
[ 46.576919] [RCE] VM GOS[#3] addr=0xc2103000
[ 46.576928] [RCE] VM GOS[#4] addr=0xc2104000
[ 46.576936] [RCE] VM GOS[#5] addr=0xc2105000
[ 46.576947] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 46.576959] [RCE] VI GOS[#0] set to VM GOS[4] base 0xc2104000
[ 46.594834] tegra194-vi5 15c10000.vi: vi_capture_ivc_status_callback: status chan_id 0 msg_id 2
[ 46.594851] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 46.595050] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 46.595074] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:0
[ 49.232753] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 49.232917] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 49.233075] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 49.233224] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 0 msg_id 20
[ 49.233884] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 0 msg_id 21
[ 49.233949] tegra194-vi5 15c10000.vi: vi_capture_shutdown--
[ 49.233956] tegra194-vi5 15c10000.vi: vi_channel_power_off_vi_device
[ 49.235378] t194-nvcsi 15a00000.nvcsi: csi5_stop_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 49.235390] t194-nvcsi 15a00000.nvcsi: csi5_stream_close: stream_id=2, csi_port=2
[ 49.235403] t194-nvcsi 15a00000.nvcsi: csi5_start_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 49.235410] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=2, csi_port=2
[ 49.235418] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=2, csi_port=2
[ 49.235427] tegra194-vi5 15c10000.vi: vi_channel_power_on_vi_device
[ 49.235436] tegra194-vi5 15c10000.vi: vi_capture_init++
[ 49.235522] tegra194-vi5 15c10000.vi: chan flags 4163
[ 49.235544] tegra194-vi5 15c10000.vi: chan mask ffffffffffffffff
[ 49.235551] tegra194-vi5 15c10000.vi: queue depth 4
[ 49.235556] tegra194-vi5 15c10000.vi: request size 704
[ 49.235597] tegra194-vi5 15c10000.vi: 6 GoS tables configured.
[ 49.235604] tegra194-vi5 15c10000.vi: gos[0] = 0xc2100000
[ 49.235611] tegra194-vi5 15c10000.vi: gos[1] = 0xc2101000
[ 49.235617] tegra194-vi5 15c10000.vi: gos[2] = 0xc2102000
[ 49.235624] tegra194-vi5 15c10000.vi: gos[3] = 0xc2103000
[ 49.235630] tegra194-vi5 15c10000.vi: gos[4] = 0xc2104000
[ 49.235636] tegra194-vi5 15c10000.vi: gos[5] = 0xc2105000
[ 49.235644] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 65 msg_id 16
[ 49.235729] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x39
[ 49.235920] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x41
[ 49.236077] tegra-capture-ivc ivc-bc00000.rtcpu:ivccontrol@3: No callback found for msg id: 0x37
[ 49.236286] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 65 msg_id 17
[ 49.236297] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 49.284708] [RCE] Configuring VI GoS.
[ 49.284722] [RCE] VM GOS[#0] addr=0xc2100000
[ 49.284743] [RCE] VM GOS[#1] addr=0xc2101000
[ 49.284752] [RCE] VM GOS[#2] addr=0xc2102000
[ 49.284761] [RCE] VM GOS[#3] addr=0xc2103000
[ 49.284769] [RCE] VM GOS[#4] addr=0xc2104000
[ 49.284778] [RCE] VM GOS[#5] addr=0xc2105000
[ 49.292437] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:0
[ 49.292486] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 49.309590] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:1
[ 49.314117] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:2
[ 49.316041] tegra194-vi5 15c10000.vi: vi_capture_ivc_status_callback: status chan_id 0 msg_id 2
[ 49.316061] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 49.316249] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 49.316258] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:3
[ 52.045151] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 52.045316] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 52.045495] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 52.045642] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 0 msg_id 20
[ 52.045921] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 0 msg_id 21
[ 52.045961] tegra194-vi5 15c10000.vi: vi_capture_shutdown--
[ 52.045969] tegra194-vi5 15c10000.vi: vi_channel_power_off_vi_device
[ 52.047662] t194-nvcsi 15a00000.nvcsi: csi5_stop_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 52.047671] t194-nvcsi 15a00000.nvcsi: csi5_stream_close: stream_id=2, csi_port=2
[ 52.047683] t194-nvcsi 15a00000.nvcsi: csi5_start_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 52.047690] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=2, csi_port=2
[ 52.047698] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=2, csi_port=2
[ 52.047706] tegra194-vi5 15c10000.vi: vi_channel_power_on_vi_device
[ 52.047714] tegra194-vi5 15c10000.vi: vi_capture_init++
[ 52.047797] tegra194-vi5 15c10000.vi: chan flags 4163
[ 52.047807] tegra194-vi5 15c10000.vi: chan mask ffffffffffffffff
[ 52.047813] tegra194-vi5 15c10000.vi: queue depth 4
[ 52.047819] tegra194-vi5 15c10000.vi: request size 704
[ 52.047860] tegra194-vi5 15c10000.vi: 6 GoS tables configured.
