Hi , I tried to use the face_xy project on Getting Started with AI on Jetson Nano Courses , but I had a problem.
While I running Data Collection , the error has occured : Error displaying widget: model not found .
I install package from jaybdub and jetcard , but still not working.
Can have any idea to solve? Thanks for help.
kayccc
July 13, 2020, 11:06pm
3
Hi kjoelovelife,
Please refer to below topic if can help: Jupyter ipywidgets v7.5 "Error displaying widget"
Thanks , it can load module, but there is another problem occured , stop at " loading widget " ,
and no image show on jupyter lab.
Hi kjoelovelife,
Could you try installing the âno_typescriptâ branch, and see if the issue persists?
I would also recommend using Chrome browser if youâre not already.
Please let me know if this works for you or you run into any issues.
Best,
John
Sorry too late to reply.
It still not working ,
Hi kjoelovelife,
Do you mind sharing the steps you took to install Jupyter clickable image widget?
I believe the no-typescript version has been merged into master branch now.
Best,
John
Yes, and below are my install step:
sudo apt -y install curl dirmngr apt-transport-https lsb-release ca-certificates
curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
sudo apt -y install nodejs node-gyp âgccâ g++ âmakeâ
sudo pip3 install jupyter jupyterlab
sudo python3 -m pip install git+https://github.com/ipython/traitlets@4.x
sudo jupyter labextension install @jupyter-widgets /jupyterlab-manager
sudo jupyter labextension install @jupyterlab /statusbar
git clone --branch no_typescript GitHub - jaybdub/jupyter_clickable_image_widget
cd jupyter_clickable_image_widget
sudo pip3 install -e .
jupyter labextension install js
i have the same problem. It says: âError displaying widget: model not foundâ
Jupyter lab: v 2.2.9
jupyter-clickable-image-widget
Version: 0.1.0a0
nodejs
version 8.10.0
cython 0.29.21
Thanks. This worked for me, but I had to use:
sudo npm install -g node-gyp
