Need help interpreting Camera BringUp Trace Data on Jetson AGX Xavier
OLD System:
ImageSensor(0v10635) - Serializer(max96705)-Deserializer(max9286)-Jetson AGX Xavier Module
Linux4Tegra R32.2.3, JetPack 4.2.3
New System:
ImageSensor(0v10635) - Serializer(max96705)-Deserializer(max96712)-Jetson AGX Xavier Module
The single HW difference is the max9286 is replaced with the max96712.
When we capture a single image we use the following command:
gst-launch-1.0 -q v4l2src device=/dev/gmsl/cam0 num-buffers=1 ! jpegenc ! filesink location=test.new.jpg
When we capture on the OLD system the trace output gives us the following:
# tracer: nop
# entries-in-buffer/entries-written: 189/189   #P:8
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
     kworker/0:0-4     [000] ....    76.779561: rtos_queue_peek_from_isr_failed: tstamp:2601440779 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    76.895554: rtos_queue_peek_from_isr_failed: tstamp:2606440780 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    77.071570: rtos_queue_peek_from_isr_failed: tstamp:2611440779 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    77.239548: rtos_queue_peek_from_isr_failed: tstamp:2616440870 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    77.407562: rtos_queue_peek_from_isr_failed: tstamp:2621440780 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    77.575545: rtos_queue_peek_from_isr_failed: tstamp:2626440776 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    77.687566: rtos_queue_peek_from_isr_failed: tstamp:2631440776 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    77.855570: rtos_queue_peek_from_isr_failed: tstamp:2636440776 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    78.023554: rtos_queue_peek_from_isr_failed: tstamp:2641440779 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    78.195656: rtos_queue_peek_from_isr_failed: tstamp:2646440859 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    78.363567: rtos_queue_peek_from_isr_failed: tstamp:2651440775 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    78.539593: rtos_queue_peek_from_isr_failed: tstamp:2656440776 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    78.651569: rtos_queue_peek_from_isr_failed: tstamp:2661440778 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    78.819534: rtos_queue_peek_from_isr_failed: tstamp:2666440776 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    78.987584: rtos_queue_peek_from_isr_failed: tstamp:2671440796 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    79.155539: rtos_queue_peek_from_isr_failed: tstamp:2676440776 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    79.323569: rtos_queue_peek_from_isr_failed: tstamp:2681440776 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    79.491565: rtos_queue_peek_from_isr_failed: tstamp:2686440776 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    79.659696: rtos_queue_peek_from_isr_failed: tstamp:2691440775 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    79.771561: rtos_queue_peek_from_isr_failed: tstamp:2696440797 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    79.939755: rtos_queue_peek_from_isr_failed: tstamp:2701440981 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    80.107849: rtos_queue_peek_from_isr_failed: tstamp:2706440778 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    80.275832: rtos_queue_peek_from_isr_failed: tstamp:2711440964 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    80.443550: rtos_queue_peek_from_isr_failed: tstamp:2716440778 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    80.611566: rtos_queue_peek_from_isr_failed: tstamp:2721440797 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    80.779700: rtos_queue_peek_from_isr_failed: tstamp:2726440795 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    80.891780: rtos_queue_peek_from_isr_failed: tstamp:2731440778 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    81.059706: rtos_queue_peek_from_isr_failed: tstamp:2736440983 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    81.227701: rtos_queue_peek_from_isr_failed: tstamp:2741440981 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    81.395702: rtos_queue_peek_from_isr_failed: tstamp:2746440779 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    81.563551: rtos_queue_peek_from_isr_failed: tstamp:2751440780 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    81.619847: rtos_queue_peek_from_isr_failed: tstamp:2753832504 queue:0x0bcbcf78
  gst-launch-1.0-8582  [006] ....    92.693531: tegra_channel_open: vi-output, ov10635 2-0032
  gst-launch-1.0-8582  [001] ....    92.696902: tegra_channel_set_power: ov10635 2-0032 : 0x1
  gst-launch-1.0-8582  [001] ....    92.696944: camera_common_s_power: status : 0x1
  gst-launch-1.0-8582  [001] ....    92.702464: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  gst-launch-1.0-8582  [001] ....    92.702486: csi_s_power: enable : 0x1
  gst-launch-1.0-8582  [001] ....    92.712609: tegra_channel_close: vi-output, ov10635 2-0032
  gst-launch-1.0-8582  [001] ....    92.712616: tegra_channel_set_power: ov10635 2-0032 : 0x0
  gst-launch-1.0-8582  [001] ....    92.712624: camera_common_s_power: status : 0x0
  gst-launch-1.0-8582  [001] ....    92.712736: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  gst-launch-1.0-8582  [001] ....    92.712738: csi_s_power: enable : 0x0
  gst-launch-1.0-8582  [001] ....    92.736532: tegra_channel_open: vi-output, ov10635 2-0032
  gst-launch-1.0-8582  [001] ....    92.736543: tegra_channel_set_power: ov10635 2-0032 : 0x1
  gst-launch-1.0-8582  [001] ....    92.736550: camera_common_s_power: status : 0x1
  gst-launch-1.0-8582  [001] ....    92.742056: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  gst-launch-1.0-8582  [001] ....    92.742061: csi_s_power: enable : 0x1
    v4l2src0:src-8587  [003] ....    92.747126: tegra_channel_capture_setup: vnc_id 0 W 1280 H 800 fmt 13
     kworker/0:2-1199  [000] ....    92.771525: rtos_queue_peek_from_isr_failed: tstamp:3102759900 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    92.771532: rtcpu_start: tstamp:3102761132
     kworker/0:2-1199  [000] ....    92.771534: rtos_queue_send_from_isr_failed: tstamp:3102808747 queue:0x0bcb41f8
     kworker/0:2-1199  [000] ....    92.771536: rtos_queue_send_from_isr_failed: tstamp:3102808885 queue:0x0bcb8a60
     kworker/0:2-1199  [000] ....    92.771537: rtos_queue_send_from_isr_failed: tstamp:3102809049 queue:0x0bcba5e0
