if I have a 2d geometry, i want to stretch 2d geometry to generate 3D geometry, more complex, can I stretch 2D geometry spirally?
Hi @tao-zhan18
Not right now. Presently, you’ll need to use the 3D geometric primitives to create a volume to sample from. If you use a CAD software you can consider exporting this to STL and using the tessellated geometry feature in the docker image.
