Camera static calibration error: Could not make progress initializing the world positions
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
I keep getting this error when run the ./calibration-graph-cli --dir=‘/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022’ command:
Terminating app due to unexpected exception:
Could not make progress initializing the world positions. This probably indicates a disconnected graph. Check that all targets are detected in the images and that there are enough targets and images to link all cameras. Nodes with missing poses: external,
The problem I have added images and looking at the constraints that are outputted, I think there are enough targets and images that link all cameras (see below). I have added also added a text file with the whole terminal output of ./calibration-grap-cli . I could also send you my data calibration folder with all the images.
calib-last.txt (67.4 KB)So at this point I am not sure what is wrong.
I use targets [89-96]. Where 89, 94 are ground targets. [180-183] are my wheel targets.
New pose for camera camera_front_right_60fov
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/extrinsics/camera_front_right_60fov.png: targets 96(35 tags) 91(35 tags) 90(35 tags)
Found constraint between [camera_front_right_60fov, target-96]: 140 points
Found constraint between [camera_front_right_60fov, target-91]: 140 points
Found constraint between [camera_front_right_60fov, target-90]: 140 points
New pose for camera camera_front_middle_right_60fov
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/extrinsics/camera_front_middle_right_60fov.png: targets 96(35 tags) 91(35 tags) 90(35 tags)
Found constraint between [camera_front_middle_right_60fov, target-96]: 140 points
Found constraint between [camera_front_middle_right_60fov, target-91]: 140 points
Found constraint between [camera_front_middle_right_60fov, target-90]: 140 points
New pose for camera camera_front_middle_60fov
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/extrinsics/camera_front_middle_60fov.png: targets 96(35 tags) 91(35 tags) 90(35 tags)
Found constraint between [camera_front_middle_60fov, target-96]: 140 points
Found constraint between [camera_front_middle_60fov, target-91]: 140 points
Found constraint between [camera_front_middle_60fov, target-90]: 140 points
New pose for camera camera_front_left_60fov
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/extrinsics/camera_front_left_60fov.png: targets 96(35 tags) 91(35 tags) 90(35 tags)
Found constraint between [camera_front_left_60fov, target-96]: 140 points
Found constraint between [camera_front_left_60fov, target-91]: 140 points
Found constraint between [camera_front_left_60fov, target-90]: 140 points
New pose for camera external
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9972.JPG: targets 182(9 tags) 95(35 tags)
Found constraint between [external, target-182]: 36 points
Found constraint between [external, target-95]: 140 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/aMG_9960.JPG: targets 89(35 tags)
Found constraint between [external, target-89]: 140 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9931.JPG: targets 96(35 tags) 91(35 tags) 90(35 tags)
Found constraint between [external, target-96]: 140 points
Found constraint between [external, target-91]: 140 points
Found constraint between [external, target-90]: 140 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9975.JPG: targets 92(20 tags), 11 invalid tags
Found constraint between [external, target-92]: 80 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9974.JPG: targets 92(35 tags), 5 invalid tags
Found constraint between [external, target-92]: 140 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9932.JPG: targets 182(9 tags) 95(35 tags)
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9939.JPG: targets 182(9 tags), 25 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9964.JPG: targets 89(35 tags)
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9940.JPG: targets 94(34 tags) 93(35 tags), 4 invalid tags
Found constraint between [external, target-94]: 136 points
Found constraint between [external, target-93]: 140 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9986.JPG: targets 96(35 tags) 92(28 tags) 91(24 tags)
Found constraint between [external, target-92]: 112 points
Found constraint between [external, target-91]: 96 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9936.JPG: targets 94(21 tags) 93(35 tags)
Found constraint between [external, target-94]: 84 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9947.JPG: targets 96(35 tags) 91(35 tags) 90(35 tags)
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9943.JPG: targets 94(27 tags) 93(35 tags), 5 invalid tags
Found constraint between [external, target-94]: 108 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9982.JPG: targets 180(9 tags) 93(35 tags)
Found constraint between [external, target-180]: 36 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9966.JPG: targets 182(9 tags) 94(35 tags)
Found constraint between [external, target-94]: 140 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9953.JPG: targets 183(8 tags) 92(35 tags), 11 invalid tags