[ 52.047867] tegra194-vi5 15c10000.vi: gos[0] = 0xc2100000
[ 52.047873] tegra194-vi5 15c10000.vi: gos[1] = 0xc2101000
[ 52.047880] tegra194-vi5 15c10000.vi: gos[2] = 0xc2102000
[ 52.047887] tegra194-vi5 15c10000.vi: gos[3] = 0xc2103000
[ 52.047893] tegra194-vi5 15c10000.vi: gos[4] = 0xc2104000
[ 52.047899] tegra194-vi5 15c10000.vi: gos[5] = 0xc2105000
[ 52.047935] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 66 msg_id 16
[ 52.048110] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 66 msg_id 17
[ 52.048119] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 52.052056] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:0
[ 52.052162] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 52.057141] [RCE] Configuring VI GoS.
[ 52.057155] [RCE] VM GOS[#0] addr=0xc2100000
[ 52.057164] [RCE] VM GOS[#1] addr=0xc2101000
[ 52.057175] [RCE] VM GOS[#2] addr=0xc2102000
[ 52.057183] [RCE] VM GOS[#3] addr=0xc2103000
[ 52.057197] [RCE] VM GOS[#4] addr=0xc2104000
[ 52.057206] [RCE] VM GOS[#5] addr=0xc2105000
[ 52.057290] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:1
[ 52.059907] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:2
[ 52.080530] tegra194-vi5 15c10000.vi: vi_capture_ivc_status_callback: status chan_id 0 msg_id 2
[ 52.080539] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 52.080564] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 52.080610] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:3
[ 54.602316] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 54.602508] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 54.602656] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 54.602841] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 0 msg_id 20
[ 54.603900] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 0 msg_id 21
[ 54.603935] tegra194-vi5 15c10000.vi: vi_capture_shutdown--
[ 54.603942] tegra194-vi5 15c10000.vi: vi_channel_power_off_vi_device
[ 54.605227] t194-nvcsi 15a00000.nvcsi: csi5_stop_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 54.605239] t194-nvcsi 15a00000.nvcsi: csi5_stream_close: stream_id=2, csi_port=2
[ 54.605252] t194-nvcsi 15a00000.nvcsi: csi5_start_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 54.605260] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=2, csi_port=2
[ 54.605295] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=2, csi_port=2
[ 54.605305] tegra194-vi5 15c10000.vi: vi_channel_power_on_vi_device
[ 54.605315] tegra194-vi5 15c10000.vi: vi_capture_init++
[ 54.605427] tegra194-vi5 15c10000.vi: chan flags 4163
[ 54.605437] tegra194-vi5 15c10000.vi: chan mask ffffffffffffffff
[ 54.605443] tegra194-vi5 15c10000.vi: queue depth 4
[ 54.605449] tegra194-vi5 15c10000.vi: request size 704
[ 54.605493] tegra194-vi5 15c10000.vi: 6 GoS tables configured.
[ 54.605500] tegra194-vi5 15c10000.vi: gos[0] = 0xc2100000
[ 54.605507] tegra194-vi5 15c10000.vi: gos[1] = 0xc2101000
[ 54.605514] tegra194-vi5 15c10000.vi: gos[2] = 0xc2102000
[ 54.605520] tegra194-vi5 15c10000.vi: gos[3] = 0xc2103000
[ 54.605526] tegra194-vi5 15c10000.vi: gos[4] = 0xc2104000
[ 54.605532] tegra194-vi5 15c10000.vi: gos[5] = 0xc2105000
[ 54.605540] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 67 msg_id 16
[ 54.605747] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 67 msg_id 17
[ 54.605760] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 54.609106] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:0
[ 54.609168] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 54.610525] [RCE] Configuring VI GoS.