     kworker/0:2-1199  [000] ....    92.771538: rtos_queue_send_from_isr_failed: tstamp:3102809183 queue:0x0bcbb3a0
     kworker/0:2-1199  [000] ....    92.771540: rtos_queue_send_from_isr_failed: tstamp:3102809316 queue:0x0bcbc160
     kworker/0:2-1199  [000] ....    92.771553: rtcpu_string: tstamp:3102817143 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
     kworker/0:2-1199  [000] ....    92.771556: rtcpu_string: tstamp:3102817248 id:0x04010000 str:"on 2.2
    v4l2src0:src-8587  [003] ....    92.772030: tegra_channel_set_stream: enable : 0x1
    v4l2src0:src-8587  [003] ....    92.798540: tegra_channel_set_stream: 15a00000.nvcsi--7 : 0x1
    v4l2src0:src-8587  [003] ....    92.798546: csi_s_stream: enable : 0x1
    v4l2src0:src-8587  [003] ....    92.798556: tegra_channel_set_stream: ov10635 2-0032 : 0x1
     kworker/0:2-1199  [000] ....    92.827646: rtos_queue_send_from_isr_failed: tstamp:3102833979 queue:0x0bcb41f8
     kworker/0:2-1199  [000] ....    92.827650: rtos_queue_send_from_isr_failed: tstamp:3102834119 queue:0x0bcb8a60
     kworker/0:2-1199  [000] ....    92.827652: rtos_queue_send_from_isr_failed: tstamp:3102834259 queue:0x0bcba5e0
     kworker/0:2-1199  [000] ....    92.827653: rtos_queue_send_from_isr_failed: tstamp:3102834392 queue:0x0bcbb3a0
     kworker/0:2-1199  [000] ....    92.827654: rtos_queue_send_from_isr_failed: tstamp:3102834525 queue:0x0bcbc160
     kworker/0:2-1199  [000] ....    92.827657: rtcpu_vinotify_event: tstamp:3103130508 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4801467456 data:0x10000000
     kworker/0:2-1199  [000] ....    92.827658: rtcpu_vinotify_event: tstamp:3103130858 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4801471296 data:0x31000001
     kworker/0:2-1199  [000] ....    92.827660: rtcpu_vinotify_event: tstamp:3103131213 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4801472288 data:0x07020001
     kworker/0:2-1199  [000] ....    92.827661: rtcpu_vinotify_event: tstamp:3103131500 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4801508832 data:0x10000000
     kworker/0:2-1199  [000] ....    92.827662: rtcpu_vinotify_event: tstamp:3103131846 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4801512736 data:0x31000002
     kworker/0:2-1199  [000] ....    92.827664: rtos_queue_send_from_isr_failed: tstamp:3103665607 queue:0x0bcb41f8
     kworker/0:2-1199  [000] ....    92.827665: rtos_queue_send_from_isr_failed: tstamp:3103665748 queue:0x0bcb8a60
     kworker/0:2-1199  [000] ....    92.827667: rtos_queue_send_from_isr_failed: tstamp:3103665888 queue:0x0bcba5e0
     kworker/0:2-1199  [000] ....    92.827668: rtos_queue_send_from_isr_failed: tstamp:3103666021 queue:0x0bcbb3a0
     kworker/0:2-1199  [000] ....    92.827669: rtos_queue_send_from_isr_failed: tstamp:3103666155 queue:0x0bcbc160
     kworker/0:2-1199  [000] ....    92.827696: rtcpu_nvcsi_intr: tstamp:3103668689 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000089
     kworker/0:2-1199  [000] ....    92.827707: rtcpu_nvcsi_intr: tstamp:3103668689 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
     kworker/0:2-1199  [000] ....    92.827709: rtcpu_vinotify_error: tstamp:3103672470 tag:CSIMUX_STREAM channel:0x00 frame:1 vi_tstamp:3103671849 data:0x00000001
     kworker/0:2-1199  [000] ....    92.827710: rtcpu_vinotify_event: tstamp:3103757379 tag:CSIMUX_STREAM channel:0x00 frame:1 vi_tstamp:3103671849 data:0x00000001
     kworker/0:2-1199  [000] .n..    92.827752: rtcpu_vinotify_event: tstamp:3104384218 tag:FS channel:0x01 frame:102 vi_tstamp:3104310376 data:0x00000010
     kworker/0:2-1199  [000] ....    92.827771: rtcpu_vinotify_event: tstamp:3104384350 tag:ATOMP_FS channel:0x00 frame:102 vi_tstamp:3104310376 data:0x00000000
     kworker/0:2-1199  [000] ....    92.827773: rtcpu_vinotify_event: tstamp:3104384499 tag:CHANSEL_PXL_SOF channel:0x23 frame:102 vi_tstamp:3104333994 data:0x00000001
     kworker/0:2-1199  [000] ....    92.827774: rtcpu_vinotify_event: tstamp:3104384629 tag:RESERVED_19 channel:0x23 frame:102 vi_tstamp:4849407808 data:0x08020001
 vi-output, ov10-8590  [005] ....    92.852729: tegra_channel_capture_frame: sof:99.338687808
 vi-output, ov10-8590  [005] ....    92.852733: tegra_channel_capture_frame: eof:99.371335968
     kworker/0:2-1199  [000] ....    92.883547: rtcpu_vinotify_event: tstamp:3105324399 tag:CHANSEL_PXL_EOF channel:0x23 frame:102 vi_tstamp:3105226918 data:0x031f0002
     kworker/0:2-1199  [000] ....    92.883558: rtcpu_vinotify_event: tstamp:3105324528 tag:ATOMP_FRAME_DONE channel:0x23 frame:102 vi_tstamp:3105226932 data:0x00000000
     kworker/0:2-1199  [000] ....    92.883559: rtcpu_vinotify_event: tstamp:3105324695 tag:RESERVED_19 channel:0x23 frame:102 vi_tstamp:4877981792 data:0x02020001
     kworker/0:2-1199  [000] ....    92.883578: rtcpu_vinotify_event: tstamp:3105355221 tag:FE channel:0x01 frame:102 vi_tstamp:3105354248 data:0x00000020
     kworker/0:2-1199  [000] ....    92.883579: rtcpu_vinotify_event: tstamp:3105355365 tag:ATOMP_FE channel:0x00 frame:102 vi_tstamp:3105354249 data:0x00000000
     kworker/0:2-1199  [000] ....    92.883580: rtcpu_vinotify_event: tstamp:3105355492 tag:RESERVED_19 channel:0x23 frame:102 vi_tstamp:4882057184 data:0x00020001
     kworker/0:2-1199  [000] ....    92.883594: rtcpu_vinotify_event: tstamp:3105637664 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4882059936 data:0x07020002
     kworker/0:2-1199  [000] ....    92.883595: rtcpu_vinotify_event: tstamp:3105637793 tag:FS channel:0x01 frame:103 vi_tstamp:3105354338 data:0x00000010
     kworker/0:2-1199  [000] ....    92.883596: rtcpu_vinotify_event: tstamp:3105637939 tag:ATOMP_FS channel:0x00 frame:103 vi_tstamp:3105354339 data:0x00000000
     kworker/0:2-1199  [000] ....    92.883597: rtcpu_vinotify_event: tstamp:3105638066 tag:CHANSEL_PXL_SOF channel:0x23 frame:103 vi_tstamp:3105377957 data:0x00000001
     kworker/0:2-1199  [000] ....    92.883597: rtcpu_vinotify_event: tstamp:3105638215 tag:RESERVED_19 channel:0x23 frame:103 vi_tstamp:4882814624 data:0x08020002
 vi-output, ov10-8590  [002] ....    92.886157: tegra_channel_capture_frame: sof:99.372094624
 vi-output, ov10-8590  [002] ....    92.886161: tegra_channel_capture_frame: eof:99.404742784
     kworker/0:2-1199  [000] ....    92.939613: rtcpu_vinotify_error: tstamp:3106422585 tag:CHANSEL_NOMATCH channel:0x41 frame:104 vi_tstamp:3106421921 data:0x000003c9
     kworker/0:2-1199  [000] ....    92.939619: rtcpu_vinotify_event: tstamp:3106577902 tag:CHANSEL_PXL_EOF channel:0x23 frame:103 vi_tstamp:3106270881 data:0x031f0002
