Can I get static friction or dynamic friction during the simulation physics? If there is only one friction, I can calculate the result. But most of the time there will be two frictions and the results cannot be calculated.I can’t find related variable of Force in the source code.I am using UE4.20
Related topics
Topic | Replies | Views | Activity | |
Can I get the force of the specified collision in the constraint component? | 0 | 579 | November 18, 2018 | |
Physx 3.3.2 friction between fluid and static object | 0 | 875 | July 13, 2015 | |
2.8.3 (Unity3d): What is the exact calculation used for dynamic friction force? | 6 | 4028 | January 9, 2017 | |
PhysX 3.3.x - General equations used for applying Dynamic Friction and Restitution on collision? | 0 | 533 | September 22, 2017 | |
Get output or properties of objects | 0 | 475 | July 2, 2019 | |
Static/Dynamic friction values for PhysicsMaterial | 2 | 479 | April 12, 2024 | |
Recovering frictional forces from gym.get_env_rigid_contacts? | 1 | 602 | January 9, 2024 | |
Physics Material Properties - Friction and Restitution | 1 | 1182 | April 21, 2022 | |
Physics base equation/strange friction behaviour | 1 | 777 | November 20, 2014 | |
Physics base equation/strange friction behavior | 1 | 1091 | November 20, 2014 |
