验证步骤:
- can0不接入任何设备,使用cansend发送正常(接入can盒正常收发);can1也正常
2. can3同样不接入任何设备,使用cansend发送数据,会出现bus off(接入can盒无法正常收发,也会出现bus off);can2也同样的情况
3. can3的loopback模式正常,can2也同样如此
验证步骤:
Hi 1516775545,
Are you using the devkit or custom board for Thor?
My understanding is that CAN0/CAN1 are configured for CAN by default, but CAN2/CAN3 are not.
Has the pinmux been configured for CAN2 and CAN3?
custom board for Thor! CAN2 and CAN3 have been configured. The pinmux is as follows:
Thor-dvt-pinmux.zip (5.5 KB)
If it is not configured, the loopback mode cannot be used either, right?
Could you use 2 CAN transceivers for CAN2 and CAN3 respectively and connect CAN-H/CAN-H and CAN-L/CAN-L to verify?
CAN2 and CAN3 tests passed; issue with pinmux configuration.