Found constraint between [external, target-183]: 32 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9924.JPG: targets 180(9 tags) 93(35 tags)
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9977.JPG: targets 95(35 tags), 6 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9971.JPG: targets 182(9 tags), 29 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9922.JPG: targets 181(9 tags) 94(13 tags) 91(32 tags), 18 invalid tags
Found constraint between [external, target-181]: 36 points
Found constraint between [external, target-94]: 52 points
Found constraint between [external, target-91]: 128 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9983.JPG: targets 181(9 tags) 94(31 tags)
Found constraint between [external, target-94]: 124 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9979.JPG: targets 89(35 tags), 1 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9957.JPG: targets, 26 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/aMG_9962.JPG: targets 180(6 tags) 89(35 tags), 1 invalid tags
Found constraint between [external, target-180]: 24 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9941.JPG: targets 182(9 tags) 95(35 tags) 90(32 tags), 4 invalid tags
Found constraint between [external, target-90]: 128 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9946.JPG: targets 183(9 tags) 91(35 tags) 90(6 tags), 30 invalid tags
Found constraint between [external, target-183]: 36 points
Found constraint between [external, target-90]: 24 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9923.JPG: targets 181(9 tags) 93(35 tags)
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9973.JPG: targets 182(9 tags) 94(33 tags)
Found constraint between [external, target-94]: 132 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9944.JPG: targets 183(8 tags), 7 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9984.JPG: targets 96(35 tags) 92(32 tags) 91(23 tags), 1 invalid tags
Found constraint between [external, target-92]: 128 points
Found constraint between [external, target-91]: 92 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9987.JPG: targets 183(9 tags) 96(35 tags) 91(35 tags) 90(16 tags) 89(28 tags), 9 invalid tags
Found constraint between [external, target-90]: 64 points
Found constraint between [external, target-89]: 112 points
Detections don’t agree.
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9930.JPG: targets 95(14 tags), 31 invalid tags
Found constraint between [external, target-95]: 56 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9942.JPG: targets 182(9 tags) 96(35 tags) 94(22 tags) 91(30 tags)
Found constraint between [external, target-94]: 88 points
Found constraint between [external, target-91]: 120 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9929.JPG: targets 183(9 tags), 14 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9959.JPG: targets 182(9 tags) 96(35 tags) 94(23 tags) 91(30 tags)
Found constraint between [external, target-94]: 92 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9969.JPG: targets 95(35 tags) 90(35 tags)
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9978.JPG: targets 183(9 tags) 89(35 tags)
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9934.JPG: targets 92(35 tags), 16 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9976.JPG: targets 181(6 tags) 94(25 tags)
Found constraint between [external, target-181]: 24 points
Found constraint between [external, target-94]: 100 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9970.JPG: targets 182(9 tags) 95(35 tags)
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/aMG_9963.JPG: targets 96(33 tags) 91(34 tags) 90(5 tags), 49 invalid tags
Found constraint between [external, target-96]: 132 points
Found constraint between [external, target-91]: 136 points
Found constraint between [external, target-90]: 20 points
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9921.JPG: targets 181(9 tags) 91(35 tags), 22 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9954.JPG: targets 93(35 tags), 5 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9980.JPG: targets 183(9 tags) 89(35 tags)
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9985.JPG: targets 96(35 tags) 92(35 tags), 10 invalid tags
/home/nvidia/calibration_cameras/calib-carlos-pinhole-extrinsics-02-15-2022/external/IMG_9926.JPG: targets 180(9 tags) 96(22 tags) 91(33 tags), 30 invalid tags
Found constraint between [external, target-96]: 88 points
Found constraint between [external, target-91]: 132 points
[13-02-2022 07:03:37] Saved graph to /home/nvidia/calibration_ca
Dear @cad297,
We will check internally and update you on this issue.
Dear @cad297,
Could you please file a bug and update bug ID here to follow up. Please login to https://developer.nvidia.com/drive with your credentials. Please check MyAccount->MyBugs-> Submit a new bug to file bug
I am facing a similar issue. Is there an update on this issue? Will updating to driveworks 4.0 help?
Hi @cad297
Have you filed a bug for this issue? Please share the bug # here.
Hi @mamoona.b.shami Please create your own topic linked to this one so that we can collect your environment information there. Thanks.