[ 54.610559] [RCE] VM GOS[#0] addr=0xc2100000
[ 54.610573] [RCE] VM GOS[#1] addr=0xc2101000
[ 54.610587] [RCE] VM GOS[#2] addr=0xc2102000
[ 54.610617] [RCE] VM GOS[#3] addr=0xc2103000
[ 54.610674] [RCE] VM GOS[#4] addr=0xc2104000
[ 54.610690] [RCE] VM GOS[#5] addr=0xc2105000
[ 54.613269] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:1
[ 54.617489] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:2
[ 54.628982] tegra194-vi5 15c10000.vi: vi_capture_ivc_status_callback: status chan_id 0 msg_id 2
[ 54.629010] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 54.629216] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 54.629244] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:3
[ 57.159953] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 57.160116] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 57.160266] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 57.160424] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 0 msg_id 20
[ 57.160891] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 0 msg_id 21
[ 57.160936] tegra194-vi5 15c10000.vi: vi_capture_shutdown--
[ 57.160975] tegra194-vi5 15c10000.vi: vi_channel_power_off_vi_device
[ 57.162690] t194-nvcsi 15a00000.nvcsi: csi5_stop_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 57.162699] t194-nvcsi 15a00000.nvcsi: csi5_stream_close: stream_id=2, csi_port=2
[ 57.162710] t194-nvcsi 15a00000.nvcsi: csi5_start_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 57.162718] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=2, csi_port=2
[ 57.162726] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=2, csi_port=2
[ 57.162734] tegra194-vi5 15c10000.vi: vi_channel_power_on_vi_device
[ 57.162743] tegra194-vi5 15c10000.vi: vi_capture_init++
[ 57.162841] tegra194-vi5 15c10000.vi: chan flags 4163
[ 57.162863] tegra194-vi5 15c10000.vi: chan mask ffffffffffffffff
[ 57.162874] tegra194-vi5 15c10000.vi: queue depth 4
[ 57.162880] tegra194-vi5 15c10000.vi: request size 704
[ 57.162918] tegra194-vi5 15c10000.vi: 6 GoS tables configured.
[ 57.162929] tegra194-vi5 15c10000.vi: gos[0] = 0xc2100000
[ 57.162936] tegra194-vi5 15c10000.vi: gos[1] = 0xc2101000
[ 57.162956] tegra194-vi5 15c10000.vi: gos[2] = 0xc2102000
[ 57.162963] tegra194-vi5 15c10000.vi: gos[3] = 0xc2103000
[ 57.162969] tegra194-vi5 15c10000.vi: gos[4] = 0xc2104000
[ 57.162975] tegra194-vi5 15c10000.vi: gos[5] = 0xc2105000
[ 57.162983] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 68 msg_id 16
[ 57.163145] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 68 msg_id 17
[ 57.163158] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 57.187706] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:0
[ 57.187735] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 57.192429] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:1
[ 57.196381] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:2
[ 57.215993] [RCE] Configuring VI GoS.
[ 57.216016] [RCE] VM GOS[#0] addr=0xc2100000
[ 57.216034] [RCE] VM GOS[#1] addr=0xc2101000
[ 57.216051] [RCE] VM GOS[#2] addr=0xc2102000
[ 57.216068] [RCE] VM GOS[#3] addr=0xc2103000
[ 57.216155] [RCE] VM GOS[#4] addr=0xc2104000
[ 57.216174] [RCE] VM GOS[#5] addr=0xc2105000
[ 57.220616] tegra194-vi5 15c10000.vi: vi_capture_ivc_status_callback: status chan_id 0 msg_id 2
[ 57.221509] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 57.221721] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 57.221757] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:3
[ 59.973778] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 59.973940] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 59.974089] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 59.974245] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 0 msg_id 20
[ 59.984768] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 0 msg_id 21
[ 59.984805] tegra194-vi5 15c10000.vi: vi_capture_shutdown--
[ 59.984810] tegra194-vi5 15c10000.vi: vi_channel_power_off_vi_device
[ 59.986462] t194-nvcsi 15a00000.nvcsi: csi5_stop_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 59.986469] t194-nvcsi 15a00000.nvcsi: csi5_stream_close: stream_id=2, csi_port=2
[ 59.986479] t194-nvcsi 15a00000.nvcsi: csi5_start_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 59.986483] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=2, csi_port=2
[ 59.986487] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=2, csi_port=2
[ 59.986495] tegra194-vi5 15c10000.vi: vi_channel_power_on_vi_device
[ 59.986500] tegra194-vi5 15c10000.vi: vi_capture_init++
[ 59.986600] tegra194-vi5 15c10000.vi: chan flags 4163
[ 59.986605] tegra194-vi5 15c10000.vi: chan mask ffffffffffffffff
[ 59.986608] tegra194-vi5 15c10000.vi: queue depth 4
[ 59.986611] tegra194-vi5 15c10000.vi: request size 704
[ 59.986641] tegra194-vi5 15c10000.vi: 6 GoS tables configured.