     kworker/0:2-1199  [000] ....    92.939621: rtcpu_vinotify_event: tstamp:3106578049 tag:ATOMP_FRAME_DONE channel:0x23 frame:103 vi_tstamp:3106270894 data:0x00000000
     kworker/0:2-1199  [000] ....    92.939622: rtcpu_vinotify_event: tstamp:3106578179 tag:RESERVED_19 channel:0x23 frame:103 vi_tstamp:4911388608 data:0x02020002
     kworker/0:2-1199  [000] ....    92.939623: rtcpu_vinotify_event: tstamp:3106578318 tag:FE channel:0x01 frame:103 vi_tstamp:3106398212 data:0x00000020
     kworker/0:2-1199  [000] ....    92.939625: rtcpu_vinotify_event: tstamp:3106578446 tag:ATOMP_FE channel:0x00 frame:103 vi_tstamp:3106398212 data:0x00000000
     kworker/0:2-1199  [000] ....    92.939626: rtcpu_vinotify_event: tstamp:3106578590 tag:RESERVED_19 channel:0x23 frame:103 vi_tstamp:4915464000 data:0x00020002
     kworker/0:2-1199  [000] ....    92.939658: rtcpu_vinotify_event: tstamp:3106578713 tag:FS channel:0x01 frame:104 vi_tstamp:3106398301 data:0x00000010
     kworker/0:2-1199  [000] ....    92.939659: rtcpu_vinotify_event: tstamp:3106578852 tag:CHANSEL_NOMATCH channel:0x41 frame:104 vi_tstamp:3106421921 data:0x000003c9
     kworker/0:2-1199  [000] ....    92.939665: rtos_queue_send_from_isr_failed: tstamp:3107400748 queue:0x0bcb41f8
     kworker/0:2-1199  [000] ....    92.939666: rtos_queue_send_from_isr_failed: tstamp:3107400888 queue:0x0bcb8a60
     kworker/0:2-1199  [000] ....    92.939668: rtos_queue_send_from_isr_failed: tstamp:3107401027 queue:0x0bcba5e0
     kworker/0:2-1199  [000] ....    92.939680: rtos_queue_send_from_isr_failed: tstamp:3107401163 queue:0x0bcbb3a0
     kworker/0:2-1199  [000] ....    92.939681: rtos_queue_send_from_isr_failed: tstamp:3107401296 queue:0x0bcbc160
     kworker/0:2-1199  [000] ....    92.939683: rtcpu_vinotify_event: tstamp:3107403201 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4947601728 data:0x10000000
     kworker/0:2-1199  [000] ....    92.939684: rtcpu_vinotify_event: tstamp:3107403348 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4947605600 data:0x31000003
     kworker/0:2-1199  [000] ....    92.939685: rtcpu_vinotify_event: tstamp:3107403472 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4947606592 data:0x07020003
     kworker/0:2-1199  [000] ....    92.939688: rtcpu_vinotify_event: tstamp:3107706343 tag:FE channel:0x01 frame:104 vi_tstamp:3107442174 data:0x00000020
     kworker/0:2-1199  [000] ....    92.939689: rtcpu_vinotify_event: tstamp:3107706470 tag:FS channel:0x01 frame:105 vi_tstamp:3107442265 data:0x00000010
     kworker/0:2-1199  [000] ....    92.939690: rtcpu_vinotify_event: tstamp:3107706627 tag:ATOMP_FS channel:0x00 frame:105 vi_tstamp:3107442265 data:0x00000000
     kworker/0:2-1199  [000] ....    92.939692: rtcpu_vinotify_event: tstamp:3107706772 tag:CHANSEL_PXL_SOF channel:0x23 frame:105 vi_tstamp:3107465883 data:0x00000001
     kworker/0:2-1199  [000] ....    92.939693: rtcpu_vinotify_event: tstamp:3107706946 tag:RESERVED_19 channel:0x23 frame:105 vi_tstamp:4949628224 data:0x08020003
     kworker/0:2-1199  [000] ....    92.939695: rtos_queue_peek_from_isr_failed: tstamp:3107760267 queue:0x0bcbcf78
 vi-output, ov10-8590  [003] ....    92.952947: tegra_channel_capture_frame: sof:99.438908256
 vi-output, ov10-8590  [003] ....    92.952953: tegra_channel_capture_frame: eof:99.471556384
  gst-launch-1.0-8582  [001] ....    92.952993: tegra_channel_set_stream: enable : 0x0
  gst-launch-1.0-8582  [001] ....    92.952997: tegra_channel_set_stream: ov10635 2-0032 : 0x0
  gst-launch-1.0-8582  [001] ....    92.953648: tegra_channel_set_stream: 15a00000.nvcsi--7 : 0x0
  gst-launch-1.0-8582  [001] ....    92.953653: csi_s_stream: enable : 0x0
  gst-launch-1.0-8582  [001] ....    92.966897: tegra_channel_close: vi-output, ov10635 2-0032
  gst-launch-1.0-8582  [001] ....    92.966911: tegra_channel_set_power: ov10635 2-0032 : 0x0
  gst-launch-1.0-8582  [001] ....    92.966928: camera_common_s_power: status : 0x0
  gst-launch-1.0-8582  [001] ....    92.967049: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  gst-launch-1.0-8582  [001] ....    92.967053: csi_s_power: enable : 0x0
     kworker/0:2-1199  [000] ....    92.999608: rtcpu_vinotify_error: tstamp:3108510530 tag:CHANSEL_NOMATCH channel:0x41 frame:106 vi_tstamp:3108509845 data:0x000003c9
     kworker/0:2-1199  [000] ....    92.999614: rtos_queue_send_from_isr_failed: tstamp:3108512803 queue:0x0bcb41f8
     kworker/0:2-1199  [000] ....    92.999616: rtos_queue_send_from_isr_failed: tstamp:3108512943 queue:0x0bcb8a60
     kworker/0:2-1199  [000] ....    92.999618: rtos_queue_send_from_isr_failed: tstamp:3108513083 queue:0x0bcba5e0
     kworker/0:2-1199  [000] ....    92.999619: rtos_queue_send_from_isr_failed: tstamp:3108513236 queue:0x0bcbb3a0
     kworker/0:2-1199  [000] ....    92.999621: rtos_queue_send_from_isr_failed: tstamp:3108513370 queue:0x0bcbc160
     kworker/0:2-1199  [000] ....    92.999622: rtos_queue_send_from_isr_failed: tstamp:3108605889 queue:0x0bcb41f8
     kworker/0:2-1199  [000] ....    92.999624: rtos_queue_send_from_isr_failed: tstamp:3108606038 queue:0x0bcb8a60
     kworker/0:2-1199  [000] ....    92.999625: rtos_queue_send_from_isr_failed: tstamp:3108606177 queue:0x0bcba5e0
     kworker/0:2-1199  [000] ....    92.999627: rtos_queue_send_from_isr_failed: tstamp:3108606309 queue:0x0bcbb3a0
     kworker/0:2-1199  [000] ....    92.999628: rtos_queue_send_from_isr_failed: tstamp:3108606443 queue:0x0bcbc160
     kworker/0:2-1199  [000] ....    92.999631: rtcpu_vinotify_event: tstamp:3108646535 tag:CHANSEL_PXL_EOF channel:0x23 frame:105 vi_tstamp:3108358807 data:0x031f0002
     kworker/0:2-1199  [000] ....    92.999633: rtcpu_vinotify_event: tstamp:3108646685 tag:ATOMP_FRAME_DONE channel:0x23 frame:105 vi_tstamp:3108358820 data:0x00000000
     kworker/0:2-1199  [000] ....    92.999635: rtcpu_vinotify_event: tstamp:3108646816 tag:RESERVED_19 channel:0x23 frame:105 vi_tstamp:4978202240 data:0x02020003
     kworker/0:2-1199  [000] ....    92.999636: rtcpu_vinotify_event: tstamp:3108646959 tag:FE channel:0x01 frame:105 vi_tstamp:3108486137 data:0x00000020
     kworker/0:2-1199  [000] ....    92.999638: rtcpu_vinotify_event: tstamp:3108647087 tag:ATOMP_FE channel:0x00 frame:105 vi_tstamp:3108486137 data:0x00000000
     kworker/0:2-1199  [000] ....    92.999639: rtcpu_vinotify_event: tstamp:3108647230 tag:RESERVED_19 channel:0x23 frame:105 vi_tstamp:4982277600 data:0x00020003
     kworker/0:2-1199  [000] ....    92.999640: rtcpu_vinotify_event: tstamp:3108647353 tag:FS channel:0x01 frame:106 vi_tstamp:3108486227 data:0x00000010
