Hi shgarg,
After CAN up on network, I checked the parent is still ‘osc’.
Now twice modprobe mttcan, then mttcan works fine with NX CAN.
nvidia@xavier:~$ sudo modprobe can
nvidia@xavier:~$ sudo modprobe can-raw
nvidia@xavier:~$ sudo modprobe can-dev
nvidia@xavier:~$ sudo modprobe mttcan
nvidia@xavier:~$
nvidia@xavier:~$ sudo ip link set can0 down
nvidia@xavier:~$ sudo ip link set can1 down
nvidia@xavier:~$ sudo ip link set can0 up type can bitrate 1000000 dbitrate 1000000 restart-ms 1000 berr-reporting on fd on
nvidia@xavier:~$ sudo ip link set can1 up type can bitrate 1000000 dbitrate 1000000 restart-ms 1000 berr-reporting on fd on
nvidia@xavier:~$ cat /proc/device-tree/mttcan@c310000/pll_source
pllc
nvidia@xavier:~$ sudo cat /sys/kernel/debug/bpmp/debug/clk/can1/parent
osc
nvidia@xavier:~$ sudo ip link set up can0
nvidia@xavier:~$ sudo ip link set up can1
nvidia@xavier:~$
pllc
nvidia@xaviersudo cat /sys/kernel/debug/bpmp/debug/clk/can1/parent
osc
nvidia@xavier:~$ ip -s -d link show can0
14: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 72 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
link/can promiscuity 0
can <BERR-REPORTING,FD> state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 1000
bitrate 1010526 sample-point 0.736
tq 52 prop-seg 6 phase-seg1 7 phase-seg2 5 sjw 1
mttcan: tseg1 2..255 tseg2 0..127 sjw 1..127 brp 1..511 brp-inc 1
dbitrate 1010526 dsample-point 0.736
dtq 52 dprop-seg 6 dphase-seg1 7 dphase-seg2 5 dsjw 1
mttcan: dtseg1 1..31 dtseg2 0..15 dsjw 1..15 dbrp 1..15 dbrp-inc 1
clock 38400000
re-started bus-errors arbit-lost error-warn error-pass bus-off
0 0 0 0 0 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
RX: bytes packets errors dropped overrun mcast
0 0 0 0 0 0
TX: bytes packets errors dropped carrier collsns
0 0 0 0 0 0
