My laptop has two flexnet addresses. I used the first one to get a license, but I hae difficulties to start VF. It complans that license server can not be accessed. The Imgrd.exe servise is running and has permission for the firewall. What is the next thing to check?
This flexnet licensing is so confusing…
Below is some sort of a log that it had created.
Thank you very much in advance,
Alex
1:36:44 (lmgrd) -----------------------------------------------
1:36:44 (lmgrd) Please Note:
1:36:44 (lmgrd)
1:36:44 (lmgrd) This log is intended for debug purposes only.
1:36:44 (lmgrd) In order to capture accurate license
1:36:44 (lmgrd) usage data into an organized repository,
1:36:44 (lmgrd) please enable report logging. Use Macrovision’s
1:36:44 (lmgrd) software license administration solution,
1:36:44 (lmgrd) FLEXnet Manager, to readily gain visibility
1:36:44 (lmgrd) into license usage data and to create
1:36:44 (lmgrd) insightful reports on critical information like
1:36:44 (lmgrd) license availability and usage. FLEXnet Manager
1:36:44 (lmgrd) can be fully automated to run these reports on
1:36:44 (lmgrd) schedule and can be used to track license
1:36:44 (lmgrd) servers and usage across a heterogeneous
1:36:44 (lmgrd) network of servers including Windows NT, Linux
1:36:44 (lmgrd) and UNIX. Contact Macrovision at
1:36:44 (lmgrd) www.macrovision.com for more details on how to
1:36:44 (lmgrd) obtain an evaluation copy of FLEXnet Manager
1:36:44 (lmgrd) for your enterprise.
1:36:44 (lmgrd)
1:36:44 (lmgrd)
1:36:44 (lmgrd)
1:36:44 (lmgrd) pid 2724
1:36:45 (lmgrd) Done rereading
1:36:45 (lmgrd) FLEXnet Licensing (v11.5.0.0 build 56285 i86_n3) started on ama001-PC (IBM PC) (9/25/2008)
1:36:45 (lmgrd) Copyright (c) 1988-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
1:36:45 (lmgrd) US Patents 5,390,297 and 5,671,412.
1:36:45 (lmgrd) World Wide Web: http://www.macrovision.com
1:36:45 (lmgrd) License file(s): C:\Program Files\PGI\license.dat
1:36:45 (lmgrd) lmgrd tcp-port 27000
1:36:45 (lmgrd) Starting vendor daemons …
1:36:45 (lmgrd) Started pgroupd (pid 2928)
1:36:45 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:36:45 (pgroupd) Server started on ama001-PC for:
1:36:45 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:36:45 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:36:45 (pgroupd) pgi-f77-win32 pgi-dbg)
1:36:45 (pgroupd) pgi71-pvf (consisting of: pvf
1:36:45 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:36:45 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:36:45 (pgroupd) pgdbg)
1:36:45 (pgroupd) EXTERNAL FILTERS are OFF
1:36:56 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:36:56 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:00 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:00 (lmgrd) Since this is an unknown status, license server
1:37:00 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
1:37:00 (lmgrd) REStarted pgroupd (pid 1092)
1:37:00 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:37:01 (pgroupd) Server started on ama001-PC for:
1:37:01 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:37:01 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:37:01 (pgroupd) pgi-f77-win32 pgi-dbg)
1:37:01 (pgroupd) pgi71-pvf (consisting of: pvf
1:37:01 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:37:01 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:37:01 (pgroupd) pgdbg)
1:37:01 (pgroupd) EXTERNAL FILTERS are OFF
1:37:02 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:37:02 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:05 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:05 (lmgrd) Since this is an unknown status, license server
1:37:05 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
1:37:05 (lmgrd) REStarted pgroupd (pid 3660)
1:37:05 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:37:05 (pgroupd) Server started on ama001-PC for:
1:37:05 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:37:05 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:37:05 (pgroupd) pgi-f77-win32 pgi-dbg)
1:37:05 (pgroupd) pgi71-pvf (consisting of: pvf
1:37:05 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:37:05 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:37:05 (pgroupd) pgdbg)
1:37:05 (pgroupd) EXTERNAL FILTERS are OFF
1:37:05 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:37:05 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:10 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:10 (lmgrd) Since this is an unknown status, license server
1:37:10 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
1:37:10 (lmgrd) REStarted pgroupd (pid 3408)
1:37:11 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:37:11 (pgroupd) Server started on ama001-PC for:
1:37:11 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:37:11 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:37:11 (pgroupd) pgi-f77-win32 pgi-dbg)
1:37:11 (pgroupd) pgi71-pvf (consisting of: pvf
1:37:11 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:37:11 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:37:11 (pgroupd) pgdbg)
1:37:11 (pgroupd) EXTERNAL FILTERS are OFF
1:37:11 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:37:11 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:15 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:15 (lmgrd) Since this is an unknown status, license server
1:37:15 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
1:37:15 (lmgrd) REStarted pgroupd (pid 3892)
1:37:15 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:37:15 (pgroupd) Server started on ama001-PC for:
1:37:15 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:37:15 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:37:15 (pgroupd) pgi-f77-win32 pgi-dbg)