     kworker/0:2-1199  [000] ....    92.999642: rtcpu_vinotify_event: tstamp:3108647492 tag:CHANSEL_NOMATCH channel:0x41 frame:106 vi_tstamp:3108509845 data:0x000003c9
     kworker/0:2-1199  [000] ....    93.111567: rtos_queue_peek_from_isr_failed: tstamp:3112760433 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    93.279542: rtos_queue_peek_from_isr_failed: tstamp:3117760451 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    93.447914: rtos_queue_peek_from_isr_failed: tstamp:3122760424 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    93.615546: rtos_queue_peek_from_isr_failed: tstamp:3127760451 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    93.783554: rtos_queue_peek_from_isr_failed: tstamp:3132760430 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    93.895621: rtos_queue_peek_from_isr_failed: tstamp:3137760431 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    94.067574: rtos_queue_peek_from_isr_failed: tstamp:3142760246 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    94.235631: rtos_queue_peek_from_isr_failed: tstamp:3147760430 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    94.403544: rtos_queue_peek_from_isr_failed: tstamp:3152760242 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    94.571580: rtos_queue_peek_from_isr_failed: tstamp:3157760246 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    94.739729: rtos_queue_peek_from_isr_failed: tstamp:3162760451 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    94.851619: rtos_queue_peek_from_isr_failed: tstamp:3167760308 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    95.019704: rtos_queue_peek_from_isr_failed: tstamp:3172760452 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    95.187663: rtos_queue_peek_from_isr_failed: tstamp:3177760247 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    95.355771: rtos_queue_peek_from_isr_failed: tstamp:3182760431 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    95.527505: rtos_queue_peek_from_isr_failed: tstamp:3187760242 queue:0x0bcbcf78
     kworker/0:2-1199  [000] .n..    95.699593: rtos_queue_peek_from_isr_failed: tstamp:3192760431 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    95.811861: rtos_queue_peek_from_isr_failed: tstamp:3197760450 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    95.979554: rtos_queue_peek_from_isr_failed: tstamp:3202760434 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    96.147781: rtos_queue_peek_from_isr_failed: tstamp:3207760430 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    96.315713: rtos_queue_peek_from_isr_failed: tstamp:3212760435 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    96.483621: rtos_queue_peek_from_isr_failed: tstamp:3217760454 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    96.651782: rtos_queue_peek_from_isr_failed: tstamp:3222760448 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    96.819705: rtos_queue_peek_from_isr_failed: tstamp:3227760242 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    96.931525: rtos_queue_peek_from_isr_failed: tstamp:3232760290 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    97.099702: rtos_queue_peek_from_isr_failed: tstamp:3237760451 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    97.267663: rtos_queue_peek_from_isr_failed: tstamp:3242760246 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    97.435733: rtos_queue_peek_from_isr_failed: tstamp:3247760451 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    97.603648: rtos_queue_peek_from_isr_failed: tstamp:3252760438 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    97.771734: rtos_queue_peek_from_isr_failed: tstamp:3257760451 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    97.939845: rtos_queue_peek_from_isr_failed: tstamp:3262760448 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    98.051576: rtos_queue_peek_from_isr_failed: tstamp:3267760297 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    98.219715: rtos_queue_peek_from_isr_failed: tstamp:3272760451 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    98.387717: rtos_queue_peek_from_isr_failed: tstamp:3277760451 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    98.555715: rtos_queue_peek_from_isr_failed: tstamp:3282760430 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    98.723788: rtos_queue_peek_from_isr_failed: tstamp:3287760451 queue:0x0bcbcf78
     kworker/0:2-1199  [000] ....    98.779671: rtos_queue_peek_from_isr_failed: tstamp:3289828065 queue:0x0bcbcf78
When we capture on the NEW system the trace output gives us the following:
# entries-in-buffer/entries-written: 212/212   #P:4
#                              _-----=> irqs-off
#                            ||| /     delay
     kworker/0:1-831   [000] ....    72.886838: rtos_queue_peek_from_isr_failed: tstamp:2478681477 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    73.054643: rtos_queue_peek_from_isr_failed: tstamp:2483681477 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    73.222752: rtos_queue_peek_from_isr_failed: tstamp:2488681457 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    73.390823: rtos_queue_peek_from_isr_failed: tstamp:2493681492 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    73.558751: rtos_queue_peek_from_isr_failed: tstamp:2498681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    73.670587: rtos_queue_peek_from_isr_failed: tstamp:2503681477 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    73.842606: rtos_queue_peek_from_isr_failed: tstamp:2508681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    74.010745: rtos_queue_peek_from_isr_failed: tstamp:2513681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    74.178595: rtos_queue_peek_from_isr_failed: tstamp:2518681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    74.346620: rtos_queue_peek_from_isr_failed: tstamp:2523681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    74.514599: rtos_queue_peek_from_isr_failed: tstamp:2528681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    74.626622: rtos_queue_peek_from_isr_failed: tstamp:2533681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    74.794619: rtos_queue_peek_from_isr_failed: tstamp:2538681453 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    74.966677: rtos_queue_peek_from_isr_failed: tstamp:2543681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    75.134668: rtos_queue_peek_from_isr_failed: tstamp:2548681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    75.302597: rtos_queue_peek_from_isr_failed: tstamp:2553681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    75.470784: rtos_queue_peek_from_isr_failed: tstamp:2558681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    75.638743: rtos_queue_peek_from_isr_failed: tstamp:2563681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    75.750770: rtos_queue_peek_from_isr_failed: tstamp:2568681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    75.918608: rtos_queue_peek_from_isr_failed: tstamp:2573681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    76.086597: rtos_queue_peek_from_isr_failed: tstamp:2578681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    76.254693: rtos_queue_peek_from_isr_failed: tstamp:2583681453 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    76.422691: rtos_queue_peek_from_isr_failed: tstamp:2588681478 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    76.590658: rtos_queue_peek_from_isr_failed: tstamp:2593681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    76.758611: rtos_queue_peek_from_isr_failed: tstamp:2598681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    76.870600: rtos_queue_peek_from_isr_failed: tstamp:2603681413 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    77.038706: rtos_queue_peek_from_isr_failed: tstamp:2608681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    77.210667: rtos_queue_peek_from_isr_failed: tstamp:2613681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    77.378650: rtos_queue_peek_from_isr_failed: tstamp:2618681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    77.546885: rtos_queue_peek_from_isr_failed: tstamp:2623681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    77.714633: rtos_queue_peek_from_isr_failed: tstamp:2628681474 queue:0x0bcbcf78
     kworker/0:1-831   [000] ....    77.826684: rtos_queue_peek_from_isr_failed: tstamp:2632843203 queue:0x0bcbcf78
 gst-plugin-scan-8455  [001] ....    85.060758: tegra_channel_open: vi-output, ov10635 2-0032
 gst-plugin-scan-8455  [001] ....    85.065089: tegra_channel_set_power: ov10635 2-0032 : 0x1
 gst-plugin-scan-8455  [001] ....    85.065150: camera_common_s_power: status : 0x1
 gst-plugin-scan-8455  [001] ....    85.070858: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
 gst-plugin-scan-8455  [001] ....    85.070886: csi_s_power: enable : 0x1
 gst-plugin-scan-8455  [001] ....    85.074366: tegra_channel_close: vi-output, ov10635 2-0032
 gst-plugin-scan-8455  [001] ....    85.074392: tegra_channel_set_power: ov10635 2-0032 : 0x0
 gst-plugin-scan-8455  [001] ....    85.074418: camera_common_s_power: status : 0x0
 gst-plugin-scan-8455  [001] ....    85.074620: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
 gst-plugin-scan-8455  [001] ....    85.074625: csi_s_power: enable : 0x0
  gst-launch-1.0-8453  [001] ....    85.224510: tegra_channel_open: vi-output, ov10635 2-0032
  gst-launch-1.0-8453  [001] ....    85.224564: tegra_channel_set_power: ov10635 2-0032 : 0x1
  gst-launch-1.0-8453  [001] ....    85.224595: camera_common_s_power: status : 0x1
  gst-launch-1.0-8453  [001] ....    85.230458: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  gst-launch-1.0-8453  [001] ....    85.230612: csi_s_power: enable : 0x1
  gst-launch-1.0-8453  [001] ....    85.230870: tegra_channel_close: vi-output, ov10635 2-0032
  gst-launch-1.0-8453  [001] ....    85.230886: tegra_channel_set_power: ov10635 2-0032 : 0x0
  gst-launch-1.0-8453  [001] ....    85.230914: camera_common_s_power: status : 0x0
  gst-launch-1.0-8453  [001] ....    85.231059: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  gst-launch-1.0-8453  [001] ....    85.231061: csi_s_power: enable : 0x0
  gst-launch-1.0-8453  [001] ....    85.297384: tegra_channel_open: vi-output, ov10635 2-0032
  gst-launch-1.0-8453  [001] ....    85.297421: tegra_channel_set_power: ov10635 2-0032 : 0x1
  gst-launch-1.0-8453  [001] ....    85.297442: camera_common_s_power: status : 0x1
  gst-launch-1.0-8453  [001] ....    85.302971: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x1
  gst-launch-1.0-8453  [001] ....    85.302988: csi_s_power: enable : 0x1
    v4l2src0:src-8459  [000] ....    85.327678: tegra_channel_capture_setup: vnc_id 0 W 1280 H 800 fmt 13
    v4l2src0:src-8459  [000] ....    85.426944: tegra_channel_set_stream: enable : 0x1
    v4l2src0:src-8459  [000] ....    85.438310: tegra_channel_set_stream: 15a00000.nvcsi--7 : 0x1
    v4l2src0:src-8459  [000] ....    85.438318: csi_s_stream: enable : 0x1
    v4l2src0:src-8459  [000] ....    85.438331: tegra_channel_set_stream: ov10635 2-0032 : 0x1
     kworker/0:2-1647  [000] ....    85.446579: rtos_queue_peek_from_isr_failed: tstamp:2870594682 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    85.446587: rtcpu_start: tstamp:2870597047
     kworker/0:2-1647  [000] ....    85.446590: rtos_queue_send_from_isr_failed: tstamp:2870852707 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    85.446591: rtos_queue_send_from_isr_failed: tstamp:2870853227 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    85.446593: rtos_queue_send_from_isr_failed: tstamp:2870853729 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    85.446594: rtos_queue_send_from_isr_failed: tstamp:2870854227 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    85.446595: rtos_queue_send_from_isr_failed: tstamp:2870854731 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    85.446598: rtcpu_string: tstamp:2870874543 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
     kworker/0:2-1647  [000] ....    85.446601: rtcpu_string: tstamp:2870875014 id:0x04010000 str:"on 2.2
     kworker/0:2-1647  [000] ....    85.446666: rtos_queue_send_from_isr_failed: tstamp:2871121930 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    85.446668: rtos_queue_send_from_isr_failed: tstamp:2871122576 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    85.446669: rtos_queue_send_from_isr_failed: tstamp:2871123082 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    85.446671: rtos_queue_send_from_isr_failed: tstamp:2871123579 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    85.446672: rtos_queue_send_from_isr_failed: tstamp:2871124078 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    85.446675: rtcpu_vinotify_event: tstamp:2871218673 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1681783072 data:0x10000000
     kworker/0:2-1647  [000] ....    85.446677: rtcpu_vinotify_event: tstamp:2871219172 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1681793152 data:0x31000001