[ 59.986644] tegra194-vi5 15c10000.vi: gos[0] = 0xc2100000
[ 59.986648] tegra194-vi5 15c10000.vi: gos[1] = 0xc2101000
[ 59.986651] tegra194-vi5 15c10000.vi: gos[2] = 0xc2102000
[ 59.986654] tegra194-vi5 15c10000.vi: gos[3] = 0xc2103000
[ 59.986657] tegra194-vi5 15c10000.vi: gos[4] = 0xc2104000
[ 59.986660] tegra194-vi5 15c10000.vi: gos[5] = 0xc2105000
[ 59.986665] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 69 msg_id 16
[ 59.986895] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 69 msg_id 17
[ 59.986903] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 59.987094] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:0
[ 59.987106] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 59.989777] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:1
[ 59.993528] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:2
[ 59.993861] [RCE] Configuring VI GoS.
[ 59.993891] [RCE] VM GOS[#0] addr=0xc2100000
[ 59.993905] [RCE] VM GOS[#1] addr=0xc2101000
[ 59.993927] [RCE] VM GOS[#2] addr=0xc2102000
[ 59.993937] [RCE] VM GOS[#3] addr=0xc2103000
[ 59.993965] [RCE] VM GOS[#4] addr=0xc2104000
[ 59.993988] [RCE] VM GOS[#5] addr=0xc2105000
[ 60.028202] tegra194-vi5 15c10000.vi: vi_capture_ivc_status_callback: status chan_id 0 msg_id 2
[ 60.028214] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 60.028414] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 60.028445] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:3
[ 62.532093] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 62.532282] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 62.532438] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 62.532612] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 0 msg_id 20
[ 62.533091] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 0 msg_id 21
[ 62.533127] tegra194-vi5 15c10000.vi: vi_capture_shutdown--
[ 62.533135] tegra194-vi5 15c10000.vi: vi_channel_power_off_vi_device
[ 62.535221] t194-nvcsi 15a00000.nvcsi: csi5_stop_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 62.535232] t194-nvcsi 15a00000.nvcsi: csi5_stream_close: stream_id=2, csi_port=2
[ 62.535246] t194-nvcsi 15a00000.nvcsi: csi5_start_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 62.535253] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=2, csi_port=2
[ 62.535261] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=2, csi_port=2
[ 62.535271] tegra194-vi5 15c10000.vi: vi_channel_power_on_vi_device
[ 62.535280] tegra194-vi5 15c10000.vi: vi_capture_init++
[ 62.535414] tegra194-vi5 15c10000.vi: chan flags 4163
[ 62.535424] tegra194-vi5 15c10000.vi: chan mask ffffffffffffffff
[ 62.535430] tegra194-vi5 15c10000.vi: queue depth 4
[ 62.535435] tegra194-vi5 15c10000.vi: request size 704
[ 62.535479] tegra194-vi5 15c10000.vi: 6 GoS tables configured.
[ 62.535492] tegra194-vi5 15c10000.vi: gos[0] = 0xc2100000
[ 62.535499] tegra194-vi5 15c10000.vi: gos[1] = 0xc2101000
[ 62.535505] tegra194-vi5 15c10000.vi: gos[2] = 0xc2102000
[ 62.535511] tegra194-vi5 15c10000.vi: gos[3] = 0xc2103000
[ 62.535517] tegra194-vi5 15c10000.vi: gos[4] = 0xc2104000
[ 62.535524] tegra194-vi5 15c10000.vi: gos[5] = 0xc2105000
[ 62.535531] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 70 msg_id 16
[ 62.535735] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 70 msg_id 17
[ 62.535750] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 62.548211] [RCE] Configuring VI GoS.
