Can not connect through Omniverse Streaming Client
Hi. I’m trying to connect to my remote Create through Omniverse Streaming Client with LAN, but It does not work.
I got the following error message.
Unable to initiate a connection to the server. Please validate the server address is accurate, and that is reachable from the network
Following the Streaming Clinet Documantation, I copy and paster the following command (kit.bat apps/omni.create.kit --enable omni.kit.livestream.native --no-window) at the directory I installed the Create, and confiremed that The Omniverse Create is running as no-window mode on my remote server.
I think the IP address is correct because I can stream via WebSocket with the same one.
(i.e., http://{my-IP}:8111/streaming/clinet is no problem)
Could you gime me some advices?
Thanks in advance !
Hello @teyon.son! I am asking the dev team for some assistance.
I have a few questions for you:
  • What version of the Streaming Client are you using?
  • Is your Server using the same Operating System as the Client?
  • Also, you say that you are connecting through LAN, but then you mention that you are running no-window mode on your remote server. Is your Server and Client on the same network?
Hello again @teyon.son! The dev team had a few more questions for you:
  • What version of Create are you using?
  • Can you confirm if the ports you are using for streaming are cleared by your firewall settings?
Here are some links to the documentation for reference: Using Omniverse Streaming Client — Omniverse Streaming Client documentation
Hello @WendyGram
Thank you for your kind response.
Server ( Workstation ) : Omniverse Create 2022.1.4
Client: Omniverse Streaming Client 103.1.1
yes, both server and client is windows.
more specifically,
Server (Workstation): Microsoft Windows 10 Pro
Client: Microsoft Windows 10 Pro for Workstations
Sorry for my ambiguous expression. I should have said just Server instead of a remote server.
Yes, the server and client are on the same network.
I understand. I’m going to respond after checking the port.
Thank you.
Had something similar on my AWS instance. Solved it by opening the ports specificed in their documentation:
https://docs.omniverse.nvidia.com/app_streaming-client/app_streaming-client/user-manual.html
and accessing it via server_ip/streaming/client
hope this helps!
Hi, @michael.s1.ellis
Thank you for letting me know!
I have some questions.
Did you access that AWS instance through Omniverse Client App?
if yes, Should I desginate “$(server_ip)/streaming/client” for Server window of Omniverse Clinet App ?
In the second screenshot which is in this document ( https://docs.omniverse.nvidia.com/app_streaming-client/app_streaming-client/user-manual.html), they just disignated not “$(server_ip)/streaming/client” but server IP address (In this sreenshot, 127.0.0.1 ).
If I remember correctly, I need to use “”$(server_ip)/streaming/client" for streaming via websocket/ webrtc.
Yes I am using the Omniverse streaming client v103.1. My custom app is ran on the AWS ubuntu instance (after having the ports opened) with ./run_app.sh --enable omni.kit.livestream.native --no-window
I was originally using the websocket prior, and recently made the change to connect by filling out the top portion of the Omniverse streaming client Server (on a windows machine) field with: server_ip/streaming/client/ which was not very well documented and honestly just a guess.
I certainly hope this helps.
Hi, @michael.s1.ellis .
Thank you for your reply, and I apologize for the late reply.
That’s what I wanted to know. Thank you for your Kind & swift response.
Thanks to your tips, Omniverse Client Streming worked well on my env :)
I tried several things ( e.g., port setting, FW setting, etc…), and It seems like the problem was, activating several extensions which provide a live stream feature.
( I have not investigated yet, but the extension you checked autoreload activate automatically loads to Create even though you launch from cmd)
I disabled these extensions except omni.kit.livestream.native, it worked now.