     kworker/0:2-1647  [000] ....    85.446678: rtcpu_vinotify_event: tstamp:2871219781 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:1681794144 data:0x07020001
     kworker/0:2-1647  [000] ....    85.446679: rtcpu_vinotify_event: tstamp:2871220286 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1681911168 data:0x10000000
     kworker/0:2-1647  [000] ....    85.446681: rtcpu_vinotify_event: tstamp:2871220889 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:1681921312 data:0x31000002
     kworker/0:2-1647  [000] ....    85.446682: rtos_queue_send_from_isr_failed: tstamp:2871581228 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    85.446684: rtos_queue_send_from_isr_failed: tstamp:2871581390 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    85.446685: rtos_queue_send_from_isr_failed: tstamp:2871581553 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    85.446686: rtos_queue_send_from_isr_failed: tstamp:2871581710 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    85.446688: rtos_queue_send_from_isr_failed: tstamp:2871581866 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    85.446690: rtcpu_nvcsi_intr: tstamp:2871584447 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000001
     kworker/0:2-1647  [000] ....    85.614567: rtos_queue_peek_from_isr_failed: tstamp:2875595098 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    85.782561: rtos_queue_peek_from_isr_failed: tstamp:2880595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    85.899810: rtos_queue_peek_from_isr_failed: tstamp:2885595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    86.066573: rtos_queue_peek_from_isr_failed: tstamp:2890595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    86.234594: rtos_queue_peek_from_isr_failed: tstamp:2895595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    86.402569: rtos_queue_peek_from_isr_failed: tstamp:2900595115 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    86.570610: rtos_queue_peek_from_isr_failed: tstamp:2905595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    86.738637: rtos_queue_peek_from_isr_failed: tstamp:2910595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    86.850573: rtos_queue_peek_from_isr_failed: tstamp:2915595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    87.018585: rtos_queue_peek_from_isr_failed: tstamp:2920595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    87.190583: rtos_queue_peek_from_isr_failed: tstamp:2925595100 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    87.370601: rtos_queue_peek_from_isr_failed: tstamp:2930595098 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    87.538573: rtos_queue_peek_from_isr_failed: tstamp:2935595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    87.650586: rtos_queue_peek_from_isr_failed: tstamp:2940595098 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    87.818593: rtos_queue_peek_from_isr_failed: tstamp:2945595098 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    87.990587: rtos_queue_peek_from_isr_failed: tstamp:2950595113 queue:0x0bcbcf78
 vi-output, ov10-8462  [002] ....    88.041087: tegra_channel_capture_setup: vnc_id 0 W 1280 H 800 fmt 13
     kworker/0:2-1647  [000] ....    88.046586: rtos_queue_send_from_isr_failed: tstamp:2952842256 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    88.046591: rtos_queue_send_from_isr_failed: tstamp:2952842419 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    88.046593: rtos_queue_send_from_isr_failed: tstamp:2952842580 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    88.046595: rtos_queue_send_from_isr_failed: tstamp:2952842737 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    88.046596: rtos_queue_send_from_isr_failed: tstamp:2952842893 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    88.046597: rtos_queue_send_from_isr_failed: tstamp:2952914398 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    88.046599: rtos_queue_send_from_isr_failed: tstamp:2952914559 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    88.046600: rtos_queue_send_from_isr_failed: tstamp:2952914721 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    88.046602: rtos_queue_send_from_isr_failed: tstamp:2952914878 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    88.046603: rtos_queue_send_from_isr_failed: tstamp:2952915035 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    88.158592: rtos_queue_peek_from_isr_failed: tstamp:2955595102 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    88.326614: rtos_queue_peek_from_isr_failed: tstamp:2960595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    88.498632: rtos_queue_peek_from_isr_failed: tstamp:2965595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    88.554611: rtos_queue_send_from_isr_failed: tstamp:2967611755 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    88.554617: rtos_queue_send_from_isr_failed: tstamp:2967611918 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    88.554619: rtos_queue_send_from_isr_failed: tstamp:2967612099 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    88.554620: rtos_queue_send_from_isr_failed: tstamp:2967612257 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    88.554621: rtos_queue_send_from_isr_failed: tstamp:2967612414 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    88.554624: rtcpu_vinotify_event: tstamp:2967641584 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4769332128 data:0x10000000
     kworker/0:2-1647  [000] ....    88.554626: rtcpu_vinotify_event: tstamp:2967641765 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:4769335968 data:0x31000001
     kworker/0:2-1647  [000] ....    88.554627: rtcpu_vinotify_event: tstamp:2967641915 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:4769336992 data:0x07020001
     kworker/0:0-4     [000] ....    88.610633: rtos_queue_peek_from_isr_failed: tstamp:2970595098 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    88.778566: rtos_queue_peek_from_isr_failed: tstamp:2975595098 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    88.946596: rtos_queue_peek_from_isr_failed: tstamp:2980595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    89.114592: rtos_queue_peek_from_isr_failed: tstamp:2985595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    89.282575: rtos_queue_peek_from_isr_failed: tstamp:2990595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    89.450584: rtos_queue_peek_from_isr_failed: tstamp:2995595102 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    89.618606: rtos_queue_peek_from_isr_failed: tstamp:3000595098 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    89.730588: rtos_queue_peek_from_isr_failed: tstamp:3005595098 queue:0x0bcbcf78