[ 62.548239] [RCE] VM GOS[#0] addr=0xc2100000
[ 62.548248] [RCE] VM GOS[#1] addr=0xc2101000
[ 62.548257] [RCE] VM GOS[#2] addr=0xc2102000
[ 62.548266] [RCE] VM GOS[#3] addr=0xc2103000
[ 62.548289] [RCE] VM GOS[#4] addr=0xc2104000
[ 62.548298] [RCE] VM GOS[#5] addr=0xc2105000
[ 62.579755] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:0
[ 62.579776] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 62.584293] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:1
[ 62.587557] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:2
[ 62.619839] tegra194-vi5 15c10000.vi: vi_capture_ivc_status_callback: status chan_id 0 msg_id 2
[ 62.619848] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 62.619872] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 62.619897] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:3
[ 65.346557] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 65.346720] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 65.346865] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 65.347019] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 0 msg_id 20
[ 65.347875] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 0 msg_id 21
[ 65.347913] tegra194-vi5 15c10000.vi: vi_capture_shutdown--
[ 65.347953] tegra194-vi5 15c10000.vi: vi_channel_power_off_vi_device
[ 65.349324] t194-nvcsi 15a00000.nvcsi: csi5_stop_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 65.349335] t194-nvcsi 15a00000.nvcsi: csi5_stream_close: stream_id=2, csi_port=2
[ 65.349349] t194-nvcsi 15a00000.nvcsi: csi5_start_streaming: csi_pt=2, st_id=2, vc_id=0, pg_mode=0x0
[ 65.349356] t194-nvcsi 15a00000.nvcsi: csi5_stream_set_config: stream_id=2, csi_port=2
[ 65.349396] t194-nvcsi 15a00000.nvcsi: csi5_stream_open: stream_id=2, csi_port=2
[ 65.349408] tegra194-vi5 15c10000.vi: vi_channel_power_on_vi_device
[ 65.349417] tegra194-vi5 15c10000.vi: vi_capture_init++
[ 65.349555] tegra194-vi5 15c10000.vi: chan flags 4163
[ 65.349564] tegra194-vi5 15c10000.vi: chan mask ffffffffffffffff
[ 65.349570] tegra194-vi5 15c10000.vi: queue depth 4
[ 65.349576] tegra194-vi5 15c10000.vi: request size 704
[ 65.349646] tegra194-vi5 15c10000.vi: 6 GoS tables configured.
[ 65.349654] tegra194-vi5 15c10000.vi: gos[0] = 0xc2100000
[ 65.349661] tegra194-vi5 15c10000.vi: gos[1] = 0xc2101000
[ 65.349667] tegra194-vi5 15c10000.vi: gos[2] = 0xc2102000
[ 65.349674] tegra194-vi5 15c10000.vi: gos[3] = 0xc2103000
[ 65.349680] tegra194-vi5 15c10000.vi: gos[4] = 0xc2104000
[ 65.349686] tegra194-vi5 15c10000.vi: gos[5] = 0xc2105000
[ 65.349693] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: sending chan_id 71 msg_id 16
[ 65.349856] tegra194-vi5 15c10000.vi: vi_capture_ivc_send_control: response chan_id 71 msg_id 17
[ 65.349866] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 65.354355] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:0
[ 65.354384] tegra194-vi5 15c10000.vi: vi_capture_status: waiting for status, timeout:2500 ms
[ 65.358139] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:1
[ 65.361138] tegra194-vi5 15c10000.vi: vi_capture_request: sending chan_id 0 msg_id 1 buf:2
[ 65.374689] [RCE] Configuring VI GoS.
[ 65.374713] [RCE] VM GOS[#0] addr=0xc2100000
[ 65.374733] [RCE] VM GOS[#1] addr=0xc2101000
[ 65.374751] [RCE] VM GOS[#2] addr=0xc2102000
[ 65.374769] [RCE] VM GOS[#3] addr=0xc2103000
[ 65.374786] [RCE] VM GOS[#4] addr=0xc2104000
[ 65.374803] [RCE] VM GOS[#5] addr=0xc2105000
[ 65.384233] tegra194-vi5 15c10000.vi: vi_capture_ivc_status_callback: status chan_id 0 msg_id 2
[ 65.384241] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
I looking at TRM and finding no useful information.
Any suggestions or approaches are very welcome!
BR.
