Can I use OSD on Deepstream docker container via X11 forwarding with putty and xming?
Ubuntu20.04 (And I used Docker(Ubuntu20.04))
• Hardware Platform (Jetson / GPU) 3080ti
• DeepStream Version 6.1.0
• TensorRT Version 8.2.5.1
• NVIDIA GPU Driver Version (valid for GPU only) 510.85.02
• Issue Type( questions, new requirements, bugs) bugs
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) python3 deepstream_test_1.py ../../../../samples/streams/sample_720p.h264
hello.
I want to get the deepstream docker container and run the example on github below.
As for the working environment, I want to see the OSD screen on the local computer with the deepstream code running in the docker container in the server as shown below.
[Work environment]
local computer - Ubuntu20.04 Server - Docker Container
I want to run deepstream-test1/deepstream_test1.py , but after inferring only a brief frame, the job ends immediately.
Error message:
Error: gst-stream-error-quark: Internal data stream error. (1): gstnvinfer.cpp(2299): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
For reference, the following code running in docker conatiner via xming and putty works fine on my local monitor.
ex) xclock
Please let me know how to solve this.
thank you
Deepstream do not support forward X11 from remote server to local monitor. if display on remote server unavailable, you can modify the app to save the output to file. please refer to this, DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