     kworker/0:0-4     [000] ....    89.898631: rtos_queue_peek_from_isr_failed: tstamp:3010595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    90.066709: rtos_queue_peek_from_isr_failed: tstamp:3015595098 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    90.242572: rtos_queue_peek_from_isr_failed: tstamp:3020595097 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    90.410589: rtos_queue_peek_from_isr_failed: tstamp:3025595115 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    90.578603: rtos_queue_peek_from_isr_failed: tstamp:3030595098 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    90.690597: rtos_queue_peek_from_isr_failed: tstamp:3035595098 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    90.858579: rtos_queue_peek_from_isr_failed: tstamp:3040595118 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    91.026582: rtos_queue_peek_from_isr_failed: tstamp:3045595098 queue:0x0bcbcf78
 vi-output, ov10-8462  [000] ....    91.113108: tegra_channel_capture_setup: vnc_id 0 W 1280 H 800 fmt 13
  gst-launch-1.0-8453  [002] ....    91.113623: tegra_channel_set_stream: enable : 0x0
  gst-launch-1.0-8453  [002] ....    91.113629: tegra_channel_set_stream: ov10635 2-0032 : 0x0
  gst-launch-1.0-8453  [000] ....    91.114448: tegra_channel_set_stream: 15a00000.nvcsi--7 : 0x0
  gst-launch-1.0-8453  [000] ....    91.114454: csi_s_stream: enable : 0x0
  gst-launch-1.0-8453  [002] ....    91.129492: tegra_channel_close: vi-output, ov10635 2-0032
  gst-launch-1.0-8453  [002] ....    91.129537: tegra_channel_set_power: ov10635 2-0032 : 0x0
  gst-launch-1.0-8453  [002] ....    91.129571: camera_common_s_power: status : 0x0
  gst-launch-1.0-8453  [002] ....    91.129702: tegra_channel_set_power: 15a00000.nvcsi--7 : 0x0
  gst-launch-1.0-8453  [002] ....    91.129712: csi_s_power: enable : 0x0
     kworker/0:2-1647  [000] ....    91.138735: rtos_queue_send_from_isr_failed: tstamp:3048843878 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    91.138757: rtos_queue_send_from_isr_failed: tstamp:3048844040 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    91.138763: rtos_queue_send_from_isr_failed: tstamp:3048844202 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    91.138764: rtos_queue_send_from_isr_failed: tstamp:3048844359 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    91.138766: rtos_queue_send_from_isr_failed: tstamp:3048844517 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    91.138767: rtos_queue_send_from_isr_failed: tstamp:3048914625 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    91.138768: rtos_queue_send_from_isr_failed: tstamp:3048914804 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    91.138770: rtos_queue_send_from_isr_failed: tstamp:3048914963 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    91.138771: rtos_queue_send_from_isr_failed: tstamp:3048915120 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    91.138772: rtos_queue_send_from_isr_failed: tstamp:3048915276 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    91.138774: rtos_queue_send_from_isr_failed: tstamp:3048923839 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    91.138775: rtos_queue_send_from_isr_failed: tstamp:3048924018 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    91.138776: rtos_queue_send_from_isr_failed: tstamp:3048924178 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    91.138778: rtos_queue_send_from_isr_failed: tstamp:3048924335 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    91.138779: rtos_queue_send_from_isr_failed: tstamp:3048924491 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    91.138780: rtos_queue_send_from_isr_failed: tstamp:3048960355 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    91.138782: rtos_queue_send_from_isr_failed: tstamp:3048960513 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    91.138783: rtos_queue_send_from_isr_failed: tstamp:3048960671 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    91.138784: rtos_queue_send_from_isr_failed: tstamp:3048960828 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    91.138786: rtos_queue_send_from_isr_failed: tstamp:3048960984 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    91.138787: rtos_queue_send_from_isr_failed: tstamp:3049176360 queue:0x0bcb41f8
     kworker/0:2-1647  [000] ....    91.138788: rtos_queue_send_from_isr_failed: tstamp:3049176881 queue:0x0bcb8a60
     kworker/0:2-1647  [000] ....    91.138790: rtos_queue_send_from_isr_failed: tstamp:3049177384 queue:0x0bcba5e0
     kworker/0:2-1647  [000] ....    91.138791: rtos_queue_send_from_isr_failed: tstamp:3049177884 queue:0x0bcbb3a0
     kworker/0:2-1647  [000] ....    91.138792: rtos_queue_send_from_isr_failed: tstamp:3049178383 queue:0x0bcbc160
     kworker/0:2-1647  [000] ....    91.194859: rtos_queue_peek_from_isr_failed: tstamp:3050595168 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    91.362911: rtos_queue_peek_from_isr_failed: tstamp:3055595279 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    91.530901: rtos_queue_peek_from_isr_failed: tstamp:3060595272 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    91.702946: rtos_queue_peek_from_isr_failed: tstamp:3065595273 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    91.815107: rtos_queue_peek_from_isr_failed: tstamp:3070595276 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    91.986841: rtos_queue_peek_from_isr_failed: tstamp:3075595171 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    92.154969: rtos_queue_peek_from_isr_failed: tstamp:3080595295 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    92.330948: rtos_queue_peek_from_isr_failed: tstamp:3085595293 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    92.498797: rtos_queue_peek_from_isr_failed: tstamp:3090595284 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    92.610981: rtos_queue_peek_from_isr_failed: tstamp:3095595276 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    92.782750: rtos_queue_peek_from_isr_failed: tstamp:3100595276 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    92.954717: rtos_queue_peek_from_isr_failed: tstamp:3105595172 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    93.126640: rtos_queue_peek_from_isr_failed: tstamp:3110595294 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    