1:37:15 (pgroupd) pgi71-pvf (consisting of: pvf
1:37:15 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:37:15 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:37:15 (pgroupd) pgdbg)
1:37:15 (pgroupd) EXTERNAL FILTERS are OFF
1:37:15 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:37:15 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:20 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:20 (lmgrd) Since this is an unknown status, license server
1:37:20 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
1:37:20 (lmgrd) REStarted pgroupd (pid 2444)
1:37:20 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:37:20 (pgroupd) Server started on ama001-PC for:
1:37:20 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:37:20 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:37:20 (pgroupd) pgi-f77-win32 pgi-dbg)
1:37:20 (pgroupd) pgi71-pvf (consisting of: pvf
1:37:20 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:37:20 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:37:20 (pgroupd) pgdbg)
1:37:20 (pgroupd) EXTERNAL FILTERS are OFF
1:37:20 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:37:20 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:25 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:25 (lmgrd) Since this is an unknown status, license server
1:37:25 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
1:37:25 (lmgrd) REStarted pgroupd (pid 3024)
1:37:25 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:37:25 (pgroupd) Server started on ama001-PC for:
1:37:25 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:37:25 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:37:25 (pgroupd) pgi-f77-win32 pgi-dbg)
1:37:25 (pgroupd) pgi71-pvf (consisting of: pvf
1:37:25 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:37:25 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:37:25 (pgroupd) pgdbg)
1:37:25 (pgroupd) EXTERNAL FILTERS are OFF
1:37:25 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:37:25 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:30 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:30 (lmgrd) Since this is an unknown status, license server
1:37:30 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
1:37:30 (lmgrd) REStarted pgroupd (pid 4304)
1:37:30 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:37:30 (pgroupd) Server started on ama001-PC for:
1:37:30 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:37:30 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:37:30 (pgroupd) pgi-f77-win32 pgi-dbg)
1:37:30 (pgroupd) pgi71-pvf (consisting of: pvf
1:37:30 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:37:30 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:37:30 (pgroupd) pgdbg)
1:37:30 (pgroupd) EXTERNAL FILTERS are OFF
1:37:30 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:37:30 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:35 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:35 (lmgrd) Since this is an unknown status, license server
1:37:35 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
1:37:35 (lmgrd) REStarted pgroupd (pid 4644)
1:37:35 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:37:36 (pgroupd) Server started on ama001-PC for:
1:37:36 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:37:36 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:37:36 (pgroupd) pgi-f77-win32 pgi-dbg)
1:37:36 (pgroupd) pgi71-pvf (consisting of: pvf
1:37:36 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:37:36 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:37:36 (pgroupd) pgdbg)
1:37:36 (pgroupd) EXTERNAL FILTERS are OFF
1:37:36 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:37:36 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:40 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:40 (lmgrd) Since this is an unknown status, license server
1:37:40 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
1:37:40 (lmgrd) REStarted pgroupd (pid 4960)
1:37:40 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:37:40 (pgroupd) Server started on ama001-PC for:
1:37:40 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:37:40 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:37:40 (pgroupd) pgi-f77-win32 pgi-dbg)
1:37:40 (pgroupd) pgi71-pvf (consisting of: pvf
1:37:40 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:37:40 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:37:40 (pgroupd) pgdbg)
1:37:40 (pgroupd) EXTERNAL FILTERS are OFF
1:37:40 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:37:40 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:45 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:45 (lmgrd) Since this is an unknown status, license server
1:37:45 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
1:37:45 (lmgrd) REStarted pgroupd (pid 5280)
1:37:46 (pgroupd) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
1:37:46 (pgroupd) Server started on ama001-PC for:
1:37:46 (pgroupd) pgi72-pvf (consisting of: pgi-pvf
1:37:46 (pgroupd) pgi-f95-win64 pgi-f77-win64 pgi-f95-win32
1:37:46 (pgroupd) pgi-f77-win32 pgi-dbg)
1:37:46 (pgroupd) pgi71-pvf (consisting of: pvf
1:37:46 (pgroupd) pgf90-win64 pgf77-win64 pvfdbg-win64
1:37:46 (pgroupd) pgf90-win32 pgf77-win32 pvfdbg-win32
1:37:46 (pgroupd) pgdbg)
1:37:47 (pgroupd) EXTERNAL FILTERS are OFF
1:37:47 (pgroupd) Vendor daemon can’t talk to lmgrd (Cannot connect to license server system. (-15,10:10013 “WinSock: Access denied”))
1:37:47 (pgroupd) EXITING DUE TO SIGNAL 28 Exit reason 5
1:37:50 (lmgrd) pgroupd exited with status 28 (Communications error)
1:37:50 (lmgrd) Please correct problem and restart daemons