93.294596: rtos_queue_peek_from_isr_failed: tstamp:3115595272 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    93.407467: rtos_queue_peek_from_isr_failed: tstamp:3120595272 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    93.582647: rtos_queue_peek_from_isr_failed: tstamp:3125595273 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    93.750917: rtos_queue_peek_from_isr_failed: tstamp:3130595291 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    93.918650: rtos_queue_peek_from_isr_failed: tstamp:3135595291 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    94.086605: rtos_queue_peek_from_isr_failed: tstamp:3140595272 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    94.254544: rtos_queue_peek_from_isr_failed: tstamp:3145595294 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    94.422556: rtos_queue_peek_from_isr_failed: tstamp:3150595273 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    94.534671: rtos_queue_peek_from_isr_failed: tstamp:3155595281 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    94.702528: rtos_queue_peek_from_isr_failed: tstamp:3160595275 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    94.870444: rtos_queue_peek_from_isr_failed: tstamp:3165595273 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    95.039960: rtos_queue_peek_from_isr_failed: tstamp:3170595275 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    95.206521: rtos_queue_peek_from_isr_failed: tstamp:3175595295 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    95.378488: rtos_queue_peek_from_isr_failed: tstamp:3180595295 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    95.490592: rtos_queue_peek_from_isr_failed: tstamp:3185595275 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    95.658410: rtos_queue_peek_from_isr_failed: tstamp:3190595286 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    95.826425: rtos_queue_peek_from_isr_failed: tstamp:3195595290 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    95.994437: rtos_queue_peek_from_isr_failed: tstamp:3200595272 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    96.162620: rtos_queue_peek_from_isr_failed: tstamp:3205595279 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    96.330400: rtos_queue_peek_from_isr_failed: tstamp:3210595271 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    96.498453: rtos_queue_peek_from_isr_failed: tstamp:3215595272 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    96.610408: rtos_queue_peek_from_isr_failed: tstamp:3220595276 queue:0x0bcbcf78
     kworker/0:2-1647  [000] ....    96.778313: rtos_queue_peek_from_isr_failed: tstamp:3224830324 queue:0x0bcbcf78
The most significant difference we noted was that once the capture attempt started:
The OLD had the following
kworker/0:2-1199  [000] ....    92.827707: rtcpu_nvcsi_intr: tstamp:3103668689 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088```
The New had the following
Are questions are:
  1. What do these lines mean? What are they telling us is going on?
  2. What does the phy:0 mean?
  3. what do the status values mean? status:0x00000089, status:0x00000088, status:0x00000001
Have a check the REG NVCSI_PHY_0_CILA_INTR_0_STATUS_CILA_0 in TRM for the detail information.
ShaneCCC Thank your for your response.
While continuing to debug Camera BringUp We had the following trace output:
     kworker/0:2-1634  [000] ....    86.301432: rtos_queue_send_from_isr_failed: tstamp:2897558996 queue:0x0bcbb3a0
     kworker/0:2-1634  [000] ....    86.301434: rtos_queue_send_from_isr_failed: tstamp:2897559171 queue:0x0bcbc160
     kworker/0:2-1634  [000] ....    86.301436: rtcpu_nvcsi_intr: tstamp:2897561770 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000089
     kworker/0:2-1634  [000] ....    86.301438: rtcpu_nvcsi_intr: tstamp:2897561770 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000088
     kworker/0:2-1634  [000] ....    86.301440: rtcpu_vinotify_error: tstamp:2897565916 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:2897565238 data:0x00000100
     kworker/0:2-1634  [000] ....    86.301441: rtcpu_vinotify_event: tstamp:2897793874 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:2897565238 data:0x00000100
     kworker/0:2-1634  [000] ....    86.357309: rtcpu_vinotify_error: tstamp:2898382017 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:2898381346 data:0x000003c9
     kworker/0:2-1634  [000] ....    86.357317: rtcpu_vinotify_event: tstamp:2898419918 tag:FS channel:0x00 frame:0 vi_tstamp:2898360128 data:0x00000012
     kworker/0:2-1634  [000] ....    86.357319: rtcpu_vinotify_event: tstamp:2898420065 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:2898381346 data:0x000003c9
     kworker/0:2-1634  [000] ....    86.357320: rtcpu_vinotify_error: tstamp:2899423643 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:2899422972 data:0x000003c9
     kworker/0:2-1634  [000] ....    86.417318: rtcpu_vinotify_event: tstamp:2899672051 tag:FE channel:0x00 frame:0 vi_tstamp:2899401663 data:0x00000022
     kworker/0:2-1634  [000] ....    86.417323: rtcpu_vinotify_event: tstamp:2899672199 tag:FS channel:0x00 frame:0 vi_tstamp:2899401754 data:0x00000012
     kworker/0:2-1634  [000] ....    86.417325: rtcpu_vinotify_event: tstamp:2899672391 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:2899422972 data:0x000003c9
     kworker/0:2-1634  [000] ....    86.417327: rtcpu_vinotify_error: tstamp:2900465269 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:2900464598 data:0x000003c9
     kworker/0:2-1634  [000] ....    86.417355: rtcpu_vinotify_event: tstamp:2900611136 tag:FE channel:0x00 frame:0 vi_tstamp:2900443290 data:0x00000022
     kworker/0:2-1634  [000] ....    86.417357: rtcpu_vinotify_event: tstamp:2900611309 tag:FS channel:0x00 frame:0 vi_tstamp:2900443381 data:0x00000012
     kworker/0:2-1634  [000] ....    86.417358: rtcpu_vinotify_event: tstamp:2900611458 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:2900464598 data:0x000003c9
  1. For the lines with CSIMUX_STREAM the value 0x100 looks like it means FIFO_LOF_STREAM_0. Do you know what can cause these types of errors?
  2. For the lines with CHANSEL_NOMATCH what does the data value 0x3c9 mean?
  3. Where can i find a decoding for this CHANSEL_NOMATCH messages data values?
  4. When frame is mentioned its values is consistently zero. Does this indicate a problem? If so what type of problem?
Looks like could be sensor output embedded data but device tree didn’t configure the embedded_metadata_height correctly.
